POV-Ray : Newsgroups : povray.off-topic : Problem of the day Server Time
19 Jan 2026 07:12:33 EST (-0500)
  Problem of the day (Message 1 to 10 of 34)
Subject: Problem of the day
Date: 17 Dec 2008 08:49:39
Message: <49490373$1@news.povray.org>
If you have a box with N balls numbered 1 to N, and you repeatedly pull one
out at random (replacing it each time), on average how many times would you
expect to pull out a ball until you have seen all the balls 1 to N?
Subject: Re: Problem of the day
Date: 17 Dec 2008 09:01:49
Message: <4949064d$1@news.povray.org>
> one out at random (replacing it each time), on average how many times
> would you expect to pull out a ball until you have seen all the balls 1
> to N?
N is trivially the lower bound.
Each ball appears with probability 1/N, so the probability for all balls
to appear (given that these events are clearly independent) in N trials
would be (1/N)^N, which is 1/(N^N).
Hmm, but wait! This does not count for ordering. There are N!
permutations of N events, so taking *that* into account, we now actually
have N! / N^N.
Now, if we perform K trails, the probability of seeing all the balls is
(N! + (K-N)!) / N^N. (Assuming K >= N.)
Assuming that by "on average" you mean "with probability > 50%", it is
now a matter of choosing K such that the above formula comes out to more
than 0.5.
Date: 17 Dec 2008 09:14:30
Message: <49490946$1@news.povray.org>
Can you explain how you got that formula?
Date: 17 Dec 2008 09:18:33
Message: <49490a39@news.povray.org>
>> is (N! + (K-N)!) / N^N. (Assuming K >= N.)
Intuitively, assuming N trials the formula is just N! / N^N, so if we
add (K-N) extra trails, you get the formula above.
On reflection, I'm not sure that's actually correct...
Date: 17 Dec 2008 09:29:22
Message: <49490cc2$1@news.povray.org>
> Intuitively, assuming N trials the formula is just N! / N^N, so if we add
What if K=5 and N=2? I think the answer should be a 30/32 chance of seeing
both balls, but your formula gives 8/4 !
Date: 17 Dec 2008 09:41:27
Message: <49490f97$1@news.povray.org>
> have N! / N^N.
> Now, if we perform K trails...
Let's try that again...
If we select one ball, the probability of it being ball #1 is 1/N.
If we select K balls, the probability of ball #1 appearing becomes 1/N +
1/N + 1/N + 1/N + ... K times over, minus the probability of ball #1
appearing more than once.
In other words, we have K/N - E, and I can't figure out how to compute E.
(Presumably combinatorics provides a trivial way to solve this. Too bad
I don't know combinatorics, eh?)
Date: 17 Dec 2008 09:52:31
Message: <4949122f$1@news.povray.org>
You can think of it the other way round, ie the probability of ball #1
appearing after K tries is 1 minus the probability of ball #1 not occurring
after K tries.  That is 1-((N-1)/N)^K.
Date: 17 Dec 2008 10:18:38
Message: <4949184e@news.povray.org>
>> + 1/N + 1/N + 1/N + ... K times over, minus the probability of ball #1
> occurring after K tries.
Ah. So instead of a chain of non-exclusive OR events, you construct a
chain of independent AND events? Ingenius...
Date: 17 Dec 2008 10:48:18
Message: <49491f42$1@news.povray.org>
> to N?
I'm sure the answer is in the back of a textbook somewhere ... :)
~Mike
Date: 17 Dec 2008 12:08:41
Message: <op.umbgj7wlmn4jds@phils.mshome.net>
And lo On Wed, 17 Dec 2008 13:49:38 -0000, scott <sco### [at] scottcom> did
spake thusly:
> to N?
Do a search for Coupon Collector's Problem. For equal random drawings it's
roughly nHn that is n * Sum k=1-n of 1/k multiplied by n
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
