POV-Ray : Newsgroups : povray.off-topic : ODBC Server Time
27 Jun 2026 20:54:00 EDT (-0400)
  ODBC (Message 1 to 10 of 12)
Subject: ODBC
Date: 2 Feb 2009 15:33:37
Message: <498758a1@news.povray.org>
As I understand it, M$ Access is just a graphical frontend for the M$
Jet engine, which actually comes with Windows itself. Does that mean I
can configure an ODBC connection to an Access database, even though I
don't have access?
More generally, does anybody here know how to work ODBC?
http://blog.orphi.me.uk/
Subject: Re: ODBC
Date: 2 Feb 2009 15:47:26
Message: <49875bde$1@news.povray.org>
That is correct.
Subject: Re: ODBC
Date: 2 Feb 2009 15:50:02
Message: <49875c7a$1@news.povray.org>
> don't have access?
You might need this:
http://www.microsoft.com/downloads/details.aspx?FamilyID=2deddec4-350e-4cd0-a12a-d7f70a153156&DisplayLang=en
ODBC is relatively simple, but, Gail could probably help... maybe..
~Mike
Subject: Re: ODBC
Date: 2 Feb 2009 15:52:24
Message: <49875d08$1@news.povray.org>
>> Does that mean I
>> don't have access?
Mmm, OK.
(Failing that, I just use one of the machines at work... muhuhuhu!)
This is my feeling also. ;-)
I have actually had cause to meddle with ODBC a very little in the past.
But considering I want to attempt to develop a program that talks to a
database, if it doesn't work I won't know if my program is wrong, the
ODBC library is broken, or I just haven't configured ODBC correctly! :-S
Subject: Re: ODBC
Date: 2 Feb 2009 15:53:29
Message: <49875d49$1@news.povray.org>
You can actually manipulate the database programatically.  I haven't used
Access in years so I don't remember the specifics of creating a connection,
using the cursors, etc. If you don't actually have Access, I can't really
see why you might want to do that though.
Subject: Re: ODBC
Date: 2 Feb 2009 15:55:57
Message: <49875ddd$1@news.povray.org>
Purely for test purposes. I want to write a trivial DB application to
check that the library for writin DB applications works correctly.
Subject: Re: ODBC
Date: 2 Feb 2009 17:09:06
Message: <49876f02$1@news.povray.org>
I can tell you that to access Access, the usual API is DAO
(http://en.wikipedia.org/wiki/Data_Access_Objects). Using ODBC and Access I
think you would need to have the database already created to create a DSN;
you need a file to which it will point. If you don't have Access you might
be able to start with a populated mdb then drop the tables you don't need
then create the ones you do though.
Subject: Re: ODBC
Date: 3 Feb 2009 09:01:39
Message: <49884e43$1@news.povray.org>
> don't have access?
There are a bunch of options to open a .mdb without MS Access.
MS Access just gives you a pretty front end - it can be useful in
creating a new database and tables, but isn't required.  In fact, I have
not used MS Access in several years, tho just about all of our data is
in .mdb files.
I personally stay from ODBC because it requires a setup on each computer.
I usually access the file directly through code.
small example in .NET - forgive the line wraps
Private Function GetSCIDandUTMTable(ByVal databasePath As String) As
System.Data.DataTable
	Dim myDatabaseConnection As System.Data.OleDb.OleDbConnection
	myDatabaseConnection = New
System.Data.OleDb.OleDbConnection("provider=Microsoft.Jet.OLEDB.4.0;Data
Source= " & databasePath)
	myDatabaseConnection.Open()
	Dim queryString As String
	queryString = "select"
	queryString &= " SCID"
	queryString &= ",WorldX"
	queryString &= ",WorldY"
	queryString &= " from"
	queryString &= " myInfoStore"
	Dim myDataAdapter As System.Data.OleDb.OleDbDataAdapter = Nothing
	Dim myDataSet As New System.Data.DataSet
	Dim myDataView As System.Data.DataView
	Dim myDataTable As System.Data.DataTable
	myDataAdapter = New System.Data.OleDb.OleDbDataAdapter(queryString,
myDatabaseConnection)
	myDataAdapter.Fill(myDataSet, "MyData")
	myDatabaseConnection.Close()
	myDataView = New System.Data.DataView(myDataSet.Tables("MyData"))
	myDataTable = myDataView.Table
	Return myDataTable
End Function
In my case we don't keep one large dataset, we have a separate .mdb for
each job that we work on - so literally hundreds of .mdb files.
Our tools are designed to allow the sure to easily select the .mdb file
they are working with.
Tom
Subject: Re: ODBC
Date: 3 Feb 2009 09:04:22
Message: <49884ee6$1@news.povray.org>
> in .mdb files.
My goal isn't to access an MDB file; my goal is to use an MDB file to
test whether my ODBC program works correctly. ;-)
 From the other responses, it looks like it should be feasible to do
this. Time to start playing, I think...
Subject: Re: ODBC
Date: 3 Feb 2009 09:24:42
Message: <498853aa$1@news.povray.org>
>> have not used MS Access in several years, tho just about all of our
>> data is in .mdb files.
That's one of the nice things about ODBC - you can repoint it without
having to modify code that uses it.
It's been almost 10 years since I last used ODBC - sorry, not  much help
there.
Tom
