POV-Ray : Newsgroups : povray.off-topic : Processor speed Server Time
19 Oct 2026 10:32:11 EDT (-0400)
  Processor speed (Message 1 to 23 of 23)
Subject: Processor speed
Date: 28 Oct 2008 09:47:32
Message: <490717f4@news.povray.org>
Is integer addition faster or slower than floating-point addition? How
about multiplication? How do trigonometric functions compare? Is single
precision any faster than double precision? Are 8-bit integers faster
than 16-bit integers?
Does anybody know of a resource where I can get an idea of the relative
difference in speed between the various arithmetic operations on
different data types on "typical" current-generation CPUs?
Subject: Re: Processor speed
Date: 28 Oct 2008 10:10:03
Message: <web.49071c8c55b618d81ccf29180@news.povray.org>
Have a look here:
http://siyobik.info/index.php?module=x86
I suppose the latency times at the end of the page show how many instruction
cycles the CPU needs for the instruction
Date: 28 Oct 2008 10:30:01
Message: <web.490720cf55b618d81ccf29180@news.povray.org>
Just found this:
http://software.intel.com/en-us/articles/instruction-latencies-in-assembly-code-for-64-bit-intel-architecture
and this:
http://swox.com/doc/x86-timing.pdf
Date: 28 Oct 2008 13:25:04
Message: <49074aef@news.povray.org>
  Impossible to say. It depends on the processor type, the integrity of
the pipelines, the combination of instructions, and tons of other things.
  It also depends on what you are doing. If you are loading the values of
two variables into the FPU, calculating the addition, and then storing the
result into a variable, then that's definitely slower than integer addition
because the loads and stores consume a lot more clock cycles for the FPU.
  If you are measuring purely the clock cycles taken by one single addition,
disregarding everything else, then they are probably equally fast (although
with modern Intel/AMD processors I cannot even say that for sure, as they
have microcodes which take fractions of a clock cycle and weirdness like
that).
> How about multiplication?
  It depends on the processor. Some processors have 1-clock-cycle FPU
multiplication, while others don't. Some have special circuitry for
calculating CPU register multiplication in 1 clock cycle, others have
a small fraction of that circuitry which calculates it in 2 or a few
clock cycles, and yet others calculate it with the FPU (which curiously
makes integer multiplication slower than floating point multiplication).
  What do you think?
> Is single precision any faster than double precision?
  Only if we measure with the pipeline and cache capacity requirements.
> Are 8-bit integers faster than 16-bit integers?
Date: 28 Oct 2008 15:28:55
Message: <490767f7@news.povray.org>
> that).
Interesting. I have always heard that floating-point arithmetic is much
slower than integer arithmetic. (That's why they invented the FPU, but
it's still slower.) So you're saying they're actually roughly the same
speed now?
 From one table I saw, integer multiplication is significantly slower
than integer addition, and integer division is markedly slower again. I
don't know if the same holds for floating-point though, or how fast/slow
floating-point arithmetic is compared to integer arithmetic in general.
>   What do you think?
I think they're slower, but how much? 2x slower? 20,000x slower? I have
no idea.
OK, cool. So basically there is no way I can tell whether implementing
an algorithm one way or the other will yield the best speed. Yay, me. :-/
http://blog.orphi.me.uk/
Date: 28 Oct 2008 15:31:47
Message: <490768a3@news.povray.org>
It won't tell you everything about the speed of the final program, but I
can't imagine it'd be hard to write some test programs and then time
them to determine some of these answers for yourself.
Date: 28 Oct 2008 15:34:04
Message: <4907692c@news.povray.org>
I guess I'm still used to the Old Days of computing, when the speed of
the CPU was the primary bottleneck. Of course, these days the memory
subsystem is the primary bottleneck - to the point where algorithms
which are "less efficient" on paper can actually run faster in reality
if they have superior cache behaviour.
Obviously, cache behaviour is something I have absolutely no control
over, so there's no point worrying about it.
Date: 28 Oct 2008 15:36:26
Message: <490769ba@news.povray.org>
Not only that, but modern processors can get a significant speed boost
based on the order of instructions presented. e.g. if you have 2
instructions, one dependent on the previous, it's entirely possible to
move an instruction between those two to take advantage of the
processor's pipelining. But, then you have to know what instructions
each pipeline can handle, and those 2 instructions cannot share any
resources. e.g. You may have something like:
(my x86 assembler is a bit rough so my syntax may be off.)
mov ecx, 10h
add ecx, ah
mov ebx, [var1]
add ebx, 16
The above could be rearranged to give better performance:
mov ecx, 10h    ; p1
mov ebx, [var1] ; p2
add ecx, ah     ; p1
add ebx, 16     ; p2
~Mike
Date: 28 Oct 2008 15:41:54
Message: <49076b02$1@news.povray.org>
Not entirely true; If you want good speed I think it's worth trying to
code things so all the necessary memory will fit within your cache.  Of
course this will put a limit on the size of problem you can solve
without slowing things down a bit.  I'm sure that someone like Warp
could give you more detailed pointers, although if you're doing this in
haskell it may not lend itself to this sort of optimization as well as,
say, C++.
Date: 28 Oct 2008 15:50:10
Message: <49076cf2$1@news.povray.org>
> Not entirely true;
Well, no. You can use large arrays and access them in a specific order
in an attempt to improve cache coherancy. But beyond that, in a GC
language where the runtime randomly allocates and rearranges data in RAM
from time to time, you really have very little control.
Date: 28 Oct 2008 16:24:10
Message: <490774ea$1@news.povray.org>
>>> implementing an algorithm one way or the other will yield the best
>>> speed. Yay, me. :-/
>> I can't imagine it'd be hard to write some test programs and then time
Depends on what language you are using.
Even today some programs are written to use only internal registers -
only using external memory when absolutely necessary.
Also, depending on what processing unit you are using it could be faster
to count down to zero than up to a given number - based on the machine
instructions available and the time cost of each instruction.
When you get into high level languages you are going to lose some
efficiency in execution because the focus starts towards ease of actual
programming vs execution efficiency.
You get to a point where the program just runs and the compiler gives
little care to optimizing the execution speed.  It's easier to program,
but at a cost.
Tom
Date: 28 Oct 2008 19:13:15
Message: <49079c8b@news.povray.org>
  Intel processors have reordered instructions automatically since the
Pentium Pro (AFAIR).
Date: 28 Oct 2008 19:24:29
Message: <49079f2d@news.povray.org>
  An FPU addition has taken 1 clock cycle since probably the 486 (the
version which had the integrated FPU), or at most the Pentium.
  The first Intel processor to have a 1-clock-cycle FPU multiplication
was, if I remember correctly, the Pentium. (You can believe this requires
a rather large percentage of the entire area of the microchip.)
  Of course the Pentium was not the first processor to have a 1-clock-cycle
floating point multiplication. Many RISC processors had that probably 10
years earlier. It's old technology.
  Division is much more complicated than multiplication, which is why
it has always taken (and will most probably always take) quite many clock
cycles to compute.
  Of course the actual throughput of the FPU in most programs is slower
than that because of all the data which has to be transferred between the
memory and the FPU. You can write specialized code (usually in ASM) which
takes full advantage of the FPU by calculating as much as possible without
having to constantly load and store the values from/to memory, but compilers
are not even today very good at making this kind of optimization. If you
examine the assembler output of a compiler, you will usually notice that
it loads and stores FPU registers *a alot*, often more than would be
necessary.
  This may be one of the reason why XMM, SSE and other SIMD chips have
been developed, ie. so that with a new protocol it would be possible to
write code which utilizes the auxiliary chip better.
> So you're saying they're actually roughly the same speed now?
  When counting in clock cycles they have been about the same speed since
the 486. The FPU is just a bit hindered by a more complicated data transfer
between the memory and the FPU.
Date: 28 Oct 2008 19:27:34
Message: <49079fe6@news.povray.org>
  If the GC'd language doesn't reorder elements in memory to be more
cache-friendly, that can have a rather large penalty in speed.
  The speed difference between cache-friendly and cache-unfriendly code
can be surprisingly large, even if both do the exact same thing otherwise.
We are talking about something of an order of magnitude slower at worst.
Cache misses are *very* expensive.
Date: 28 Oct 2008 19:52:02
Message: <4907a5a2$1@news.povray.org>
I think getting the compiler to do this was one of the basic ideas
behind RISC, until they figured out that it meant you had to recompile
your source code for every minor rev of your CPU. :-) I even remember
that the compiler was supposed to know how long instructions took, so
you didn't have any hardware to wait for an instruction to complete
before you started using its results.
A lot of the RISC stuff that sounded real cool actually turned out to be
a bad idea if you wanted to run the same code on multiple compatible CPUs.
Hmmmm... I've never heard of that. I wonder how easy it is to figure out
how to arrange things (based on compile-time or run-time information
rather than intuitive understanding of the algorithm) to make cache
misses mless common.
Date: 28 Oct 2008 20:29:08
Message: <4907ae54@news.povray.org>
  I would say that in the general case it's extremely difficult. It could
be rather easy in simple cases, though.
  For example, if you are eg. traversing a list from the beginning to the
end, and doing that a lot of times, then if the list elements are in
sequential order in memory (and one right after the other), it will be
much more cache-friendly than if the elements are located randomly in
memory. Theoretically a compiler could perhaps be able to optimize such
lists (even if it means reordering memory blocks for that to be possible,
as memory fragmentation can naturally cause list elements to be scattered
randomly in memory).
  The absolute worst case scenario would be that the list is so large that
it does not fit entirely in the cache, the elements are scattered randomly
in memory, far apart from each other (they don't even have to be a lot
apart from each other; I don't remember how large a typical cache block
is, but it was something like 32 bytes or so), and the list is traversed
several times. This causes each single list element access to cause a
cache miss, which makes it really slow.
  Sometimes you could make your program faster by simply doing things a
bit differently. For example, if you are running an algorithm on a list
several times, and the algorithm doesn't actually require you to traverse
the list completely in order to get partial results, you could run the
algorithm on only a part of the list the necessary number of times, after
which you run it on the next part of the list, etc. If the size of the
partial list is small enough, all of its elements will fit in the cache
and the subsequent passes will become a lot faster. This should be so
even if all the list elements are scattered randomly in memory (it causes
the first traversal of the partial list to be slow, but subsequent
traversals should be fast because all the elements will be in the cache).
Date: 29 Oct 2008 05:13:48
Message: <4908294c$1@news.povray.org>
I'm told there are special processor intructions for accessing memory
locations where you "know" that the data will only be read once, so
there's no point attempting to cache it. This way you can save the cache
for stuff that *will* be accessed multiple times.
Of course, unless you're programming in assembly, this isn't much help.
This is the kind of thing that Haskell does to you automatically. Of
course, Haskell "lists" are linked lists, scattered over all of the heap
(and periodically moving around). I don't know much about how CPU caches
work, but I imagine having the data scattered over several memory pages
isn't very cache-friendly.
Date: 29 Oct 2008 13:19:34
Message: <49089b26$1@news.povray.org>
Or if your compiler is smart enough. For example, C's memset(), which
just assigns a specific value to a range of locations (say, to zero out
an array) can often be coded to use instructions that say "I'm going to
clobber this whole cache line, so don't read it."  I guess that counts
as writing in assembly if you consider the authors of the routine, but
you don't need to do that to use it.
I don't think it's a matter of being spread over several pages, but a
matter of having small pieces (much smaller than a cache line) being
randomly accessed.
I.e., when you read xyz[37] as an integer in C (that's the 38'th element
of the array of integers), the cache may pull in
xyz[35],xyz[36],...,xyz[39] in one memory cycle. If you're walking
sequentially through the array, this is helpful. If you're jumping all
over, this isn't helpful (altho maybe not harmful, depending on what
your access just replaces).  If you're using linked lists, even going
sequentially will cause the cache accesses to be unhelpful, because
xyz[37] isn't next to xyz[38].
Date: 31 Oct 2008 04:52:44
Message: <490ac75c@news.povray.org>
Darren New wrote:
>> I don't know much about how CPU caches work, but I imagine having the
>> data scattered over several memory pages isn't very cache-friendly.
> randomly accessed.
How wide is a typical cache line?
IIRC, a Haskell linked list node is 3 pointers wide.
Although, if they happen to be allocated sequentially, they might
possibly be...
Date: 31 Oct 2008 13:50:03
Message: <490b454b$1@news.povray.org>
Warp said 32 bytes. I thought that was way smaller than I remembered,
but I went and variously tracked it down, and indeed, most of the modern
machines seem to have 32-byte cache lines.  I think they used to be
wider, like 128 bytes, but maybe I'm misremembering, or thinking of
mainframes, or something.
Date: 31 Oct 2008 14:21:34
Message: <490b4cae$1@news.povray.org>
Right. So just to make sure I understand this... you're saying the cache
is managed in chunks of 32 bytes at a time? Like, if you fetch 1 byte of
data from memory, 32 bytes will be loaded into the least recently used
cache line? (Or whatever the cache policy is.)
Are the cache lines aligned in any sort of way? (I'm wondering if it
grabs 32 bytes at the nearest 32-byte boundary or not.)
Date: 31 Oct 2008 15:59:14
Message: <490b6392$1@news.povray.org>
That's how I understand it. I believe it's more accurate to say that the
bus between the memory and the registers is actually 32-bytes wide. I
may be mistaken in that, tho.
I'm also pretty certain it is on 32-byte boundaries. Otherwise, the
addressing logic winds up being slower than the time you save caching stuff.
Date: 31 Oct 2008 17:55:04
Message: <490b7eb8@news.povray.org>
  You should read this article series if you want to know everything there
is to know about memory and cache:
http://lwn.net/Articles/250967/
