Using winMP, PrintScreen doesn't work, it just captures the 'frame' (if you
like), of the actual program leaving the work area black.
Anyone know?
~Steve~
Subject: Re: How do you take a screenshot of an animation?
Date: 6 Jan 2009 11:20:08
Message: <496384b8$1@news.povray.org>
> you like), of the actual program leaving the work area black.
> Anyone know?
> ~Steve~
Dunno on Windows, on Linux I use mplayer and can change the output to xv
or x11 to grab screencaps, or tell it to output to png/jpg (I forget
which). If there's a version for Windows (and I believe there is), you
might try that.
Jim
Date: 6 Jan 2009 11:24:43
Message: <496385cb$1@news.povray.org>
"St." <dot### [at] dot com> a écrit dans le message de news:
496383f4@news.povray.org...
> Anyone know?
# Open Window Media Player
# Then go to Tools | Options
# In Options, select the Performance Tab
# Way below you click on the Advanced Button
# Uncheck “Use Overlays’
# Click Ok
G.
"Gilles Tran" <gil### [at] agroparistech fr> wrote in message
news:496385cb$1@news.povray.org...
>> Anyone know?
> # Uncheck "Use Overlays'
> # Click Ok
Oh, wow, thanks Gilles. I had a good look originally, but it wasn't at
all obvious that it was the advanced button. In fact, I missed that
completely. Thanks, works a treat.
~Steve~
> G.
EVERYTHING IS UNDER THE ADVANCED TAB!!
[I have no idea why...]
Date: 6 Jan 2009 11:48:39
Message: <49638b67@news.povray.org>
> > # Click Ok
Note that performance will suffer when you do that, so be sure to turn
it back on afterwards.
"Invisible" <voi### [at] dev null> wrote in message
news:496388f7$1@news.povray.org...
Well, yeah, possibly, but it still isn't obvious what 'Use Overlays'
means.
(Unless you read a manpage of course).
~Steve~
> > Anyone know?
> > ~Steve~
> might try that.
> Jim
On Windows your can do this with the KMPlayer
(not identical with the LINUX kmplayer)
http://www.kmplayer.com/forums/
"Warp" <war### [at] tag povray org> wrote in message
news:49638b67@news.povray.org...
Ah, ok, thanks Warp, I'll do that. That's something else that isn't
entirely obvious.
~Steve~
> - Warp
> means.
It means basically that the video data isn't rendered into the main
framebuffer, it's "overlaid" onto the image by the video hardware. Thus,
when you hit the printscreen button and the framebuffer gets copied...
no image!
Doing it this way given better performance - hence Warp's suggestion to
turn it back on after. ;-)
news:49638df2$1@news.povray.org...
>> means.
> when you hit the printscreen button and the framebuffer gets copied... no
> image!
Ah, ok, understood.
Heh, well I've just turned it back on and noticed that there is another
field for 'Use Overlays' in the DVD Video section! I assume this does
exactly the same thing when playing a DVD?
~Steve~
Date: 6 Jan 2009 12:35:18
Message: <49639656@news.povray.org>
All video players using DirectX have this option (at least internally;
some might not offer it in their GUI). It's a hardware/DirectX thing.
> means.
That's *why* it's under the advanced tab. :-) You shouldn't be screwing with
the setting if you don't know what an "overlay" is.
My brother, who finds Macs challenging, wonders why some of the flags under
the "Advanced" tabs in Windows can't be put into descriptions that someone
who doesn't know how the computer works can understand.
Why is there a chainsaw in DOOM?
There aren't any trees on Mars.
Date: 6 Jan 2009 13:51:13
Message: <4963a821@news.povray.org>
Maybe there should be a note like: "GIYF"
I don't know that google would be enough to explain what "always expand ALT
text for images" or "move system caret with focus/selection changes" or
"force off-screen compositing even under Terminal Server" would mean, or why
you would want to "use passive FTP" or "send IDN server names for Intranet
addresses". Some stuff computers do is just harder than driving a car, is
the problem. He wants his computer to be a tool, when it's really more a
toolbox.
On the other hand, "underline links always/never/hover" is there, as is "use
smooth scrolling", both of which seem pretty straightforward to understand.
Date: 6 Jan 2009 23:04:10
Message: <496429ba@news.povray.org>
> entirely obvious.
Things may become a bit more obvious if you change your media player ;-)
"Apple I" (c) Copyright 1767, Sir Isaac Newton.
/ \/ \ u e e n / \/ a w a z
>>>>>>mue### [at] nawaz org<<<<<<
anl
Since you clearly know more about this than me... In what way is
"DirectShow" related to "DirectX"?
And lo On Wed, 07 Jan 2009 09:11:59 -0000, Invisible <voi### [at] dev null> did
spake thusly:
Orignally all the APIs were called DirectSomething and then got grouped
and distributed under the generic DirectX title. DirectShow was renamed
from ActiveShow at that time for consistency reasons but was later dropped
from DirectX downloads and was issued under the Windows SDK.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
