POV-Ray : Newsgroups : povray.off-topic : More VM fun Server Time
2 Nov 2026 17:57:10 EST (-0500)
  More VM fun (Message 1 to 16 of 16)
Subject: More VM fun
Date: 14 Feb 2009 06:31:41
Message: <4996ab9d$1@news.povray.org>
OK, so I need to do some stuff that will only work on Linux.
What I *could* do is set up a Linux system under QEMU, but that's quite
slow. So I thought I'd go with VirtualBox instead.
Nuhuh. Apparently VirtualBox is "free" so long as you only use it for a
week or two. You can also obtain a copy licenced under the GPL, but then
you have to compile it from source yourself. (Which, obviously, is
impossible.)
OK then. So how about VMserver then?
Nuhuh. They're demanding a real email address before they will let me
download the product, and it looks like they're going to demand that I
"activate" it after it's installed.
So can anybody suggest a virtual machine implementation that really *is*
free? (And works hosted on Windows.)
http://blog.orphi.me.uk/
Subject: Re: More VM fun
Date: 14 Feb 2009 06:59:37
Message: <op.upcblmu47bxctx@e6600>
On Sat, 14 Feb 2009 12:31:41 +0100, Orchid XP v8 <voi### [at] devnull> wrote:
> week or two.
There is no such limitation if you stick to "Personal use" as defined in
§2 of the license.
> You can also obtain a copy licenced under the GPL, but then you have to
> compile it from source yourself. (Which, obviously, is impossible.)
Why would that be impossible?
FE
Date: 14 Feb 2009 07:12:13
Message: <4996b51d$1@news.povray.org>
>> a week or two.
> §2 of the license.
Damn legalese doesn't make this very clear.
>> to compile it from source yourself. (Which, obviously, is impossible.)
OK, I rephrase: It's infeasible on Windows. You could probably do it on
Linux, given sufficient time and energy.
Date: 14 Feb 2009 12:01:19
Message: <4996f8df$1@news.povray.org>
Microsoft VirtualPC. Works fine as long as you run 32-bit OSes under it. You
*do* need to "install" it, tho.
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 14 Feb 2009 12:53:35
Message: <4997051f$1@news.povray.org>
>> *is* free? (And works hosted on Windows.)
> You *do* need to "install" it, tho.
The Wikipedia article suggests that it only gives you low-resolution
16-bit graphics, and also that only certain OSes work. (E.g., not all
flavours of Linux will install.) I would expect a VM to either work
properly, or not. It appears this one is "not".
Date: 14 Feb 2009 14:19:15
Message: <49971933@news.povray.org>
> impossible.)
I know many people who have run VirtualBox from downloaded binaries and
it hasn't been "time bombed".  There is a pay-for version, but there's
also a free version.
In fact, just looking here now, Virutalbox-OSE is the name of the package
on OpenSUSE 11.0.  OSE = Open Source Edition.
VMware Server does require a "real" e-mail address, but the system will
accept mailinator.com e-mail addresses if you don't want to provide a
real address.
And it doesn't require activation, you just need a license key.  I have
it installed on a system.
I would go with VMware Server for cross-platform support.
Jim
Date: 14 Feb 2009 14:20:00
Message: <49971960$1@news.povray.org>
Assuming the development prerequisites are all installed:
./configure && make && sudo make install
Should do the trick.
Jim
Date: 14 Feb 2009 14:27:09
Message: <49971b0d$1@news.povray.org>
>> impossible.)
 From the VirtualBox website, the OSE is available as source only. You
have to build it yourself. (Suffice it to say my Windows box doesn't
have automake, autoconf, Perl, Python, sed, grep, gcc, ld, tar, or any
of the other things that 99% of all programs require in order to build.)
There's a binary package, but it has a different license.
> real address.
Hmm. Interesting.
In the end, I got to fed up I used my laptop instead. ;-) My bedroom is
currently a tangle of Ethernet cables...
Date: 14 Feb 2009 14:53:44
Message: <49972148$1@news.povray.org>
>>> a week or two. You can also obtain a copy licenced under the GPL, but
>>> then you have to compile it from source yourself. (Which, obviously,
>>> is impossible.)
>> package on OpenSUSE 11.0.  OSE = Open Source Edition.
Maybe from the virtualbox website, but the beauty of open source software
is that others can package it *for* you:
--- snip ---
[jhenderson@krikkit ~]$ zypper if virtualbox-ose
Repository 'Packman Repository' is out-of-date. You can run 'zypper
refresh' as root to update it.
Reading installed packages...
Information for package virtualbox-ose:
Repository: openSUSE-11.0-Updates
Version: 1.5.6-33.2
Arch: x86_64
Vendor: SUSE LINUX Products GmbH, Nuernberg, Germany
Installed: No
Status: not installed
Installed Size: 15.6 M
Summary: VirtualBox OSE is an Emulator
Description:
VirtualBox OSE is an extremely feature rich, high performance product
for enterprise customers, it is also the only professional solution
that is freely available as Open Source Software under the terms of the
GNU Public License (GPL).
--- snip ---
This is NOT a source package.  It's a binary installable on my system
from the openSUSE repositories.
So no, you don't have to build it from source, you have to look in your
distro's package management system to see if someone has provided a
binary package of the OSE version.
>> real address.
> Hmm. Interesting.
Mailinator is a very useful service.  I use it often for site
registration when I don't want to be spammed by the website.  Very few
reject mailinator.com e-mail addresses, but I have run across a couple.
Jetable is another service that provides some obfuscation and temporary e-
mail addresses (but Jetable will forward stuff to you).
I know that feeling - though the bedroom hasn't been the place for that
in many years....my home office space currently is.  Stupid cable
management stickies didn't stick to my glass desk very well.
Jim
Date: 14 Feb 2009 15:12:12
Message: <4997259c$1@news.povray.org>
> 16-bit graphics,
The wikipedia article is incorrect. Oh, OK, 16 or 32 bit, but not 24 bit.
That's possible. My stuff is running at 32 bits.
OK, I just went into SuSE and set the color depth to 24 bits, no problem.
Gee, I guess since Microsoft never improves their products, the wikipedia
editors must not know wtf they're talking about, eh? Maybe they know less
about Linux than I do? ;-)
I dunno. I haven't found any flavors of Linux that don't work. I'm pretty
sure I ran ubuntu on it, but give it a go and let us know. Note that
"Microsoft doesn't support running Linux under VirtualPC" is different from
"Linux doesn't run under VirtualPC".
The wikipedia article also says it runs 64-bit OSes, but that doesn't seem
to be the case here. Maybe I have a slightly different version, or maybe the
free one has some limitations.
Hmmm... Actually, yes, it looks like Ubuntu doesn't boot. Something about a
bad checksum on mumblefrob isapnp. (Funny enough, I can torrent down the ISO
faster than I can burn it to a real CD.)  Oh, on second look, the CD doesn't
boot on either of the machines I have hooked up to screens here, so it
doesn't really look like it's definitely a problem with VirtualPC.
It has some flakes, it seems. But I'm not sure how much I'd blame that on
VirtualPC and how much I'd blame it on Linux.  Certainly if the CD doesn't
boot on the actual hardware, it's hard to say the emulated hardware will do
better. And it's not like there haven't been (for example) calls to boycot
certain manufacturers for making motherboards that only work with Windows,
only three months later to find out it's because the Linux kernel wasn't
actually following the standards and hence wasn't working with that
motherboard. :-)
I don't imagine you'll find other VMs that are perfect either.
I guess it depends on what you want it for. What kinds of things will you be
doing with Linux on a virtual machine where (say) 16-bit graphics wouldn't
be good enough for you?  What do you do with Linux that makes Ubuntu
necessary where OpenSuSE wouldn't suffice?
   "Ouch ouch ouch!"
Date: 14 Feb 2009 15:19:16
Message: <49972744$1@news.povray.org>
>> 16-bit graphics,
*gasp* OMG!
Oh, OK then.
*envy*
I'm currently sucking down KNOPPIX at a rate of about 8 KB/sec.
Currently 10% done after several hours.
Date: 14 Feb 2009 15:27:05
Message: <49972919$1@news.povray.org>
Eight minutes, here. ;-)  Of course, you need enough machines in the swarm
to actually feed you that fast. :-)
I'm trying the "server" version of ubuntu to see if it'll boot. The
"desktop" version brings up the "what next" menu, and when you hit enter on
a choice it spins up the CD for a few seconds then comes back to the menu.
On the 64-bit machine, it spends 5 minutes loading the kernel, then pops up
a box saying "Boot loader: OK" and when you press enter you're back at the
main menu again. WTF guys?  If I run across a version of ubuntu that
actually boots, I'll try it under VirtualPC.
   "Ouch ouch ouch!"
Date: 14 Feb 2009 15:38:34
Message: <49972bca$1@news.povray.org>
Git.
> swarm to actually feed you that fast. :-)
Well, actually earlier today it was 50 KB/sec. But around about 5 PM it
suddenly dropped to 8 KB/sec. (As in, there was a sharp line in the
traffic history.) And it's been setting at exactly 8 KB/sec ever since.
I almost wonder if my ISP is shaping the traffic...
Also, I'm downloading the *previous* version of KNOPPIX, which possibly
has a smaller swarm. (Still, it says 14 peers and 228 seeds, you'd
*think* that's enough...)
> on a choice it spins up the CD for a few seconds then comes back to the
> menu. On the 64-bit machine, it spends 5 minutes loading the kernel,
> then pops up a box saying "Boot loader: OK" and when you press enter
> you're back at the main menu again. WTF guys?  If I run across a version
> of ubuntu that actually boots, I'll try it under VirtualPC.
LOL!
The Real WTF(tm) is how each release of Ubuntu has a stupid name. My
laptop is running Ubuntu "hardy ferron".
It said there were updates to be installed. I told it to go for it. Took
about an hour. o_O I was almost wondering if by the time it finished
some new updates would be available! ;-)
Actually, I just checked. The updater complained it couldn't resolve the
DNS name of the update server. I tried 3 times; failed each time. (It
takes *forever*, mind you. For some reason it insists on rebuilding the
package dependency tree, even though it hasn't changed.) So I pinged the
update server. Now suddenly the update program sees it. WTF??
Date: 14 Feb 2009 16:01:06
Message: <49973112$1@news.povray.org>
I think it's also likely that a lot of people have stuff on home machines
and they set the schedule to let it run all-out when they're at work. I've
seen the opposite on some torrents, too, where weekends or evenings it'll be
fast and during the work day it'll be a trickle. Probably the same thing,
I'd guess, only the other direction.
> LOL!
Server gets a little farther, in both real and VirtualPC, but neither
actually get to the point where it gives you a prompt you can do something
with.
I know a guy working on a project where the first release was named "Blame
Canada."  Then it was "Blame Datshunds", then "Blame Egrets" or some such...
Hey, welcome to open source. :-)
I'm dicking around with Blender right now. You wouldn't believe how ...
awful it is.  After figuring out that shadows don't work in ray tracing mode
unless you tell the thing the shadows are casting *onto* that it should pay
attention to whether things are transparent, I'm now stuck with a piece of
cloth that will only interact with some objects and not others, even tho the
other objects are dupicates of the ones it interacts with. WTF mohn?
   "Ouch ouch ouch!"
Date: 14 Feb 2009 16:22:16
Message: <49973608$1@news.povray.org>
> "Blame Canada."  Then it was "Blame Datshunds", then "Blame Egrets" or
> some such...
Heh, nice.
>> So I pinged the update server. Now suddenly the update
Hmm, yes...
Although at least with most Linux distros, you get the feeling that it's
more that just one person's hobby project. Too many Haskell things
really *are* a one-man hobby project! :-/
Date: 14 Feb 2009 17:16:37
Message: <499742c5$1@news.povray.org>
> something with.
OK. It helps immensely to have a CD without physical errors on it after
you've burned it. :-) Now it boots fine on real hardware and complains about
the emulated CD drive on the VirtualPC.  Given that it just booted the boot
code and install menu off the CD, and given that other Linuxes seem to work
OK, I'm not sure what Ubuntu is doing that would be a problem. Maybe trying
to check more types of hardware for greater compatibility, and failing
because it can't figure out what kind of hardware it is or some such.
   "Ouch ouch ouch!"
