POV-Ray : Newsgroups : povray.off-topic : Acer Aspire 5000 Server Time
2 Nov 2026 20:47:31 EST (-0500)
  Acer Aspire 5000 (Message 1 to 50 of 63)
Goto Latest 50 Messages Next 13 Messages >>>
Subject: Acer Aspire 5000
Date: 7 Jan 2009 11:52:50
Message: <4964dde2$1@news.povray.org>
OK, so here's a question...
My sister has an Acer Aspire 5000 laptop. It used to work just fine, but
recently it has developed some disturbing symptoms - basically random
freezing.
The utterly weird thing is, it behaves perfectly under [several
different variants of] Linux, but continues to randomly freeze when
running under Windows. [I have reinstalled Windows several times now.
Interestingly, it always seems to hang at the same places in the
installation sequence.]
The symptoms:
- Laptop no longer responds to keyboard or mouse. (Mouse pointer won't
move, Ctrl+Alt+Del is no-op, the capslock light doesn't function when I
press the key, etc.)
- On every laptop known to man, holding down the power button will
forcibly power down the laptop. This does not work while the laptop is
frozen. (Fortunately the battery typically dies after ~5 minutes or so.)
- The laptop *does* respond to some things though. Unplugging the
Ethernet cable still pops up that retarded "a cable is unplugged" message.
- The fans seem to spin up while the laptop is hang, suggesting an
infinite loop in the software somewhere.
- I am reasonably sure the laptop is not overheating. It seems cold to
the touch, and it repeatedly hangs at *exactly* the point in Windows,
and has never done this even once under Linux.
- Repeated memory tests reveal no problems of any kind.
- I have reinstalled Windows multiple times, without any Internet
access, so I'm downright certain it's not a virus or a software
configuration issue.
To reiterate, when the laptop was new, it had none of these issues.
(Although it was dissapointingly slow.)
Does anybody have the slightest clue what the *hell* is causing this
frustrating behaviour?
Subject: Re: Acer Aspire 5000
Date: 7 Jan 2009 12:07:31
Message: <4964e153@news.povray.org>
Invisible wrote:
Are they any devices/gizmos/etc that don't work on Linux? WLAN?
Bluetooth? Card reader? Anything?
-Aero
Date: 7 Jan 2009 12:54:25
Message: <4964ec51$1@news.povray.org>
Wow. I was under the impression this was built right into the power
supplies. Maybe not on a laptop, tho.
I have a friend who was designing motherboards for specialized systems like
disk array servers. He told me he spent three days trying to figure out why
the system would power off seven seconds after he plugged it in each time.
Turns out it took three seconds to initialize the board enough that the
signal from the power supply could be read, and he'd wired that wire
backwards, so four seconds later it would turn off again.
   Why is there a chainsaw in DOOM?
   There aren't any trees on Mars.
Date: 7 Jan 2009 13:09:11
Message: <4964efc7$1@news.povray.org>
Here's a thought. See if you can configure the BIOS to turn off APCI stuff?
The "advanced" power control? Linux tends to handle this differently, and
perhaps Windows is confused by some problem being caused by this.
No idea why it would crop up after a while, tho.
Date: 7 Jan 2009 15:53:29
Message: <49651649$1@news.povray.org>
What are you using to do the memory tests?
Jim
Date: 7 Jan 2009 17:16:50
Message: <496529d2$1@news.povray.org>
memtest86
http://blog.orphi.me.uk/
Date: 7 Jan 2009 17:48:17
Message: <49653131$1@news.povray.org>
> memtest86
86, or 86+?  ISTR that 86+ is more thorough, but 86 should be sufficient.
Jim
Date: 8 Jan 2009 02:54:58
Message: <4965b152$1@news.povray.org>
> The utterly weird thing is, it behaves perfectly under [several different
> variants of] Linux, but continues to randomly freeze when running under
> Windows. [I have reinstalled Windows several times now. Interestingly, it
> always seems to hang at the same places in the installation sequence.]
Sounds to me like it is one particular piece of hardware/driver
malfunctioning.  Under Linux it either has a different driver or is just not
used at all (as already mentioned).
I would try booting Windows in safe mode and seeing if that is stable.  If
so then I would reboot normally and disable all non-critical hardware in
device manager.  If it is still stable then selectively restart hardware
until it you find the culprit.  If you are really lucky a driver update
might fix it...
Date: 8 Jan 2009 04:11:37
Message: <4965c349$1@news.povray.org>
> malfunctioning.
This is my feeling also. It used to work just fine, and now it doesn't,
despite multiple reinstalls, which suggests a hardware issue. (But I
have no idea which bit of hardware.)
I did think perhaps it was the audio - my sister mentioned the sound
suddenly stopped working a while ago, and sure enough the machine locked
shortly after I installed the audio drive.
...but then I reinstalled without the audio driver, and it still
randomly hangs. *sigh*
Ah, the joy of intermittent faults. Is it *really* gone? Or is it just
not happening right now? :-/
> If so then I would reboot normally and disable all non-critical hardware
> in device manager.  If it is still stable then selectively restart
> hardware until it you find the culprit.  If you are really lucky a
> driver update might fix it...
Well, currently I have installed Windows plus every update that Windows
Update will give me. I haven't *seen* it crash since that time, but.....
Date: 8 Jan 2009 04:51:55
Message: <4965ccbb@news.povray.org>
Ah, the joy of *extremely* intermittent faults :-)
Have you looked in the Event Viewer (I think it's called that in XP too) to
see what happened when it crashed?
It seems from your comments that the laptop is still running, just not
responding to user input.  Is this the internal mouse and keyboard? Try
plugging in an external USB mouse next time it "freezes".
Date: 8 Jan 2009 04:57:10
Message: <4965cdf6@news.povray.org>
Indeed!
> to see what happened when it crashed?
Yeah, "crashed" would seem an exaggeration. More like "suddenly going
extremely slowly". (IIRC, the CPU graph in Task Manager stops scrolling,
for example.)
I'm using the internal glide pad. I didn't have a USB mouse with me. I
guess I could give that a try...
Date: 8 Jan 2009 06:35:57
Message: <4965e51d$1@news.povray.org>
Indeed.
On the other hand, I was *also* under the impression that the cooling
fan is hardware-controlled. But it turns out to be software-controled. (!!)
I discovered this while trying to install SUSE on my dad's ancient brick
of a laptop. The install kept failing in bizare and unexplained ways.
Until I picked up the laptop and almost burnt my hand off!
We rebooted the laptop, and as soon as the BIOS screen showed up, the
fans started spinning like mad. We waited for them to slow down. (It
took a while.) Then we resumed the installation attempt. Same problem.
No matter how hot the laptop got, no fans.
The solution in the end was quite simple. Reboot with the laptop hot.
The fans spin up to full power. Rather than waiting for them to stop,
just start installing. The fans remained at full speed until the system
soft-reset onto the new kernel. After that they appeared to work "normally".
GO. FIGURE.
Date: 8 Jan 2009 07:12:00
Message: <4965ed90@news.povray.org>
> We rebooted the laptop, and as soon as the BIOS screen showed up, the fans
What software was running then while you were waiting?
> The solution in the end was quite simple. Reboot with the laptop hot. The
> fans spin up to full power. Rather than waiting for them to stop, just
> "normally".
I notice when I boot up my Vista box, that every fan runs at full blast
until some point during Vista boot, whereby first the CPU fan virtually
turns off, then a few seconds after the desktop appears the GPU fan
virtually turns off, all I can hear then is just occasional blips of hard
drive head movement - until I fire up a 3D game, then all hell breaks loose
again :-)
Date: 8 Jan 2009 07:17:03
Message: <4965eebf$1@news.povray.org>
The BIOS configuration interface.
> hard drive head movement - until I fire up a 3D game, then all hell
> breaks loose again :-)
Interesting. All the fans in my PC just run constantly anyway. The four
harddrives are just about inaudible.
(I can't believe I have four harddrives...)
Date: 8 Jan 2009 07:29:29
Message: <4965f1a9$1@news.povray.org>
So your conclusion is that the BIOS software controls the fan speed, but for
some reason SUSE manages to disable this fan speed control function of the
BIOS?  Or that Windows has its own fan speed control software?
>> loose again :-)
There should be an option in the BIOS to control the CPU fan speed based on
temperature, it can be disguised under a number of weird names (I think mine
is "AI Fan Control" or something stupid like that).
As for the GPU fan (which is far louder on my machine than the CPU fan), it
seems this is built into the OS/driver.  Actually I don't remember XP ever
reducing the speed, so maybe it's something new for Vista?
> The four harddrives are just about inaudible.
So are mine when the GPU fan is on!
Date: 8 Jan 2009 07:43:47
Message: <4965f503$1@news.povray.org>
> for some reason SUSE manages to disable this fan speed control function
> of the BIOS?  Or that Windows has its own fan speed control software?
My conclusion is that Windows (and SUSE when it's finished installing)
controls the fan speed, but the SUSE installation program doesn't.
> on temperature, it can be disguised under a number of weird names (I
> think mine is "AI Fan Control" or something stupid like that).
Possibly I need to install AMD's Cool'n'Quiet driver or something, IDK.
(The idea of a "processor driver" is highly amusing to me. Of course,
it's not actually a driver for the *processor* at all. It's a driver for
some of the processor's special features, like frequency scaling, fan
speeds, power management, etc.)
> it seems this is built into the OS/driver.  Actually I don't remember XP
> ever reducing the speed, so maybe it's something new for Vista?
I don't know. But if I ever get the cash for a more powerful 3D card,
presumably it'll be far louder. ;-)
I'm just glad there's an indicator light on the front! Unfortunately,
only one, not one for each HD.
It's a pitty nobody has ever had the forethought to put a network
activity indicator on the front of the case. (Dell came close - their
OptiPlex cases have a link light.)
Date: 8 Jan 2009 09:55:27
Message: <496613df$1@news.povray.org>
> freezing.
I have an aspire 5100 that did the same thing for about the 1st year
that I had it.  I tried all sorts of things, but no change.  It would
freeze with a weird pattern on the screen and nothing would bring it
back.  I forget if the power button worked or if I had to pull the
battery to get it to turn off.  It was very annoying as whatever I would
be working on would be lost.
I tried reinstalling windows, upgrading drivers, the works, no luck.
I gave up on trying to fix it and just saved frequently.
Now it works flawlessly - I don't know what fixed it, and I don't know
what was wrong, but it doesn't lock up anymore at all.  I can't remember
the last time it froze.
My guess was the wireless drivers, but I have nothing to substantiate
it.  Try using it with the wireless turned off and see if that changes
anything.
Tom
Date: 8 Jan 2009 12:41:00
Message: <49663aac$1@news.povray.org>
Well, keeping it at the selected speed is hardware. Selecting what speed to
keep it at is software. But I know what you mean.
Most BIOSen I've seen have a flag that says whether you want the OS or the
BIOS to control the speed.
Date: 8 Jan 2009 12:43:57
Message: <49663b5d$1@news.povray.org>
Most times the BIOS (or whatever firmware is on the gfx card) will set the
fans to full speed on reset, just for safety.
What confuses me is I can turn on a hard drive that has no activity on it,
and it'll sit there making little chuckling noises, seeking around and such.
Like, even a USB drive not plugged into a USB cable will click and seek and
such.  I'm assuming the firmware is testing the drive or something, looking
for sectors to spare out, but it' kind of weird.
At least if you let Vista sit for a couple hours, all the background crap
finishes up and the drive stops working.
Date: 8 Jan 2009 13:43:06
Message: <4966493a$1@news.povray.org>
> to keep it at is software. But I know what you mean.
> the BIOS to control the speed.
I guess I just *assumed* that a safety-critical feature like "don't burn
down my house" would be hard-wired into the device. You know, like how
your boiler turns off when the house is warm, without needing any
software. Apparently not...
Date: 8 Jan 2009 13:45:08
Message: <496649b4$1@news.povray.org>
> that I had it.
Oh... good. o_O
Nice to know it's well-designed then. :-/
Seriously, I bought my sister a new laptop because hers was lame. This
new one is really failing to impress me.
> anything.
Well, initially I didn't even *install* the wireless drivers. (I
couldn't, because I didn't have them to hand.) Made no difference. Ditto
for sound and video.
Date: 8 Jan 2009 13:51:49
Message: <49664b45$1@news.povray.org>
I don't think CPU temperature is safety critical. The CPU basically burns
out before the heat gets high enough to set anything outside the case on fire.
Date: 8 Jan 2009 16:07:58
Message: <49666b2e$1@news.povray.org>
>> burn down my house" would be hard-wired into the device.
> burns out before the heat gets high enough to set anything outside the
> case on fire.
Well, perhaps. But CPU temperature is *utterly* critical to being able
to continue using your laptop. If it gets hot enough, the CPU will burn
out, and then your laptop is a very expensive paper weight. (!)
I'd be... kind of "upset" if that happened to me. o_O
Date: 8 Jan 2009 18:59:19
Message: <49669357$1@news.povray.org>
>> case on fire.
Yep. But that's not safety critical. :-) Indeed, that's exactly why it
*isn't* safety critical.  Unlike say batteries blowing up, which *are*
safety critical and which therefore have hardware in the charger to keep
from blowing them up.
Date: 8 Jan 2009 23:44:17
Message: <4966d621@news.povray.org>
Then they can sell you a new one (naturally you'll buy the same brand as
the one that melted, won't you?).
-Aero
Date: 9 Jan 2009 03:05:42
Message: <49670556$1@news.povray.org>
> such. Like, even a USB drive not plugged into a USB cable will click and
> seek and such.  I'm assuming the firmware is testing the drive or
> something, looking for sectors to spare out, but it' kind of weird.
Probably some sort of continuous calibration system to account for
temperature changes etc, I guess the head movement mechanisms need to be
controlled pretty accurately!
Date: 9 Jan 2009 03:08:45
Message: <4967060d$1@news.povray.org>
> Well, perhaps. But CPU temperature is *utterly* critical to being able to
> continue using your laptop. If it gets hot enough, the CPU will burn out,
Can this actually happen though, or does the CPU just shut down before it
knows it is going to melt?
When I built my sister's PC the heat sink clip had snapped without me
knowing, so the heat sink was hanging off one side.  Every time I tried to
install Windows it just turned off after about 20 seconds.  It wasn't until
I took the case off that I realised the problem.
Date: 9 Jan 2009 04:18:05
Message: <4967164d@news.povray.org>
>> it, and it'll sit there making little chuckling noises, seeking around
>> and such. Like, even a USB drive not plugged into a USB cable will
>> click and seek and such.  I'm assuming the firmware is testing the
>> drive or something, looking for sectors to spare out, but it' kind of
>> weird.
Yeah, I always thought the sounds a HD makes when turned on was just the
drive mechanism trying to find track 0 or something like that.
Date: 9 Jan 2009 04:19:57
Message: <496716bd@news.povray.org>
Yes, I *will* buy the same CPU brand as the melted one. You know why?
The rival brand uses a different socket. :-P
OTOH, it would probably be both *cheaper* and more beneficial to just
buy an entire new laptop! ;-)
Date: 9 Jan 2009 04:20:56
Message: <496716f8@news.povray.org>
>> burn out, and then your laptop is a very expensive paper weight. (!)
> it knows it is going to melt?
I am unsure. One would hope that powering down the system if a
hard-limit temperature is reached *is* in hardware rather than software.
OTOH, here we have a laptop which got sufficiently hot for the CPU to
malfunction fairly seriously, yet still the power remains on.
Date: 9 Jan 2009 04:37:14
Message: <49671aca$1@news.povray.org>
> I am unsure. One would hope that powering down the system if a hard-limit
> temperature is reached *is* in hardware rather than software. OTOH, here
> we have a laptop which got sufficiently hot for the CPU to malfunction
http://www.tomshardware.com/reviews/hot-spot,365.html
It's quite old, but the basic outcome seems to be that the Intel CPUs are
impossible to damage by overheating.  With the AMD chip it relies on the
motherboard, but their demo shows that a motherboard temperature sensor
cannot react quickly enough to avoid frying the CPU when the HS comes off.
Date: 9 Jan 2009 05:04:54
Message: <49672146@news.povray.org>
> are impossible to damage by overheating.  With the AMD chip it relies on
> the motherboard, but their demo shows that a motherboard temperature
> sensor cannot react quickly enough to avoid frying the CPU when the HS
> comes off.
Oh wow... 370°C after 1 second? That's pretty special!
Looking at this, it seems that in "the old days" some CPUs didn't have
any temperature sensors at all. I would imagine given the *huge* amounts
of heat that newer CPUs generate, this must have changed by now.
I still don't know whether the fan speed is hardware or software
controlled, but I would think by now the system will at least turn
itself off in a thermal emergency without software intervention.
As an aside... How much heat does the human brain generate? (By every
estimate I've seen, it has vastly superior theoretical computational
power compared to any supercomputer yet built by man.) How come human
brains don't ignite and burn during normal operation? I don't see any
really large heat sinks on a human...
Date: 9 Jan 2009 05:10:57
Message: <1l8em4l5k464jk1fiikibksb7si498pqj4@4ax.com>
On Fri, 09 Jan 2009 10:04:54 +0000, Invisible <voi### [at] devnull> wrote:
> How come human
It is fluid cooled and what about those heatsinks on the side of your head?
Regards
Date: 9 Jan 2009 05:26:47
Message: <49672667$1@news.povray.org>
>> How come human
Water cooled? Elite!
But I mean, *damn*, you'd have to have a high-volume fluid pumping
system, and a very large surface area to dissapate the heat over.
...oh, wait...
Date: 9 Jan 2009 05:34:27
Message: <49672833@news.povray.org>
You can do a quick estimation by seeing how much heat is radiated, the skin
temperature is approximately 32 degrees, room temperature is 20 degrees, and
the surface area of your head is, umm about 0.08m^2.  Using the
Stefan-Boltzmann law I make that about 6W of radiated heat.  Given that the
human body generates about 100W, I think the 6W figure is too low, as some
of the heat from the brain will be taken into the body by the blood stream
(liquid cooling!).  I guess around 20W would be a more sensible figure.
> (By every estimate I've seen, it has vastly superior theoretical
> computational power compared to any supercomputer yet built by man.)
If my computer were as slow as me doing sums it would probably run on solar
power in the dark!  And if I tried to do 3 billion sums in one second my
head would surely explode.
Date: 9 Jan 2009 05:58:06
Message: <49672dbe$1@news.povray.org>
> Given
> that the human body generates about 100W, I think the 6W figure is too
> low, as some of the heat from the brain will be taken into the body by
> the blood stream (liquid cooling!).  I guess around 20W would be a more
> sensible figure.
http://vadim.oversigma.com/MAS862/Project.html
Suggests that the entire body consumes about 100W, and the brain itself
uses 20 - 40 W. (So... a pretty significant fraction, considering that
the human body is *not* a data processing device, primarily.) That's how
much energy it *uses*, I wonder how much of that ends up as heat?
> solar power in the dark!  And if I tried to do 3 billion sums in one
> second my head would surely explode.
Well, you say that, but how many "sums" does it take to compare a
snippet of sound to many millions of other recorded examples like it and
determine that, yes, this is The Beetles singing "All you need is love"?
The human brain doesn't work the same way a computer does. This isn't
exactly news. Indeed, this is why computers are useful in the first
place! But based on the number of switching elements in a computer vs
those in the brain, AFAIK the brain comes out rather favourably.
(The same website above gives the number of transisters in a Pentium IV
as K * 10^7, while the number of neurons in a brain is K * 10^11. Kind
of a big difference...)
Date: 9 Jan 2009 05:59:23
Message: <49672e0b$1@news.povray.org>
"The power consumption of the Pentium 4 may exceed that of the human
brain. That explains why Pentium cooling systems are getting close in
size to the human head."
I LOLd! :-D
Date: 9 Jan 2009 06:14:39
Message: <4967319f$1@news.povray.org>
> uses 20 - 40 W. (So... a pretty significant fraction, considering that the
> human body is *not* a data processing device, primarily.) That's how much
Well there aren't too many options for "used energy" to be converted to.
Maybe some is used to increase the kinetic energy of some blood, but I would
say that almost all is converted to heat.
> exactly news. Indeed, this is why computers are useful in the first place!
> But based on the number of switching elements in a computer vs those in
I guess the brain also makes even Windows ME look good for uptime records
Date: 9 Jan 2009 06:19:53
Message: <496732d9$1@news.povray.org>
>> itself uses 20 - 40 W. (So... a pretty significant fraction,
>> considering that the human body is *not* a data processing device,
>> primarily.) That's how much energy it *uses*, I wonder how much of
> would say that almost all is converted to heat.
Well, I guess the brain does use *some* of that energy for chemical
transformations. (It turns raw ingredients into hormones and releases
them, for example.) But yeah, *most* of it is porbably heat...
FWIW, how much heat does an Intel Core 2 Quad generate?
> records :-)
HAHAHAH! PWN3D! :-D
Date: 9 Jan 2009 06:34:38
Message: <4967364e$1@news.povray.org>
About 120W under full load.
Date: 9 Jan 2009 06:37:04
Message: <496736e0$1@news.povray.org>
...so, more than an entire human being?
Perhaps *this* is why the human brain is in little danger of burning to
a crisp? ;-)
Date: 9 Jan 2009 06:43:05
Message: <9udem4plrt6nhdas2ru7oio23pniib85f7@4ax.com>
On Fri, 09 Jan 2009 10:26:48 +0000, Invisible <voi### [at] devnull> wrote:
>>> How come human
>...oh, wait...
Yes, the cardiovascular system is an effective heat exchanger working with the
lungs and skin. :)
Regards
Date: 9 Jan 2009 06:44:13
Message: <4967388d$1@news.povray.org>
> Perhaps *this* is why the human brain is in little danger of burning to a
> crisp? ;-)
Maybe not burning to a crisp, but if you raise the temperature of your
innards by just a few degrees things begin to screw up very rapidly.  You
have quite a sophisticated temperature control system to keep you at around
37 degrees inside...
Date: 9 Jan 2009 06:48:12
Message: <4967397c$1@news.povray.org>
Stephen wrote:
>> ...oh, wait...
> lungs and skin. :)
More impressive is the scientific *fact* this this system is somehow
able to keep the contents of the human body at a temperature drastically
*lower* than the surrounding ambient, even though the human body itself
generates heat, in utter defience of the 2nd law of thermodynamics.
I'd never believe it if I hadn't seen it with my own eyes...
Date: 9 Jan 2009 06:52:05
Message: <49673a65$1@news.povray.org>
> You have quite a sophisticated temperature control system to keep you at
> around 37 degrees inside...
Or, to put it the correct way round, your life processes are designed to
work at one specific temperature *because* you have an elaborate system
designed to keep things at exactly that temperature. ;-)
Date: 9 Jan 2009 07:01:42
Message: <49673ca6@news.povray.org>
http://en.wikipedia.org/wiki/Evaporation
Date: 9 Jan 2009 07:15:29
Message: <iufem41il2p85vmjemt64fubrm5rbjnq5h@4ax.com>
On Fri, 09 Jan 2009 11:48:15 +0000, Invisible <voi### [at] devnull> wrote:
>Stephen wrote:
>>> ...oh, wait...
>> lungs and skin. :)
Sorry, but the ambient temperature is generally lower than body temperature.
When it is higher we use evaporation, as Scott says.
Although it is amazing the temperatures that we can tolerate. Once I was working
above a gas turbine and the air temperature was 99 °C.
Regards
Date: 9 Jan 2009 07:55:18
Message: <49674936$1@news.povray.org>
Yes, _usually_ it is, and this is quite unsurprising.
I watched some people put a guy in a room at 40°C, and yet somehow he
didn't die. Indeed, although he came out looking half dead, a
radiothermometer confirms that his *internal* temperature barely moved.
It went up something like 0.1°C, which is nothing.
Interesting. I'm told 80°C is the threshold of pain (and also burns
damage), so I would have expected 99°C to be a fatality without some
*serious* protective clothing...
Date: 9 Jan 2009 09:15:13
Message: <p3mem4hjv54rtbtva01b1pg9bgumuhpt5q@4ax.com>
Again several years ago, when I was working offshore, I worked for two days on a
separation train where the ambient temperature was IIRC about 50deg C. There was
a team of us taking turns monitoring the instrumentation as the HVAC system had
failed. We would spend about 30 mins in the heat and 30 mins cooling down then
back into the heat. All of us were able to keep it up foe 12 hours a day. I
can't remember how much water we drank but we were given salt tablets as well.
Remember "Production Rules". :)
No serious PPE (Personal Protective Equipment). Safety boots, jeans, tee shirt,
overalls, leather/cotton gloves and hard hat. I tried removing my tee shirt but
the metal on the overalls was too hot to touch. I know what the temperature was
because I took a mercury thermometer up to check as I wanted to know what the
temperature was and a bi-metallic strip thermometer was reading over 100C.
Regards
Date: 9 Jan 2009 09:28:51
Message: <49675f23$1@news.povray.org>
Damn. Well considering that permanent tissue damage occurs at 80°C, I
can only assume that your drenched clothing somehow kept you a few
degrees cooler than that or something. (Surely water must evapourate
stupidly fast at almost boiling point!)
Reminds me of the time I was trapped by a fire. I didn't realise that
skin could actually excrete water that fast. I'm not kidding, I had
water *pouring* off me like water flows out of a tap. I have no idea how
much water there is in the human body, but I'd suggest fatal dehydration
couldn't take very long at that speed. (I had one *bad* headache
afterwards!)
