POV-Ray : Newsgroups : povray.off-topic : Coin game Server Time
2 Nov 2026 20:47:25 EST (-0500)
  Coin game (Message 1 to 29 of 29)
Subject: Coin game
Date: 8 Jan 2009 06:32:14
Message: <4965e43e@news.povray.org>
Here's an interesting puzzle.
A game is played by repeatedly tossing a coin until it lands heads.  If it
lands heads on the first try, you win $1 and the game is over.  If it lands
heads on the 2nd try, you win $2 and the game is over.  On the 3rd try $4,
and in general if you get the head on the nth try, you win $2^(n-1).
I simulated this game in C++ and after 1e6 goes the average win-per-go
settles down quite nicely to $8.09 and stays there up to 1e8 goes.  Is that
correct?  How much should you be willing to pay for each go?  Does it depend
on how many goes you are going to have?
Subject: Re: Coin game
Date: 8 Jan 2009 08:22:19
Message: <4965fe0b$1@news.povray.org>
> it lands heads on the first try, you win $1 and the game is over.  If it
> lands heads on the 2nd try, you win $2 and the game is over.  On the 3rd
> try $4, and in general if you get the head on the nth try, you win
> $2^(n-1).
> that correct?  How much should you be willing to pay for each go?  Does
> it depend on how many goes you are going to have?
By "average" you mean "arithmetic mean"?
The probability of N tosses is 2^(-N). So the probability of winning
2^(N-1) dollas is 2^(-N).
[This simple analysis ignores the fact that if, say, you tossed a coin
100 times without getting any heads at all, almost any *real* human
would question whether the coin is loaded...]
Just as the probability of individual scores have a probability
distribution, so the average scores should have one. And, by the central
limit theorum, I would suggest that these converge on being normally
distributed for larger and larger numbers of turns.
But what would the mean and standard deviation be? I have no idea.
Date: 8 Jan 2009 09:20:12
Message: <49660b9c@news.povray.org>
Yup, total amount won over all games divided by the number of games played.
Date: 8 Jan 2009 09:31:29
Message: <49660e41$1@news.povray.org>
Hmm. Tricky.
The number of heads given N tosses of the coin follows a Poisson
distribution, and the number of tails before hitting a head follows a
geometric distribution, but what the **** is the average score? A curios
puzzle indeed...
Date: 8 Jan 2009 10:00:40
Message: <49661518$1@news.povray.org>
> $2^(n-1).
what kind of coin?
what kind of surface does it land on?
any pay out for it landing on its edge?
Date: 8 Jan 2009 10:28:07
Message: <49661b87@news.povray.org>
> what kind of coin?
Just assume there is a 50% chance of heads or tails.
Date: 8 Jan 2009 10:38:52
Message: <49661e0c$1@news.povray.org>
> Hmm. Tricky.
> puzzle indeed...
How about if you assume initially the game is limited to a certain number of
tosses, and if a head fails to show up within that limit you win nothing...
Date: 8 Jan 2009 10:46:59
Message: <49661ff3$1@news.povray.org>
> $2^(n-1).
The probability to win at n:th round is (1/2)^n. If you win, you get
2^(n-1). So, the theoretical predicted win-per-go is
(1/2)^1*2^(0)+(1/2)^2*2^1+(1/2)^3*2^2.... witch is the same as 1/2 + 1/2
+ 1/2 + 1/2... => infinite.
So, if you are able to have an unlimited number of goes and the other
part of the game is able to pay you what ever it has to, it doesn't
matter how much you pay for the each round: you will eventually make profit.
At least that's how our maths book explained it to me like two months ago :)
-- Arttu Voutilainen
Date: 8 Jan 2009 11:06:57
Message: <496624a1@news.povray.org>
  How did you implement it? What type of integers did you use to count the
amount of money? (Note that a 32-bit integer will overflow after only 32
tosses of the coin, which is perfectly within the realm of possibility.)
Date: 8 Jan 2009 11:10:38
Message: <4966257e$1@news.povray.org>
"scott" <sco### [at] scottcom> wrote in message news:4965e43e@news.povray.org...
lands
that
> correct?
No. More properly, it's useless. You won't be able to solve this empirically
as such. Most influential outcomes on payoff are least likely, which you
will not ever come across in finite time.
Infinite. Sum(n,0,inf)( (1/2)^n * 2^(n-1) ) = sum(n,0,inf)(1/2) = inf.
Of course it only makes sense to play if both you and the casino have
infinite time and infinite money.
> Does it depend on how many goes you are going to have?
No, each round of game is independent, is it not?
Date: 8 Jan 2009 11:19:21
Message: <49662789$1@news.povray.org>
I used 32bit and then 64bit integers, but the result was the same.
Date: 8 Jan 2009 11:27:37
Message: <49662979$1@news.povray.org>
What if you don't have infinite time?
Yes, but somehow you have to calculate the "realistic" amount that you will
win in finite time, so you can decide how much you are willing to pay for
this game.
If I offered you a go for $2 would you take it? How about $5, $10, $100 ?
There is a stark contrast to these values and the theoretical infinite
average expected winnings.
Date: 8 Jan 2009 11:28:02
Message: <49662992@news.povray.org>
  Did you at least put an assert() to check that no more than 31 (or 63)
tosses were ever made?
Date: 8 Jan 2009 11:47:44
Message: <49662e30@news.povray.org>
news:49662979$1@news.povray.org...
Then we decide on a cutoff.
will
> this game.
Sure, if you tell me exactly what the finite time is.
It's an even game for 4 throws, favours me for higher. You must show me that
you have $8.
> How about $5,
It's an even game for 10 throws, favours me for higher. You must show me
that you have $512.
> $10,
It's an even game for 20 throws, favours me for higher. You must show me
that you have $524,288.
This is on par with typical lotteries. Odds of winning the biggest jackpot
is almost one in a million, with more probable smaller prizes.
> $100 ?
It's an even game for 200 throws, favours me for higher. You must show me
that you have over $8e59.
Even then, I don't think I'd play, as I don't know where I'd put that money
if I win.
The progression on maximum winnings possible might be a clue why.
Date: 8 Jan 2009 11:56:03
Message: <49663023$1@news.povray.org>
> $2^(n-1).
The expected payoff is infinite of course.  Personally, I'd pay about
$10 to play the game, which indicates that I'm not attempting to
maximize my expected payoff in making this decision.  The best I can
formalize my reasoning is that the `utility' to me of winning a sum of
money levels off asymptotically as that sum of money decreases.  For
example, as far as I'm concerned there's no difference between winning
$10^20 and $10^30, despite the fact that the latter is a vastly larger sum.
Furthermore, since I have only a very limited amount of money, losing $x
has a higher negative utility than gaining $x -- as indicated by the
fact that I wouldn't play a game with zero expected payoff (unless the
game itself was fun of course).
To properly estimate how much I should pay to play under this view I
should make a guess at my payoff vs. utility curve and then calculate an
expected utility, but that's a bit more effort than I's probably care to
spend were I presented with such a situation, so I'll take the
satisficing approach and just say $10.
Also, I assume that you're familiar with the name of this puzzle, but on
the off chance that you're not:
http://en.wikipedia.org/wiki/St._Petersburg_paradox
Date: 8 Jan 2009 12:10:30
Message: <49663386@news.povray.org>
I tried it myself with the program at the end of this post, and got a
bit different of a result. The program printed:
times tested: 100000000, sum: 1600092924, average: 16.0009
times tested: 200000000, sum: 2952473665, average: 14.7624
times tested: 300000000, sum: 4316535702, average: 14.3885
times tested: 400000000, sum: 6018669380, average: 15.0467
times tested: 500000000, sum: 7585216727, average: 15.1704
times tested: 600000000, sum: 8915924298, average: 14.8599
times tested: 700000000, sum: 10662688388, average: 15.2324
times tested: 800000000, sum: 12027713479, average: 15.0346
times tested: 900000000, sum: 13468996092, average: 14.9656
times tested: 1000000000, sum: 15300481793, average: 15.3005
  The program:
#include "IsaacRand.hh"
#include <iostream>
#include <cassert>
int main()
    typedef unsigned long long ULL;
    IsaacRand rng(0);
    ULL sum = 0;
    std::cout << "sizeof(sum) = " << sizeof(sum) << std::endl;
    ULL counter;
    for(counter = 0; counter < 1000000000ULL; ++counter)
        ULL rounds = 0;
        while(rng.getNext() % 2 == 0)
            ++rounds;
            assert(rounds < 64);
        if(rounds) sum += 1ULL << rounds;
        else ++sum;
        if(counter % 100000000 == 100000000-1)
            std::cout << "times tested: " << counter+1
                      << ", sum: " << sum << ", average: "
                      << double(sum)/double(counter) << std::endl;
Date: 8 Jan 2009 12:59:12
Message: <49663ef0$1@news.povray.org>
> if I win.
I can help with that!
   Why is there a chainsaw in DOOM?
   There aren't any trees on Mars.
Date: 8 Jan 2009 14:08:44
Message: <49664f3c$1@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:49663ef0$1@news.povray.org...
money
> > if I win.
Thanks, but I need help from a couple more people to stash away equivalent
of 40,000 universes' weight of money in 100 dollar bills.
Date: 8 Jan 2009 15:14:22
Message: <49665e9e@news.povray.org>
Btw, this might be of interest:
Date: 9 Jan 2009 02:50:36
Message: <496701cc$1@news.povray.org>
>> > the
>> > 32
>> > possibility.)
It seems that the number of tosses never exceeds 16, even when running it
1e9 times (where you would expect around 30 tosses is likely to come up).
OK I just fixed it now, I changed my head/tail generator from:
(rand()%2) == 0
to
rand() <= RAND_MAX/2
and now it seems to behave better, after 1e9 goes the maximum number of
tosses in a row is 29, and the average winnings per go are around $14.30.
I guess that the RNG doesn't have more than 16 odd or even integers in a
row, but it does has more than 16 either side of the mid-value.  Perhaps I
need a better RNG to investigate further.
Date: 9 Jan 2009 02:57:34
Message: <4967036e$1@news.povray.org>
>> $10,
OOC why the 20 and why the $2^19 figues?  That's what I was really
interested in.
Date: 9 Jan 2009 03:00:28
Message: <4967041c$1@news.povray.org>
No I wasn't aware of the name (so as usual it is then very hard to find any
info about it), thanks!
Date: 9 Jan 2009 04:06:26
Message: <49671392@news.povray.org>
> (rand()%2) == 0
> to
  The rand() function in most compilers is of extremely poor quality and
should never be used for this type of application. You should always use
a very high-quality RNG with a humongous period.
  I used (my C++ version of) the ISAAC RNG, which should be of fairly high
quality.
Date: 9 Jan 2009 04:15:49
Message: <496715c5$1@news.povray.org>
> quality.
I understand the Mersenne Twister is designed specifically for these
kinds of simulations - but I don't know how widely available it is...
PS. One time I wrote my own PRNG just to generate some random data for
testing purposes. I don't know why I didn't use the PRNG library, but I
should have; on investigation, it turns out that my own PRNG almost
always has a period of 2. (!!) Oops...
Date: 9 Jan 2009 04:52:40
Message: <49671e67@news.povray.org>
  The ISAAC RNG is faster than MT. I don't know about quality, but it should
be very competitive at least.
  One of the basic things taught at school is that you should never attempt
to make your own PRNG if you don't have extensive experience about the
subject, if you want any kind of quality to it.
  Another thing with the exact same rule is a hashing function.
Date: 9 Jan 2009 05:00:54
Message: <49672056$1@news.povray.org>
Well I seriously doubt it can possibly be any *worse* than an LCG.
(Otherwise... why would they have designed it?)
Or, indeed, several other kinds of construct. (E.g., it's notoriously
hard to make a good encryption algorithm.)
In my defense, in the incident in question "good quality" random numbers
weren't necessary. I just needed lots of different numbers with no
particular pattern to them. OTOH, what I got was something like
   3, 11, 3, 11, 3, 11, 3, 11...
which is obviously no use at all. The PRNG generates longer sequences in
a few cases, but most of the time it does not. And I somehow failed to
notice this.
In future, I'm going to use the PRNG library. No matter how stupid its
API is!
Date: 9 Jan 2009 09:07:04
Message: <49675a08$1@news.povray.org>
I just found out that Windows includes a better RNG anyway, you call it with
the API function CryptGenRandom.  More details here:
http://en.wikipedia.org/wiki/CryptGenRandom
It's a fair bit slower than rand(), but by making use of every bit returned
(rather than just testing the LSB) it is comparable.
Date: 9 Jan 2009 12:09:03
Message: <496784af@news.povray.org>
This method seems to work pretty well: http://xkcd.com/221/
Date: 9 Jan 2009 12:51:01
Message: <49678e85$1@news.povray.org>
And even if you do. Knuth tells stories of his own attempts while writing
his semi-numeric methods tome, having thought he came up with a great RNG
and found it generated a couple hundred numbers before settling into a short
cycle of something like 3 or 4 values.
