POV-Ray : Newsgroups : povray.off-topic : GRUB uglies Server Time
15 Apr 2026 00:20:22 EDT (-0400)
  GRUB uglies (Message 1 to 10 of 13)
Subject: GRUB uglies
Date: 7 Nov 2008 23:42:35
Message: <491518bb$1@news.povray.org>
OK, quick summary of below:
Got SuSE 11 x64 installed on /dev/sda2, all one big primary partition.
If I tar up all the files, zero out the partition, reformat it, and
restore the files, how do I fix GRUB so that I can chainloader to
partition 1 of disk 0 (aka /dev/sda2) and have GRUB boot?
So I have my new 64-bit computer, and I'm putting Linux (SuSE 11 x64)
and Vista on it, and I'm trying to figure out how to recover from
disaster. As in, the main drive fails and has to be replaced.
Vista makes this pretty easy. The drive ghosting works fabulously, and
you just slap the backup drive in and boot the CD and say "Here, put
that back."  If the boot sector's screwed, you can fix that too from the
recovery CD, with a bit of googling.  The file-at-a-time backup program
is really nice, except for the unacceptable glaring hole that MS put in
it, namely that it picks what file extensions it'll back up, and you
can't change that. Sheesh. Yes, really, I want to back up both PHP files
*and* executables, thanks.  Oh well.  Easy enough to script around if
you need per-file backups (assuming you can find the 64-bit versions of
some of the utilities, which was another hour of hunting, since they're
not labeled with bit size).
Anyway, on to GRUB.  I put Vista in the first partition, and Linux in
the second. Install works fine. I "dd" the boot sector off /dev/sda2 and
copy it to Vista and set up Vista to give me the choice of what to boot.
Picking Linux from Vista gives me the Grub menu. Cool.
Now I boot the Linux rescue CD, mount /dev/sda2 on /tmp/root and my
backup drive on /tmp/back, and then
   cd /tmp/root ; tar cvfzp /tmp/back/linux.tgz .
All goes well.
Now the test:  Wipe the drive to zeros, restore vista (which restores
the partition table since it isn't there), and then use the Linux rescue
  CD to do the following:
   mkfs.ext3 -L SUSE /dev/sda2
   mount /dev/sda2 /tmp/root
   cd /tmp/root
   tar xvfzp /tmp/back/linux.tgz
All the stuff restores correctly.
Now, at this point, I've been unable to get GRUB to do its thing.
grub
   device (hd0) /dev/sda
   root (hd0,1)
   setup (hd0)
This leaves me with a system that when I boot it, just says "GRUB" or
basically never gets anywhere close to the menu or booting.  Using "dd"
to put the boot sector back (from a copy on the backup drive) before or
after doesn't help either.
The partition type is indeed 0x83.
Using the repair option and telling it to repair the boot system leaves
me with a boot menu that doesn't match what I backed up, and boots me
into a text console with an apparently passworded root account. F'ing weird.
Never had this problem with SuSE 10 x86. That was very straightforward
once I figured out GRUB was hiding information outside the file system
and had to be reset. (Or, rather, that it was encoding parts of the file
system into executable files, or whatever it's doing.)
Any suggestions on what to try?
Subject: Re: GRUB uglies
Date: 8 Nov 2008 06:09:10
Message: <op.ukarxkam7bxctx@e6600.bredbandsbolaget.se>
> grub
>    root (hd0,1)
>    setup (hd0)
I think you may have to chroot into the Linux installation before setting
up GRUB if the installed version is not the same as the one on the CD.
GRUB will crap out if stage1 and stage2 are from different versions.
You did not show the contents of grub.conf, so we will just have to assume
it is correct.
It is not clear to me exactly what you are trying to accomplish. Do you
want GRUB to chain-load Vista, or do you want the Vista loader to
chain-load GRUB?
FE
Date: 8 Nov 2008 11:45:16
Message: <4915c21c$1@news.povray.org>
> setting up GRUB if the installed version is not the same as the one on
> the CD. GRUB will crap out if stage1 and stage2 are from different
> versions.
Hmmm. Fair enough. But I didn't do any updates on at least some of the
tests, so I'm assuming the two versions were the same.
> assume it is correct.
I didn't touch it, other than to copy it to a tar file and back. No
manual editing at all.
> chain-load GRUB?
I want Vista to chain-load GRUB. (More precisely, I want Vista to chain
load Linux, but LILO wasn't happy either.)  I can do it easily when I
first install Linux, but if I get into a situation with an unrecoverable
error (dead hard drive, user screw-up, etc) where I have to restore from
backups, I can't get Linux to boot again.
Having GRUB chain-load Vista would be acceptable too. If the Linux gets
screwed up, I have the tools on bootable CD to fix stuff to boot
directly into the Vista partition, so I could back up anything I hadn't
backed up there if I screw up GRUB, for example. But I need to be able
to recover from a crash that makes the partition unbootable.
Date: 8 Nov 2008 12:15:27
Message: <op.uka8v0qw7bxctx@e6600.bredbandsbolaget.se>
>> versions.
The version that gets installed from the CD might not be the same as the
one installed *on* the CD.
Personally I use grub4dos for that. That way, I do not need to change
anything on the Windows side when I update GRUB on the Linux side. Not
sure how well it works with Vista though; setting it up on XP is trivial.
Also, should you not be doing "setup (hd0,1)" if you want to chain-load
 from the Vista boot-loader?
FE
Date: 8 Nov 2008 12:22:45
Message: <4915cae5@news.povray.org>
Good point, good point. I never ran into that before, but you could be
right there.
Unless GRUB rewrites the per-sector partition, I don't need to change
anything on the Vista side either. I didn't have trouble changing, for
example, the menus, IIRC.  I'll check it out.
There's also a program called EditBCD or some such that can install a
variety of boot loaders. I was just trying to do it all with native code.
Should I?  What GRUB actually does when it sets up is still kind of
mysterious to my. I'm basing my commands on what I did when I set up a
bunch of 32-bit machines at work - after restoring the dump, the script
ran those grub commands and then it would boot. (Well, not exactly,
because it was a RAID at work, so it had to do it with two different
devices as root.)
I'll try it with setup (hd0,1) next, and with a chroot first. Thanks for
the advice!
Date: 8 Nov 2008 12:35:38
Message: <op.uka9tnk07bxctx@e6600.bredbandsbolaget.se>
Changing the config is not a problem. Updating GRUB to a newer version is.
Anytime you re-setup the GRUB boot-loader you have to update the copy you
keep on the Windows side.
> mysterious to my.
"setup (hd0)" installs GRUB to the MBR of hd0, i.e. it overwrites the
first stage of the Vista boot-loader. If you want to chain-load Linux, you
should install GRUB to the boot sector of the Linux boot partition.
FE
Date: 8 Nov 2008 12:44:51
Message: <4915d013$1@news.povray.org>
> is. Anytime you re-setup the GRUB boot-loader you have to update the
> copy you keep on the Windows side.
Yes, that I'm aware of. Fortunately easy to fix from the SuSE rescue
disk, if it updates and I don't notice.
> you should install GRUB to the boot sector of the Linux boot partition.
Mwa ha!  Very good!  Thanks!  I'll give that a try as soon as I get
stuff reinstalled. :-)
{I guess I should have put off the wipe until I got an answer. ;-)
Date: 8 Nov 2008 14:33:49
Message: <4915e99d$1@news.povray.org>
Using setup (hd0,1) seems to have done the trick. Thanks!
I can't chroot, since /tmp/root/dev doesn't seem to be set up, but that
shouldn't be much of a problem, methinks. I wouldn't think grub gets
updated incompatibly very often. :-)  Given that it's pretty trivial to
back up every file on a partition under Linux and to frob the results
off a live or rescue CD, I don't expect even a disaster where I have to
reinstall would be that much of a problem.
Thanks for the clue!
Date: 8 Nov 2008 15:00:43
Message: <4915efeb$1@news.povray.org>
> versions.
Yeah, I would concur with that - have had that experience myself.
Jim
Date: 9 Nov 2008 13:00:23
Message: <49172537@news.povray.org>
My stumbling block here is that if I use chroot, I no longer have /dev
for GRUB to write things to. If it comes to that much of a disaster,
I'll reinstall stuff and rescue things on a per-file/per-directory
basis. :-)
