POV-Ray : Newsgroups : povray.off-topic : Phone for Invisible... Server Time
2 Nov 2026 22:46:04 EST (-0500)
  Phone for Invisible... (Message 1 to 14 of 14)
Subject: Phone for Invisible...
Date: 22 Nov 2008 04:02:45
Message: <4927cab5@news.povray.org>
http://www.pomegranatephone.com/default.html
...or rather not :)
Subject: Re: Phone for Invisible...
Date: 22 Nov 2008 04:26:13
Message: <4927d035@news.povray.org>
> ...or rather not :)
  For a moment it got me, until I watched on the projector feature, which
made it rather clear that it's a spoof.
  Reading *who* made this spoof (and how much it cost to make), I really
can't understand what's the point.
Date: 22 Nov 2008 12:55:35
Message: <49284797@news.povray.org>
I want to know what the stand-by time is while using the projector. :-)
I'll second that wtf.
Date: 22 Nov 2008 14:13:05
Message: <492859c1$1@news.povray.org>
Am Sat, 22 Nov 2008 09:55:37 -0800 schrieb Darren New:
>>   which
Well, if they get the laser projectors work I wouldn't be surprised if
the projectors get *much* smaller than they are now (Still they will use
a lot of power). I think Frauenhofer Institute has some prototype
working, where the optics (excluding the electronics) is only a few cubic
cm. Unless green lasers get cheap though, it will probably take some time
until we see them in the stores :).
>>   really
It seems to be some virial marketing campaign for the tourism in some
region in Canada, but I don't even get that far (I can see all "features"
of the phone, but when I klick on release date for example the flash
player stops, before it loads completely.)
Date: 24 Nov 2008 02:36:24
Message: <492a5978$1@news.povray.org>
I think both the non-rectangular display and the projector, are features
that are only available in the R&D stage at the moment.  Won't be long
though...
Date: 24 Nov 2008 03:02:53
Message: <492a5fad$1@news.povray.org>
> cm.
I saw a demo from these guys a couple of years ago which was only a few cc:
http://www.lightblueoptics.com
But as you mentioned, they told me back then the problem was the cost and
availability of small green laser diodes.  I'm sure that's on the way to
getting fixed though, and then we'll have all sorts of cool applications :-)
BTW the technology used is pretty interesting, they use a micro display,
just like in a conventional projector, but instead of creating the image on
the display, they create a hologram from the image and show this on the
display, then use the lasers with the display to recreate the image on any
surface.  The benefits of this system are that the image is always perfectly
in focus (so no need for moving lens) and that if one pixel or line fails in
the display, it affects every pixel in the final image equally so you
essentially don't notice it.  These two things will make them potentially
very cheap to manufacturer once the laser diodes drop in price.
Date: 24 Nov 2008 04:51:26
Message: <492a791e@news.povray.org>
"scott" <sco### [at] scottcom> wrote in message
news:492a5978$1@news.povray.org...
> though...
I'd rather the coffee maker.
Tim Cook
http://empyrean.freesitespace.net
Date: 24 Nov 2008 15:31:17
Message: <492b0f15$1@news.povray.org>
Am Mon, 24 Nov 2008 04:51:16 -0500 schrieb Tim Cook:
http://www.handpresso.com/
Date: 24 Nov 2008 15:36:12
Message: <492b103c$1@news.povray.org>
Am Mon, 24 Nov 2008 09:02:52 +0100 schrieb scott:
>> use a lot of power). I think Frauenhofer Institute has some prototype
>> cubic cm.
> cc:
That's pretty impressive! I want one :).
> make them potentially very cheap to manufacturer once the laser diodes
> drop in price.
On an only slightly related note, I'm still waiting till the OLED screens
get cheap enough for consumer laptops :). My current laptop should
survive till then.
Date: 25 Nov 2008 03:00:42
Message: <492bb0aa@news.povray.org>
> survive till then.
OLED is fighting a very tough battle against LCD, when OLED was first
invented it instantly addressed many problems that LCD had (response time,
colour range, viewing angle, contrast).  But the problem is OLED can't
improve any further (except for the lifetime and cost issues), whereas LCD
has been catching up in leaps and bounds over the last 5-10 years.
If you buy a good quality LCD today (eg one used in a TV set or good
monitor, not a cheap laptop display), you will be very hard pressed to tell
it apart from an OLED display.  THe only thing LCD really needs to improve
to be totally on par with OLED is the contrast.  Currently consumer LCD
contrast tops out at about 1000:1 - 2000:1, this is still not good enough
for good blacks in a dark room.
When any consumer OLED monitor is released, it's going to need to pretty
sophisticated electronics or software to counteract the ageing of each
sub-pixel.  In current displays it doesn't matter if your display gets a bit
darker after a year or two of use, but it will be a bit annoying if you get
a permanent imprint of the windows task bar at the bottom of your monitor
Date: 25 Nov 2008 07:43:35
Message: <492bf2f7@news.povray.org>
> bit darker after a year or two of use, but it will be a bit annoying if
> you get a permanent imprint of the windows task bar at the bottom of
> your monitor :-)
You mean there'd be a real reason to have a screen saver again?  LOL!
Date: 25 Nov 2008 09:07:40
Message: <492c06ac$1@news.povray.org>
Yeh it looks like it!  Actually there is a SOny 11" OLED TV on Amazon, I was
reading through the user manual (from the Sony website) and it said that is
shifts the image around every so often to avoid burn-in.
I would be more concerned though about people who use their computers a lot,
I mean my screen saver is hardly ever on because I'm mostly at the computer
during the day.  There's a timer on my old monitor (that I just use as a
secondary display for my laptop now) which says it's been on for 6519 hours.
I would hazard a guess that for the majority of that it's said "Start" at
the bottom left corner!  Even with standard LEDs, after 6000 hours you are
going to see at least a 10% drop in brightness (which you hardly notice on
LCD because it affects the whole image), I think this would be quite visible
if it varied pixel by pixel though.
Date: 25 Nov 2008 09:27:19
Message: <492c0b47@news.povray.org>
  Wouldn't help with larger areas with an uniform color...
Date: 25 Nov 2008 10:23:18
Message: <492c1866$1@news.povray.org>
>> was
>> is
Agreed, but at least the moving around should stop any recognisable pattern
burning in - like the word "Start" or "88:88:88" where the clock is - it
would just be more of a dark blur in that area.
I guess this is primarily a TV so there probably won't be the same issues as
with a computer monitor or any other display where static information is
shown in certain areas of the screen.
