POV-Ray : Newsgroups : povray.off-topic : Filtering - don't bank on it... Server Time
19 Oct 2026 10:32:14 EDT (-0400)
  Filtering - don't bank on it... (Message 1 to 24 of 24)
Subject: Filtering - don't bank on it...
Date: 4 Nov 2008 10:42:48
Message: <49106d78$1@news.povray.org>
And so, I have spent an entire day constructing a filter bank.
Actually constructing a bank of filters that split a signal into several
signals is pretty easy. Getting it so that adding those signals together
actually yields the original signal has taken me *an entire day* to day
right.
For the longest time, the wave kept coming out somewhat out-of-phase
with the original. Eventually I figured out that that's because I need
to shift the input signal in relation to the filter kernel (thus making
it technically non-causal).
And then the signal still doesn't "quite" match the original, especially
at low frequencies. A added another channel for very low frequencies,
and now the signals match in shape, but not quite in amplitude.
Another hour spent fiddling with scaling factors, and I discover that if
the 1x and 2x channels are set to half the amplitude of all the other
channels, I get a crisp, perfect signal match. Yay, me!! :-D
...Further testing reveals that while the filter bank does split the
signal into different parts, and adding them back together exactly
reproduces the original signal, each channel actually contains a fairly
wide collection of frequencies. For example, the 64x channel still
contains entirely too many high frequencies.
Damnit! >_<
I hypothesize that this is due to spectural leakage caused by the
rectangular window over the filter kernels. Maybe with a Blackman window
or something I can get channels that actually contain only certain
frequencies.
Hmm, and how much do you want to bet that as soon as I change the
details of my filter bank, the signal reconstruction will stop working
again?
I can't help feeling that somebody somewhere has already figured all
this stuff out, and if I could just get my hands on that information,
all of this stuff would suddenly seem a whole lot easier... :-(
Subject: Re: Filtering - don't bank on it...
Date: 4 Nov 2008 11:38:20
Message: <49107a7c$1@news.povray.org>
Remember when "don't bank on it" actually meant something? :-)
Date: 4 Nov 2008 12:04:02
Message: <49108082@news.povray.org>
> right.
> Damnit! >_<
> frequencies.
> again?
  Sorry for quoting the entire long post, but I find it rather amusing
that this amount of text doesn't really tell exactly *what* you are doing.
  The only thing the text refers to is some completely unspecified "signal",
as well as a completely unspecified "wave".
  What "signal"? Radio signal? TV signal? Sound signal? Video signal?
Something completely different? What is the source of this signal? What
is it that you are trying to do with this "filter" you are applying to this
"signal"? What is the point of your post anyways?
Date: 4 Nov 2008 12:35:01
Message: <web.491086eff3d32ffd6117f2130@news.povray.org>
> > And so,
Why are we here? What is the meaning of 42?
Message: <web.49108721f3d32ffd6117f2130@news.povray.org>
LOL
Date: 4 Nov 2008 14:13:57
Message: <49109ef5$1@news.povray.org>
I want to split a sound signal into several frequency bands.
Actually, technically I *have* split a sound signal into several
frequency bands... but not in a very useful way. In particular, the
lowest frequency band still contains large amounts of high frequencies.
It's really frustrating to have worked this long on something and not
got very far. I should probably go read a book or something...
http://blog.orphi.me.uk/
Date: 4 Nov 2008 14:17:51
Message: <49109fdf@news.povray.org>
Stephen wrote:
> Why are we here?
We're bored?
Would it be wrong to reply "4 * 10^2 + 2 * 10^2"? ;-)
Date: 4 Nov 2008 14:18:19
Message: <49109ffb@news.povray.org>
Yes... yes it would... PWN3D! >_<
Date: 4 Nov 2008 14:31:01
Message: <4910a2f4@news.povray.org>
  Why?
  (Btw, did you know that even if a sound signal has only one single
frequency, a discrete fourier transform is usually completely unable
to find that single frequency, and instead will find a large (potentially
infinite) amount of frequencies around that real frequency?)
Date: 4 Nov 2008 14:50:30
Message: <4910a786$1@news.povray.org>
>   Why?
I think you just answered the question, right there. :-)
No, in seriousness... I'm playing around with designing an audio codec.
Most of the ones I've seen are based on chopping the signal into bits,
taking some kind of Fourier-related transform, selectively removing some
of the data, and then trying to hide the discontinuities between
segments. My plan is to seperate a signal into several continuous
signals, and process those.
Date: 4 Nov 2008 15:25:18
Message: <4910B003.5020407@hotmail.com>
Why?
Remember Westheimer's Discovery: A couple of months in the laboratory
can frequently save a couple of hours in the library
Date: 5 Nov 2008 02:51:38
Message: <4911508a@news.povray.org>
Would help if I actually wrote something before posting... ;-)
Don't worry about the phase of the signals then, your ears don't care.  In
hardware filters the phase is rarely preserved, and actually often varies as
a function of frequency.  Just make sure the phase shift is the same for the
Left and Right channels, otherwise you might mess up some stereo effect.
Date: 5 Nov 2008 02:56:55
Message: <491151c7$1@news.povray.org>
It just depends how many samples you use for your fourier transform, the
more samples you take, the more accurately you can divide up the frequency
spectrum.  If you have a couple of seconds of normal audio recording (so
like 100k samples), you should be able to find a single frequency pretty
accurately, certainly to within 1 Hz.
Date: 5 Nov 2008 04:16:11
Message: <4911645b$1@news.povray.org>
> In hardware filters the phase is rarely preserved, and actually often
> varies as a function of frequency.  Just make sure the phase shift is
> the same for the Left and Right channels, otherwise you might mess up
> some stereo effect.
More significantly, if the same frequency is present in more than one
channel, phase will matter. (I still need to add the channels back
together again and end up with the same signal as before, which won't
happen if phase differences cause spurious boosting/cutting.)
Besides, in a digital FIR filter, it's trivial to make the filter
zero-phase.
Date: 5 Nov 2008 12:23:53
Message: <4911d6a8@news.povray.org>
  If the actual frequency falls in between two frequencies of the DFT,
there's no way for the DFT to produce just one or a few lines. Only if
the frequency happens to be exactly on one of the frequencies sampled
by the DFT, it will generate one single line.
Date: 5 Nov 2008 14:39:01
Message: <4911f655$1@news.povray.org>
I think phase matters for mentally positioning the source of a sound,
too. I'm pretty sure that's one of the ways they make those "surround
sound headphones" and those "sounds like you're there" recordings.
Date: 5 Nov 2008 14:43:27
Message: <4911f75f@news.povray.org>
Oh, sure. But if you want that level of sound clarity, you're using
lossy audio compression...why? ;-)
Date: 5 Nov 2008 14:56:16
Message: <4911fa60$1@news.povray.org>
Just saying....
Date: 5 Nov 2008 23:56:49
Message: <49127911$1@news.povray.org>
On Tue, 04 Nov 2008 19:17:50 +0000, Orchid XP v8 wrote:
> Stephen wrote:
>> Why are we here?
> We're bored?
Yes, because you've just described the number 600. ;-)
Jim
Date: 6 Nov 2008 03:34:13
Message: <4912ac05@news.povray.org>
Of course there is, try it.  If you create a frequency that is half-way
between two frequencies in the DFT, your DFT histogram will still look the
same shape, the peak will just be shared between the two frequencies.
And of course if you analyse the DFT properly (ie not just look at a picture
of the magnitude of each result) you will be able to determine the exact
frequency.  I mean in the worst case you can just do an inverse DFT to get
back the exact same signal!
Date: 6 Nov 2008 07:32:49
Message: <4912e3f1@news.povray.org>
> frequency spectrum.  If you have a couple of seconds of normal audio
> recording (so like 100k samples), you should be able to find a single
> frequency pretty accurately, certainly to within 1 Hz.
IIRC, there's a version of the Fourier transform from a discrete time
domain to a continuous frequency domain. Anybody know details?
Date: 6 Nov 2008 09:15:36
Message: <4912fc08@news.povray.org>
  The same shape as what?
  Basically you are saying that you can recreate a sine wave (which is one
single frequency) with the sum of two sine waves (the two frequencies in
the discrete frequency spectrum)? Not only that, but the two sine waves
in question are adjacent to each other in the discrete frequency spectrum?
  I would be interested in seeing some simple math about this.
Date: 6 Nov 2008 09:19:02
Message: <4912fcd6$1@news.povray.org>
>> the
As a frequency that is exactly lined up with one of the bands of the DFT.
No, I am saying that given a finite DFT transform result with more than one
non-zero entry, if you perform the inverse DFT you will recreate a single
frequency sine wave.
Date: 6 Nov 2008 09:20:25
Message: <4912fd29$1@news.povray.org>
   sin x + sin y = 2 cos (x-y)/2 sin (x+y)/2
If we replace x and y with jt and kt, we have
   sin jt + sin kt = 2 cos t(j-k)/2 sin t(j+k)/2
If j and k are very close, (j-k)/2 would be nearly zero, so the cos term
would be nearly unity. Then we would have just
   sin jt + sin kt = 2 sin t(j+k)/2
In other words, a sine wave who's frequency is the arithmetic mean of
the frequences of the two waves being added. QED.
