POV-Ray : Newsgroups : povray.off-topic : Woo, GPU! Server Time
14 Oct 2026 07:05:48 EDT (-0400)
  Woo, GPU! (Message 51 to 71 of 71)
<<< Previous 50 Messages Goto Initial 50 Messages
Subject: Re: Woo, mass breakage
Date: 30 Jan 2009 06:09:34
Message: <4982dfee@news.povray.org>
>> Now *all* I have to do is figure out how to put NTLDR and friends back
>> onto the drive using the recovery console and my PC will be usable
>> again... o_O
How did you manage to mess that up by simply replacing a graphics card?!?!
Date: 30 Jan 2009 06:16:17
Message: <4982e181$1@news.povray.org>
>>> back onto the drive using the recovery console and my PC will be
>>> usable again... o_O
Read again, carefully: I haven't even changed the graphics card yet. All
I've actually done is move some hardware around so that there's a big
enough space to insert the card.
The reason Windoze is upset is because I removed HD 0. (For reasons
beyond my comprehension, M$ insists that the boot files must always be
on HD 0, even if the OS itself isn't.) So I need to put the boot files
onto the drive that has now become HD 0. Unfortunately the documentation
for this isn't that easy to find, but I believe I know how to fix this now.
Subject: Re: Woo, GPU!
Date: 30 Jan 2009 06:17:39
Message: <4982e1d3$1@news.povray.org>
Orchid XP v8 wrote:
> "Powering your XFX graphics card"
> "XFX does not support the use of two 4-pin to one 6-pin power cable
> converter for these graphics cards."
> So, uh, why did you supply just such a converter IN THE BOX WITH THE
> CARD???
> Is it just me?! o_O
Seriously - I'm still bemused by this one... :-?
Date: 30 Jan 2009 06:31:29
Message: <4982e511$1@news.povray.org>
>> Luckily those are not very expensive.
> Well, that's the main thing, yes. ;-)
> (Otherwise, right now you'd see my sitting in the corner crying.)
...or rather, "300W PSUs are not very expensive". Typically you can buy
one of those for about £6, or anything upwards.
Unfortunately, I need a minimum of 500W (and the "recommended" is 630W,
and if you ever go to SLI that becomes 680W). PSUs in that sort of range
typically go for about £60. (Occasionally you will see *one* model at
£20 or so, but when you read the spec you discover that it only has 3
plugs or something daft.)
I'm thinking... if I'm going to actually spend real money on getting a
bigger PSU, I might as well spent a little bit more on one that can do
the job *properly*. (I.e., one with enough connectors, and a decent
Wattage.)
Date: 30 Jan 2009 06:58:13
Message: <4982eb55$1@news.povray.org>
I'm thinking just buy 2x 300W ones for 12 pounds :-)
Date: 30 Jan 2009 07:02:24
Message: <4982ec50$1@news.povray.org>
>> buy one of those for about £6, or anything upwards.
>> 630W, and if you ever go to SLI that becomes 680W). PSUs in that sort
>> of range typically go for about £60.
Mmm, yes... One PSU to power my PC, and the second one to power my GPU!! :-D
I'm not really sure how the case arrangements for that work out though.
(Notice that the recommended power is 630W, so 2x300W would still be
insufficient. However, I think my current PSU might be 400W, so...)
Anyway, it seems that if you want 700W *and* two 6-pin PCIe connectors,
you're talking about quite a lot of money. But if you settle for 650W,
you can find it quite a bit cheaper. I'm thinking I might go for this:
http://www.ebuyer.com/product/151295
It exceeds the recommended Wattage, it has two seperate PCIe connectors,
and it has enough other connectors to run the rest of my stuff. (It's
also 80plus certified, which is nice...) Only £40, which isn't as bad as
the £80+ for something like a modular Thermaltake 800W unit.
Date: 30 Jan 2009 13:03:39
Message: <498340fb$1@news.povray.org>
Like everything, the exceptionally cheap ones are crap and will die, ofte
n
taking out other parts, in a year or so. Spend the extra and get the good
 one.
> (Occasionally you will see *one* model at £20 or so,
And it'll either be a piece of crap or specialized for a particular produ
ct
line.
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 30 Jan 2009 13:08:48
Message: <49834230$1@news.povray.org>
Invisible wrote:
> Hopefully at this point the system should become bootable again.
You might need to use mbrfix (or is it fixmbr?)
Or use diskpart to make the partition active, I think. It's been a while
since I tried to fix an XP partition.
   "Ouch ouch ouch!"
Date: 30 Jan 2009 14:09:07
Message: <49835053$1@news.povray.org>
> often taking out other parts, in a year or so. Spend the extra and get
> the good one.
Yeah, if I buy I PSU, I tend to not buy *the* cheapest one. I like to
buy one that's a little more. Not too much, but just so that it's not
the £6 model. Maybe £15 or something?
I'm like that with a lot of things though. I tend to avoid *the*
cheapest one, and go for one a few notches higher up.
OTOH, when looking at something like CPUs, I tend to not go for *the*
most powerful one, because typically it's 8x the price for 8% more
performance. ;-)
http://blog.orphi.me.uk/
Date: 30 Jan 2009 14:10:22
Message: <4983509e@news.povray.org>
Yes. Actually I already did this from KNOPPIX. Just marking the
partition as "bootable" seemed to be enough to get me to the "CAN'T FIND
NTLDR" message. But I found the corresponding commands (it *is* fixmbr
and fixboot BTW) in the Recovery Console also.
Subject: Re: Woo, normality!
Date: 30 Jan 2009 14:13:37
Message: <49835161$1@news.povray.org>
Invisible wrote:
> - Build a new BOOT.INI file: bootcfg /all
> - This last command spends a few hours scanning all your HDs looking for
> anything that looks like a Windows installation. It then gives you an
> interactive prompt asking which ones to add to the boot menu.
Actually, that's "bootcfg /add" or /rebuild.
And, for whatever reason, it doesn't work. After a while it crashes out
with an error message about an unreadable filesystem or something.
Interestingly, it seems that placing NTLDR and NTDETECT.COM onto the
drive is sufficient to make it boot. When you boot the system, it says
"INVALID BOOT.INI; BOOTING FROM C:\WINDOWS". I'm guessing this only
works for certain cases. Since by Windows installation is your standard
"the OS is in the standard place on the first HD", it Just Works(tm).
Weirdly, once Windows has loaded there is apparently no way to recreate
a correct BOOT.INI file. However, cut-and-pasting the example one from
M$'s website seems to have fixed things nicely.
Wee, my PC works again! :-D
Date: 30 Jan 2009 14:42:20
Message: <4983581c@news.povray.org>
OK. If you got that far, all you need to do is copy boot.ini, ntldr, and the
ohter one whose name I forget offhand, and you should be good. (I'm not 100%
sure you need boot.ini if you put windows in the obvious place, either.)
   "Ouch ouch ouch!"
Date: 30 Jan 2009 14:44:44
Message: <498358ac$1@news.povray.org>
>> FIND NTLDR" message. But I found the corresponding commands (it *is*
>> fixmbr and fixboot BTW) in the Recovery Console also.
> the ohter one whose name I forget offhand, and you should be good. (I'm
> not 100% sure you need boot.ini if you put windows in the obvious place,
> either.)
NTLDR and NTDETECT.COM - and no, you apparently don't need BOOT.INI (see
my other post). And there's nowhere to "copy" BOOT.INI from. ;-)
Date: 30 Jan 2009 14:59:50
Message: <49835c36$1@news.povray.org>
Well, you could copy it onto a floppy and then from there onto the hard
drive, assuming it was the same. And you can "copy con boot.ini" I believe.
   "Ouch ouch ouch!"
Subject: Boom boom
Date: 3 Feb 2009 14:38:14
Message: <49889d26$1@news.povray.org>
Muhuhuhu! The new bigger, badder PSU is here! 8-D
Subject: Re: Boom boom
Date: 3 Feb 2009 14:59:09
Message: <4988a20d$1@news.povray.org>
The PSU is now installed. Now I'm going to download the drivers for the
new card, uninstall the drivers for the old card, and fit The Daddy... :-D
Date: 3 Feb 2009 15:06:09
Message: <4988a3b1$1@news.povray.org>
Jesus Christ, the video driver is 110 MB?? o_O
Date: 3 Feb 2009 15:22:57
Message: <4988a7a1$1@news.povray.org>
Orchid XP v8 wrote:
> Ooo, check this out... I didn't see this part... I also get a free copy
> of FarCry 2! :-D
> And "3DMark Vantage Advanced Edition" for free.
And 3DMark Vantage *only* works with Windows Vista. Oh well...
Date: 3 Feb 2009 15:37:37
Message: <4988ab11$1@news.povray.org>
Don't worry about it. It isn't impressive.
   "Ouch ouch ouch!"
Date: 3 Feb 2009 16:33:56
Message: <4988b844$1@news.povray.org>
Heh. Oh well. It's just that I've never been able to run 3DMark
properly. (I always have the free version that's crippled so you can't
run half the tests or adjust any settings.) And now I've got a real
geniune license code to run the full product, except... but for this
version of Windows.
I guess they assume that if you just paid £200 for a card with DirectX
10 support, you'd also want to run it under an OS that supports DirectX 10.
Date: 3 Feb 2009 16:35:07
Message: <4988b88b@news.povray.org>
The new GPU is up and running. :-D
And... oh my *god*... it's so quiet!!
My PC just got about 5x quieter than it was before. o_O
(Although I notice it gradually gets louder than I ask it to do
something 3D.)
