Cousin Ricky <ric### [at] yahoocom> wrote:
> Next project: artifical gravity to prevent bone loss.
A rotating spaceship should be close enough.
Warp wrote:
> Cousin Ricky <ric### [at] yahoocom> wrote:>> Next project: artifical gravity to prevent bone loss.> > A rotating spaceship should be close enough.>
So how do we keep the phasers aimed at the Borg ships?
John
"Eppur si muove" - Galileo Galilei
Warp <war### [at] tagpovrayorg> wrote:
> Cousin Ricky <ric### [at] yahoocom> wrote:> > Next project: artifical gravity to prevent bone loss.>> A rotating spaceship should be close enough.>> --> - Warp
A proper spaceship would be even better.
Doctor John <joh### [at] homecom> wrote:
> Warp wrote:> > Cousin Ricky <ric### [at] yahoocom> wrote:> >> Next project: artifical gravity to prevent bone loss.> >> > A rotating spaceship should be close enough.> >> So how do we keep the phasers aimed at the Borg ships?>> John>
Keep Scotty drunk ;)
Stephen wrote:
> Doctor John <joh### [at] homecom> wrote:>> Warp wrote:>>> Cousin Ricky <ric### [at] yahoocom> wrote:>>>> Next project: artifical gravity to prevent bone loss.>>> A rotating spaceship should be close enough.>>>>> So how do we keep the phasers aimed at the Borg ships?>>>> John>>> > Keep Scotty drunk ;)> > Stephen>
Is that a hint? ;-)
John
> Stephen wrote:> > Doctor John <joh### [at] homecom> wrote:> >> Warp wrote:> >>> Cousin Ricky <ric### [at] yahoocom> wrote:> >>>> Next project: artifical gravity to prevent bone loss.> >>> A rotating spaceship should be close enough.> >>>> >> So how do we keep the phasers aimed at the Borg ships?> >>> >> John> >>> >> > Keep Scotty drunk ;)> >> > Stephen> >> Is that a hint? ;-)>> John>
Now that you mention it :)
Me
If we can have computers on tanks that are going 40MPH over terrain
rough enough to have the tank leaving the ground, firing mortars at
other tanks on the same sort of terrain several miles away and hitting
them with good accuracy, I'm pretty sure a bit of constant rotation
won't be the problem there. :-)
Doctor John wrote:
> Warp wrote:>> Cousin Ricky <ric### [at] yahoocom> wrote:>>> Next project: artifical gravity to prevent bone loss.>> A rotating spaceship should be close enough.>>> So how do we keep the phasers aimed at the Borg ships?
Multiple redundancy. If we fit enough phasers, some of them will always
be aimed at the Borg.
Darren New wrote:
> Doctor John wrote:>> So how do we keep the phasers aimed at the Borg ships?> > If we can have computers on tanks that are going 40MPH over terrain > rough enough to have the tank leaving the ground, firing mortars at > other tanks on the same sort of terrain several miles away and hitting > them with good accuracy, I'm pretty sure a bit of constant rotation > won't be the problem there. :-)
Ah, angular momentum. It makes the world go round! :-D
http://blog.orphi.me.uk/http://www.zazzle.com/MathematicalOrchid*
