POV-Ray : Newsgroups : povray.off-topic : As fast as C Server Time
2 Nov 2026 21:49:55 EST (-0500)
  As fast as C (Message 1 to 19 of 19)
Subject: As fast as C
Date: 16 Dec 2008 07:55:47
Message: <4947a553$1@news.povray.org>
http://c2.com/cgi/wiki?AsFastAsCee
My God... the cacophony of bickering voices!
Subject: Re: As fast as C
Date: 16 Dec 2008 08:23:00
Message: <4947abb3@news.povray.org>
Einstein already said you can't go faster than c...
Date: 16 Dec 2008 08:24:58
Message: <4947ac2a$1@news.povray.org>
Best. Quote. Ever.
25 points to Nicolas!!
Date: 16 Dec 2008 08:33:43
Message: <4947ae37$1@news.povray.org>
It isn't just the programming language, it's how you write in the
programming language.
Simply changing the order you list your commands can make a big
difference in speed.
On some processors counting down to zero is faster than counting up to a
specific number.
Date: 16 Dec 2008 08:37:20
Message: <4947af10$1@news.povray.org>
It isn't just the language. It's the interpretter or compiler. It's the
libraries. It's the runtime system (e.g., the garbage collector, the I/O
subsystem, the concurrency implementation).
But yes, some languages make it more awkward to do things in certain
ways, and easier to do things in certain other ways. Which may help or
hinder performance. Also, the limitations of the language may make the
compiler's job harder or easier.
> specific number.
If you're comparing JIT-compiled Java to purely interpretted Lisp, I
guarantee you it makes no measurable difference. The overhead of
everything else outweighs it manytimes over.
Date: 16 Dec 2008 09:34:16
Message: <4947bc68$1@news.povray.org>
>> specific number.
Sure, but there are circumstances when it is measureable, like if you are
writing the row-copy code to draw part of a sprite onto the screen.
Actually I remember on my 32bit ARM CPU, if you want to copy a large number
of bytes from a word (32-bit) aligned address to a non-word-aligned address
there were two ways to do it.  The first was to just use the load-byte and
store-byte commands, but a way faster method was to load and store words at
a time with some clever bit shifting and masking.  Even though the code
looked uglier and longer, it was much faster.  Similarly, counting down to
zero saved one clock cycle per loop, and when your loop is only a few clock
cycles and your game is limited by the speed of drawing sprites on the
screen it makes a big difference.
Date: 16 Dec 2008 09:43:47
Message: <4947bea3@news.povray.org>
>>> to a specific number.
> Sure, but there are circumstances when it is measureable.
I'm sure there are. I'm saying that in very high-level languages (e.g.,
Perl, VB, etc.) there are much bigger influences to worry about fist.
> number of bytes from a word (32-bit) aligned address to a
> non-word-aligned address there were two ways to do it.  The first was to
> just use the load-byte and store-byte commands, but a way faster method
> was to load and store words at a time with some clever bit shifting and
> masking.  Even though the code looked uglier and longer, it was much
> faster.  Similarly, counting down to zero saved one clock cycle per
> loop, and when your loop is only a few clock cycles and your game is
> limited by the speed of drawing sprites on the screen it makes a big
> difference.
Now, see, as I understand it, computer technology has now reached the
point were saving a few cycles makes *no difference* at all, and the
_only_ thing that matters is cache hit ratios.
If you use a faster addressing mode, maybe your program will complete a
few microseconds faster. If you have a pipeline stall, your program will
halt for a dozen cycles, and if there's a miss in the L2 cache, the CPU
will basically shut down and do nothing for several thousand cycles.
It's got so bad that theoretically "inferior" algorithms can actually be
faster due to cache behaviour, even though they take "more operations"
to do.
Personally, I find that sad...
Date: 16 Dec 2008 09:49:37
Message: <4947c001$1@news.povray.org>
> faster due to cache behaviour, even though they take "more operations" to
> do.
Only "inferior" if you assume they run on a machine that can access every
single data location and process every single instruction at a constant
speed.
As you pointed out, this certainly isn't the case and things are much more
complex now, but that shouldn't put you off trying to optimise your code,
you should just optimise it to work with the cache first rather than with
the ALU.
Date: 16 Dec 2008 09:52:44
Message: <4947c0bc$1@news.povray.org>
>> be faster due to cache behaviour, even though they take "more
>> operations" to do.
> every single data location and process every single instruction at a
> constant speed.
Or rather, if you assume that every possible "operation" takes the same
amount of time - a highly useful simplification if you're trying to
compare several different algorithms.
> more complex now, but that shouldn't put you off trying to optimise your
> code, you should just optimise it to work with the cache first rather
> than with the ALU.
What this means is that any programming language that features automatic
memory management is instantly many hundred times slower than a language
using manual memory management, and there's nothing you can do about it.
I find that sad.
Date: 16 Dec 2008 10:11:15
Message: <4947c513@news.povray.org>
Invisible escreveu:
> Best. Quote. Ever.
Indeed!  Insightful +5! :D
Date: 16 Dec 2008 10:13:44
Message: <4947c5a8$1@news.povray.org>
> I find that sad.
What's sad is if the authors of such languages have not thought about cache
usage when designing the compiler.
I don't see how it's any different to people using BASIC complaining that
they can't benefit from the "count down to zero" loop because BASIC won't
let them remove the extra compare instruction.
As always, if you want complete control over the CPU use assembler, if you
want a little less control use a language like C.  You use higher level
languages to make writing the code easier, but you lose direct control of
the CPU.
Date: 16 Dec 2008 10:21:00
Message: <4947c75c$1@news.povray.org>
> cache usage when designing the compiler.
What's sad is that a cache need to exist in the first place. It means
that whole classes of highly efficient algorithms aren't efficient any
more. It means you have to mutilate your program designs just to keep
the cache happy.
But still, there's nothing that anybody can ever do about it, so I guess
there's no point worrying about it...
> you want a little less control use a language like C.  You use higher
> level languages to make writing the code easier, but you lose direct
> control of the CPU.
I don't *want* low-level control over the CPU - the sad thing is that
with current designs, it's completely necessary if you want any
semblance of performance. With current designs, it seems that basically
any attempt to use any language higher than assembly is doomed to abject
failure, performance-wise. And this saddens me.
Date: 16 Dec 2008 11:03:43
Message: <4947d15f@news.povray.org>
> What's sad is that a cache need to exist in the first place. It means that
> whole classes of highly efficient algorithms aren't efficient any more. It
> means you have to mutilate your program designs just to keep the cache
> happy.
Ermm, caches make things faster and more efficeint to varying degrees, not
slower.
Date: 16 Dec 2008 11:05:23
Message: <4947d1c3$1@news.povray.org>
> not slower.
Caches make _some_ things faster. Other things stay laughably slow. :-(
Date: 16 Dec 2008 11:33:45
Message: <4947d869$1@news.povray.org>
>> not slower.
So what's the problem then?  Some things are faster, others stay the same
speed.
Unless, of course, you could afford to have 8GB of on-die RAM at the same
speed as the L1 cache :-)
Caches are just a very cost effective way of speeding most things up, do you
have a better suggestion?
Date: 16 Dec 2008 12:47:40
Message: <4947e9bc$1@news.povray.org>
Huh? Where did you come up with this factoid? GC can actually help improve
cache hits, while manual memory management requires you to touch all kinds
of pages at times when it might not be beneficial. For example, if you need
to free the root of a large tree on the heap, using manual memory
management, you now have to run through the whole tree, touching every page
where there's a leaf, and cleaning it up. If 50 instructions later you free
another tree, you have to do that all again, even if it's all in the same
pages as the first tree.
Of course, the higher level the language is, the more opportunity for
optimizations. For example, the talk on that page about what the .NET system
does is incorrect. That's the .NET that was around when they wrote that
sentence. You can (and always could), of course, precompile an entire
assembly, rather than waiting for JIT - of course the data structure
libraries don't get recompiled every time you run the program. And later
compilers will do all kinds of cross-assembly optimizations if you want, in
a way that would be very difficult for a C compiler to manage (like taking
unused slots out of a struct to save memory).
> But still, there's nothing that anybody can ever do about it, so I guess there's no
Sure there is. Slow your CPU down a whole bunch. Happy now?
   The NFL should go international. I'd pay to
   see the Detroit Lions vs the Roman Catholics.
Date: 16 Dec 2008 13:11:26
Message: <4947ef4e@news.povray.org>
Woohoo snap :) Genius.
Date: 18 Dec 2008 14:28:36
Message: <494aa464$1@news.povray.org>
LOL, good one in deed :-D
Date: 18 Dec 2008 15:21:22
Message: <494ab0c2@news.povray.org>
My personal opinion:
As you know I don't know much of programming but for I've seen C (ANSI
C, C++, C# and al the variants) is the King Language, if it keeps
evolving in its abstractions/implementations to cover more needs it will
be there for ever or at least until a better language come along, if so,
I'm sure will have to be based on C at least conceptually.
C I believe is a reference for the other languages, like the Grandfather
of programming languages.
FWIW I believe C should have a kind of optimizer/distiller that gives
the assembler-level optimized (speed and/or size) .exe image, for every
hardware platform, so the programmer doesn't have to worry about
low-level tricks and concentrate more in the program abstract idea and
its implementation. I think the compiler gives optimizations only by
changing the order of the statements because it's partially optimized
according to certain statement criteria it recognizes but not fully
optimized for the assembly language level.
Cheers.
