POV-Ray : Newsgroups : povray.off-topic : DFT and FFT Server Time
19 Oct 2026 05:00:51 EDT (-0400)
  DFT and FFT (Message 1 to 50 of 55)
Goto Latest 50 Messages Next 5 Messages >>>
Subject: DFT and FFT
Date: 16 Jan 2009 14:51:27
Message: <4970e53f$1@news.povray.org>
So, in my quest of understanding I have decided to look closer at these
magical functions. Everyone who's ever encountered an audio player
probably knows what an FFT. Or has a vague abstract idea as to what it
can be used for. because it's usually called something like FFT. or FFT
filter. FFT spectrum. Whatever. I've seen the term floated around in
such a cavalier manner.
OK, so it's the application of the FFT. Or rather the DFT, seeing as FFT
is just an optimization of the DFT.
I have a very good handle now on what DFT actually does, and it's a
pretty nifty transform. What I can't seem to wrap my head around is FFT.
  But I think I'm getting there. I know it does a bizarre sort at the
beginning, essentially ordering the data as if the indexes had their
bits reversed, which allows the next step to happen. The values are then
recombined, reversing the previous sorting process in such a way as to
reveal the sine and cosine components of the source signal.
That part is really toasting my brain. I /almost/ understand the theory
behind it, but there's some part that's blocking me. The amazing part is
that it takes two nested loops of, say 256 values, and makes it
essentially a 2-deep nesting of around 8 values with a rather small
inner loop.
And its entirely reversible. (!)
The cool thing is you can take frequency domain set, multiply it by
another frequency domain set, invert the DFT, and boom, you just
filtered your data. No messy convolution.
As an example, you can achieve a blur effect on an image by using
multiply operations on the image's frequency domain data. rather than
create a convolution matrix to do the same thing.
I'm not 100 % on the theory of noise reduction, but my basic
understanding is it basically analyzes a constant signal area of the
image in the frequency domain, then subtracts that spectrum from the
noisy signal, thereby cleaning the image, and only minimally harming the
actual image. Thats my guess, at least. I know most of the popular NR
algorithms out there work in the frequency domain...
Anyway, I'm rambling :)
~Mike
Subject: Re: DFT and FFT
Date: 16 Jan 2009 16:40:01
Message: <web.4970fd1592d55383ef2b9ba40@news.povray.org>
Yikes.  Never had to worry about those details.  I'm usually content enough just
to know that FFTW works!  That said, I'm remembering something about a recursive
factorization for the DFT matrix.  Is that the basis for the FFT, or are the
practical algorithms much more complicated than that?
Anyway, here's someone describing some of the details:
http://ocw.mit.edu/OcwWeb/Mathematics/18-06Spring-2005/VideoLectures/detail/lecture26.htm
And here's a book with some details:
http://books.google.com/books?id=coq49_LRURUC&pg=PA391&lpg=PA391
That's really just a property of the Fourier transform itself, isn't it?  At
least to a constant.
Yes, very convenient.  O(n^2) to O(n log n).  Much less messy, too.
> I'm not 100 % on the theory of noise reduction...
Don't wavelets come into play here?  Fourier transforms aren't local, so doesn't
that amount to a low-pass filter?  I guess you could just break it up like jpeg,
but then you may as well move on to wavelets.  I never really had a reason to
dig into all the details, but I think it might be a worthwhile endeavor.
An enjoyable ramble.
 - Ricky
Date: 16 Jan 2009 16:49:26
Message: <497100e6$1@news.povray.org>
Every signal can be represented as a sequence of samples, or as the sum
of some sine (and cosine) components of different frequencies. Two
different ways to describe the same signal. The DFT (and its inverse)
convert one into another. This presumably you have already long figured out.
The FFT works by a divide-and-concor method, rather like quicksort and
mergesort. Take your signal, split it into two signals, transform them
both [by recursively applying the same algorithm], combine the results
back together into a single result.
The whole "swap the bits of the indicies around" trick is an
optimisation to avoid recursively shuffling the samples around. It lets
you do all the shuffling in a single step instead of log N steps, that's
all.
Much like quicksort, the DFT of 1 sample is... that 1 sample, unaltered.
Combining in the frequency domain must undo what was done by splitting
in the frequency domain... There are actually several slightly different
(but essentially equivilent) ways to arrange the FFT.
Multiplication in the frequency domain is convulotion in the time
domain, and vice versa. FFT convolution is mildly more tricky than it
looks at first. (You gotta chop the input into "blocks" to run it
through the FFT, and you need to overlap them after you're done or the
"blur" will stop at the block edges - which is wrong.)
Any further questions?
http://blog.orphi.me.uk/
Date: 16 Jan 2009 16:51:54
Message: <4971017a$1@news.povray.org>
...he says, as if he knows *exactly* what he's talking about! ;-)
Date: 16 Jan 2009 20:33:48
Message: <4971357c$1@news.povray.org>
> out.
Yep. I pretty much figured that out ... real is the cosine, imaginary is
the sine components. Add those components together, and you get the
original time-domain signal. (Well, really average)
> all.
That much I got, and the order of the data seemed to make sense to me,
what's racking my brain is the butterfly... That seems to be the "magic"
piece that makes the whole thing work.
Yep, figured that part out, too. Realizing that 1 sample is essentially
DC, and the real value at index 0 is the DC component made that clear.
I'm supposing this is where Hamming and Blackmann windows come into play?
Heh, as more come to me. I'm tossing together a little C# app to play
around with the FFT and be able to examine it in both rectangular and
polar forms.
I knew you'd have something to add to this, since you seem to be quite
advanced in mathematics.
Date: 16 Jan 2009 22:50:01
Message: <web.4971548f92d55383ef2b9ba40@news.povray.org>
> polar forms.
Aha, I knew I had that lying around somewhere.  If you just want to play with
the behavior and not implement it yourself, there's always Matlab, or its free
equivalent, Octave.  Here's the simplest low-pass filter:
n=101; tmin=0; tmax=10;
%calculate time & frequency
  tbase = linspace(tmin,tmax,n);
  dt    = (tmax-tmin)/(n-1);
  ni    = floor((n-1)/2);
  fbase = [0:floor(n/2),ni:-1:1] /ni/2.0/dt;
%calculate y and fft(y)
  y = rand(size(tbase));
  Y = fft(y);
%filter
  Y_filt = Y;
  Y_filt(find(fbase>2.0)) = 0;
  y_filt = ifft(Y_filt);
%plot
  figure(1);  plot(tbase,y,tbase,y_filt);
  figure(2);  plot(fbase,abs(Y_filt));
 - Ricky
Date: 17 Jan 2009 05:53:50
Message: <4971b8be$1@news.povray.org>
Well, you *could* take the time-domain signal and cut it into two
halves. But that's not very easy to undo in the frequency domain. So
what they usually do is take all the odd samples and all the even samples.
Taking all the even samples is just halving the sampling rate. [Assuming
0-based indexing!] Halving the time domain means doubling the frequency
domain. (Think about it: You take a sound, cut out half the samples,
that's like doubling the playback speed. All the pitches are twice as high!)
Taking all the odd samples is like shifting one sample to the side and
then halving the sampling rate as per above. In the frequency domain,
such a time shift is a multiplication by a sinewave.
So, to undo all this, double both signals, multiply one by a sinewave,
then add them back together. Hence, the butterfly.
>> by splitting in the frequency domain...
Grr... "Combining in the *frequency domain* must ondo what was done by
splitting in the *time domain*." Get it right, boy! >_<
No. Those come into play if you're trying to desing a digital filter.
(E.g., a "perfect" lowpass filter has an infinite frequency response,
but we can't do that. If you just chop the ends off it screws up the
frequency response. Using (say) a Hamming window reduces the effect -
but doesn't eliminate it.)
Recall that the convolution of a signal by some kernel is *longer* than
the original signal. This is the effect you have to repeat when doing
FFT convolution. (The details escape me at this exact moment... Suffice
it to say that your inverse-FFT results have to be overlapped to get a
smooth result.)
Meh. I wanted to build a digital filter, so I read a rather excellent
book on the subject. ;-)
Wanna see the Z-transform?
Date: 17 Jan 2009 14:00:36
Message: <49722ad4$1@news.povray.org>
But, you see ... you have an interest in such things.
Z transform?
Date: 17 Jan 2009 14:51:20
Message: <497236b8$1@news.povray.org>
I read Wikipedia - and discovered that it is *completely useless* for
learning this kind of thing! But then I found a book online, and read
that. ;-)
> Z transform?
Weeell... The Fourier transform comes in several different "flavours",
but essentially you have
- The continuous Fourier transform takes a formula and turns it into a
different formula.
- The discrete Fourier transform takes some numbers and turns them into
some other numbers.
There is a generalisation of the [continuous] Fourier transform called
the Laplace transform. The correspondin discrete version is called the
Z-transform.
The Laplace transform is the trippy mumma you use for designing Infinite
Inpulse Response filters.
See, Finite Impulse Response (FIR) filters are very easy to design, and
very flexible, but they take quite a bit of compute power. If you want
precise filtering (e.g., for scientific purposes) then you're going to
use FIR.
On the other hand, Infinite Impulse Response filters use feedback to
generate an impulse response which is effectively "infinitely long". The
downside is that only certain impulse responses can be created by
feedback. Oh, and that controlling feedback is damned tricky.
Enter the Laplace transform. This makes it relatively easy to figure out
how much feedback to apply.
It just so happens that the impulse response of a perfect lowpass filter
"nearly" matches the kinds of impulse responses that an IIR can produce.
The net result of this is that with only a tiny amount of calculation,
you can get pretty good results.
In other words, IIR is massively, massively faster than FIR. (It's also
far less precise, nowhere near as flexible, and way harder to design.)
While we're on the subject, the Laplace transform turns differential
equations into algebraic equations, making them drastically easier to
solve. As I understand it, that's why mathematicians came up with it in
the first place.
Jesus Christ, SOMEBODY HIRE ME!! >_<
Date: 17 Jan 2009 17:53:08
Message: <49726154$1@news.povray.org>
I want you to know that's the first explanation of it I've ever been able to
follow.  I'm not a very mathematical person.
You definitely should write some Haskell documentation. :-)
   Why is there a chainsaw in DOOM?
   There aren't any trees on Mars.
Date: 18 Jan 2009 06:28:09
Message: <49731249@news.povray.org>
> able to follow.
Shamelessly paraphrased from The DSP Guide. ;-) But thank you.
It seems to be that (in general) there are two ways to explain any
mathematical result:
- As a sequence of mechanical transformations of symbols.
- As a vague but intuitive examination of *why* this (or at least
something roughly this shape) should work.
Non-mathematicians tend to respond better to the latter, and it's
terribly hard to glean from the former.
I still vividly remember the day I figured out why that famous formula
actually solves quadratic equations. Maybe I'll share it with you?
...says the guy who actually knows WTF a nondeterministic Turing machine
*is*! :-P
Heh, yeah.
Sadly, before you can document something, you must comprehend it. Also,
the Haskell library documentation uses literate proramming - i.e., the
documentation is inside the library source code, so to update it you'd
have to submit a patch to the library maintainer, yadda yadda yackt...
Subject: ax^2 + bx + c = 0
Date: 18 Jan 2009 07:00:48
Message: <497319f0$1@news.povray.org>
OK, so "everybody knows" (?!) that ax^2 + bx + c = 0 can be transformed
into the magical expression
   x = (-b +/- Sqrt(b^2 - 4ac)) / 2a
But why is that, exactly? Well, looking in my sister's A-level maths
book [unlike me, my sister was *taught* mathematics] I discover a long
sequence of algebraic manipulations that slowly transforms the one into
the other.
Well, that proves it *works*, but *why* does it work??
One day, I figured it out. Watch this:
The (linear) polynomial (x - A) has one solution: A. And the quadratic
polynomial (x - A)(x - B) has two solutions: A and B. So here we just
*constructed* a quadratic with *known* solutions!
(This may seem completely unremarkable, but remember I have no
mathematical training. It seemed pretty impressive to me!)
Now, if we expand that out, we get
   x^2 - Ax - Bx + AB = 0
and with some rearranging,
   x^2 + (-A-B)x + (AB) = 0
If we match that up against
   x^2 + bx + c = 0
then we have
   b = -A-B
   c = AB
Or, put another way, -b = A+B. In other words, if we take
   ax^2 + bx + c = 0
and divide through a, we now know the sum and product of the solutions!
But how do we figure out the solutions themselves given only their sum
and product?
Well, given that -b = A+B, there are an infinite number of possible
solutions. Similarly, c = AB on its own has infinitely many solutions.
Hopefully there is only two solutions to *both* equations. But what are
they? Hmm.
The next revelation: Since -b = A+B, then -b/2 = (A+B)/2. In other
words, the arithmetic mean of A and B. So -b/2 is a point exactly half
way between the two solutions. If I can just figure out how far apart
they are, I can compute them!
Clearly you can't determine the seperation from the sum. It's not
obvious that you can determine it from the product either though. But
that product must come into the equation somehow. Hmm.
Of course, I already know what the final solution is, just not why. That
gave me a clue.
So what we have is A+B, but what we *want* is A-B. Well now, what
happens if we square these?
   (A+B)^2 = A^2 + 2AB + B^2
   (A-B)^2 = A^2 - 2AB - B^2   (A mathematician would know this off by
heart, but it took me a while to work out.)
Ooo, that's *interesting*... The difference between the two is only in
the product in the middle! And we *have* that product!
 From here, it's just a matter of tying up loose ends. b^2 = (A+B)^2.
The difference between sum^2 and difference^2 is exactly 4AB, so we have
   (A-B)^2 = (A+B)^2 - 4AB = b^2 - 4c
Since we want to add/subtract half the difference to half the sum, we have
   x = -b/2 +/- Sqrt(b^2 - 4c)/2
     = (-b +/- Sqrt(b^2 - 4c))/2
Ah, but we already eliminated "a", didn't we? Can we put that right back
into the main formula? Well, comparing with the "standard" formula and
shifting a little algebra, it becomes clear that we can.
   x = (-b +/- Sqrt(b^2 - 4ac))/2a
QED.
Bouyed up by this, I immediately set about performing the same trick for
the cubic. Obviously, this did not end well.
However figured out that you can compute the difference from the sum and
the product... GENIUS!! o_O I would never have known in a million years...
Date: 18 Jan 2009 14:34:22
Message: <4973843e$1@news.povray.org>
That's the "formal" mechanism I was talking about in the programming
language thread.
Yeah. Math tends to go for the "do all the gruntwork first, building bottom
up to the final statement, and finish", usually without explaining why you
would care about the final statement. :-)
Sure.
> *is*! :-P
That's pretty trivial mathematics compared to tensor calculus type stuff.
:-)  I'm not too bad at discrete math.
Write it, patch it, suck out the docs, say "isn't this great? Here's the patch."
Date: 18 Jan 2009 14:55:01
Message: <web.4973884992d55383ef2b9ba40@news.povray.org>
Tensor calculus isn't so bad.  Among other things, I gave my nephew my tensor
calculus book this past summer for his baby shower.  Gotta get kids started
early these days, y'know.
 - Ricky
Date: 18 Jan 2009 16:49:09
Message: <4973a3d5$1@news.povray.org>
I still can't figure out what a "tensor" is. :-P
Date: 18 Jan 2009 17:02:40
Message: <4973A768.2060408@hotmail.com>
>>> stuff.
>> tensor
>> started
multidimensional vector.
Date: 18 Jan 2009 17:35:00
Message: <web.4973ad9892d55383ef2b9ba40@news.povray.org>
scalar = tensor of rank 0
vector = tensor of rank 1
For example, the stress tensor is a rank 2 tensor since you quantify stress in a
plane and thus need two indices to describe which plane you're talking about.
So the (1,3) element if you wrote it as a matrix would correspond to stress in
the x-z plane.  This makes for 9 elements total.  Now if we're talking
relativity and such, it gets a little more complex.  But I guess you already
looked it up on Wikipedia, so I don't know what I'm rambling on about.
 - Ricky
Date: 18 Jan 2009 18:15:00
Message: <web.4973b72c92d5538357817c010@news.povray.org>
meh, from the title thought you were talking about Final Fantasy Tactics and
perhaps some sequel... :)
Subject: Re: ax^2 + bx + c = 0
Date: 19 Jan 2009 00:07:14
Message: <49740a82@news.povray.org>
Very cool. :-)
Date: 19 Jan 2009 07:17:30
Message: <49746f5a@news.povray.org>
> But why is that, exactly? Well, looking in my sister's A-level maths book
> [unlike me, my sister was *taught* mathematics] I discover a long sequence
> of algebraic manipulations that slowly transforms the one into the other.
It's not that hard or long, just involves dividing by a, completing the
square for the first two terms, rearranging, taking the square root, and
rearranging again for x.
But I imagine the cubic is a lot harder.
Date: 19 Jan 2009 07:31:49
Message: <497472b5@news.povray.org>
>> into the other.
Yeah. As I said, a sequence of algebraic operations which "just happen"
to lead to the answer we seek. (As in, there's no *apparent* reason why
this particular sequence of operations does it, as opposed to some other.)
I also note in passing that I have no clue what "completing the square"
actually means. But then, I have no formal mathematical education at
all, so it's a miracle I even comprehend algebra in the first place!
http://planetmath.org/?op=getobj&from=objects&id=1407
Does it make your eyes bleed?
Date: 19 Jan 2009 07:58:33
Message: <497478f9$1@news.povray.org>
Actually... if you gather up some of those subexpressions and represent
them as single letters, it's not that complicated.
Date: 19 Jan 2009 08:04:24
Message: <49747a58$1@news.povray.org>
Unless my eyes deceive me, this is equivilent:
J = 2a^3 - 9ab + 26c
K = Sqrt(J^2 + 4(-a^2 + 3b)^3)
M = (1 + i Sqrt(3))/2
N = (-1 + i Sqrt(3))/2
r1 = -(a/3) +   Cbrt((-J + K)/54) +   Cbrt((-J - K)/54)
r2 = -(a/3) + M Cbrt((-J + K)/54) + N Cbrt((-J - K)/54)
r3 = -(a/3) + N Cbrt((-J + K)/54) + M Cbrt((-J - K)/54)
While hardly on the same level as the quadratic, it's not "that" hard.
Date: 19 Jan 2009 08:57:29
Message: <497486c9$1@news.povray.org>
> Yeah. As I said, a sequence of algebraic operations which "just happen" to
> lead to the answer we seek. (As in, there's no *apparent* reason why this
Maybe if you've never done any equation solving before, but the steps are
pretty obvious steps to take to rearrange an equation like that (ie to get
all the x's in one place).
> actually means.
It's the key step to rearranging the quadratic equation in terms of x, and
useful in lots of other areas too.  It's the process of rewriting terms like
x^2+cx in the form (x+a)^2 + b.  It's not hard, and after performing a
square root allows you to get the x by itself.
Date: 19 Jan 2009 08:58:25
Message: <49748701$1@news.povray.org>
Did you try to derive those equations from ax^3+bx^2+cx+d=0 ?? :-)
Date: 19 Jan 2009 09:01:15
Message: <497487ab$1@news.povray.org>
No - because it solves the *monic* equation x^3 + ax^2 + bx + c = 0. :-P
(Notice the absence of a "d" in any of the equations above.)
I'm surprised nobody has yet pointed out that it's "+ 27c" and not "+ 26c".
Date: 19 Jan 2009 09:37:19
Message: <4974901f$1@news.povray.org>
So... a rank-0 tensor is just a number, a rank-1 tensor is a 1D grid of
numbers, a rank-2 tensor is a 2D grid of numbers, and a rank-3 tensor
is... what? A 3D grid of numbers?
I guess that's simple enough. How how do you do arithmetic with them? ;-)
Date: 19 Jan 2009 11:42:20
Message: <4974ad6c$1@news.povray.org>
> smooth result.)
Looking at dspguide.com (The first site that actually got me to make a
bit of sense out of FFT in the first place) it seems the overlap is
quite simple. What to overlap seems to be the length of the filter
kernel... But, how do you determine that if, say ... you present the
user with an interface that allows them to create a graph of which
frequencies to pass...?
I suppose this is where you'd want to use a Blackmann window to clean up
the edges of the kernel before applying it to the input data.
~Mike
Date: 19 Jan 2009 12:01:47
Message: <4974b1fb$1@news.povray.org>
> quite simple.
dspguide.com is the resource I used - and yet, it's really very good,
IMHO. The stuff about IIR filter design is quite fun. ;-)
If you have an N-point filter kernel, you can take X samples of input,
add on N-1 zeros at the end, FFT, multiply, inverse-FFT, overlap by N-1
samples with the previous window. This should produce the same results
as doing a normal convolution.
Using a larger N gives you more precise control over the frequency
response (because there are more points in it).
You know how if you JPEG-compress something too much, you get ghosting?
Well if you aren't careful with your filter kernel, your frequency
response ends up with ghosting. The Blackmann window is a way to try to
get rid of that. (By blurring the whole thing, unfortunately.)
Date: 19 Jan 2009 12:54:39
Message: <4974be5f$1@news.povray.org>
I think they actually have to be vectors, don't they? Not just pairs of numbers?
Date: 19 Jan 2009 14:13:28
Message: <4974d0d8@news.povray.org>
According to the book, my thinking was sound. You take an iFFT of the
arbitrary filter, apply a Hamming or Blackmann window to the shifted and
zero-padded filter kernel. Then you execute the filter by convolution,
or FFT convolution. Depending on the size of the filter kernel you've
generated. Bigger means FFT is more advantageous.
That's for FIR filters.
Now I'm reading a bout IIR filters and ... they're simple to code, but a
bear to design..
~Mike
Date: 19 Jan 2009 14:21:29
Message: <4974d2b9$1@news.povray.org>
> bear to design..
Exactly. But great for simulating old analogue subtractive synthesizers. ;-)
Date: 20 Jan 2009 08:16:45
Message: <4975cebd$1@news.povray.org>
Not quite...
Let's say you want to build a band-pass filter. It passes 100 Hz
unchanged, but it filters out everything else. A "perfect" version of
this filter is very simple - and very impossible. Its impulse response
would simply by a 100 Hz sinewave extending an infinite distance into
the past and into the future.
It should be completely obvious that no filter real-world filter can
possibly react to inputs that haven't happened yet - but that is what
this design calls for. (It is a "non-causal filter".)
Anyway, if you build an FIR by simply taking that infinite sinewave and
chopping the ends off to make it finite, you've just truncated the
impulse response. And that distorts the frequency response. The longer
the IR is, the less the distortion - and the more arithmetic your
digital filter is going to have to do when you run it.
If, instead of just chopping the ends off, you use a Blackmann window...
Well, you're multiplying the IR by the window. Multiplication in the
time domain is convolution in the frequency domain. The frequency
spectrum of a Blackmann window is such that this convolution is
essentially a blurring operation. It blurs out the small ripples,
without destroying the peak at 100 Hz which we'd like to keep. (It does
widen it slightly though.)
Anyway, coming back to general filter design...
- You figure out what frequency response you want, and how many points
you've going to use. (Note that before and after the inverse-FFT, the
number of "points" remains the same.)
- Obviously more points give you more control over the frequency
response; you've got more control points to move. It also means less
rippling between the centers of those control points.
- Take your desired frequency response. Take the inverse-FFT. Now
multiply that by your chosen windowing function.
- You now have your filter kernel.
Notice there's no zero-padding here. (I think you're possibly confused
by the guide's suggestion that you can zero-pad the IR before taking an
FFT in order to get better frequency resolution so you can see what your
filter's "real" frequency response is - this does not exactly match what
you originally requested because the IR is finite.)
Anyway, you can now "run" the filter in two ways: Take the convolution
of the kernel and your signal, or do an FFT-convolution.
To do an FFT-convolution, you want the filter's frequency response (not
its impulse response). Chop your input signal into blocks, zero-pad each
block, FFT, multiply, inverse-FFT, overlap consecutive blocks to build
an output signal. You're done.
(It strikes me that if you were trying to do this "real time", the
blocking would necessarily add some latency to the system that a
convolution implementation wouldn't have...)
Date: 20 Jan 2009 09:12:43
Message: <4975dbdb$1@news.povray.org>
>> and zero-padded filter kernel. Then you execute the filter by
>> convolution, or FFT convolution. Depending on the size of the filter
>> kernel you've generated. Bigger means FFT is more advantageous.
> Not quite...
Right, no way that could ever work.
Right... once you've chosen the frequencies to pass, you can then obtain
the impulse response by an iFFT, and applying the window. Depending on
the number of points the filter's frequency response will be an
approximation of the desired frequency response.
You'd want to zero pad the kernel for FFT convolution though, right?
Yeah, there would be a bit of latency I would expect.
FWIW, a long time ago I fooled around with an emulation project for the
MT-32 sound module, which has a resonant low-pass filter.  With a few
multiplies and a few adds per cycle, it would filter in realtime pretty
easily. I didn't understand the theory behind it, but the code looked
deceptively simple... Until I found the code for calculating the
coefficients. I found the same filter code on Gamedev.net. From the
looks of it, it's simply a 6-pole Chebyshev filter. The coefficients
were generated by what appeared to be the z-transform you were
discussing earlier. The resonance parameter is apparently is how much
ripple was allowed in the passband. More ripple = bigger spike at the
cut-off frequency.
Other interesting things about the module itself: It's essentially
subtractive synthesis combined with PCM samples. Each patch could
contain up to 4 partials: 2 pairs. Each pair had a ring modulator. If
one side of the modulator was unconnected (no partial) it would simply
generate white noise. IIRC, it had a few different waveforms, including
the PCM "waveform."
~Mike
Date: 20 Jan 2009 09:50:25
Message: <4975e4b1@news.povray.org>
Indeed.
(Although you *can* apply that kind of thing in the weird world of
mathematics. If you have a mathematical formula that describes your
entire signal - past, present and future - then you really *can* pass it
through a "perfect" filter like this. That's the magic of integral
calculus. But I digress...)
Yes.
> Depending on
Yes.
In general, if you ask for the frequency response that changes smoothly,
you'll get a close approximation. If you ask for a frequency response
with sharp discontinuities in it, you'll get ripples. (The inverse-DFT
is almost identical to the forward-DFT, remember.)
A lowpass filter consists of a straight line from 0 Hz to the cutoff
frequency, a sharp discontinuity from 100% to 0%, and then a straight
line from there onwards. Hence the impossibility of implementing it
"perfectly". Most other "standard" filter types have abrupt changes like
this too.
>> an FFT in order to get better frequency resolution so you can see what
>> your filter's "real" frequency response is - this does not exactly
>> match what you originally requested because the IR is finite.)
Checking the documentation carefully, it appears that the procedure is thus:
   To FFT-convolve a kernel containing X samples with a signal block
containing Y samples, pad *both* the kernel and the signal block to
X+Y-1 samples long, FFT to the frequency domain, multiply, inverse-FFT
back to the time domain again. Your new output signal block is larger
than the block you started with, so overlap it with its siblings.
So yes, you do pad the kernel as well as the input signal blocks. (The
amount of padding depends on the size of block you chop the signal
into.) I hypothesize that small blocks = FFT isn't much faster, large
blocks = you have to do lots of multiplies, so there's some sweet spot
somewhere in the middle for best performance.
...whereas if you just do a 500-point convolution, there will be 500
samples woth of latency. No more, no less.
> easily.
That's the magic of IIR. It's *very* compute-efficient.
> coefficients.
Uh, yes. ;-)
> discussing earlier.
Precisely.
The math isn't actually "hard" - again it's a few trig functions and a
couple of multiplies - it's just very "fiddly" to implement correctly.
There are lots of opportunities to screw it up.
> cut-off frequency.
Indeed.
Actually - when you get that far - these IIR filters are designed by
looking at the complex plane. You position "poles" and "zeros", and
these define a surface. The vertical slice going through the origin is
the frequency response of the filter. So it's like having a giant
elastic sheet, and moving these poles and zeros around to bend the part
of the sheet crossing that line into the shape you want.
A Chebyshev low-pass filter arranges poles in a semicircle. The
resonance comes from deforming this circle to make it elliptical. As you
do so, the poles get nearer to the line, and the "ripples" you see are
actually the edges of the peak surrounding each pole. I'll draw you a
graph if you like... ;-)
The other fun thing is, the mathematical analysis may show you that an
IIR filter will do one thing, but when you actually implement it
something totally different happens due to rounding errors! IIR filters
work using feedback, and feedback magnifies rounding errors. (FIR
filters by contrast are pretty much unaffected by them, because there's
no feedback.)
> the PCM "waveform."
Sounds pretty interesting.
Personally I'd love to implement something like that myself - but I
don't have access to anything that can talk to the sound hardware. :-(
(Haskell has a binding for libSDL - but it doesn't work on Windoze.)
Date: 20 Jan 2009 10:04:32
Message: <4975e800$1@news.povray.org>
I know this is probably painful, but ... under the windows platform does
Haskell have access to COM libraries? DirectX uses COM, you may be able
to use DirectSound (or is it DirectShow, now?) via its COM interfaces..
Either than or write a simple C Dll, and import the functions from that
DLL into the Haskell application.
You'll of course need to download the DirectX SDK for that to work.
~Mike
Date: 20 Jan 2009 10:11:21
Message: <4975e999$1@news.povray.org>
It has access to most of the Win32 API. If I can figure out what calls
to execute, it should be doable.
Seems plausible.
Heh. As if I could *ever* do that... I don't even know how DLLs work!
That's the easy part. ;-)
Date: 20 Jan 2009 10:24:07
Message: <4975ec97$1@news.povray.org>
> Personally I'd love to implement something like that myself - but I don't
You could always just output a raw .wav file and then send it somewhere to
play it (eg mediaplayer or winamp, surely also a smaller command line player
somewhere out there).
Date: 20 Jan 2009 10:24:30
Message: <4975ecae$1@news.povray.org>
Oh, now. DLLs aren't big scary things. They're just libraries. Creating
a DLL project in Visual C is a snap. Then you just create the functions
you want to export using the extern "C" __declspec( dllexport )
decoration on the function.
Depends ... ;) if you're impatient like me it's excruciating.
~Mike
Date: 20 Jan 2009 10:34:44
Message: <4975ef14@news.povray.org>
> It has access to most of the Win32 API. If I can figure out what calls to
http://msdn.microsoft.com/en-us/library/ms712879.aspx
You could first start off by checking that it plays a pre-existing WAV file,
then write the WAV file and play it immediately afterwards, then try out the
SND_MEMORY flag to play it directly from memory...
Date: 20 Jan 2009 10:38:24
Message: <4975eff0@news.povray.org>
> to play it (eg mediaplayer or winamp, surely also a smaller command line
> player somewhere out there).
Have you seen the format spec for the .WAV file format??
It's actually RIFF - a multilation of the Amiga IFF format with all the
4-byte values incorrectly written backwards. (Hence "R" for "reverse".)
You can't just say "hey, here's some data". You have to include a header
that describes - in the most retarded way imaginable - exactly what the
layout of the payload is. (E.g., mono or stereo, 8-bit or 16-bit, signed
or unsigned, etc.)
It's no mean feat to set all this up...
What I guess I *could* do is write a small Java application that accepts
raw audio data over TCP and then writes it to the sound hardware.
(Although talking to the sound hardware in Java isn't exactly easy
either - it's a 12-step process of getting a factory factory factory
that possibly yields a factory factory that can then be queried for the
kinds of factories it knows how to produce... you get the picture.)
Date: 20 Jan 2009 10:46:24
Message: <4975f1d0@news.povray.org>
  I think the R stands for Resource.
Date: 20 Jan 2009 10:55:08
Message: <4975f3dc@news.povray.org>
>> somewhere to play it (eg mediaplayer or winamp, surely also a smaller
>> command line player somewhere out there).
> or unsigned, etc.)
IIRC the data in the wav file isn't too, too bad to format correctly,
but the header needs to be right.
I remember a conversation with a friend while I was screwing around with
linux.
I can't remember the exact syntax .. but something like this.
cat mysound.wav | /dev/snd
"You can't cat a wav file!"
"Yeah, I can. Watch"
I hit enter and ... after a short burst of static, it plays the file,
albeit at the wrong sampling rate.
"Huh, I didn't know you could do that ..."
~Mike
Date: 20 Jan 2009 10:59:27
Message: <4975f4df$1@news.povray.org>
You mean this:
http://ccrma.stanford.edu/courses/422/projects/WaveFormat/
Looks very simple to me, about the same level of difficulty as writing a
windows bmp file, ie very easy.
Date: 20 Jan 2009 11:19:40
Message: <4975f99b@news.povray.org>
  The amount of things wrong in everything of the above is mind-boggling. ;)
  (For one, you are trying to run /dev/snd as if it was a program. Of course
that's not the only problem.)
Date: 20 Jan 2009 11:23:05
Message: <4975fa69$1@news.povray.org>
Hmm, does Linux use the same format as DOS for redirection? e.g. it
should be > /dev/snd (or whatever)
I know what I did was truly ugly, but it worked, that's what was funny.
But, I can't remember the syntax (It's been years since I've really used
  linux from a command line.)
~Mike
Date: 20 Jan 2009 12:15:54
Message: <497606ca@news.povray.org>
  | is a pipe: The standard output of the program on the left side is
redirected to the standard input of the program on the right side.
However, /dev/snd is not a program and cannot be run.
  If you want to redirect the standard output of a program to a file
(or, in this case, a device), > is the operator for it.
Date: 20 Jan 2009 12:39:57
Message: <49760c6d$1@news.povray.org>
That's what Microsoft wants you to think. Originally it was "reverse", until
they realized how few people were familiar with the Amiga formats or something.
It's *exactly* IFF, with the endianness reversed. :-)
Altho it does annoy me when I see it mentioned in the press how "RIFF is an
extensible format created by Microsoft...."
I do like how PNG took it a step farther and encoded into the chunk names
whether you need to understand the chunk to parse the file, etc.
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 21 Jan 2009 04:17:14
Message: <4976e81a$1@news.povray.org>
Now try doing that with a sound that's been LZW-compressed. ;-)
Doesn't sound very nice...
Date: 21 Jan 2009 08:37:24
Message: <49772514$1@news.povray.org>
I imagine it's about as pleasing as loading an MP3 as a raw PCM audio
file and playing it. For some reason this one audio app I have
recognizes every MP3 correctly, except for a handful of files from one
particular album. Weird.
~Mike
