POV-Ray : Newsgroups : povray.off-topic : Sudoku Server Time
19 Jan 2026 02:04:10 EST (-0500)
  Sudoku (Message 1 to 10 of 51)
Subject: Sudoku
Date: 23 Jan 2009 10:11:42
Message: <4979de2e$1@news.povray.org>
Sudoku. Nobody knows exactly how to pronounce it, but almost everybody
knows what the rules are. And each person has their own Special Method
for playing it.
Apparently it's actually a graph colouring problem. Or, equivilently, an
exact cover problem. And it's provably NP-complete. (So, uh, how come
it's solvable then? I thought "NP-complete" is supposed to mean
"impossible to solve in less time than the age of the universe"?)
It appears you can theoretically solve it using the dancing links algorithm.
Subject: Re: Sudoku
Date: 23 Jan 2009 10:35:18
Message: <4979e3b6@news.povray.org>
  I'm not surprised *you* don't know how to pronounce it. ;)
  Solving a sudoku is O(1) because the size is fixed to a 9x9 grid.
Subject: Re: Sudoku
Date: 23 Jan 2009 10:41:00
Message: <4979e50c$1@news.povray.org>
I presume they were talking about the generalised problem of an n^2 x
n^2 grid...
Even if we assume 9x9, it's interesting to note that in paper the
process is O(1), and yet the amount of time it actually takes me to
solve one appears to be unbounded. I guess this indicates I'm using a
really, *really* inefficient solving algorithm? :-}
(Alternatively, I guess you could take N to mean not the size of the
grid but the number of unknowns...)
Subject: Re: Sudoku
Date: 23 Jan 2009 10:41:33
Message: <4979e52d$1@news.povray.org>
chromatic number.
Subject: Re: Sudoku
Date: 23 Jan 2009 10:51:59
Message: <4979e79f@news.povray.org>
> n^2 grid...
  Has it been proven that it's possible to create unambiguous sudoku
problems for all possible values of n?
  (A sudoku problem only makes sense if it's unambiguous, iow. it can be
solved unambiguously without trial-and-error, only by pure deduction.)
  It cannot be unbounded because the number of possible permutations is
fixed.
  Inside a 3x3 square, where all the numbers between 1 and 9 are put, the
number of possible permutations of those numbers is 9! = 362880. Since
there are 9 such squares, the total number of combined permutations is
9^362880. Sure, this is a huge number, but it's a fixed upper bound and
makes the solver O(1).
Subject: Re: Sudoku
Date: 23 Jan 2009 10:55:43
Message: <4979e87f$1@news.povray.org>
Isn't trial-and-error a form of deduction?  ie "If I put a 4 in here, that
square will need to be 3, and then that doesn't work so it must be a 6 in
the original square".  Of course there are more complicated chains of logic,
but essentially you try one number and see if it gives a valid result.
Subject: Re: Sudoku
Date: 23 Jan 2009 11:00:25
Message: <4979e998@news.povray.org>
  If trial-and-error was acceptable in a sudoku, then you could just as
well give an empty sudoku grid for someone to solve.
  The principle in sudoku puzzles is that they can be solved without having
to guess anything. The chain of required deductions may go very deep in
the hardest sudokus, but it's always possible to solve it without having
to guess.
Subject: Re: Sudoku
Date: 23 Jan 2009 11:01:08
Message: <4979e9c4@news.povray.org>
>> n^2 grid...
If the number of unknowns is small enough, it should be possible to make
it unambiguous. (E.g., if you have a 100 x 100 grid with 1 cell blank,
how hard can it be to figure out what the final value is?)
> fixed.
So there we have it then: An absurdly inefficient algorithm! :-}
Subject: Re: Sudoku
Date: 23 Jan 2009 11:01:31
Message: <4979e9db@news.povray.org>
> to guess.
  By the way, another requirement for the sudoku to be unambiguous is that
only one solution must exist.
Subject: Re: Sudoku
Date: 23 Jan 2009 11:05:16
Message: <4979eabc@news.povray.org>
One might argue that if, for a specific combination of givens, there is
only one possible valid solution, then there must theoretically exist
some chain of "logic" which can reveal it without backtracking.
