POV-Ray : Newsgroups : povray.off-topic : System Restore problem - XP Server Time
27 Jun 2026 20:54:00 EDT (-0400)
  System Restore problem - XP (Message 1 to 7 of 7)
Subject: System Restore problem - XP
Date: 31 Jan 2009 11:39:54
Message: <49847eda@news.povray.org>
Hola,
I had a disaster earlier this week that rendered current running XP drive
non bootable. Well it would boot, but never gave me control of the desktop.
I used a spare drive to get system booted. I mounted the bad drive as slave
and recovered users data. I then used a Western Digital tool to reblast the
corrupted drive and copy the running drive into the reformatted drive that
had the problem.
Well I'm up and running with one problem (so far) ..... System Restore
Service won't start and gave this error.
Could not start .... Error 3: The system could not find the specified path.
This is a bit more information than I got when I tried to get to system
restore through My Computer/System Restore.
I DO see looking at the root of the volume a hidden dir System Volume
Information in that dir a couple of files and another hidden dir
(_restore{stuff}), so I don't understand. At this point be willing to loose
my  restore points in favor of getting the service running again. My
question is. If I go into safe mode and rename System Volume Information
then reboot would that dir get recreated? I've had recyle bin problem and
just deleted recycler and it recreated it when I rebooted. Any insight would
be helpful.
Jim
Subject: Re: System Restore problem - XP
Date: 31 Jan 2009 13:38:07
Message: <49849a8f$1@news.povray.org>
Yes. The only things stored in that directory in XP are restore points and
mount points. If you've mounted an NTFS partition on a directory (instead of
a drive letter), you'll need to remount it.
You might not even need to go into safe mode. Just take ownership of the
directory and then change the permissions. Then reboot.
I'd suggest scheduling a chkdsk /f first, also, in case that's the problem.
Note this is from personal experience and not documentation or anything, so
if you're in a very sophisticated environment there might be more stuff in
there I don't know about.  Renaming is probably a better idea than deleting,
yes.
Also to check: look at the dependencies for the system restore service and
make sure they're all running.
There's also a mechanism that works poorly under XP but might be of help
that checks the signatures on all the Windows files and makes sure they're
good - I'm not sure what the name is, but if toasting the SVI doesn't help,
you might want to look into it. It compares stuff with the dllcache
directory and fixes or saves or whatever it needs to, but it has trouble if
you've applied certain patches.
HTH!
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 31 Jan 2009 13:47:05
Message: <49849ca9$1@news.povray.org>
>> If I go into safe mode and rename System Volume Information then
> Yes.
By which I mean I have several times in the past deleted this directory and
had it recreated without any problem, personally on my own computer. :) Just
in case you thought I was being completely theoretical. :-)
You can also delete the pagefile.sys and the hiberfil.sys while the system
isn't running, if you want.
   "Ouch ouch ouch!"
Date: 31 Jan 2009 15:40:10
Message: <4984b72a@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:49849a8f$1@news.povray.org...
> help, you might want to look into it. It compares stuff with the dllcache
> if you've applied certain patches.
would that be sfc /scannow from the command line?
Jim
Date: 31 Jan 2009 15:49:36
Message: <4984b960@news.povray.org>
Yes, that's the one I was thinking of. You can also tell it to scan on the
next reboot, I think.  Beware - I've had all kinds of ugly problems with
this. I'm not sure it works right after you've applied windows updates.
Maybe it just breaks on *some* windows updates. I wouldn't do it if you
aren't willing to lose the whole installation.
   "Ouch ouch ouch!"
Date: 31 Jan 2009 15:53:52
Message: <4984ba60@news.povray.org>
news:4984b960@news.povray.org...
yes ... i'm taking a PASS on that .... always nice to have someone concur
Thanks
Date: 2 Feb 2009 06:29:05
Message: <4986d901$1@news.povray.org>
news:49849ca9$1@news.povray.org...
> and had it recreated without any problem, personally on my own computer.
> :) Just in case you thought I was being completely theoretical. :-)
Darren .... thanks I'm G2G now :-)
