POV-Ray : Newsgroups : povray.off-topic : Haskell Server Time
2 Nov 2026 22:46:03 EST (-0500)
  Haskell (Message 1 to 50 of 106)
Goto Latest 50 Messages Next 50 Messages >>>
Subject: Haskell
Date: 27 Nov 2008 22:21:34
Message: <492f63be@news.povray.org>
My impressions so far, to whom may concern:
I read a bit of http://haskell.org/ and from
http://www.haskell.org/ghc/index.html also downloaded and installed GHC
(400+ MB installed which I find great) but.... no IDE, to make libraries
and .dll u need this thing (can't remember the name) that need this
other thing (Cywin) to emulate a Linux enviroment and get compiled so it
can be used and the 'darcs' thing to do a kind of repository and the
other thing to do documentation...
I think all of them are goo ideas, what I don't like it is the PIA of
learn how to compile them, compile them, learn how to use it SEPARATELY
and finally start to gather all the DISPERSE tutorials and find what
BROKEN links doesn't show to stat learning the language. Which is not as
easy to read for non-experienced programmers, even the intro text said
it is, I understood better Rubi and Python (a Fibonacci example), wtf!
I'm not saying is hard but is not simple nor obvious, is something in
the middle I think. No doubt it's what I'm looking for in a language,
simple yet powerfull, but u need to go deep into it to learn how to make
fast and/or small .exe files that can compete with C.
In short: is a PIA that is worth suffering it, so I'm not going to quit,
I'm going to continue reading and searching and downloading and
searching some more other peaces as I need them along. I see this
project has come a long way for a freeware, powerful, very smart,
programming language but ir really needs to put things together (IDE,
GHC, the .dll/libraries making thing, doc making thing and darcs in a
funtional package ALREADY COMPILED) and have better support (too much
disperse info and broken links).
Any advise would be VERY WELCOME, thx for ur time.
Subject: Re: Haskell
Date: 27 Nov 2008 23:05:00
Message: <web.492f6dc41bbb3fc88a22ca50@news.povray.org>
Haskell is a language and they provide a reference implementation in the form of
a compiler, plus organized repositories of useful libs.  You choose to
write-compile-debug it in whatever you like best, be it notepad, emacs or
Eclipse, which are outside the scope of the project.  They don't have the
resources of Microsoft to bundle it together with an IDE and deep bindings to
native OS APIs...
Date: 28 Nov 2008 05:12:37
Message: <492fc415$1@news.povray.org>
I'm surprised that alone didn't scare you off! ;-)
It comes with lots of libraries. (Plus their documentation.)
I'm guessing you've got the brand new 6.10.1 release, which is
significantly larger than previous releases, because it comes with the
new Data Parallel Haskell library, plus the document generation tool
[which used to be a seperate download].
AFAIK, when you install a C compiler, you don't get OpenGL bindings, a
parser library, 4 seperate multithreading tools, a set of container
libraries, graph theory libraries...
> but.... no IDE
No, there isn't.
There used to be a Haskell plugin for something called "Eclipse", but
it's suffering from bitrot ATM.
> to make libraries
Ah yes... The Windows version of GHC actually uses the Cygwin POSIX
emulator. It also uses GCC (as in, the GNU C compiler), GAS (the GNU
assembler), and the Linux "ld" tool. And it uses Perl.exe. (??!)
Having just said all that, you shouldn't actually need to install Cygwin
just to compile pure Haskell libraries from source. I've never needed to.
I'm not sure if building DLLs is actually supported ATM... I know
they're working on it, but I don't know if it's functional right now.
Darcs is a source control system (like CVS is). It's very popular for
Haskell projects, since it's written in Haskell. Some programs and
libraries are distributed as "use Darcs to download the current souce
repository, and then compile it". Others are packaged and distributed on
Hackage, and you need to use Cabal to build those. (Cabal being
Haskell's home-grown package manager. Apparently they also translate
packages to various native Linux package formats too.)
Ah yes, Haskell's legendary documentation. It's scattered all over the
place, half of it is published as academic papers that you and I can't
access, much of it is written for compiler designers and academics
rather than actual *programmers* who just want to know how to use the
thing, and lots of stuff isn't documented _at all_.
For example, laziness can be a bad thing. This is highly non-obvious,
and it ISN'T EXPLAINED ANYWHERE. If you pop into the IRC channel and ask
about it, somebody will explain it. But then it's *still* not written
down for the next newbie who wants to know. It's sort of an oral
tradition; there are many "well known" techniques, but nobody has
written any of this stuff down anywhere, making it infuriatingly hard to
learn about this stuff.
...which neatly demonstrates my point. Programs compiled with GHC
contain C debugging symbols by default - even though these are
completely useless in a *Haskell* program. By using a special
command-line switch, you can "strip" the symbols, making a typical
program about 200KB smaller. But this isn't written down anywhere; I
found out about it by chatting to people on IRC.
And yes, Haskell is designed for writing complex algorithms easily. If
you want *speed*, it's very non-obvious how to do this. There is some
scattered documentation about it, but currently the most expedient
method is to post the source code and ask Don to look at it for you. ;-)
> In short: is a PIA that is worth suffering.
That pretty much sums it up, yeah.
FWIW, getting libraries and stuff to work tends to be far easier on
Linux. (E.g., there are packages which require Automake and Bash scripts
as part of their build process... Because, *obviously*, all coding
happens on Linux, right? Right??) Us Windows users tend to be the poor
relations; even Mac OS has better support!
You might try looking through this:
http://book.realworldhaskell.org/
It's the website for a book that just got released and is meant to
explain all this stuff - not just the language syntax, but how to work
the compiler, what the best coding strategies are, etc.
I must say, I was very excited about this book, but having actually read
it now it's out, I'm dissapointed. Still, it's a single *large*,
coherant body of information, all in one place. That's a step in the
right direction...
> I see this
The *language* is fantastic! It's the other stuff that needs to go with
a language, such as...
...exactly.
Date: 28 Nov 2008 05:55:03
Message: <492fce07$1@news.povray.org>
>> but.... no IDE
> No, there isn't.
...unless you count the "Haskell mode" for emacs. :-P
Date: 28 Nov 2008 07:05:22
Message: <492fde82@news.povray.org>
  It depends on the C compiler. Some come bundled with OpenGL libraries.
> a parser library, 4 seperate multithreading tools, a set of container
  C++ is a bit better in this regard. Just because of the C++ standard,
compilers have to come with tons of libraries. And often they come with
tons of third-party libraries as well (eg. the boost library collection
is usually bundled with most linux systems alongside gcc).
  I think one of Haskell's major problems is that nobody has made an
advanced compiler for Windows, and the existing Haskell compilers only
rely on inconvenient cygwin ports.
Date: 28 Nov 2008 07:36:06
Message: <492fe5b6@news.povray.org>
Certainly the C++ containers library seems quite nice.
The thing is, the collection of libraries that come with GHC is...
pretty random, actually. E.g., there's a library for OpenGL, but there's
no GUI library (and hence no way to *use* OpenGL).
Well, the Windows version of GHC is maintained and tested by the core
GHC development team. (And, for example, it comes with bindings to the
Win32 API - incomplete though it is.) And the Cygwin thing isn't as
inconvenient as it sounds... but yeah, this really needs to change.
Apparently a long-term goal is to remove the C compiler completely, but
the internal code generator needs improving first. It's a long-term
project that they've been working on for years, but there's no much
visibly happening at the surface on this particular work item.
Of course, this is an open-source project. I suppose if it annoys me so
much, I should go fix it myself.
I mean, as if I could *ever* do something like that...
Date: 28 Nov 2008 11:28:23
Message: <49301c27$1@news.povray.org>
Warp escreveu:
Why should a compiler project package together other project's
libraries, specially ones that are likely to be found on the host system?
The situation with Haskell is different:  it doesn't come with "opengl
lib", it comes with a Haskell binding to opengl. C/C++ doesn't need
this, as it's perfectly fine calling the lib functions in the very same
syntax and calling conventions they were written in.
Date: 29 Nov 2008 20:33:38
Message: <4931ed72@news.povray.org>
Thx for the advise, I see I'm not alone in my POV (Point of View) and I
also see my common sesnse isn't far from the truth as I thought.
I thank everyone who cared on guiding me in this long Haskell road I
just started to crawl.
I have read in the Haskell site that the best way to learn Haskell is
from a book, so I've downloaded a couple (don't ask from where since
those are illegal ways, I have to, my salary is 180$us a month, I hope u
can understand if not well, I have no other choice) also Haskell98, the
most recent manual and other .pdf files and in other formats.
Also I've come aware of Leksah and how to COMPILE(darn) it. The screen
shots were from a Linux version (how convenient... for them! :D ).
I hope Haskell gets better soon, it has a SPECTACULAR FUTURE.
Well, I think I can raw my boat alone from here, again I thank you for
ur help. God bless you all.
Date: 30 Nov 2008 20:42:30
Message: <49334106@news.povray.org>
>God bless you all.
To each his own, but no matter how many times I see or hear about the
apparently happy coexistence of blatantly conflicting ideologies within
people's minds, I cannot but grin.
Date: 30 Nov 2008 20:53:59
Message: <493343b7@news.povray.org>
To each his own, but no matter how many times I hear monotheists assume that
everyone referring to god must intend that monotheist's interpretation of
their own god's holy scriptures, I have to grimace.
Me, I think Pan and Loki would both be proud.
   The NFL should go international. I'd pay to
   see the Detroit Lions vs the Roman Catholics.
Date: 1 Dec 2008 07:54:52
Message: <4933de9c@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:493343b7@news.povray.org...
that
I've yet to see a polytheist (let's not split hairs with trinity, remnants
or elements of polytheism), and hardly a non-Christian for that matter,
utter the words "God bless you", so I tend to believe it's a comparatively
safe assumption. What is much less safe is to assume it's a monotheist doing
the aforementioned assuming.
Date: 2 Dec 2008 02:22:58
Message: <4934e252@news.povray.org>
>> God bless you all.
So u assume that If I belive in God (my conception is the maker of ALL
even your soul, I believe that He came to be with us a Jesus Christ) I'm
not Catholic anymore or any CHristian religion, I'm a spiritual
Christian) I'll not do wrong things? Well I have seen religious and
"better" Christian than me, act in the most hypocrite way possible to
their proxy, my fault is from need, this book wont be probably read by
anybody else in my whole Country and the BSA only make pay for software
licenses to institutions, Universities, companies and other entities
that can actually pay for it since they are making money our of it and
have enough, the BSA understands that a third world Country can't be
left out of modern technology coz would be even poorer and in a way of
helping ppl here they don't go house by house making an auditory of
software. I hope u understand why ppl in poor Countries need to pirate
software, and also against all odds ppl here also buy (legally) software
when is rare and they "don't have to".
  Hence some software companies like Avast! and other give their
software free for home office. believe me I'd pay for software if I
could earn enough as some people actually do in my country although is
still rare.
I'm using utilities and other software to give support to PCs/Notebooks
as freeware as I can since they're are not only in many cases easy to
use and effective u don't need to download a crack/keygen that can
infect ur PC/Notebook with a lethal virus, or other inconvinients.
I'm not legal for these reasons but I feel no shame either, I hate MS
and I need the rest of the software.
I actually don't need/have to explain this to you but I do coz some ppl
here can't simply understand why oh why ppl pirate software since the
pirates actually bite the hand than gives them the bread.
Believe me, I have no conflict about it, but I know that I could do
better if I had more money. I'm working on getting my Eng. degree to
have more. Yeah I'M A PIRATE, u don't need to write to me at all.
Cheers.
Date: 2 Dec 2008 02:56:27
Message: <4934ea2b$1@news.povray.org>
software
> free for home *use*.
I correct myself.
Date: 2 Dec 2008 07:34:58
Message: <49352b72$1@news.povray.org>
> better if I had more money. I'm working on getting my Eng. degree to have
> more.
Nah, just carry on stealing software, it's way easier than an Engineering
degree :-)
Date: 2 Dec 2008 12:11:00
Message: <49356c24@news.povray.org>
"Saul Luizaga" <sau### [at] netscapenet> wrote in message
news:4934e252@news.povray.org...
> >> God bless you all.
Yes, that's the part I said I found funny. And really, it's both unnecessary
and futile for you to try justify it.
Date: 2 Dec 2008 12:53:39
Message: <49357623$1@news.povray.org>
I know is unnecessary, I already wrote it, and I'm not just justifying
it but explaining it. I don't care it get justified I thought was
something I needed to write. I hope u never get to live in a 3rd world
country and live on a local salary to actually understand the why, u
don't care enough to imagine it and suffering it would be too much for u.
Date: 2 Dec 2008 12:56:28
Message: <493576cc$1@news.povray.org>
>> have more.
> Engineering degree :-)
Well if ppl in the USA don't mind well, ok, fine by me :)
Believe it or not ppl in here ger more and more conscious that they're
using pirated software. I'm hopping my Country gets to a 1st world like
EU or USA/Canada where we can live and buy as u do.
Date: 2 Dec 2008 13:36:34
Message: <49358032$1@news.povray.org>
Truth be told, I really cannot imagine a circumstance under which not
pirating Haskell books would cause suffering for me, but I'm ready to take
your word for it.
Date: 6 Dec 2008 09:11:59
Message: <493a882f@news.povray.org>
> your word for it.
I once upon a time made a google search about PC tech jobs, I found an
offer in the UK that payed 200 Pounds a day for it, but the tech would
be available on call 24/7. For me wasn't a big deal for the amount of
money. Here in Bolivia i make 180 US$ a month which most of it if for
services and food, so u can see the differences, buying a PC is a
sacrifice, paying for software would be like buying another 2 PCs.
As a funny fact: the first time I saw a 'COMPUTER SHOPPER' magazine I
was surprised that they offered software for a price with a new PC since
here was always free for a new PC. U can buy very expensive programs
like AutoCAD 2008 for about 2 US$ if the program is 1 DVD, 1.5 US$ if
it's 1 CD, and so on. Now with torrents has become a way of living for
some ppl, the persons that sell are some times ppl that don't know what
they sell, they were hired to do the job. U can find a great variety of
the most popular software here, all kinds, some "stores" has a website
with a forums and has received formal threats from the BSA, but no
closure so far and other 'stores' are doing the same.
Another funny fact: For some software would be cheaper for any of u
"legal guys" to fly here "buy" the software and fly bak to ur countries :D.
U may thing is easy life here with such convenient software availability
but no actually things suck very much, u have almost no rights here even
when there is laws and Human Rights type organizations, justice is
luxury u must pay, here in my job my own boss stoles sells from me to
avoid giving me commissions, I can't quit coz I still need this
miserable job. So, the sacrifice would be stop eating, transporting to
my job or not having electricity, land phone or water or Internet to pay
any software. I have no social life coz I can't pay for it. Fair enough
for u? or I need to be more miserable to fit ur conscience criteria? I'm
asking this rhetorically, as I said my conscience is at peace.
Date: 7 Dec 2008 18:22:40
Message: <493c5ac0@news.povray.org>
news:493a882f@news.povray.org...
take
> > your word for it.
I don't remember saying stealing is OK so long as you are poor and
miserable. In fact, I think abiding by ethical principles only when
convenient is, well, not really much of a virtue, but that's just me. You
are entitled to your own philosophy.
> I'm asking this rhetorically, as I said my conscience is at peace.
Ah, then I'm answering rhetorically as well.
Date: 7 Dec 2008 21:18:56
Message: <493c8410@news.povray.org>
	Your statement would have value if abiding by ethical principles was a
binary state. Some don't see the world that way.
Feet Smell?  Nose Run?  Hey, you're upside down!
                   /  \/  \ u e e n     /  \/  a w a z
                       >>>>>>mue### [at] nawazorg<<<<<<
                                   anl
Date: 8 Dec 2008 14:06:24
Message: <493d7030$1@news.povray.org>
"Mueen Nawaz" <m.n### [at] ieeeorg> wrote in message
news:493c8410@news.povray.org...
You
Fair enough. I freely admit that stealing a loaf of bread whilst starving is
vastly a different proposition than pirating Haskell books, and implied as
much (quoting myself; "...I really cannot imagine a circumstance under which
not pirating Haskell books would cause suffering for me"). In the former
case, I'd say that not stealing the bread is the unethical choice. On the
other hand, software, audio or media piracy doesn't follow from necessity at
all, the sob stories to justify it notwithstanding. It won't cause any sort
of suffering not to have an mp3 of the latest hit, or not to have a copy of
the latest version of Photoshop. It only follows from entitlement mentality,
not of necessity. There are literally millions of web pages with free
information about anything you can imagine, including Haskell, there is
radio, TV, libraries (the brick and mortar kind), OS or free software that
does pretty much anything you are likely to need... etc. Piracy
justification arguments are vacuous for that reason.
Date: 11 Dec 2008 13:13:00
Message: <4941582c@news.povray.org>
> You
U try to show urself tolerant and understanding but u don't see the big
picture and when I tried to show to u, u wrote that my ethics has no
much virtue and that utterly I have not valid excuse, yeah... right...
Totalitarian ppl like urself is what causes ppl to have all kinds of
trouble, like dictators for example or closed minded-regimens like
Communist Governments. That is simply not being tolerant or understanding.
I'm not saying I feel guilty, all the contrary, but narrowing the vision
because u assume "u know" my current condition and my Country's
therefore I'm totally guilty is wrong and pretentious assumption from u.
I wrote u once that u don't care enough to imagine less fortunate
conditions than urs and u still don't but u pretend to give me solutions
that are ethically correct and would simply be the "perfect" solution no
mather what I can argument. As I mentioned before u as other "perfect"
Christians (Catholic and Protestants included) are the first to betray
their ethics when things get hard, I laugh at "ethic" and "legal" ppl
claiming  how perfect they behave, the higher they are the harder they
fall, I have seen it COUNTLESS times. Ppl that actually sees necessity
where there are some has true ethics and endures even prosper in harsh
times. I'm not one of them but I try to imitate them, I have ethics that
most technicians don't follow coz it's "too good". The only complain
u'll probably find on any of my clients or my Company's clients is that
I'm slow, coz I take 3 times the time to make a PC/Notebook, the fastest
and secured possible today with all the software they're gonna need.
The system tools and utilities I use to make my job are often google
searchs to find the best tools, some of them are freeware, those are
mostly the software I use not the latest mp3 or apps, even I could
EASILY download probably all that I would want. I have ethics, one that
can respect ppl and their property and can put food on my plate for me
and my family. U think what ever u want about it, u don't know me, my
situation and probably don't even know where Bolivia is a World map, let
alone the way of life here or any third world Country for that matter.
But u must be comfortably  earning enough money to live and pay ur way
of life in a first world Country with all the things u want at pass of
ur credit card... so typical...
Date: 11 Dec 2008 13:42:45
Message: <49415f25$1@news.povray.org>
> ....which neatly demonstrates my point. Programs compiled with GHC
> right direction...
It sounds like you are getting / are very involved with Haskell and know
  at least more than me about its inner workings.
FWIW Why not start writing some of the things that you just mentioned
down and make them available.
You could provide a web site with simple articles explaining some of
these things.
You could turn it into a <gasp> published book </gasp>.
Tom
Date: 11 Dec 2008 15:29:35
Message: <4941782f@news.povray.org>
FWIW, I'm more tolerant to some piracy than to people using "u" and "ppl"
and "coz" repeatedly >.<
Date: 11 Dec 2008 15:45:49
Message: <49417bfd@news.povray.org>
[snipped a bunch of ad hominems]
If "u" are going to pirate, pirate. That's your business. I doubt that
calling me a totalitarian dictator, communist, uncaring, pretentious,
ignorant... etc, as well as making quick (and wrong) assumptions about my
origins or beliefs will strengthen the argument that it's just fine for
those from the third world to pirate.
Date: 11 Dec 2008 16:12:17
Message: <49418231@news.povray.org>
> these things.
I have written one or two small things...
http://blog.orphi.me.uk/archives/332
http://blog.orphi.me.uk/archives/49
http://blog.orphi.me.uk/archives/40
http://blog.orphi.me.uk/archives/37
http://blog.orphi.me.uk/archives/38
http://blog.orphi.me.uk/archives/39
http://blog.orphi.me.uk/archives/34
http://blog.orphi.me.uk/archives/32
...just the odd item. I stopped when I realised that nobody ever reads
any of this stuff, because I am the only human alive who gives a ****
about Haskell.
Date: 11 Dec 2008 16:40:16
Message: <494188c0$1@news.povray.org>
Orchid XP v8 wrote:
>> know  at least more than me about its inner workings.
>> these things.
> ....just the odd item. I stopped when I realised that nobody ever reads
> about Haskell.
I see that they are under a blog entry for Haskell.
There are 12 entries - but I bet you could write up a bunch more if you
thought about it.
Now, set up a web site that is dedicated to Haskell.
Web site hosting is cheap & setting up an actual site isn't too hard either.
I am saying this because I believe that your interest in Haskell can do
something for you besides being a nerdy pastime.
I am encouraging you to take something that you enjoy and have a passion
for and make it into something.
Who knows, you may actually be able to contribute some significant material.
Now, if I can only take my own advice.
Tom
Date: 12 Dec 2008 04:20:40
Message: <49422ce8$1@news.povray.org>
> thought about it.
> either.
More to the point, I already have a web host. (Guess where my blog is...)
I guess I should work on getting Indoculate working properly again...
Then I can set about writing stuff. ;-)
Well isn't *that* the thing? ;-)
Date: 12 Dec 2008 08:26:41
Message: <49426691$1@news.povray.org>
>> you thought about it.
>> either.
I do believe that you have a wealth of knowledge that others can benefit
from - more than just on a blog or forum.
And having others encourage me and point out some directions makes it
all that much easier.
Date: 12 Dec 2008 08:34:32
Message: <49426868@news.povray.org>
Heh. The hard part is figuring out how to take a big heap of knowledge
and structure it into something coherant with a logical order to is that
somebody else might even be able to follow. ;-)
Amen!
Damn, if I had more friends, I'd probably get a whole lot more done... ;-)
Date: 12 Dec 2008 11:45:11
Message: <49429517$1@news.povray.org>
Invisible wrote:
>> benefit from - more than just on a blog or forum.
you know the types of things you already have
	some blog entries
	some programs
	etc...
Start putting together some data structure that you can 'copy' your
current data into and then add to at will.
	databases
	files
	etc...
Don't worry to much about making it look perfect - just get the data out
there and have your backend fully functional.  You can always change
what a web page looks like - CSS, but it can be a PITA to change how you
store the data.
> Amen!
you do have friends here
you just don't know what they look like  ;-)
Date: 12 Dec 2008 11:53:17
Message: <494296fd$1@news.povray.org>
>> that somebody else might even be able to follow. ;-)
> store the data.
Hence Indoculate - my tool that accepts a markup language I invented
which exactly matches the structure I want, and turns it into something
that a computer will accept. (Basically HTML or PDF.) But it's currently
broken... *sigh*
For somebody as lacking in motivation and self-belief as me, a much
higher level of encouragement would be useful... :-S
I could have written something today, but I've basically spent my entire
day sitting reading web comics because I couldn't be bothered to start
anything. "Who's going to read it anyway?"
Date: 12 Dec 2008 12:57:18
Message: <4942a5fd@news.povray.org>
Tip: don't structure it yet. Start with some content, once you have
something written you may have a clearer view of how to structure it.
I doubt anyone starts writing a book from the index.
Date: 12 Dec 2008 13:08:11
Message: <4942a88b$1@news.povray.org>
Yes, that's the hard part. :-)  It's one of the problems with open source
software that's doing something totally new, where there's two or three
people who know how it works inside and out, and they don't know how to
explain it to someone who doesn't already know what they're talking about.
It's a tremendously useful skill to have: the ability to explain to grandma
(or your boss) what she needs to know about the technology. (That's probably
one reason I use too many analogies - I find they work well with
non-technical people.)
It's also one of the important skills you learn from a PhD.
I'll second the notion that if you can sit down and write something like you
post here, and just churn it out, do so. Getting the ideas down is good.
After that, if you want to go further, sit down and make an outline (as in
"table of contents" type outline). Break it down until the structure has an
entry for each idea, where "each idea" is covered in a paragraph or two.
Then read the outline and make sure someone else could understand it on the
first read through. Then you just fill in the outline.
Date: 12 Dec 2008 13:11:52
Message: <4942a968$1@news.povray.org>
Some people might...
Heh, this tends to be *exactly* how I write programs, BTW. But then,
writing documentation is rather like programming... except that instead
of operating with the internal state of a machine, it's a human. But you
still have the same problems of figuring out the best way to structure
things, etc.
I have lost count of how many times I've written an authoritative tome
on Haskell, only to get about 8% of the way through the material and
think "meh, that's a silly approach, I should start by explaining X
first instead of starting from Y..." I've started and restarted writing
so many times I can't even count!
I've said it before and I'll say it again: The trouble with explaining
Haskell is that there's lots of interrelated concepts that you seemingly
need to grasp all at the same time, with no logical "place to start".
Date: 12 Dec 2008 15:52:33
Message: <4942cf11$1@news.povray.org>
You noticed?
> source software that's doing something totally new, where there's two or
> three people who know how it works inside and out, and they don't know
> how to explain it to someone who doesn't already know what they're
> talking about.
Welcome to Haskell!
I am *totally certain* that the guy who designed the undecidable
typeclass instance translation rules to System F knows *exactly* what
they're talking about and why it works... but they're far too busy
programming it to tell anybody about it in words of less than 6
syllables. o_O
> grandma (or your boss) what she needs to know about the technology.
> (That's probably one reason I use too many analogies - I find they work
> well with non-technical people.)
Indeed.
IMHO, the *key* skill here is looking at a thing and figuring out what
*is* important, and what is *not* important, for the purposes of the
discussion in question.
A computer is a very large, complex device, and the software that powers
it is built from abstract concepts implemented on top of concepts
constructed from yet more concepts, in a mind-blowing vertical tower of
abstraction.
Just imagine trying to explain to a Victorian scientist how to design,
build and program a modern-day computer. I mean, apart from the minor
detail of needing semiconductor technology and microscopic lithography,
you'd have to give them a lecture in electronics, Boolean algebra, logic
gates, sequential logic design, binary encodings, processor design,
instruction sets, computer programming, subroutine calls, interrupt
handlers, I/O device design, system programming, compiler design,
language design, memory allocation and task scheduling algorithms...
shall I stop yet? :-P
Having just said all that, if somebody wants to know how to connect
several PCs to a single Internet connection, you *could* tell them about
IP addressing and subnet masks and the intricasies of NAT... or you
could just tell them to plug a few boxes together and it'll work. Guess
which answer most people want to hear. ;-)
I'll take your word for it, Dr New.
> you post here, and just churn it out, do so. Getting the ideas down is
> good.
I had an idea that I could produce a kind of "portfolio" of good-quality
written documents (various subject areas and target audiences) and I
could show it to people and say "hey dude, I'm clever!" The thing I
posted here is a first attempt at one such portfolio document.
(I'm polishing up my Parsec thing to make another such document. And I
may or may not to a layman's overview of computer hardware - I don't
know if I could do it justice...)
> in "table of contents" type outline). Break it down until the structure
> has an entry for each idea, where "each idea" is covered in a paragraph
> or two. Then read the outline and make sure someone else could
> understand it on the first read through. Then you just fill in the outline.
The trick to this seems to be figuring out which concepts "depend on"
which other concepts, which ideas "lead to" others, and finding an
optimal order to present the ideas. And some good metaphores and
examples usually help immensely... ;-)
Date: 12 Dec 2008 19:57:37
Message: <49430881$1@news.povray.org>
That's an excellent idea.
Give it a go. Worst thing that happens is people say "don't put that one in
your portfolio."
Indeed, you might be in a good position to write documentation rather than
programs. Consider looking for work as a technical writer.
Yep. It often takes me three or four start-from-scratch rewrites of an
outline before I fill it in. Often takes longer to do the TOC than the paper.
Date: 12 Dec 2008 20:04:31
Message: <49430a1f$1@news.povray.org>
> origins or beliefs
Yeah like u ddn't do it first. This proves u and and U is what matters,
Fine by me.
yeah, what ever...
Date: 12 Dec 2008 20:04:47
Message: <49430a2f@news.povray.org>
Don't like it, don't read it.
Date: 12 Dec 2008 20:18:24
Message: <49430d60$1@news.povray.org>
	You're winning a lot of friends here...
Beware of quantum ducks.       Quark!     Quark!
                                   anl
Date: 12 Dec 2008 20:31:16
Message: <49431064@news.povray.org>
>> these things.
> about Haskell.
U assume too much, I'm another fan, and congratz on the blog, one of the
coolest I've ever seen that also will help me when i decide to do as
complicated as those.
Date: 12 Dec 2008 22:58:04
Message: <494332cc$1@news.povray.org>
news:49430a1f$1@news.povray.org...
> > origins or beliefs
Difference is, I never mentioned "God" to suggest a belief in a deity on my
part. Little detail, but if "v" are going to be pedantic, let's get those
right.
> Fine by me.
Ah, something we can agree on.
Date: 13 Dec 2008 04:59:52
Message: <49438798@news.povray.org>
>> good-quality written documents (various subject areas and target
>> audiences) and I could show it to people and say "hey dude, I'm
>> clever!" The thing I posted here is a first attempt at one such
>> portfolio document.
Yay, me!
> in your portfolio."
Yeah, I guess. (Oh, and on THAT subject there really WILL be some
large-scale simplifications!)
> than programs. Consider looking for work as a technical writer.
You're not the first person to make this suggestion.
Unfortunately, technical writers seem to be even rarer than programmers! ;-)
> paper.
I've had *a tad* more than 4 rewrites on "explaining Haskell". Like, the
other day I found one version from 2004 or something, and I'm like
"JESUS, I've been using Haskell for THAT LONG?! I had no idea!"
But still, after all this time, I can't think of a good way to explain
it all in a coherant way. Have you looked at Real World Haskell? It's
very messy. And it's written by three experts!
Also, there's so many ways to explain Haskell... Do you want the "here's
the elegant theory that powers the language" intro? Or the "this is how
you write useful code" into? At which point to you mention lazy
evaluation? Monads? The type system? Concurrency primitives? Useful
libraries? Do you mention all the built-in list functions, or show how
to derive them from first principles? Does recursion come before ADTs?...
It's pretty hard to figure out! o_O
Date: 13 Dec 2008 15:42:51
Message: <49441e4b$1@news.povray.org>
>> paper.
You didn't read. It takes me four complete rewrites of the *table of
contents* before I'm ready to write a 20 page paper.
They may be *too* expert. That's often the problem. They already know it
all, so they can't easily put it down in an order that assumes you don't.
All the more reason to give it a go, yes? :-)  Just try to figure out what
order to introduce the concepts. Don't fear splitting up a concept into
smaller chunks that make sense in order.
Date: 13 Dec 2008 20:26:09
Message: <494460b1@news.povray.org>
Once u understand how short can sentences be just by adding "u" instead
of "you" and other abbreviations u read faster and u write faster BUT
NO, u can't simply make a small mental effort and take it as an internet
slang and  get use to it, if not imitate it... is all the same, our
newsgroup, our way, or the highway... fine, so be it. Bye.
Date: 13 Dec 2008 20:27:27
Message: <494460ff@news.povray.org>
>>> origins or beliefs
> right.
What has my belief in God anything to do with piracy, I cleared that
already, I believe in Him but I do wrong things to survive, read the
posts above and what about the pedantic? dude, u were saying u were
ready to take my word on why not pirating software would lead me to
suffering in my country and once I explained why, instead of actually
accept my word as u wrote u would u do exactly the opposite and I'm
pedant? hahaha.
>> Fine by me.
Again, I explained I have no choice and I'm right not coz I say so, but
coz my situation says so, but u again missed the point and come to make
redundant assumptions, so u take the fast and easy cynic highway to
criticize me, but I'm sure coz u r "legal" guy u will not cease to say u
r not the closed mineded but me, the infamous pirate, is laughable to
see how ppl that were once trying to understand u turns cynic and closed
mineded once u justify ur point and they can't beat the logic, so
keeping on writing to u is simply pointless, now I'm starting to notice
ur frustration and intolerant attitude calling me pedant when wasn't me
who broke his word about getting ready to take my word for it, dude the
more u write the more typically intolerant ur behave/attitude it is, so
be it; peace out.
Date: 14 Dec 2008 04:20:45
Message: <suj9k4pijskt7s8jd9513lobrf5bqkg7tu@4ax.com>
On Sat, 13 Dec 2008 21:25:44 -0400, Saul Luizaga <sau### [at] netscapenet> wrote:
To a native English speaker it makes you sound juvenile or ignorant. Also other
people do not read your text faster.
http://news.bbc.co.uk/1/hi/technology/7775013.stm
Hrd 2 rd
Regards
Date: 14 Dec 2008 09:55:56
Message: <49451e7c@news.povray.org>
> Hrd 2 rd
"It's just another form of the Queen's English - not better, not worse,"
Once u get use to it u read a lot faster, but here most ppl presume of
making intellectual milestones writing or discovering intellectual
interesting stuff and mostly as a show-off of their mental capacity but
a small challenge and bam! oh is too hard... OK...
Date: 14 Dec 2008 10:46:46
Message: <49452a66@news.povray.org>
> other people do not read your text faster.
I had to copy his message to a text editor and do s/u/you/ and other
replacements...
