As I understand it, M$ Access is just a graphical frontend for the M$
Jet engine, which actually comes with Windows itself. Does that mean I
can configure an ODBC connection to an Access database, even though I
don't have access?
More generally, does anybody here know how to work ODBC?
http://blog.orphi.me.uk/
That is correct.
H²
> don't have access?
You might need this:
http://www.microsoft.com/downloads/details.aspx?FamilyID=2deddec4-350e-4cd0-a12a-d7f70a153156&DisplayLang=en
ODBC is relatively simple, but, Gail could probably help... maybe..
~Mike
>> Does that mean I
>> don't have access?
Mmm, OK.
(Failing that, I just use one of the machines at work... muhuhuhu!)
This is my feeling also. ;-)
I have actually had cause to meddle with ODBC a very little in the past.
But considering I want to attempt to develop a program that talks to a
database, if it doesn't work I won't know if my program is wrong, the
ODBC library is broken, or I just haven't configured ODBC correctly! :-S
You can actually manipulate the database programatically. I haven't used
Access in years so I don't remember the specifics of creating a connection,
using the cursors, etc. If you don't actually have Access, I can't really
see why you might want to do that though.
H²
Purely for test purposes. I want to write a trivial DB application to
check that the library for writin DB applications works correctly.
I can tell you that to access Access, the usual API is DAO
(http://en.wikipedia.org/wiki/Data_Access_Objects). Using ODBC and Access I
think you would need to have the database already created to create a DSN;
you need a file to which it will point. If you don't have Access you might
be able to start with a populated mdb then drop the tables you don't need
then create the ones you do though.
H²
> don't have access?
There are a bunch of options to open a .mdb without MS Access.
MS Access just gives you a pretty front end - it can be useful in
creating a new database and tables, but isn't required. In fact, I have
not used MS Access in several years, tho just about all of our data is
in .mdb files.
I personally stay from ODBC because it requires a setup on each computer.
I usually access the file directly through code.
small example in .NET - forgive the line wraps
Private Function GetSCIDandUTMTable(ByVal databasePath As String) As
System.Data.DataTable
Dim myDatabaseConnection As System.Data.OleDb.OleDbConnection
myDatabaseConnection = New
System.Data.OleDb.OleDbConnection("provider=Microsoft.Jet.OLEDB.4.0;Data
Source= " & databasePath)
myDatabaseConnection.Open()
Dim queryString As String
queryString = "select"
queryString &= " SCID"
queryString &= ",WorldX"
queryString &= ",WorldY"
queryString &= " from"
queryString &= " myInfoStore"
Dim myDataAdapter As System.Data.OleDb.OleDbDataAdapter = Nothing
Dim myDataSet As New System.Data.DataSet
Dim myDataView As System.Data.DataView
Dim myDataTable As System.Data.DataTable
myDataAdapter = New System.Data.OleDb.OleDbDataAdapter(queryString,
myDatabaseConnection)
myDataAdapter.Fill(myDataSet, "MyData")
myDatabaseConnection.Close()
myDataView = New System.Data.DataView(myDataSet.Tables("MyData"))
myDataTable = myDataView.Table
Return myDataTable
End Function
In my case we don't keep one large dataset, we have a separate .mdb for
each job that we work on - so literally hundreds of .mdb files.
Our tools are designed to allow the sure to easily select the .mdb file
they are working with.
Tom
> in .mdb files.
My goal isn't to access an MDB file; my goal is to use an MDB file to
test whether my ODBC program works correctly. ;-)
From the other responses, it looks like it should be feasible to do
this. Time to start playing, I think...
>> have not used MS Access in several years, tho just about all of our
>> data is in .mdb files.
That's one of the nice things about ODBC - you can repoint it without
having to modify code that uses it.
It's been almost 10 years since I last used ODBC - sorry, not much help
there.
Tom
The library I'm using supports ODBC, and also supports the native
protocols of a few specific DBs, but I think learning to work ODBC once
is probably my best bet. ;-)
> there.
No worries.
> don't have access?
Note however.. Some ODBC drivers do not provide access to the set of DB
management functions needed to "create" new DBs and tables, or they
require that you access the driver differently, depending on if you are
"creating" a DB, or just accessing its contents to read and write to it.
Took me a bit of hunting to figure that one out, since it wasn't
entirely "obvious", given most examples of "accessing" the data have the
bad habit of "assuming" the table already exists to "be" accessed. :p
void main () {
If Schrödingers_cat is alive or version > 98 {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
