POV-Ray : Newsgroups : povray.off-topic : Oh dear... Server Time
2 Nov 2026 23:43:53 EST (-0500)
  Oh dear... (Message 1 to 50 of 130)
Goto Latest 50 Messages Next 50 Messages >>>
Subject: Oh dear...
Date: 12 Nov 2008 06:29:02
Message: <491abdfe$1@news.povray.org>
I just asked about backing up our database server. (There's a new backup
procedure coming in.) For my trouble, they asked if I could just script
the database backup to put the files onto a different server.
This is no use at all; I need to backup the entire server, including the
OS, so that if there's a problem I can just shove in a tape and put
everything back to normal, rather than manually installing the OS,
device drivers, Oracle, etc.
But here's the worrying this: The database admin from HQ sent me a copy
of "the backup script we use here".
And guess what? It isn't a backup. It's an export.
For those of you who aren't Oracle experts:
- A *backup* is where you take the database files and copy them.
- An *export* is where you run a special program that extracts the data
from the database and puts it into a (binary) flat file.
An export allows you to *recreate* the database, but it isn't "the
database itself". It contains all the _data_ from the database, but none
of the _metadata_.
In particular, to use an export file, you "import" it. This is
equivilent to running lots of SQL "insert" statements. In particular,
importing data causes triggers to fire. The documentation says you need
to think about whether triggers should be disabled before the import begins.
How great would that be? You "restore" your "backup" and the system
modifies it as you restore it!
The thing is, exports are really designed for transferring data from DB
to DB, possibly running incompatible versions of Oracle. It's not really
a good idea for "backups". (Although some of the official Oracle
documentation suggests that is it.)
Now a *real* backup includes all the database configuration metadata and
so forth. And best of all, if you follow best practices, you don't have
to shut the database down to back it up, and you can do point-in-time
recovery. Basically you can rewind the database to any second in time,
not just to the instant when a "backup" was taken.
Export, on the other hand, runs as a normal database transaction. In
particular, since it is usually a very *long* transaction, it can cause
problems with overflowing transaction logs and so forth.
In summary:
- Backups
   - Run while the database is in use. (Slows it down slightly, obviously.)
   - Recover the database to any point in its history, not just when a
"backup" happened.
   - The restored database is *identical* to the original, down to the
bit-pattern level.
- Exports
   - Slower than backups. (Produce smaller files though.)
   - Contain "logical" structures only. No undo data, no transaction
logs, nothing.
   - Running an export is a transaction. The undo buffer has to be large
enough to copy.
   - Running an import is a transaction. Applicable triggers will fire.
   - Point-in-time recovery is impossible.
   - Can move data from DB to DB. (This is the designed purpose, actually.)
If you do an export and your server goes down, once the server OS is
back and Oracle is installed, you have to create an empty database,
recreate all the user account info, and then import all the data. Then
you need to put back any triggers you're supposed to have, possibly move
tables into the correct tablespaces, and probably recreate your indexes.
(Alternatively, keep the indexes in the export and watch it go even slower.)
To recover using a backup, once the OS and Oracle are back, you copy the
files back to their original locations, and start Oracle. It will
complain about the files being inconsistent. Tell it to perform a
recover. (Usually takes a few seconds.) Now open the database. You are done.
I am SORELY TEMPTED to tell this admin what an idiot he is...
...but on the other hand, it's been a while since I did any serious
Oracle stuff. If I don't get all of my facts straight, it will be *me*
who looks stupid. I'd hate to write a long email explaining what a
smart-arse I am and then discover that I got some small technical detail
wrong and actually the other guy was right all along.
Oh the frustrations of working here! >_<
Subject: Re: Oh dear...
Date: 12 Nov 2008 12:47:32
Message: <491b16b4@news.povray.org>
This is how you manage these things:
Pretend you're not as smart as the person you're talking to, and you
don't know as much. (I'll make it short and over-the-top to illustrate,
but of course if you turn it into two pages you don't need to make it
sound smarmy.) Assume that the guy is not stupid, but that he has
requirements you aren't aware of.
Thanks. I looked over your backup plans, and I'd like to understand more
why your method is superior. I've been using backup method B, which as
you know saves all the metadata and makes it quick to restore in the
event of a disaster. I thought this was why we were making the backups,
but perhaps I'm misinformed.
You're suggesting that we switch to backup method E, which has the
advantage of letting us restore to later versions of oracle but would
seem to have the disadvantage that it would take much more effort to
recover from a disaster. For example, since method E does not save the
user account information, we would still need to export that
independently at the time of making backups with method E or risk
needing to recreate that information while the company waits.
Perhaps the best approach would be to take backup method E each month,
and backup method B each day (since B allows rolling back to any
previous point in time), and save the monthly of each indefinitely. This
would seem to be the best of both worlds.
Please clarify how you would like me to handle the following situations
using backup method E:
1) Saving user account information in a secure way,
2) Which triggers should be enabled if data needs to be restored,
3) Whether indecies should be included in the exports,
4) How often we should do exports to insure we don't overflow
transaction buffer pools,
5) ... anything else you think is problematic ...
The first part says "Oh, have we changed what we're doing? Is that why
you're changing stuff that works?"
The second says "I know there are advantages to your way of doing it,
but there are disadvantages, and you job is to weigh them and figure out
whether it's worth the risk to get the advantages."
The third part says "Here's a way to save face and not look like an
idiot by reversing yourself. We can still make backups the way you want,
and just not use them. And three months from now, when the system
becomes unusable for an hour in the middle of the day because of your
backups, you can tell me to stop doing it that way, as if I hadn't told
you that in the first place three months ago."
The fourth is "Please put in writing all the solutions to the problems
you're causing, so I don't get blamed. If you don't know what I'm
talking about, understand that I know more about this than you, and
hence maybe you should take my advice."
But if you do it politely, careful of his ego and humble in your
criticism, it works pretty well. If you say "please explain to this poor
ignorant peon why you're making such a boneheaded decision", you not
only look better in the event that you're wrong, but you haven't ticked
him off by being right. Especially if it goes back and forth a couple
times, with him changing his story a little each time until he has been
agreeing with you all along. :-)
Date: 12 Nov 2008 12:52:12
Message: <491b17cc$1@news.povray.org>
And here, you can add something like "Has Oracle improved this feature?
Have they eliminated the need to reconstruct all the metadata before
restoring an E backup? If so, could you be so kind as to point me
towards the new manuals that describe this so I can learn how these new
features work?"
Stuff like that.
Hope this helps. I know you probably weren't asking for advice, but ...
you know me by now. ;-)
Date: 12 Nov 2008 12:59:17
Message: <491b1975@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:491b16b4@news.povray.org...
> I thought this was why we were making the backups, but perhaps I'm
> misinformed.
I'd leave that out. It could easily be interpreted as sarcastic and with a
condecending tone. The rest is fine.
Date: 12 Nov 2008 13:13:43
Message: <491b1cd7$1@news.povray.org>
>> misinformed.
> a condecending tone. The rest is fine.
As I said, it's shorter than it should be, and over-the-top to make a
point.   (It's not as over-the-top as I had expected it to be when I
started. I guess my anti-smarmy now kicks in without me having to
consciously rewrite things to get rid of it. :-)
Perhaps something more along the lines of "I was under the impression
the only reason we were making backups is to deal with disaster
recovery. Perhaps I am unaware of additional planned uses for this
data"? That sort of thing, to express that "if what you want is disaster
recovery, this is what you need, but what else do you want?"
Date: 13 Nov 2008 05:17:26
Message: <491bfeb6$1@news.povray.org>
> features work?"
> Stuff like that.
Actually, EXP.EXE is deprecated now in favour of the new data pump
feature. (But I don't know what version of Oracle they have, and hence
whether that feature is available to them.)
If you don't know my by now... wowo...
...GOD DAMNIT!! NOW I HAVE THAT SONG IN MY HEAD! >_<
Date: 13 Nov 2008 05:20:44
Message: <491bff7c$1@news.povray.org>
In fairness, as I understand it the guy is an SQL Server expert, not an
Oracle expert.
Given that the "solution" I've been offered doesn't actually solve the
problem of interest anyway, I think I shall just quietly leave things as
they are. Pointing out what we could be doing differently is likely to
get me yelled at - especially as Oracle's own documentation hints that
exporting is a way to "backup" a small database.
(I really love the way it describes "small" as "less than, say, 50 GB".
I'd like to know in which universe 50 GB can be considered "small"...)
Date: 13 Nov 2008 05:30:07
Message: <491c01af$1@news.povray.org>
Amusing thing: I deleted the email instead of sending it. Yet Outlook
still claims I replied to the email. Neat, eh?
Date: 13 Nov 2008 06:51:47
Message: <491c14d3@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:491bff7c$1@news.povray.org...
> Oracle expert.
No fairness.
SQL Server doesn't have the dump feature that he's proposing you use (well,
you can do it, but it's non-trivial). SQL Server backups are full database
backups and are online backups (can be done while DB is in use) and restore
with the DB in exactly the state that it was at the time of the backup
Date: 13 Nov 2008 07:00:35
Message: <491c16e3@news.povray.org>
>> an Oracle expert.
> No fairness.
> (well, you can do it, but it's non-trivial). SQL Server backups are full
> database backups and are online backups (can be done while DB is in use)
> and restore with the DB in exactly the state that it was at the time of
> the backup
...so, rather like real Oracle backups then.
Presumably the guy did a little researching on Oracle and found *a* way
to make a copy of the data, and that's what we're using.
Using a logical backup rather than a physical backup does take up less
disk space. However, it takes more time to backup and restore (and these
operations are logged transactions, and triggers can fire, etc.) Myself
I'd prefer a real physical backup...
Presumably the guy just isn't aware of the tradeoff. Or maybe he is, and
he seriously thinks the extra complication is justified for the disk
savings?
Date: 13 Nov 2008 13:15:46
Message: <491c6ed2$1@news.povray.org>
Telecom. Finance. Multimedia. Web services. Application Service
Providers (aka "white labeling").
Generally, "small" is anywhere you don't actually need the permission
system of your database, I'd say, because what you're doing is too simple.
Note that MySql generally backs up stuff the same way - the table
structures and the rows, but none of the system tables. I guess you
either explicitly dump them separately, or you do what I did which is
that those things don't change except manually, so you already have a
record of how it's set up.
Date: 13 Nov 2008 13:21:55
Message: <491c7043@news.povray.org>
Enterprise databases.
Personally I consider any database under 100GB small. Over about 700 GB is
large. Huge is over a couple TB.
Date: 13 Nov 2008 13:24:49
Message: <491c70f1$1@news.povray.org>
> is large. Huge is over a couple TB.
Well, I guess Oracle is *designed* for big stuff.
So I guess to all you guys, the 1.2 GB database I'm responsible is
"microscopic" then? :-)
http://blog.orphi.me.uk/
Date: 13 Nov 2008 13:29:18
Message: <491c71fe@news.povray.org>
"Orchid XP v8" <voi### [at] devnull> wrote in message
news:491c70f1$1@news.povray.org...
So's SQL Server.
Tiny. I have test databases on my desktop ten times that.
The smaller they are the easier they typically are to maintain and admin.
It's the bigger ones that are difficult because of the time required to do
anything with them (like backup, restore, defragment, etc)
Date: 13 Nov 2008 13:52:46
Message: <491c777e$1@news.povray.org>
> So's SQL Server.
Yeah - I didn't mean to imply otherwise. (Recall that the "small" quote
game from an Oracle manual.)
Really?
How much disk space do you have??
> admin. It's the bigger ones that are difficult because of the time
> required to do anything with them (like backup, restore, defragment, etc)
Yeah, I'll bet.
Mind you, having said that, it takes about 3 minutes to backup *my*
database...
Date: 13 Nov 2008 14:08:56
Message: <491c7b48$1@news.povray.org>
> database...
I've had databases that took more than three minutes to *delete*.
Mind, they were full of several thousand gig of raided multimedia...
Date: 13 Nov 2008 14:10:25
Message: <491c7ba1$1@news.povray.org>
Oddly enough, trying to delete a few thousand PNG files is an efficient
way to lock Windows Explorer up for several seconds. And the deletion
takes an anomolusly long time too... hmm.
I find the concept of "several thousand GB" intimidating. o_O
Date: 13 Nov 2008 14:42:06
Message: <491c830e@news.povray.org>
Yes, just like that. :-) It makes Linux very unhappy too.
Oddly enough, I've had occasions in Vista where I move or delete a
diretory, and it spends a huge amount of unnecessary time trawling thru
a big complex directory structure, when presumedly it could just rename
the directory itself and be done. As if it wants to count how many files
are in there before it moves them as it would with a copy.
> And the deletion takes an anomolusly long time too... hmm.
Windows does some funky stuff with NTFS and deleting lots of files. It
puts stuff in the journal that the file was deleted, but since the name
of the file is actually an attribute of the file itself and not just the
directory, you can't (for example) recreate the file after you deleted
it but before the journal has actually been flushed to disk. Plus,
apparently, there's no way to tell NTFS to flush the journal as fast as
you can.
It might be something like this that makes Windows slow at deleting
large numbers of files at once - you're waiting on a slow journal to flush.
I think on Linux it was just a combination of me picking a file system
not really optimized for bunches of little files, combined with a
journaling mode that's designed for utter safety rather than efficiency,
combined with a software RAID. I probably could have improved it a bunch
if I had an incentive to learn my options before installing things. :-)
Try to avoid working with libraries of weeks-worth of uncompressed audio
tracks.
Date: 13 Nov 2008 14:44:19
Message: <491c8393@news.povray.org>
news:491c777e$1@news.povray.org...
> Really?
Haven't we been over that before?
Desktop:
1x80GB (2 paritions, OS)
1x320GB (2 partitions, apps and data)
1x160GB (1 partition, games)
Laptop:
2x120GB drives
Server:
1x80GB (OS and apps)
4x160GB in a RAID 5 config. Results in 480GB of usable space
> Yeah, I'll bet.
> database...
That's slow for a 1.2 GB. My 10GB test DB backs up in under a minute, and
that's just on a desktop. No fast SCSI drives, backups and data on same
drive and tonnes other stuff running.
Ok, mine is SQL and yours is Oracle so maybe 3 min is reasonable.
Last DB I worked on took 4 hours to backup. That's partially cause the SAN
was badly configured though. It should have taken maybe 2 at the most.
That's a 1.2 TB database
Date: 13 Nov 2008 15:22:47
Message: <491c8c97$1@news.povray.org>
Oh, and for S&G purposes, AT&T before the breakup had 9 major databases,
the biggest of which was 320 terabytes, the next biggest of which was
something like 290 terabytes, etc. And something like 1800 full-time
employees writing SQL code in >million stored procedures.
Date: 13 Nov 2008 15:36:34
Message: <491c8fd2@news.povray.org>
news:491c8c97$1@news.povray.org...
Neat!
My first thought was - "I wanna work on one of those"
Date: 13 Nov 2008 16:00:05
Message: <491c9555$1@news.povray.org>
Darren New wrote:
>> efficient way to lock Windows Explorer up for several seconds.
> you can.
Well, you say all that, but if I do the same operation using the CLI
instead, it's instantaneous. Clearly this is just another instance of
Windows Explorer being retarded. (I know on many computers, Explorer
uses more RAM than any other process. WTF?)
> tracks.
Dude... where do you even buy that much disk space??
My PC has *four HDs* in it and it totals less than 300 GB!
Date: 13 Nov 2008 16:05:12
Message: <491c9688$1@news.povray.org>
>> Really?
> Desktop:
> Laptop:
> 2x120GB drives
> Server:
Neat. Your laptop has more HD capacity than my entire DB server. (BTW,
how the heck do you put *two* HDs in a laptop??)
>> database...
> and that's just on a desktop. No fast SCSI drives, backups and data on
> same drive and tonnes other stuff running.
Well, the "backup" part is just a file copy. The database generates
roughly 10 MB of log per week, so I doubt the running Oracle process
slows the copying down significantly.
The copy is from disk to same disk, and the "disk" is actually a RAID-5
array of Ulta320 SCSI drives. IIRC, it's 4 x 36 GB for a total of about
108 GB. (It's partitioned into two NTFS partitions. For no particular
reason. That's how the expensive Oracle consultant set it up...)
Date: 13 Nov 2008 16:09:15
Message: <491c977b@news.povray.org>
news:491c9555$1@news.povray.org...
You can buy a 1TB internal drive for a standard PC for under £100. The fact
that your PC is still last century ito disk space doesn't mean everyone's is
Date: 13 Nov 2008 16:13:21
Message: <491c9871$1@news.povray.org>
> fact that your PC is still last century ito disk space doesn't mean
> everyone's is
Damn. Now I feel silly for paying £90 for a 200 GB drive a few months ago...
Date: 13 Nov 2008 16:15:07
Message: <491c98db@news.povray.org>
news:491c9688$1@news.povray.org...
> Neat. Your laptop has more HD capacity than my entire DB server. (BTW, how
It came that way.
Some of the more high-end models do, since the laptop-size drives are more
expensive and lower capacity than the desktop drives.
It's a 17" notebook, so there's lots of space.
Date: 13 Nov 2008 16:19:03
Message: <491c99c7$1@news.povray.org>
Gail wrote:
> It came that way.
> more expensive and lower capacity than the desktop drives.
OK, that's pretty impressive. Does it have RAID capability in hardware?
Also, does it have hardware 3D acceleration? (I still can't believe you
can get that in laptops now...)
I've only ever looked at really cheap laptops. *My* laptop is powered by
an AMD AthlonXP 1700+. (Mind you, it's rather old now...)
Date: 13 Nov 2008 16:19:39
Message: <491c99eb@news.povray.org>
news:491c9871$1@news.povray.org...
>> everyone's is
> ago...
I do hope it was gold-plated.
I paid R750 8 months ago for a 320GB drive. At the exchange rate of the
time, that would have been £50.
And SA is more expensive than the UK for computer stuff.
Date: 13 Nov 2008 16:20:39
Message: <491c9a27$1@news.povray.org>
>> ago...
SATA-II. Does that count?
Orchid: PWN3D.
Date: 13 Nov 2008 16:25:14
Message: <491c9b3a@news.povray.org>
news:491c99c7$1@news.povray.org...
> Gail wrote:
>> It came that way.
No. It's still a notebook. Even my desktop doesn't have true hardware RAID.
The motherboard drivers support RAID, but I wouldn't call that hardware.
Yup. It's got a GeForce 7600 built in.
Date: 13 Nov 2008 16:26:08
Message: <491c9b70@news.povray.org>
news:491c9a27$1@news.povray.org...
>>> ago...
No. Mine's also a SATA 2.
Date: 13 Nov 2008 16:43:11
Message: <491c9f6f$1@news.povray.org>
> RAID. The motherboard drivers support RAID, but I wouldn't call that
> hardware.
OK, neither would I.
(FWIW... doesn't Windows support RAID without special drivers anyway? Or
is that only in the server editions?)
>> you can get that in laptops now...)
Damn. My *desktop* only has a GeForce 7900GT. o_O
My graphics card cost me about £300. I don't even want to know what you
paid for your laptop, do I?
Date: 13 Nov 2008 17:40:05
Message: <491cacc5@news.povray.org>
I don't know any other program that can load so many 3rd party DLLs (COM
objects to be precise).
Oh, maybe iexplore.exe.
http://www.realtamadwarek.org/friends-dont-let-friends-use-ie.jpg
Date: 13 Nov 2008 17:42:11
Message: <491CAD9B.6090805@hotmail.com>
>>> an Oracle expert.
>> No fairness.
>> full database backups and are online backups (can be done while DB is
>> in use) and restore with the DB in exactly the state that it was at
How much diskspace are we talking about? Remember current price is about
€100 for 1TB and you can expect that to halve next year.
Date: 13 Nov 2008 17:48:31
Message: <491CAF16.9080509@hotmail.com>
On 13-Nov-08 19:24, Orchid XP v8 wrote:
>> GB is large. Huge is over a couple TB.
I should learn to read the entire thread before replying :(
So this will allow me to finish the computation of the price of a full
backup: about €0.12 or less than 10 pence. Who was trying to save some
money by not doing a full backup?
Date: 13 Nov 2008 19:06:55
Message: <491cc11f@news.povray.org>
I don't know about NT-era OSes, but I remember that for a long time, the
CLI used the DOS 1.0 interface for deleting files, because it let you
specify wildcards. Hence, you had one kernel call that would delete all
the files.
If you use a UNIX-like interface, you have to do "find file, delete
file, find file, delete file, find file, delete file, ...." So on a
directory with a half-million files, you scan the thing a quarter
million times on average (on ext3, at least) or you at least wind up
doing a whole bunch of kernel calls if you have a file system that's a
little better organized about the file layout. To be fair, NTFS and
other tree-based directory systems have to rework the tree when you
delete the files, so this too will be disk I/O overhead.
Nah. It's because there's a different API for DOS 2.0 and later than for
DOS 1.0 and earlier.
Fry's. Best Buy. Circuit City. Any place that sells hard drives. Go down
to the store, shell out $500, and pick up a couple terabytes.
Date: 13 Nov 2008 19:08:38
Message: <491cc186$1@news.povray.org>
Orchid XP v8 wrote:
> (I still can't believe you can get that in laptops now...)
You can get 7.1 surround sound, mpeg encoders and decoders, and hardware
accelerated 3D in cell phones nowadays, dear. :-)
Date: 13 Nov 2008 23:30:56
Message: <FD8D79437F3A4F09BE8F09608CEDA0DF@HomePC>
> -----Original Message-----
> From: Orchid XP v8 [mailto:voi### [at] devnull]
> ago...
You* shouldn't be allowed to purchase computer equipment without first
checking here:
http://www.pricewatch.com/
On the page for 1 TB hdds:
http://www2.pricewatch.com/hard_removable_drives/sata_1tb.htm
3 of the top 5 state in their summary that international orders are OK,
so shipping to you shouldn't be a problem.  The other two might still do
it, they just don't state it.
*And I don't mean the generic "you," I mean specifically you, Andrew.
You've made comments like this in the past about other pieces of
equipment.  Really, you could save yourself a lot of money shopping
online.
...Ben Chambers
www.pacificwebguy.com
Date: 13 Nov 2008 23:31:56
Message: <5B8B0A47B889495EB29F68AD2AF8F55A@HomePC>
> From: Darren New [mailto:dne### [at] sanrrcom]
> databases,
"before the breakup"...
Wasn't that, like, 25 years ago?!?!?
...Ben Chambers
Date: 14 Nov 2008 00:24:26
Message: <491d0b8a$1@news.povray.org>
Yeah?  1984 was the MFJ.  (The "Modified Final Judgement", modifying the
"Final Judgement" of 1934 or so.  The "Final Judgement" said "AT&T can
have a monoply".  The "modification" was to amend that to say "No, you
can't, and indeed you have to help your competitors and stop doing
anything they already compete with you." Sort of like an idempotent
modification.)
Oh, you mean, back when a terabyte occupied a small room? Yes, that.
Date: 14 Nov 2008 02:48:42
Message: <491d2d5a@news.povray.org>
news:491c9f6f$1@news.povray.org...
I've got an 8800 in my new one.
It was about $1800 and that was just over a year ago.
Intel Core 2 Duo 2GHz
2 GB memory
2x120 GB hard drives
1x HD drive/multi-format CD/DVD read/write
17" screen
Very nice notebook. Heavy though.
Date: 14 Nov 2008 05:10:42
Message: <491d4ea2$1@news.povray.org>
>> way to make a copy of the data, and that's what we're using.
>> these operations are logged transactions, and triggers can fire, etc.)
>> Myself I'd prefer a real physical backup...
I have no idea how large their database is. I only know how big my one is.
Date: 14 Nov 2008 05:17:13
Message: <491d5029$1@news.povray.org>
> the files.
Seems like it's the same amount of work to me, whether the kernel does
it or the application does it.
Um... you don't cache directory blocks, no? (Especially given that
they're usually non-contiguous and so take a lot of thrashing to access,
and there often heavily accessed.)
$500 seems like a hell of a lot of money to me...
But then, 1 TB seems like a hell of a lot of space too. I have 0.3 TB
that I've never come close to filling yet.
Date: 14 Nov 2008 05:19:31
Message: <491d50b3$1@news.povray.org>
>> you paid for your laptop, do I?
Damn. For that price, it *should* be nice! o_O
Still... much cheaper than a Mac I guess...
Date: 14 Nov 2008 05:19:45
Message: <491d50c1$1@news.povray.org>
What would be the point though?
Date: 14 Nov 2008 06:26:29
Message: <491d6065$1@news.povray.org>
Not sure about the 7.1 sound, but being able to record and view movie clips
is pretty useful.  The point of hardware 3D acceleration is the same as for
desktop and laptop machines, it allows you to get higher quality visuals
than is possible in software without an insanely clocked CPU.  Pick up one
of the latest mobile phones, you'll see that a lot have some sort of 3D game
coming as standard (mine has 3D rally or some sort).  The graphics look like
it's running on a PC without a 3D accelerator (no texture filtering with
very low detail models).  I'm sure that will improve.
Date: 14 Nov 2008 06:42:45
Message: <491d6435$1@news.povray.org>
>>> hardware accelerated 3D in cell phones nowadays, dear. :-)
> clips is pretty useful.  The point of hardware 3D acceleration is the
> same as for desktop and laptop machines.
On a 40 mm screen? Why bother?
Date: 14 Nov 2008 07:12:38
Message: <491d6b36$1@news.povray.org>
Becuase you usually hold it way closer to your eyes than a typical desktop
monitor.
Have you seen an iPhone or the wave of similarly designed phones?  They have
480x320 pixel displays or higher, which is not so far away from what full
size computers were once upon a time.
Date: 14 Nov 2008 07:28:39
Message: <491d6ef7@news.povray.org>
> have 480x320 pixel displays or higher, which is not so far away from
> what full size computers were once upon a time.
iPhone?
That's not a phone - it's a hand-held computer with built-in GSM! :-P
Date: 14 Nov 2008 08:03:57
Message: <491d773d$1@news.povray.org>
> iPhone?
Did you look in a phone shop recently? Most phones have large high
resolution displays and are capable of far more than just phone calls.
I just got a new handset because my old one was really scratched and falling
apart.  It cost just over ?200 and has a large screen, it even has WLAN
built in!  I did look at another one that had GPS (but no WLAN) but I
decided the WLAN would be more actual use to me than GPS.  THe one with WLAN
and GPS was quite a bit more expensive and I didn't like the look of it.
