Hi there!
I've become a lurker in these forums lately, I know. Too much personal
stuff going on thats keeping me from being creative or from getting the
time to create the images, much less show them off (can't scream
everything private into the public, can I?).
Anyways, I'm currently pondering two rather technical issues concerning
data storage.
1. I'm suspecting my HD in my PC to fry soon. It's making weird noises,
needs time spinning up and is getting way too loud for its own good.
It's SATA and the connection-slot looks shot, the connections on the HD
lay bare when removing the cable, so I'm not even sure if the data gets
sent there properly.
Now, before you scream: "Do your backup!" - it's sitting in a Raid 1
configuration, so if that specific HD dies, I'll still have one with the
data.
However, I'm thinking of switching the expected faulty one with a
different one, which would be bigger in storage capacity. I know that
I'd lose the extra storage when I just mirror the smaller HD onto the
bigger one, but I'm thinking about just buying two bigger ones, first
mirror the smaller onto the bigger, then put the second big one into the
raid and mirror them yet again, THEN arrange new partitions on the now
unused bigger space. Anybody have a clue if that's going to work? I'd
rather not reinstall my entire PC.
2. My dad's PC (or better, its motherboard) fried itself recently and
since then he's got troubles keeping track of all his data. He's got a
PC at his office, one at home, and two laptops he's working with. You
might think no one should need that many computers, and I agree, but
that's how things turned out for him at work and due to software
licensing issues.
Anyways, he's starting to lose track of all the backups and versions of
work he's doing on various PCs and I was wondering if anyone knows of a
good, reliable software, which might just require an external HD to keep
a specific folder (or various thereof) synchronized across multiple
computers? My ideal would be something he'd install on any computer he'd
need, and then just plug the external HD in, it'll synchronise the
computer with the HD, and when he leaves the PC, he'll just synchronise
again and take the HD along. All he'd need to do every now and then is
backup the external HD and he'd have a lot less trouble keeping his
stuff uptodate and backed up.
Any ideas or suggestions?
Tim
The way I moved to a larger disk was to use DriveXML (a free
backup/restore/mirror program) to copy the small drive onto the larger
drive, then swapped out the small drive for the second big drive and
mirrored it back again.
If you're doing RAID, you'd use the RAID for that second step, of course.
Assuming you're talking Windows again...
Google for "synctoy powertools." Alternately, that's what the
"briefcase" icon is supposed to do for you, but I never got it to work
right. Maybe I just didn't understand it. The "briefcase" would be your HD.
http://technet.microsoft.com/en-us/magazine/cc162483.aspx
http://www.microsoft.com/downloads/details.aspx?familyid=C26EFA36-98E0-4EE9-A7C5-98D0592D8C52&displaylang=en
Alternately, google for jungledisk. This lets you put your encrypted
files up on Amazon's servers, and keeps them synchronized automatically
in the background. You could edit them right in that virtual drive, and
when you save it, it pushes them up in the background. I'm pretty sure
it works to map the same files to multiple machines, but you'd want to
double-check that first. Then you're not even lugging around a HD.
Have you considered what happens to your data if you lose the HD? Is
there anything on there of enough value that you're screwed if it gets
stolen? A NOC list, perhaps?
HTH.
Oh, just as a bit more detail here, DriveXML is the only backup program
I've found for free that will actually back up and restore the registry
properly. The XP backup program has restrictions that keep it from
actually working. Vista's works, tho, interestingly enough - you can
actually restore a full backup from a USB drive and have it work.
Darren New wrote:
> Tim Nikias wrote:
>> Anybody have a clue if that's going to work? I'd rather not reinstall
>> my entire PC.
Well, if I'd just exchange one HD with the bigger one, my Raid
controller would exclaim that the Raid broke and would offer me to
mirror the functional (small) HD onto the new, bigger and empty one.
That's what Raid 1 is supposed to do.
Then, I exchange the functional small HD, in effect letting the
controller believe that, yet again, one HD failed, and mirrors the first
HD onto the second.
Voila! 250GB worth of Data mirrored onto 500GB.
Final step: Just partition the remaining, unused 250GB. The controller
is a hardware one and acts as if only one HD is attached to the PC, so
in theory, that should work.
But I'll look into that tomorrow, I guess. :-)
>> My ideal would be something he'd install on any computer he'd need,
>> and then just plug the external HD in, it'll synchronise the computer
>> with the HD, and when he leaves the PC, he'll just synchronise again
I'll look into that tomorrow as well, got to get to work now. But a
server-side thingy is out of the question, my dad doesn't want to need
the internet for that.
Theft is a thing I should keep in mind, thanks for pointing that out.
Tim
> computers?
AllwaySync works really great. It cannot be confused by differing system
clocks or when files are edited at multiple locations before syncing.
There is a free version for testing purposes or personal low-volume
usage (up to 20.000 files in 30 days). The Pro versions are affordable,
too. There is a Version ('n' Go) which can be installed on the usb drive
and runs without further installing directly from there on any (Windows)
PC (Haven't tried that one myself, but the standard version [which is
for installation on one PC] works very well).
Manuel
Sure, I understand. I thought you'd wanted to actually have a bigger
file system when you were done, tho, rather than just a new empty partition.
OK. Check out synctoy. It works really nicely. I use it for keeping the
backup of my vacation photos and music library synced between backup
disks, my desktop, and my media server.
Yeah. Unfortunately, I don't think it's going to be easy to keep
everything encrypted with the native encryption stuff if you have
different logins at work and at home. At least in XP, you can't set a
folder to automatically encrypt for someone else when you create a file.
(I.e., you manually have to add the second key to every file one at a
time - rather stupidly suckful.) Unless perhaps he puts an escrow key
on and encrypts everything to the escrow key, and he copies that key to
all his machines. I don't know if you can put the key from one user as
the primary key for another user, so everyone is using the same key. If
so, problem solved once it's set up. Just encrypt the whole drive.
> HD onto the second.
I would expect the results that you just posted - that after swapping
all of the drives you would still have a 250GB mirror and the other
250GB is unused.
If you were using purely software RAID you would likely be able to do
what you want - depending on the OS.
But hardware or firmware RAID - I think you might run into trouble.
In my experience most RAID controllers will allow only 1 RAID partition
on which you can create your normal partitions - like you have now.
forgive the format
the OS sees the marked parts
A normal drive may be set up like this - forgive the format
<drive><part><data></data></part><part><data></data></part></drive>
A hardware raid setup may look like this
<drive><RAID><part><data></data></part><part><data></data></part></RAID></drive>
your situation may very well be this
<drive><RAID><part><data></data></part></RAID><space>250GB</space></drive>
Unless your RAID controller is designed specifically to do so, it cannot
expand the RAID to the entire drive - nor can it create a second RAID
section at the end of the drive.
You may be able to get it to work using Linux, but that can take a lot
of time only to find that it didn't work. Running NTFS may complicate
this to being non feasible. At any rate, the effort to do this may be
more than reinstalling the OS.
Just in case you want to try, here's a rough outline - it's Linux heavy.
It's unproven in this context, but I use something very similar to keep
expanding our linux server storage with limited drive bays, controllers
and resources.
Set up one 500GB drive as a RAID 1 drive (the entire space)
Run the other 500GB drive as is (250GB data, 250GB space)
Run Linux and be able to see and work with both drives.
Setup a partition on the entire 500GB array.
Get logical volumes running.
set up the 250GB partition as a LV.
Add the 500GB space to the LV.
tell LV to stop using the 250GB patition.
it will mirror all data to the 500 GB partition.
expand the filesystem - GParted works nice.
try it out
if it works, try *rebuilding* the 500GB array.
Again, with Windows and NTFS, this may be near impossible as linux and
NTFS are not best of friends.
Your controller may offer more than one RAID partition per HD, but I've
found that this usually is a special feature that a few controllers
offer - and when it is offered, it is advertised.
In fact, the only RAID controllers that I have run across have been
Intel's ICH series that offer Matrix storage - but I have not done a
search for the feature, only run across it while building a new PC.
This is a nice feature and I currently have it in use - I have 2 HDs -
one part is RAID1 for protection - another is RAID0 for mass storage of
junk.
Best of luck!
Tom
I'm not sure why (regardless of OS) you wouldn't just break the raid,
install the new disk, partition it large, copy the files over, then put
in the other big disk and mirror it out again. If anything goes wrong,
you have the original drive you broke off the RAID to start over with.
In both Linux and Windows, it's easy to copy all the files from a
smaller partition to a larger partition without a problem. Why make it
difficult by trying to use RAID hardware to copy files? Especially since
you'll wind up waiting for it to copy free space and everything.
If the setup can take a simple copy, that would work and save a lot of time.
But if the system cannot take a simple copy, it is an alternative.
> time.
Aside of a few troubles with how the software tells what it's doing (I
mirrored the old drive onto the new one to find that it didn't rebuild
the Raid 1, so I had to copy all over again when I said to rebuil), it
worked flawlessly:
1. Exchange first faulty HD with bigger one
2. Mirror small drive onto big one
3. Exchange second faulty small HD with bigger one
4. Mirror from big to big
5. Use Windows to partition the new 230GB worth of space
No troubles with the controller figuring that out. :-)
Tim
aka "Tim Nikias"
Tim Nikias wrote:
>> time.
> worked flawlessly:
> Regards,
> Tim
Excellent!
Just in case I need to look up a good RAID controller in the future,
what are you using?
thanks,
Tom
Tom Austin wrote:
> Tim Nikias wrote:
>>> of time.
>> worked flawlessly:
>> Regards,
>> Tim
> Excellent!
> what are you using?
It's an ULI Raid Controller which is integrated into the motherboard,
which is an Asus A8R32-MVP Deluxe. It's a few years old, when I switched
from Single Core to Dual Core and exchanged the old PC which had a
harddrive crash, which taught me the hard way of "better back up". ;-)
At the time I was told that hardware Raid controller are better than
software based, because there's no load on the processing OS, I'm not
sure if that has changed, but so far, it didn't fail and kept my data safe.
Tim
aka "Tim Nikias"
Tim Nikias wrote:
> Tom Austin wrote:
>> Tim Nikias wrote:
>>>> of time.
>>> (I mirrored the old drive onto the new one to find that it didn't
>>> rebuild the Raid 1, so I had to copy all over again when I said to
>>> rebuil), it worked flawlessly:
>>> Regards,
>>> Tim
>> Excellent!
>> what are you using?
When possible, I go hardware as well - but the cost can be a determining
factor.
I don't mind software RAID, but I've found they are a bit more touchy
when it comes to OS working smoothly with them (windows and linux).
When I have a true RAID setup I like to see 1 HD, not 3 (each physical,
then 1 that is the RAID set).
I'm glad that your upgrade went smoothly. I've found that the waters
are not usually so clear :-)
Thanks for the info about the RAID controller, I'll keep it in mind.
LAter... Tom
One advantage of a software RAID is that your OS will tell you when it
breaks. I never figured out, for example, how to get the Dell hardware
raid to actually tell me (under Linux) when one of the drives had
failed. Hence, it wasn't a whole lot of use, and I opened it up and used
the Linux software RAID instead.
Mine tells me during boot-up. Usually it just flashes the RAID Stats for
one or two seconds (how many HDs were detected and in which kind of
RAID), leaving me little time to hit Ctrl+A to enter the setup, but when
a harddrive is faulty, or it finds the RAID to be compromised (happened
once during a system crash, data didn't arrive at both HDs), it'll wait
longer, something between 5 and 10 seconds, enough to realize it's not
functional.
Since it didn't occur in any other manner to me (HD didn't switch back
on during boot, or the system crash), I wouldn't know if it could tell
me something of that sort WHILE the system is running.
Tim
aka "Tim Nikias"
Are they hot-swap drives? Pull one out and see. :-)
In any case, most of the machines I had RAID on were in another city, so
even if I rebooted them regularly, I'd not see anymessages. I need a
page, not a screen message.
That is a problem - that each RAID system needs it's own unique drivers
- windows or linux.
And of course - when you have the OS create/manage RAID you will have
access to information without special drivers.
I like hardware RAID because of the transparency it can offer - it can
appear as just 1 HD with no special OS functionality.
But it is because of this transparency that you need drivers to view the
status of the array.
I guess it depends on what one if after and needs.
Tom
Well, on Linux, a RAID puts multiple block devices representing disks
together and the resulting redundant array is shown as another block
device. Which may be mounted if it has a file system :)
Among other things, you can easily make a RAID of RAIDs.
One of the benefits is that it can work with any file system. One of the
drawbacks is it doesn't know about unused space. Put a terabyte RAID1
together and prepare to spend several hours waiting for the almost-empty
disks to rebuild.
