POV-Ray : Newsgroups : povray.off-topic : XBOX fun (or trying not to take a hammer to my router...) Server Time
3 Nov 2026 00:50:19 EST (-0500)
  XBOX fun (or trying not to take a hammer to my router...) (Message 1 to 15 of 15)
Subject: XBOX fun (or trying not to take a hammer to my router...)
Date: 4 Nov 2008 19:09:42
Message: <4910e446$1@news.povray.org>
OK... Anyone here have an XBOX 360 and a Linksys WRT150N router, and can
tell me why the hell if fails to connect in the test phase for getting
an IP?
Note, its using WEP, not WEP2, so that's not the issue. Filtering of MAC
is on, but that isn't the issue, since the only MAC in the filter is not
the one for the XBOX. I even tried setting a static IP, and even
assigning that IP as the "default" IP for that MAC address (umm, does
the name for the computer/device need to be the same, since the XBOX
doesn't seem to ID itself and setting a default IP for the mac requires
the name too... But, the same error happened when simply setting the
address in the XBOX, *and* when leaving it on "automatic".
I get the sense this is a common, and unbelievably stupid, problem with
the 360 and wireless, from the net, but the "solutions" are things I
have either already tried, am not 100% sure how to do right, or would
have an effect (I mean, what the hell would setting it DMZ matter if it
isn't getting a fracking IP in the first place?). Or, just unbelievably
stupid, like opening my network up, including disabling encryption,
which would let any idiot that drove by have access to a network with
two other computers on it, one on 24/7...
Apparently, this problem also, often, doesn't happen with people
connecting computers via wifi, just the damn 360... I have run out of
ideas at this point, and I would hate to think I just wasted $100 on
something that won't connect me..
Note: If all else failed I could try a hard line, but that runs into two
doors. I.e., where the XBOX is, and the router, its a ceiling fan, the
door out of the room, and the door of the closet. Kind of
"inconvenient", even if I didn't just lose $100 on something that won't
work. lol
Thanks.
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Subject: Re: XBOX fun (or trying not to take a hammer to my router...)
Date: 4 Nov 2008 21:02:10
Message: <4910fea2$1@news.povray.org>
> an IP?
I just spent 3 hours running a hardwire under the carpet to mine, so I
have to assume you're talking wireless. :-)
My guess is that's the issue, depending on how you have the filter set.
If there's only one MAC address, I'm assuming it's an "allow" filter,
and you're not allowing the XBox's MAC address?
Try turning off the MAC filter to start with.
Depends on whether you're relying on your router or the ISP to serve the
DHCP?
Don't you have return policies there? :-)
> Kind of "inconvenient",
Tell me about it. My hips still ache. 30+ feet of fishtape under the
carpet. :-)
Date: 5 Nov 2008 02:46:51
Message: <49114f6b@news.povray.org>
As Darren hinted to, I would first turn off all encryption and MAC filtering
and any other special features on the router and see if you can get it to
work.  You could even try a reset of router to reset any settings that might
have been changed from the defaults.  Hopefully it will work then, and you
can gradually enable the security features and see which one messes it up.
Date: 5 Nov 2008 13:51:59
Message: <4911eb4f@news.povray.org>
>> can tell me why the hell if fails to connect in the test phase for
>> getting an IP?
>> MAC is on, but that isn't the issue, since the only MAC in the filter
>> is not the one for the XBOX.
Its in the "don't allow" filter, since someone logged in the first day I
had the thing up, and I wanted to keep them out while trying to work out
  how the encryption worked. I tried shutting it off, and it didn't do
anything, but I suppose I could try again. But, wouldn't that reject it
entirely? It does connect, it just isn't being given an IP.
>> (I mean, what the hell would setting it DMZ matter if it isn't getting
> DHCP?
Hmm. Interesting point. I think I have a permanent IP, but I am not
sure, but the router *is* using the ISP to get the DHCP. Still, this
makes no sense, since the router's own IPs not "static", they get issued
to anything trying to connect to them on an "as needed" basis. I had to
manually "reserve" two for my two networked PCs, so that any wireless
system couldn't "steal" the IP and screw up stuff like the EverQuest
emulation server, which uses a "static" IP for connecting (it won't
allow anyone to connect unless they come from the same IP they last
connected from).
Again, since its my router that need to be giving out the IP for **its**
network... I don't get why the heck the thing would be complaining it
can't get one, or the router won't provide one. Still, can look to see
if I can DMZ by MAC address...
You kidding? This is Wallmart. Most of the time the policy is, "You
opened it, you can't bring it back!" Mind, this may not be the case
here, but still, would rather fix the problem, if possible.
> carpet. :-)
Gah.. Not going to go that far, just run it "around" the doors, if I
have to. But, what a damn pain. Can't help but think that MS just fucked
the design of the XBOX software here, and the problem is some insanely
stupid setting, which normally no one ever changes... :p
void main () {
   else
Date: 5 Nov 2008 13:54:12
Message: <4911ebd4$1@news.povray.org>
> filtering and any other special features on the router and see if you
> can get it to work.  You could even try a reset of router to reset any
> settings that might have been changed from the defaults.  Hopefully it
> will work then, and you can gradually enable the security features and
Gah.. All I need, an open network with two other machines already on it,
for how ever long it takes for me to figure out that the frell the
problem is.. Note, it **can't be** the security though, since I already
got "past" that part. If it was, then it would have failed, as it was
initially doing, at step 2, not step 3. Its almost certainly something
else, some place. :p
void main () {
   else
Date: 5 Nov 2008 14:46:20
Message: <4911f80c$1@news.povray.org>
OK. Nevermind then.
I'm not sure how "connected" you are. :-)
> connected from).
OK. You're probably good there then.
> network...
Yeah.
> can't get one,
I don't know. I'm kinda stumped too. Google for "xbox" and the model
number of your router?
There are actually things in the Windows DHCP packet (in the "reserved
for proprietary use" fields) that Windows requires that others don't,
and maybe your router isn't providing them? Can you get dynamic IPs on
your other windows machines?
Really? I've never had a problem returning stuff to wal-mart. I suspect
I could bring back a half-eaten box of ice-cream and get my money back.
> have to.
Check out your fry's to find wiring that's flat and will stick to the
walls. It looks way nicer. They might or might not have it there.
Alternately, what I did (for one length of speaker wire) was go to the
hardware store and buy a roll of the stuff you use to recauck your
bathtub. It's a strip of white plastic with a crease in the middle and
glue on the underside. You can cover any wiring with it and it'll likely
look better.  Assuming your walls are close to white, that is.
Date: 5 Nov 2008 14:47:56
Message: <4911f86c$1@news.povray.org>
Remember to save the config in a file first, tho. Makes it much easier
to put back. :-)
You're doing NAT, right? That gets rid of 90% of your attack vectors.
So turn off those two machines for the 10 minutes it takes to figure out
if your XBox connects. You're not running Amazon there. :-)
Date: 5 Nov 2008 21:48:04
Message: <49125ae4@news.povray.org>
>> I don't get why the heck the thing would be complaining it can't get one,
Yeah. Think I tried that before, but maybe not. The info online seems
damn useless, and mostly amounts to "reset everything back to defaults,
and if that doesn't work, either hardline it, or buy one that does
work", which I suppose is useful for some moron that has more money than
brains.. lol
Yep. It was set up to assign them automatically *every time* they
powered on and made a request. I reserved addresses for them, so that if
one was "offline" and I connected a wireless, it wouldn't assign the IP
for that machine to the wireless and mess up the values. Note, I did try
to set a "reserved" address for the MAC of the XBOX, but it demands a
"device name" or some such, which computers have, but which is
"unassigned" in the XBOX, as near as I can tell, or.. at least it
doesn't show one when looking at the data for the wireless clients while
its partly connected (but not yet with an IP). It does get far enough
that it "shows" as a wireless client in the router though, so..
somethings just going screwy after the it starts talking.
Hmm. Maybe was thinking of someone else I got guff from.. K-Mart, I
think. Brought a movie back that wouldn't play right (stupid default
audio channel was all screwed up and only the music came through) and
got the whole, "Well, we can't give you your money back, you just have
to buy a movie with the same value to replace it", BS.
>> have to.
Think I have some black... Hmm, no, actually I think I got rid of it,
and I am not sure it was CAT5E complaint anyway. Also, the closest on of
those is several thousand miles from here. :(
Huh, interesting idea.
void main () {
   else
Date: 5 Nov 2008 21:49:41
Message: <49125b45$1@news.povray.org>
> to put back. :-)
Yeah, its on NAT. And, can't turn off the machines. The one is usually
"off", and the other one is the one I need live to be able to change
settings in the router, which makes turning it off, a bit...
problematic. lol
void main () {
   else
Date: 6 Nov 2008 00:56:43
Message: <4912871b$1@news.povray.org>
I wish I could get my router to do that, but it isn't enough of a PITA
to buy a new one. :-)
What demands the device name? The router, or the xbox?
> think.
Yes. That's why they got replaced by Wal-mart, amongst other reasons. :-)
Whichever big store you have there. :-)
Inspired by running across the stuff while looking for the tools to hang
it up right. :-)
Date: 6 Nov 2008 03:13:03
Message: <4912a70f@news.povray.org>
> for how ever long it takes for me to figure out that the frell the problem
> is..
Nobody is going to hack your xbox, especially if it's not even connected to
the network properly :-) And presumably the other PC will only be connected
for brief periods to change router settings?  If you're really paranoid,
then just make sure the firewall on the PC is fully on before you connect to
the router.
> Note, it **can't be** the security though, since I already got "past" that
> part. If it was, then it would have failed, as it was initially doing, at
> step 2, not step 3. Its almost certainly something else, some place. :p
That thing where it "connects" but doesn't get an IP, I had that happen when
the machine was not in the MAC "allow" list.  Anyway, I think the 1st step
is definitely to reset the router to its default settings, that will at
least give you some further information about the problem, whether it works
or not.
Date: 6 Nov 2008 12:39:45
Message: <49132be1$1@news.povray.org>
> an IP?
BTW, since you're going to assign a constant IP address anyway, why not
just set the XBox to have a static IP address? Can you do that with the
wireless frob? It's easy with the wired one.
Date: 6 Nov 2008 14:20:17
Message: <49134371$1@news.povray.org>
>> it, for how ever long it takes for me to figure out that the frell the
>> problem is..
> to the network properly :-) And presumably the other PC will only be
> connected for brief periods to change router settings?  If you're really
> paranoid, then just make sure the firewall on the PC is fully on before
> you connect to the router.
Well, not real worried about it, in point of fact, I just don't like
fracking with something that is working, to fix something that I,
frankly, would find "convenient", but is not at all necessary.
>> that part. If it was, then it would have failed, as it was initially
>> doing, at step 2, not step 3. Its almost certainly something else,
>> some place. :p
> when the machine was not in the MAC "allow" list.  Anyway, I think the
> 1st step is definitely to reset the router to its default settings, that
> will at least give you some further information about the problem,
> whether it works or not.
I have given up at this point. Seems that this router, for other people,
either a) doesn't give out the IP at all, due to some cheap ass design
of the damn dongle and what it does support (one person suggested buying
a cheap wireless router that will work as a transmitter, then reflash it
with firmware that turns it into a dongle, instead of a router..), or,
b) it connects, but then, no matter how good the signal is, disconnects
are random intervals, rendering it useless anyway. In all cases, it
works fine with anything ***not*** made to specifically plug into the
XBOX. lol
The only solution seems to be to wait to see if they put out a fireware
version that actually works with the dongle (not sure how you even tell,
without flashing it and trying), or just buy some far cheaper, less
advanced, and shorter range, router, which is in the "somehow these do
work" list.
And, again, its "in" the allow list, so that's not the issue. If its in
the "don't allow" this router won't even allow it to get past the
"connected" stage, it just refuses the connection completely.
void main () {
   else
Date: 6 Nov 2008 16:02:42
Message: <49135b72@news.povray.org>
> brains.. lol
Welcome to USA.
*runs like hell*
Date: 12 Nov 2008 17:25:37
Message: <491b57e1$1@news.povray.org>
<--twitches..
Wasn't the router at all. Somehow, and I can't imagine how the hell this
happens, given that I never "changed" any settings prior to trying to
set the bloody thing up, the "defaults" for something to do with access
in the XBOX isn't where messed up. Got a new issue of OXM, was fiddling
around and decided.. what they hell, as long as it doesn't wipe
"everything" to restore the factory defaults for the wireless, lets do
that. Then:
Wireless - Connected
Security step - Connected
IP step - Connected
etc.
Sat there just staring at the thing thinking, "How the fuck do you ship
someone a hard drive which has the settings for networking already
fucked up, so it won't work like this the first time?"
Now.. I got all the OXM stuff I have added up, on a non-live profile,
which isn't transferable, and which I therefor have to bloody redo (and
that includes, replaying Halo 3 on Easy and Normal, while trying to
remember how to unlock the stuff I have in it, the replaying up to where
I am in Hard, now..) Apparently, its too damn hard for them to let you
say, "This 'offline' profile is the same as the online profile, please
copy any "existing" data over, and even more idiotic, if you logged in
to try to do anything online via the web, thus making a gamer ID, you
have to "recover" it, since, despite there being a "Yes, I already have
one", option, if its not "on" your HDD already, it can't get it from the
server either, until/unless you "recover my gamer ID" (Gives you an "You
can't do that at this time" error, which is the same as what you,
apparently, get if you enter the wrong password {like that makes sense
at all})..
You can tell this idiotic stuff was written by the same morons that did
the integration of features in Windows... lol
void main () {
   else
