http://news.bbc.co.uk/1/hi/technology/7784908.stm
Oh, that's nice. But does anybody have *any clue* specifically which
problem they're on about?
2 clicks away from that article:
http://www.microsoft.com/technet/security/advisory/961051.mspx
"scott" <sco### [at] scott com> wrote in message news:494793e2@news.povray.org...
In addition, see this link for how it's spreading
http://www.sqlservercentral.com/articles/Security/65235/
Interesting. I scoured the article from top to bottom looking for links,
but found nothing...
On the right hand side of almost every BBC news article it has a section
labelled "RELATED INTERNET LINKS" :-) A lot of BBC articles a pretty dumbed
down, so I often visit the related links for more details.
>> links, but found nothing...
> dumbed down, so I often visit the related links for more details.
I see the links, but I don't see anything remotely related to this story.
Are you looking at the same article that you posted the link to? See
attached images for what I saw and clicked on:
Download 'image1.png' (99 KB)
Download 'image2.png' (26 KB)
Preview of image 'image1.png'
Preview of image 'image2.png'
I just see a long list of links to various homepages. No links to a
specific article.
Is there any way of determining that the article you're looking at is
the particular one they were writing about? Or are we just going on
coincidence?
> specific article.
But you can reasonably expect an item highlighted in the BBC website to be
on the MS security blog recently...
But yes, the BBC should post the link to the actual article for further
details and not just to a list of security related articles.
"I cannot recommend people switch due to this one flaw," said John Curran,
head of Microsoft UK's Windows group.
No, of course you can't.
http://www.washingtonpost.com/wp-dyn/content/article/2005/12/29/AR2005122901456.html
Looks like another image processing buffer overflow.
The NFL should go international. I'd pay to
see the Detroit Lions vs the Roman Catholics.
> Curran, head of Microsoft UK's Windows group.
Shocker.
At times like this, I find myself wondering. About two things.
1. If the entire system was written in some "safe" language, would we
still have 45 buffer overflow flaws per week reported?
2. How much slower would the whole contraption be? (I'm guessing it
would make Vista look *fast*...)
http://blog.orphi.me.uk/
No. Pretty much by definition. You might still have holes, but they'd be
different holes.
It would be about 30% faster.
> be different holes.
Right. So you're telling me that if you wrote an OS and all the
associated large-scale applications in a "safe" language, it would be
more secure, and run faster (and obviously take drastically less time to
develop).
And people still write all OS and application software in C because...??
>> be different holes.
> develop).
because the manager is from a completely different field and tried to
catch up with the state of the art by reading K&R.
If it would indeed by 30% faster, that would only be a sign that the
current codebase sucks. (Of course being MS, that would hardly surprise
anyone.)
If the codebase sucks, it means the programmers are incompetent. Would
a change in programming language make them less incompetent?
Of because the vast majority of libraries out there you need to write
something like an OS are written in C.
Also C is conveniently low-level so that you can quite accurately access
asm and hardware directly.
Do languages like Haskell even support inline asm, linking to asm routines,
or accessing hardware directly (other than with wrappers around existing
C libraries)?
> anyone.)
A couple of possible answers:
- you take it a bit too serious
- not all programmers are equally competent at every level. A good
programming system and language can result in a better match for every
team member.
- C does not provide build in error checking, which means that often
data is checked both in the calling and the called function even if you
can simply prove that it will comply to the precondition. That might
give 30% slowing down in some cases. Of course there are also cases wher
both end fail to check, assuming that it is a task of the other. That
result in unreliable code.
- A language comes with a paradigm which enables solving problems in
certain ways. I am doing things in Matlab that I would not do in C
because although the languages are similar, some things are a few
keystrokes in Matlab and 20+ lines of code in C. Just as that some
things are more easy expressed in sql or prolog or with lex/yacc than in
C and run faster (even if you could do it in C and even if C was used as
an intermediate step).
> Just as that some
> C and run faster
That last point I don't buy.
You can do *anything* with C. You can exactly replicate the machine code
run by SQL or prolog in C. It may be more laborious to do in C than in SQL
or prolog, but it will certainly not run slower.
If you *don't know how* to make it equally fast in C, that's a completely
different, unrelated issue.
>> Just as that some
>> C and run faster
to quote my next line after that '(even if you could do it in C and even
if C was used as an intermediate step)'. So, yes I am aware that you
could, but the point is that you wouldn't.
You can implement on the fly garbage collection in C but if your library
does not support that you simply won't do that when writing e.g. a
simple TCP stack. In that case you simply allocate a buffer that is
large enough. And we all know what happens next. If you have a
language/system that does support that you go for a different solution.
I am not saying that is as it should be, simply that is like it is.
Another more safe example (as less religious aspects are involved) is
something like battle chess. There is of course a PC version of it, but
it would not have come to life if it was not for the blitter in the
Amiga. There are numerous examples of this kind where the solution space
for a project is shaped by the available hardware/language/libraries.
> develop).
Yes. Primarily because then you could turn off the memory management, the
overhead of protection rings, and so on.
Legacy.
> anyone.)
No. It's the same codebase, one running under the OS doing VMM, address
mapping, and kernel ring protections, the other running under the OS with
that turned off. If you actually turn off bounds checking, you get another
5% speed increase.
But just like staying in the cache gives you good performance, not
*flushing* that cache every time you (say) allocate a block of memory or get
an interrupt helps. Not having to do VM map lookups helps a bunch too. The
numbers and costs of different bits of hardware are all analyzed separately,
so you can decide if you like having (for example) virtual memory but not
needing kernel trap protection ring overhead.
You don't get the 30% increase in speed from using a safe language. You get
the ability to turn off protection from other users from using a safe
language, which in turn gives you speed. If you want to use AmigaOS, with no
protection from other users blasting your memory, then you would see about a
5% performance decrease for the bounds checking.
http://research.microsoft.com/apps/pubs/default.aspx?id=71996
This points to a paper published at ACM SIGPLAN, which of course you'd have
to pay for, but if you grope around the project you can find it in the
source code I think. (Unless they took it out since I downloaded it.)
http://channel9.msdn.com/shows/Going+Deep/Singularity-III-Revenge-of-the-SIP/
has an extensive interview about "software isolated processes". Check
starting about 30 minutes in. I'll see if I can dig up the actual URL to the
paper with the graphs and such in it free, when I next dig out my "old
stuff" disk.
That's just the Turing completeness argument. :-) It's not always true, tho,
depending on your underlying CPU architecture. I've used systems where C
can't be compiled.
Darren New wrote:
> the paper with the graphs and such in it free, when I next dig out my
> "old stuff" disk.
http://www.google.com/search?q=mspc2006_deconstructingisolation.pdf
I think the paper is probably still in the download, but they've probably
taken if off their site since it got published in ACM. (You have to turn
over your copyright to ACM to get published in SIGPLAN.) And sadly the "view
as HTML" leaves out the charts.
On Tue, 16 Dec 2008 16:46:03 -0500, Warp wrote:
> Would
Depends on how well they know the language they're switching to, and if
the problems with their code are syntactical or structural.
Jim
Um, they don't?
Jim
Ain't that the truth...
That's useful for OS construction. I'm not immediately seeing why that
makes it a good language for writing (say) a web browser.
> C libraries)?
Inline? No.
But if you write it and assemble it as a seperate object file, it's not
difficult to link to it. (Takes a 1-line Haskell import declaration.)
Apparently somebody *did* write an OS in Haskell. It was called "House".
Obviously, like everything to do with Haskell, it was an experimental
research project which is now long dead...
