POV-Ray : Newsgroups : povray.off-topic : Hey cool Server Time
2 Nov 2026 21:49:33 EST (-0500)
  Hey cool (Message 1 to 20 of 20)
Subject: Hey cool
Date: 12 Dec 2008 14:10:32
Message: <4942b728$1@news.povray.org>
I have OpenSUSE 11 installed as a guest OS under Virtual PC, so I no longer
have to reboot my machine to answer a boss' question about something funky
some Linux box is doing, or use ssh to tunnel a graphical interface from a
server, or something like that. Niiice.
Does "quad core" mean four complete ALUs? Or does it mean four register sets
hyperthreading? What do they call it if it's hyperthreading?
   The NFL should go international. I'd pay to
   see the Detroit Lions vs the Roman Catholics.
Subject: Re: Hey cool
Date: 12 Dec 2008 14:14:39
Message: <4942b81f@news.povray.org>
> longer have to reboot my machine to answer a boss' question about
> something funky some Linux box is doing, or use ssh to tunnel a
> graphical interface from a server, or something like that. Niiice.
Way to go.
> sets hyperthreading? What do they call it if it's hyperthreading?
It means four cores, ie. four units that really calculate things
simultaneously inside one CPU.
http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_15331_15332%5E15334,00.html
-Aero
Date: 12 Dec 2008 14:35:01
Message: <web.4942bc877555ef28773c9a3e0@news.povray.org>
So, you exchanged some weight of running an X app over the network by a lot of
weight for running 2 OSes on a single machine instead of a lightweight plain
text ssh session?  Not niiiice... :P
Date: 12 Dec 2008 15:13:27
Message: <4942c5e7$1@news.povray.org>
I have a quad-core machine with 6 gig of RAM here. :-) I'd still be running
an X app over the network - I just wouldn't have to install an X server on
Windows. I install Linux on Windows, and the X server on Linux. ;-)
Date: 12 Dec 2008 15:32:20
Message: <4942ca54$1@news.povray.org>
Uh... why not just use a Windows SSH client?
http://blog.orphi.me.uk/
Date: 12 Dec 2008 15:41:53
Message: <4942cc91$1@news.povray.org>
Because ssh is a transport, and X is a graphics subsystem? Kind of the same
reason I use pov-ray to draw pictures instead of VI.
Let me rephrase, since I seem to have confused people. Now I can remotely
log in to a server via SSH and run GUI programs on that server without
having to stop what I'm doing in Windows.  (Or install an X server on Windows.)
Date: 12 Dec 2008 15:54:36
Message: <4942cf8c$1@news.povray.org>
> same reason I use pov-ray to draw pictures instead of VI.
> remotely log in to a server via SSH and run GUI programs on that server
> without having to stop what I'm doing in Windows.  (Or install an X
> server on Windows.)
I use VNC for this very reason... ;-)
Date: 12 Dec 2008 19:02:58
Message: <4942fbb2$1@news.povray.org>
> server on Windows.)
I'll have to ask, why is X server on Windows a beast?
Date: 12 Dec 2008 20:04:11
Message: <49430a0b@news.povray.org>
As if that was too hard! Search for Xming. Or use Cygwin/X... but I'd use
Xming unless I already have Cygwin stuff installed.
Date: 12 Dec 2008 20:18:44
Message: <49430d74$1@news.povray.org>
Yeah. I did too, for a while, until I figured out how to make X run. You
thought X was slow over a slow network? Try VNC.
Date: 12 Dec 2008 20:20:47
Message: <49430def$1@news.povray.org>
I didn't say it was hard. It's simply unnecessary. Running a program
remotely isn't the only problem this solves. It lets me also set up an
environment at home matching the one at work, including Apache, MySQL, etc
etc etc, none of which reliably work the same under Windows.
I can't believe I'm getting arguments against running Linux on this forum. ;-)
Date: 13 Dec 2008 04:43:44
Message: <494383d0$1@news.povray.org>
I did. Tunnelled over SSH from my home PC to my desk at work. :-D
Date: 13 Dec 2008 05:01:07
Message: <494387e3$1@news.povray.org>
>> You thought X was slow over a slow network? Try VNC.
You know you've been raytracing too long when you set up a VPN to your
house so you can check your POV-Ray renderings from work! o_O
Date: 13 Dec 2008 05:13:18
Message: <49438abe$1@news.povray.org>
> etc etc etc, none of which reliably work the same under Windows.
Ah, that answers to my question also.
> forum. ;-)
Well, layering Win+X or Win+Lin+X there should be a slight difference in
eg. memory usage, preferring the first one.
-Aero
Date: 13 Dec 2008 13:14:44
Message: <4943fb94$1@news.povray.org>
I did that. It sucked. Until I switched to RDP, so at least the splash
screen only got sent once a day. :)
Date: 13 Dec 2008 13:15:22
Message: <4943fbba$1@news.povray.org>
Sure. But I have 6G here. I'm not running low any time soon. :-)
Date: 13 Dec 2008 14:17:37
Message: <49440a51@news.povray.org>
Having a lot of something doesn't automatically mean it's wise to use it
as quickly as possible ;). But yes, while you practically need to run
Linux somehow anyway, the solution sounds more than reasonable.
-Aero
Date: 13 Dec 2008 14:27:11
Message: <49440c8f$1@news.povray.org>
I already have Linux installed. That doesn't mean I always want to boot out
of Windows, interrupting what I'm doing, in order to load Linux when I need
it. :-)
Date: 13 Dec 2008 14:39:10
Message: <49440f5e$1@news.povray.org>
> out of Windows, interrupting what I'm doing, in order to load Linux when
> I need it. :-)
Booting between two systems is annoying, especially for cheking some
little thing. It cancels all you're doing in that very moment and takes
time. Hibernating can ease up a bit, while it's not necessary to shut
down all applications etc, but such booting is still a PITA.
-Aero
Date: 13 Dec 2008 14:52:48
Message: <49441290$1@news.povray.org>
Or, as one boss said, "The transistors don't get tired. That's why they're
there."
