POV-Ray : Newsgroups : povray.off-topic : Frustration Server Time
2 Nov 2026 19:45:31 EST (-0500)
  Frustration (Message 1 to 17 of 17)
Subject: Frustration
Date: 15 Jan 2009 14:50:57
Message: <496f93a1$1@news.povray.org>
And so, the Haskell mailing list is currently lit up with a discussion
about terminology.
Specifically, somebody wrote in a blog that he was looking for something
called "Appendable", but it turns out it's actually called "Monoid".
Unsurprisingly, the author added "Haskell, *please* stop letting
category theorists name things!"
But you see, some people apparently don't think this is a problem. (!!)
Words fail me... It's like somebody using a chainsaw to slice a loaf of
bread, and seeing absolutely nothing wrong with doing so. What do you
*say* to someone like that?! >_<
http://blog.orphi.me.uk/
Subject: Re: Frustration
Date: 15 Jan 2009 17:55:40
Message: <496fbeec$1@news.povray.org>
> about terminology.
"Have a chainsaw"?
Jim
Date: 16 Jan 2009 04:28:40
Message: <49705348$1@news.povray.org>
> "Have a chainsaw"?
LOL! Yeah, I guess so...
The guys over there are now arguing that since you need to know physics
to be a mechanical engineer, and you need to know chemistry to be a
laboritory chemist, why shouldn't you need to know predicate calculus,
abstract algebra and set theory to be a computer programmer?
Seriously, WTF??
Date: 16 Jan 2009 12:18:03
Message: <4970c14b$1@news.povray.org>
> Seriously, WTF??
Honestly, that makes sense to me. Maybe not set theory as such, but the
other two are basically what a computer program is made out of. I never
understood why people thought calculus was worthwhile for computer
programming.  (Domain knowledge, sure, but not programming.)
   Why is there a chainsaw in DOOM?
   There aren't any trees on Mars.
Date: 16 Jan 2009 13:16:22
Message: <4970cef6@news.povray.org>
>>> of bread, and seeing absolutely nothing wrong with doing so. What do
>>> you *say* to someone like that?! >_<
>> "Have a chainsaw"?
> Seriously, WTF??
I would think set theory would be useful for dealing with certain data
types.
The one that always got me was needing to know engineering physics to be
a computer programmer.  Seriously, my CS degree program was heavy on
modeling and simulation, but we had to take engineering physics (rather
than a course on engineering physics tailored for CS majors, we just had
to take the straight EP course).
But there's a bit of a difference between people who actually design
airplanes needing to know EP and those who deal with simulations of
airplanes.  The same depth of knowledge is needed because real or
simulated, the math and physics are the same for the airfoil.  But for
the person doing simulation, there's this thing called a library that we
can link into to figure out the fancy math for us - so we don't need to
memorise arcane formulae.  We just need to know the inputs to a function
and the outputs from a function.
My EP professor disagreed.
Jim
Date: 16 Jan 2009 13:40:08
Message: <4970d488$1@news.povray.org>
Darren New wrote:
> Invisible wrote:
>> why shouldn't you need to know predicate calculus, abstract algebra
>> Seriously, WTF??
I don't know. There are things you *must* know if you hope to write
nontrivial programs and expect them to work properly. And there are
other things which are useful to know, but generally not vital. I'd say
all of the above fall definitely into the range of "it's great if you
know it, but it's really not *required*".
Apparently I am entirely alone in this view.
Date: 16 Jan 2009 14:02:57
Message: <4970d9e1$1@news.povray.org>
No.
Jim
Date: 16 Jan 2009 14:32:14
Message: <4970e0be$1@news.povray.org>
I'm playing devil's advocate a bit, but ... what if there is no such
library that would give you the values you need regarding lift, etc.
What if part of what you need to do in the simulation is to create these
calculations? Then you must certainly know these arcane formulae.
Granted, if something is needed enough, you won't be the first person to
do it and a solution will be available...
~Mike
Date: 16 Jan 2009 15:24:12
Message: <4970ecec$1@news.povray.org>
You don't need to know algebra to know how to write a program? You don't
need to know how "and" and "or" works to write a program?
You can't understand what a compiler does without knowing any abstract
algebra. Heck, you can't even know the difference between a literal and an
expression without knowing abstract algebra. You realize that "pass by
value" is abstract algebra, right?
How do you know if your while loop terminates if you don't know how
predicate calculus works?
Actually, I think the answer is more that you know these things, and you
just don't know the terminology the academics use for much of the stuff.
Date: 16 Jan 2009 15:34:03
Message: <4970ef3b$1@news.povray.org>
By "calculus" I mean the calculus of integrals and derivatives, not
something like "relational calculus".
Date: 16 Jan 2009 18:10:07
Message: <497113cf$1@news.povray.org>
>> we can link into to figure out the fancy math for us - so we don't need
>> to memorise arcane formulae.  We just need to know the inputs to a
>> function and the outputs from a function.
When it comes to formulae for airfoil calculations, that's all pretty
well established now.
But even if you needed to create the library, how many people do you know
who would rely solely on their memory when creating a library that
hundreds or thousands of people might end up using?  I know *I'd* be
referring to my books to make sure I implemented the formula correctly.
Jim
Date: 17 Jan 2009 09:45:29
Message: <4971ef09$1@news.povray.org>
> an expression without knowing abstract algebra. You realize that "pass
> by value" is abstract algebra, right?
OK, now I actually *know* abstract algebra, and your statements still
make no sense to me.
You don't need to know the formal theory to understand how a simple loop
works. Basic intuition will tell you that.
The discussion seems to be gradually anealing towards the idea that it's
not the *names* that are the problem, but the near-total lack of any
semblance of documentation about them that doesn't assume you already
hold a PhD in advanced mathematics.
For example, the documentation for the Monoid class states
   "The monoid class. A minimal complete definition must supply mempty
and mappend, and these should satisfy the monoid laws.
   Methods:
   - mempty: Identity of mappend.
   - mappend: An associative operation.
   - mconcat: Fold a list using the monoid. For most types, the default
definition for mconcat will be used, but the function is included in the
class definition so that an optimized version can be provided for
specific types."
Assuming you already know what a monoid is, this is quite transparent.
If you've never heard of a monoid in your life, none of this makes the
slightest semblance of sense. And looking it up on Wikipedia still
doesn't tell you what this has to do with writing useful programs in
Haskell. (Or any other language.)
(The same library features Endo, "the monoid of endomorphisms under
composition". Even I have no clue what in the name of God that actually
means.)
The concensus seems to be that
- Haskell is inherantly mathematical, with a strong emphasis on deep
abstractions.
- Deep abstractions can be hard to learn, so we should document them better.
However - and this is what makes me so angry - there is a strong element
in the community who claim that Haskell should *only* be used by maths
experts. I find that to be arrogant and elitist.
The reasoning behind this seems to be "if you don't study category
theory, you cannot write computer programs, so it's OK for Haskell to
demand that everybody learns category theory before using it". This is
of course easily falsifiable.
Date: 17 Jan 2009 17:43:04
Message: <49725ef8$1@news.povray.org>
I suspect you just never really thought it thru. You know that a compiler is
just a bunch of rewrite rules, for example, right?
Basically, everything a computer program does is mapping strings of bits to
abstract algebras. The I/O of a Turing machine is a mapping from strings of
whatever-symbols-can-be-on-the-tape to abstract algebras.
That's because the basics of predicate calculus are easy to learn. So easy,
you probably already knew them before you knew what it was called.
I have a box with some balls in it. I pull out one ball. It's black. I can
conclude that not all the balls that were in the box were white, right? That
means if I want to check if all the balls are white in a box, I can stop the
loop once I find the first black ball.
>> you just don't know the terminology the academics use for much of the
>> stuff.
In Haskell, yes, that could be the case.  For example, "mempty is the
identity of mappend" makes perfect sense, if you know what "is an identity
of" means.
Sounds like someone needs to write a textbook about what the terms in
Haskell means.
I suppose that is. I guess it depends on their goals. Telling someone else
what they should or should not use seems arrogant.
Haskell doesn't demand anything. :-)  If you write the documentation for
people who don't study category theory, I'm sure Haskell won't object.
Date: 19 Jan 2009 05:21:02
Message: <4974540e$1@news.povray.org>
> compiler is just a bunch of rewrite rules, for example, right?
What do rewrite rules have to do with abstract algebra?
> to abstract algebras. The I/O of a Turing machine is a mapping from
> strings of whatever-symbols-can-be-on-the-tape to abstract algebras.
Still not making any sense...
>> loop works. Basic intuition will tell you that.
> easy, you probably already knew them before you knew what it was called.
Well fair enough. But certain people seem to think that "if you haven't
even bothered to do an undergraduate course in advanced mathematics, you
shouldn't be allowed near a computer". Which just seems absurd to me...
>> it's not the *names* that are the problem, but the near-total lack of
>> any semblance of documentation about them that doesn't assume you
>> already hold a PhD in advanced mathematics.
> identity of" means.
...which *I* do, but your typical programmer has *no clue*.
This is really why the whole discussion started. Some blogger tried to
switch from Python to Haskell, and was looking for a class called
"appendable" or something. But no, it's called Monoid. Notice how this
sounds almost exactly like Monad, yet does something wildly different.
(Somebody was even kind enough to point out that a Monad *is* a Monoid.
Yay, that's really going to help...)
> Haskell means.
My favourit is the documentation for the Writer monad. The documentation
basically says "This module is inspired by [some random paper]". The
paper in question is an essay on how to do polymorphic programming. It
mentions a writer monad as a brief 6-line example program in passing,
with no suggestion as to how you use it. Yay for documentation!
We need propper documentation here! The docs for existantial
quantification are similarly vague. (But hey, it's a compiler manual,
not a language tutorial... *sigh*)
>> element in the community who claim that Haskell should *only* be used
>> by maths experts. I find that to be arrogant and elitist.
> else what they should or should not use seems arrogant.
Yeah, what *are* Haskell's goals? An often-quoted one is "avoid success
at all costs". They seem to be doing a good job!
Thing is, I really love Haskell. But I'm not a mathematician, so I can't
understand lots of stuff. And the attitude seems to be "well if you're
not clever like us, you should go back to Python" or similar.
Hmm... Do you have *any idea* how many monad tutorials there are?
Not that monads are complicated. They're just very abstract, so it's
kinda hard to explain what they "are".
Imagine trying to explain what a number "is" to somebody who doesn't
already know. Well, I mean sure, the integers are easy enough. But what
about negative numbers? Fractions? Irrationals? Transcendentals?
Imaginary numbers? Hmm... actually, this is pretty hard!
And yet, most people wouldn't think twice about using "numbers". So it
can't be that hard...
I think perhaps that's Haskell's problem. It's a language which excells
at abstracting things, with the result that the standard libraries are
chock-full of constructs so abstract that they can only be named after
terms from mathematics. And even if they weren't, it would *still* be
stupidly hard to explain what they're for...
I guess Haskell will never be popular. :-(
Date: 19 Jan 2009 12:51:59
Message: <4974bdbf$1@news.povray.org>
Algebra *is* rewrite rules.
Agreed.
I think learning what an identity value is should be pretty easy. :)
So write them.
Haskell doesn't have goals. He's dead. The programming language doesn't have
goals. It was never alive.
I don't know. That was like third and fourth grade, here.
Date: 19 Jan 2009 14:06:57
Message: <4974cf51$1@news.povray.org>
AFAIK, abstract algebra is about the study of anything that has certain
mathematical properties, and what that gives rise to. You don't actually
rewrite anything.
Yes - if it was documented! (In language relevant to computer
programming...)
> So write them.
Gotta understand something before you can explain it.
>> what about negative numbers? Fractions? Irrationals? Transcendentals?
Yeah. But you try summing all that up in a short expression. Quite hard,
isn't it?
Date: 19 Jan 2009 14:36:19
Message: <4974d633$1@news.povray.org>
> rewrite anything.
The rewrite rules specify what the properties are. List some properties for
me, and I'll show you what the rewrite rules are. :-)
"Zero is the identity for addition"
A+0 = A
0+A = A
> programming...)
I dunno. I don't think I could have gotten out of third grade without
knowing the identity value for addition and multiplication.
