I'm going to post a mascotesque post.
Playing with Winamp quite a bit, and I've found a really cool feature...
Auto-tag. Took some tracks that somebody put together on a CD as a
"party favor" for my wife's wedding shower a few years ago. A real
mishmash of music and genres, and no track identification. I previously
ripped the music from the CD, calling the tracks "Wedding track 1, etc".
Yesterday I thought I would try the auto-tag feature to see how well it
worked.
#1. It worked shockingly well, One track was mislabeled, and I'm
guessing it was more a mislabeling of the CD tracks on the album that
that song belonged on in the database.
#2. It was very quick.
It uses "fingerprinting" technology to match the song with its entry on
the database. What I found even more interesting is if I stripped a
track of its name, tags, and anything other than the audio to identify
it. It would correctly identify it. Even if that song came from a
"greatest hits" album (e.g. the same exact song could be found elsewhere
on a different album)
Obviously there must be some sort of hashing involved ... but how? We're
talking a file that has been encoded with a lossy algorithm, and while
the data resembles the original, it is not the original ...
... Anyway, part 2, related...
In winamp is this "Play songs similar to ..." menu item. A little
research yields a program called MusicIP mixer. Which I'm playing with
to shuffle my music library. Essentially it groups similar songs
together. So far the shuffle is surprisingly smooth. It uses acoustic
fingerprinting as well to do its work. I listen to a fairly broad
spectrum of genres, Its nice because it doesn't say put a country song
immediately after say, Rage against the Machine ...
~Mike
> worked.
Hmm, interesting. This ought to be highly infeasible. (But then, so
should identifying a CD by it's serial number, and apparently that is a
"solved problem".)
Hahahaha!
Yeah, people look at me funny when I tell them that I have a custom
WinAmp playlist rather than just playing it on random. But Pendulum
followed by Enya is just weird!
Invisible wrote:
> Hahahaha!
You two mean that this kind of variation is bad? :P
# 2008-12-09 16:26:46: Various - Metal Rocks - CD 1 - Hypocrisy /
Unleash The Beast Enqueue again, play now or see track info
# 2008-12-09 16:21:52: Rammstein - Mutter - Nebel Enqueue again, play
# 2008-12-09 16:18:35: Sarah Brightman - Encore - One More Walk Around
The Garden (Carmelina) Enqueue again, play now or see track info
# 2008-12-09 16:13:02: AC/DC - Ballbreaker - The Honey Roll Enqueue
# 2008-12-09 16:08:39: Pink Floyd - Is There Anybody Out There? - The
Wall Live (CD 2) - In The Flesh Enqueue again, play now or see track info
# 2008-12-09 16:01:34: Pink Floyd - Is There Anybody Out There? - The
Wall Live (CD 2) - Run Like Hell Enqueue again, play now or see track info
I actually mostly like it. It brings changes to everyday life at home :).
-Aero
Actually I have a phone book entry on my phone, which you can call, hold
your phone up to some random speaker (be it in your car, on the TV, etc) for
10 seconds, then a few seconds later it texts you back the artist and song
name. It's pretty neat and has worked every time I've tried it.
Maybe it works in the frequency domain, so takes the fourier transform of
the sample, then uses some fuzzy matching algorithm to see what it matches
up with?
> (But then, so should identifying a CD by it's serial number, and
> apparently that is a "solved problem".)
What do you mean? Isn't the whole idea of a *serial* number that you can
identify which one it is?
http://mtg.upf.edu/files/publications/MMSP-2002-pcano.pdf
Apparently you take your sound signal, compute its frequency spectrum,
and then take various statistical measurements from that. (Whatever you
think is "perseptually significant"; the overall energy distribution,
the frequencies of the main spectural peaks, how fast the spectrum is
changing, whatever you think will work.) You eventually summarise all of
this data to yield a "fingerprint" code in such a way that things that
sound similar to the human ear are likely to yield similar fingerprint
codes. Then you just need to develop a fast search algorithm...
So how it works depends on *exactly* which system it uses. (WinAmp is
using MusicID from Gracenote - the people who invented CDDB, and who
therefore presumably have their hands on a huge catalogue of CD data!)
It's comparing sound signals based on their overall spectrum (how bassy
or toppy they are, possibly the pictures of the main signal spikes) and
how it evolves over time (slowly changing vs rapidly changing).
I would suggest that if you played two different tunes on the same
instrument in the same key at the same tempo, it might be rather hard
for the machine to tell them apart. But then, think about it: how well
would a human do this?
I almost want to rush out and grab WinAmp just so I can see how badly it
misclassifies material that isn't in the database... >:-D
> for 10 seconds, then a few seconds later it texts you back the artist
> and song name. It's pretty neat and has worked every time I've tried it.
Heh. Well that's one way to find out what tune that is on that YouTube
video... ;-)
What does it do if you play something that isn't in the database? (I.e.,
you pick up an instrument and play something yourself.)
> of the sample, then uses some fuzzy matching algorithm to see what it
> matches up with?
See my other reply. Statistical summaries of the frequency spectrum (not
forgetting temporal information too) plus fuzzy matching.
Yes - but if you aren't the manufacturer, it's just a useless number to
you. The only reason this is usable is that somebody sat down and
somehow built a giant database containing all the serial numbers and the
matching metadata; AFAIK, the manufacturers didn't hand this data over,
some poor sod collected it.
And that's exactly how it happened. Except replace poor sod with
CD-Ripping community. They'd tag the resultant MP3's and send the data
to CDDB, which would then get sent out to anyone else who ripped the CD.
~Mike
From what I've seen on a few tracks that weren't really released music,
it would simply come back with nothing ...
~Mike
I tried whistling a song to it once, I just got a text back saying it
couldn't recognise the song :-( grrrrr
> you. The only reason this is usable is that somebody sat down and somehow
> built a giant database containing all the serial numbers and the matching
> metadata; AFAIK, the manufacturers didn't hand this data over, some poor
> sod collected it.
Or rather, multiple poor sods collected it :-)
http://en.wikipedia.org/wiki/CDDB#History
And either someone is fucking the system up from his part or the same
serial can be used for multiple CD's. Sometimes CDDB and FreeDB give you
multiple choices, of which usually one or two is that actual album.
-Aero
They don't work from the serial number as such, but they make up some sort
of hash code based on the track lengths etc.
>> (I.e., you pick up an instrument and play something yourself.)
I forsee this degenerating into something akin to the intros round from
Nevermind the Buzzcocks. ;-)
>> over, some poor sod collected it.
Heh. Sounds almost like the way Linux happened... ;-)
> sort of hash code based on the track lengths etc.
I don't know about that... One time, I had a CD sitting on my desk, and
I noticed that round the spindle hole there is some *tiny* writing
that's barely readable.
I typed the code number into Google. It instantly gave me the entire
track listing for the CD. (!) Just from the 200-digit code printed on
the CD's surface. I imagine CDDB reads this same code. (It's almost
certainly burned onto the data track as well as being printed on the label.)
The best thing is, the CD in question was "Best Trance Anthems EVER
volume #1,374" or something! :-D
It works so that copies of audio CDs still give the correct result, actually
reading up about it, any CD that has exactly the same number of tracks
starting at the same points on the CD with the same total play time will
give the same freedb/CDDB result.
> One time, I had a CD sitting on my desk, and I noticed that round the
> spindle hole there is some *tiny* writing that's barely readable.
> I typed the code number into Google. It instantly gave me the entire track
> listing for the CD. (!) Just from the 200-digit code printed on the CD's
> surface.
Well yeh, I think that's more like a barcode, you know the one that most
shops have a database for to convert bar codes to prices at the checkout. I
imagine at least some websites have CDs listed with their corresponding
serial numbers.
> The best thing is, the CD in question was "Best Trance Anthems EVER volume
Yeh it's always cool when you're thinking "I bet nobody in the entire world
could possibly have ever even played this CD, let alone typed in all the
track names", and then wham you get the results back!
>> the CD's surface.
> checkout. I imagine at least some websites have CDs listed with their
> corresponding serial numbers.
I always assumed that was how CDDB works, and why if you burn an
identical copy of the original CD it totally fails to identify it.
> world could possibly have ever even played this CD, let alone typed in
> all the track names", and then wham you get the results back!
Somewhere I found a website full of barcodes. Just about anything, type
in a barcode and it knows what it is! (Well, almost... If you read into
this area, you quickly discover that actually there are several
different barcode systems, most of them incompatible.)
Tangentally: One of the example projects in Real World Haskell is a
barcode recognition system. As in, you give it a blurry picture of a
barcode taken with your mobile phone, and it tells you the digits. Just
by looking at the vertical bars. It even uses the check digit to make
sure it's read it correctly.
You think that's bad, before I deleted it I'd ripped a Shania Twain album of
my ex-landlord's and it played immediately following Vivaldi's Four Seasons
when I ran my music straight-through.
Slightly jarring, to say the least.
Tim Cook
http://empyrean.freesitespace.net
I just finished software doing that, except it would also recognise what
radio station you're listening to, whether it was an advertisement and from
whom, or whether it was a talk show and who was talking.
It would also do TV, and give you (for example) links to the MTV episode
information, or the buy-this link if you listened to the Home Shopping Network.
(I'm hoping the bosses find some more money, but it's looking grim still.)
The audio identification is all based around taking a short sample and
finding it amongst a set of larger samples. It's pretty freaky, because the
algorithm even finds (for example) people covering songs. We had an
American Idol caller come in and the system said "I don't know who is
singing this, but it's Yesterday by the Beatles." :-) Pretty cool.
So the Fraunhoffer stuff is recognising music based on frequency analysis,
beat detection, and a couple other parameters that are of course secret. The
signatures it generates are about 300 bytes/second of audio, with even less
than that needing to actually be in memory at any given time for a
preliminary match. But given that it's a linear size increase, I'm guessing
it's something not unlike string matching, except with fuzzy audio
characteristics. It's usually either a very good match, or one of these
"Could be Celine Dijon, could be Mozart, could be Ozzy Osborne" kind of things.
> matches up with?
Basically that sort of thing, yes.
CDDB works by looking at track lengths and positions. I.e., the information
in the table of contents that says what sector each song starts and stops
on. Audio CDs for some reason don't have serial numbers, UPC codes, lyrics,
or cover art encoded on them, which seems like rather a loss to me. (Even
stranger to me is that MP3 doesn't define that sort of thing either.)
The NFL should go international. I'd pay to
see the Detroit Lions vs the Roman Catholics.
That was very handy with my wife's collection of chinese opera music, as I
wouldn't have had any idea how to even transcribe the track names from the
box to the computer. :-)
It always worked for me, even when I took MP3s I'd ripped before and burned
them onto a new CD with cd-text included. As long as the tracks are the same
length, it should work.
> burned them onto a new CD with cd-text included. As long as the tracks
> are the same length, it should work.
Are you sure it's not just reading the track titles from the CD-text? :-P
http://blog.orphi.me.uk/
>> can identify which one it is?
> information in the table of contents that says what sector each song
> starts and stops on. Audio CDs for some reason don't have serial
> numbers, UPC codes, lyrics, or cover art encoded on them, which seems
> like rather a loss to me. (Even stranger to me is that MP3 doesn't
MP3 defines ID3 for storing basic metadata about the track.
I gather the Ogg guys have a special format especially for storing
lyrics... ;-)
Yes. If it were, it wouldn't work without the CD text, and the text would
match what's on the CD.
No it doesn't. That was tacked on long after the format was standardized and
popular. Hence the obvious kludginess of the format.
> and popular. Hence the obvious kludginess of the format.
As in, http://www.id3.org/History
They just found a way to make an MP3 player say "oh, I must have picked this
stream up in the middle. I'll wait for a sync flag so I know I'm at the
boundary of a chunk." Other than the need to kludge it into a streaming
medium that wasn't designed for such things, it's actually a pretty nicely
designed format.
