POV-Ray : Newsgroups : povray.off-topic : Virtual PC and Linux sharing files? Server Time
3 Nov 2026 22:22:29 EST (-0500)
  Virtual PC and Linux sharing files? (Message 1 to 30 of 30)
Subject: Virtual PC and Linux sharing files?
Date: 6 Jan 2009 13:11:48
Message: <49639ee4@news.povray.org>
Is there an easy way to do this? It's trivial to share a CD drive, simple to
share a SMB share if the child machine is running Windows. Has anyone run
Linux under MS Virtual PC and gotten it to mount a share to talk to the host
operating system thru?  It's kind of annoying to have to burn files to a CD
to copy them in and out.  I saw the bit about mounting .vhd drives on the
host, but it looks kind of daunting to try out.  Simpler would be better.
   Why is there a chainsaw in DOOM?
   There aren't any trees on Mars.
Subject: Re: Virtual PC and Linux sharing files?
Date: 6 Jan 2009 13:22:38
Message: <4963a16e$1@news.povray.org>
> simple to share a SMB share if the child machine is running Windows. Has
> anyone run Linux under MS Virtual PC and gotten it to mount a share to
> talk to the host operating system thru?  It's kind of annoying to have
> to burn files to a CD to copy them in and out.  I saw the bit about
> mounting .vhd drives on the host, but it looks kind of daunting to try
FWIW, I used Sun's Virtual Box (www.virtualbox.org) and was able to
share folders between Windows and Ubuntu rather easily. You may want to
try that VPC host, its very nice and has extensions for many Linux
distros that can make life easier. It was quite easy to set up, and IIRC
sharing only required running a simple installer on the guest machine.
You could also "burn" an ISO file, and mount that in Virtual PC. (IIRC,
if not mount the ISO in virtual CloneDrive on the host OS)
~Mike
Date: 6 Jan 2009 14:05:10
Message: <4963ab66$1@news.povray.org>
I can get in and out of the network. I can telnet from the guest to a
telnet-based server on the host. So the connectivity is there. I just can't
find instructions as to why, when I configure opensuse11 loaded with every
package containing "samba" or "smb" or "cifs", I can open the "windows
network" in gnome and not see any of the shares.  Basically, I'm defeated by
the user unfriendliness.
Yeah, I guess that's easier than actually burning a disk.
Date: 6 Jan 2009 14:28:24
Message: <4963b0d8$1@news.povray.org>
Darren New wrote:
> I'm defeated by the user unfriendliness.
OK. Now I can see the computers on the network (probably a firewall
misconfiguration on SuSE's end), but I still don't see any actual shares.
Weird, but that's probably something with permissions or some such now. I'm
encouraged enough to maybe continue to try to make it work. :-)
Date: 6 Jan 2009 15:02:58
Message: <4963b8f2$1@news.povray.org>
> shares. Weird, but that's probably something with permissions or some
> such now. I'm encouraged enough to maybe continue to try to make it
> work. :-)
Have you tried just mounting it to see Samba etc actually works ok?
mount -t smbfs //ip.of.host/sharename /mnt/sharedfromhost
-Aero
Date: 6 Jan 2009 15:11:13
Message: <4963bae1$1@news.povray.org>
Why not just configure SAMBA in the guest?  I don't know VPC, but if it
does anything like VMware, the Host/Guest filesystem sharing isn't as
solid as just going native CIFS or SMB.
Jim
Date: 6 Jan 2009 15:30:18
Message: <4963bf5a@news.povray.org>
I'm not sure what the difference is between SAMBA and SMB and whatever, for
one. At this point, OpenSUSE on the guest can connect to the Windows machine
it's running on (via telnet) and it can see the host machine (and itself) in
Gnome's nautilus. But It doesn't see any of the things the host is sharing.
The host can see the guest machine, but when I try to mount any of the
shares I think it should be sharing, I get "access denied", even tho there's
only root and "darren" on the guest OS, and I tried the passwords for both,
so I don't know what I'm supposed to be doing there either.
Well, yes, that's my basic goal. ;-)
smbfs isn't found.  "mount -t cifs" with the same args prompts me for a
password, then gives me error 13 = Permission denied. However, after
following thru the man page and giving a bunch of options on the command
line that it had been prompting for before, it seems to have mounted my
public share locally on the guest.
Thanks for the help there!
Date: 6 Jan 2009 15:54:04
Message: <4963c4ec$1@news.povray.org>
> for one. At this point, OpenSUSE on the guest can connect to the Windows
> machine it's running on (via telnet) and it can see the host machine
> (and itself) in Gnome's nautilus. But It doesn't see any of the things
> there's only root and "darren" on the guest OS, and I tried the
> passwords for both, so I don't know what I'm supposed to be doing there
> either.
My first thought would be firewall, by default the openSuSE firewall is
completely locked down, but if you get "access denied", then it's
permissions related on the host.
Jim
Date: 6 Jan 2009 16:07:41
Message: <4963c81d@news.povray.org>
Well, once I killed the firewall, I could see other computers on the LAN,
but not their shares etc.  Once I used a manual mount -t cifs and put in the
  -o user=...,password=... and a few other options, I could mount the share
on the guest from the host, so I'm cool now.
Again, thanks for everyone's help.
(Am I the only one that has been perpetually bugged since before Linux that
exiting a man page display clears the screen? :-)
Date: 6 Jan 2009 16:22:19
Message: <4963cb8b@news.povray.org>
> LAN, but not their shares etc.
That might even be a bug in the file manager software. That's why I
asked to try from command line.
Be welcome :).
> that exiting a man page display clears the screen? :-)
No, you're not. I tend to use multiple Xterms to cover that problem -
that way you even can scroll the man-page while writing the command.
-Aero
Date: 6 Jan 2009 16:31:07
Message: <4963cd9b$1@news.povray.org>
Just need to change your pager - less is used by default, if you change
it to "more", you can probably get around that by pressing Q. :-)
(IOW, it's not a function of man, it's a function of the pager)
Jim
Date: 6 Jan 2009 17:09:10
Message: <4963d686$1@news.povray.org>
True, but less is so much more than more, while more is so much less
than less.
IMO that's only downside of less with man-pages. With more I can't
scroll the page backwards, which is often useful feature - another one
is search. There's a good reason why less has basically substituted more.
True, but a pager better than less is still a mystery - at least for me.
> Jim
-Aero
Date: 6 Jan 2009 17:16:26
Message: <4963d83a$1@news.povray.org>
> than less.
I don't disagree with that assessment at all.  :-)
Just pointing out that the issue isn't with man or man pages, but with
the choice of pager used for viewing them.
Jim
Date: 6 Jan 2009 17:36:55
Message: <4963dd07$1@news.povray.org>
That was the hint I needed, yes. :-)
Same here. Sucks when it's before windowing systems, tho. :-)
I always wonder about the people who say how great Emacs is because it can
open multiple files at once, and I just say "I can do that with vi. It's
called X-Windows." :-)
Date: 6 Jan 2009 17:37:25
Message: <4963dd25@news.povray.org>
I knew that. It just never seems worth the effort to fix it for myself. :-)
Date: 6 Jan 2009 17:47:08
Message: <4963df6c$1@news.povray.org>
Then there usually is 6 virtual consoles or screen installed ;).
-Aero
Date: 6 Jan 2009 18:02:34
Message: <4963e30a$1@news.povray.org>
Yep. And yes, less clearing the screen after quit manages to annoy me in
many other situations also, not just man-pages.
> Jim
-Aero
Date: 6 Jan 2009 18:03:42
Message: <4963e34e@news.povray.org>
Only on Linux! :-)
Date: 6 Jan 2009 19:30:07
Message: <4963f78f$1@news.povray.org>
Same here.  I wonder if there's a way to change that behaviour - not
enough to have looked previously, but if I'm bored tonight, maybe I'll
look. ;-)
Jim
Date: 6 Jan 2009 19:30:19
Message: <4963f79b@news.povray.org>
Same here. :-)
Jim
Date: 6 Jan 2009 19:31:02
Message: <4963f7c6$1@news.povray.org>
> can open multiple files at once, and I just say "I can do that with vi.
> It's called X-Windows."
I never understood the "love" some people have for emacs.  It strikes me
as the poster child for bloatware, not so much in and of itself, but all
the addons.
Jim
Date: 7 Jan 2009 05:02:44
Message: <49647dc4$1@news.povray.org>
Darren New wrote:
> Only on Linux! :-)
I thought you cursed man-pages on Linux ;).
-Aero
Date: 7 Jan 2009 05:03:44
Message: <49647e00$1@news.povray.org>
> look. ;-)
I actually checked less's man-page and --help last night, before writing
that message. I didn't find the way.
> Jim
-Aero
Date: 7 Jan 2009 12:38:50
Message: <4964e8aa$1@news.povray.org>
I was cursing man pages "since before Linux" if you'll note. Solaris did
this crap back when OpenWindows was cutting edge and VT100s were the norm.
Date: 7 Jan 2009 12:53:03
Message: <4964ebff$1@news.povray.org>
Ah, you're right, I misread your original post.
-Aero
Date: 7 Jan 2009 15:58:15
Message: <49651767$1@news.povray.org>
Perhaps a code change, then.  Well, not "perhaps". ;-)
Jim
Date: 8 Jan 2009 12:18:32
Message: <49663568@news.povray.org>
Go ahead, make my day ;).
> Jim
-Aero
Date: 8 Jan 2009 15:45:28
Message: <496665e8$1@news.povray.org>
Hehehehehe, it doesn't bother me *that* much. ;-)
Jim
Date: 17 Jan 2009 23:02:07
Message: <4972a9bf@news.povray.org>
Vim can also open multiple files, either in a split window or in tabs. Yes,
even in text mode.
Date: 18 Jan 2009 14:21:48
Message: <4973814c$1@news.povray.org>
> even in text mode.
True but irrelevent. :-) Thanks for pointing it out if I hadn't known.
