POV-Ray : Newsgroups : povray.off-topic : Too many pipes? Server Time
19 Oct 2026 10:31:27 EDT (-0400)
  Too many pipes? (Message 1 to 50 of 51)
Goto Latest 50 Messages Next 1 Messages >>>
Subject: Too many pipes?
Date: 21 Oct 2008 07:10:27
Message: <48fdb8a3@news.povray.org>
Thus far, I have had two seperate dreams involving pipe organs. While I
was learning about organ terminology, I had a dream about playing a pipe
organ. When I started learning about the stop names, I had a second
dream in which I accidentally killed 3 people by choosing a powerful stop.
I just read that the speed of sound in air is around 340 m/s, and that
an open pipe contains 1/2 of a wave while a stopped pipe contains 1/4 of
a wave. (Not forgetting the end corrections due to the stationary air
outside the pipe.) And also that long thin pipes have more harmonics
than short wide pipes.
All of this has pretty much inevitably ended with... the wave equation.
Yah.
So apparently the wave equation tells us that the 2nd derivative of some
physical quanitity "u" with respect to time is equal to the square of
the wave propogation constant multiplied by the Laplacian of "u".
...which would probably mean something if I could figure out what a
Laplacian is! :-S
According to Wikipedia, the Laplacian of u is the sum of all partial 2nd
derivatives of u with respect to every coordinate axis.
...so...the total curvature then? ._.
Subject: Re: Too many pipes?
Date: 21 Oct 2008 07:19:38
Message: <48fdbaca@news.povray.org>
Hehe, I so knew that was coming.
> physical quanitity "u" with respect to time is equal to the square of the
> Laplacian is! :-S
Pretty much yeh - the wave equation basically says that the 2nd differential
in time is proportional to the 2nd differential in space.  Obviously the 2nd
differential in "space" depends on how many dimensions you are working in,
but you more or less just sum up the 2nd differential in each dimension.
Thinking of writing a simulator? ;-)
Date: 21 Oct 2008 07:31:01
Message: <48fdbd75$1@news.povray.org>
Yeah, pretty much.
> differential in time is proportional to the 2nd differential in space.
> Obviously the 2nd differential in "space" depends on how many dimensions
> you are working in, but you more or less just sum up the 2nd
Hmm. Seems simple enough...
Well let's put it this way: What do you think my chances of building a
working set of organ pipes are? :-P Last time I tried to cut wood, I
couldn't even cut it straight! :-/ I figure I have far more chance of
building an organ simulator...
Date: 21 Oct 2008 08:45:00
Message: <web.48fdceae45093b7798a5bb110@news.povray.org>
Some dream, huh?  Only a math/musician to dream of organs and equations... :P
Date: 21 Oct 2008 08:53:18
Message: <48fdd0be$1@news.povray.org>
For the record: I have never had dreams about equations.
Dreaming about people being killed is unfortunately very typical for me
though. :-S
Date: 21 Oct 2008 08:54:57
Message: <48fdd121$1@news.povray.org>
Well, I just implemented it, tried it, and... it doesn't work at all. :-.
Oh, wait... *second* derivative! >_< Damnit...
Oh look, and I've also implemented u = c d2u/dx2 rather than d2u/dt2 = c
d2u/dx2. I'm doing well here. :-/
Date: 21 Oct 2008 09:22:38
Message: <48fdd79e@news.povray.org>
Just practise, and you can buy (or make) some jigs that constrain the saw to
move exactly straight.  THat way you will get perfect cuts every time.
> I figure I have far more chance of building an organ simulator...
You reckon? Thinking about it, I think you will need to use the
Navier-Stokes equations, because you need to simulate the velocity of the
fluid too, not just the pressure. (the velocity of the air stream is what
causes the pressure differences which in turn cause the flow to oscillate
between going out of the mouth and staying within the pipe).
Good luck :-)
Date: 21 Oct 2008 09:30:14
Message: <48fdd966@news.povray.org>
"scott" <sco### [at] scottcom> a écrit dans le message de news:
48fdd79e@news.povray.org...
> to move exactly straight.  That way you will get perfect cuts every time.
Let's add that a plane is always meant to be checkered :-)
Marc
Date: 21 Oct 2008 09:34:11
Message: <48fdda53@news.povray.org>
"m_a_r_c" <jac### [at] wanadoofr> a écrit dans le message de news:
48fdd966@news.povray.org...
> Marc
is NOT always :-s
Marc
Date: 21 Oct 2008 09:39:14
Message: <48fddb82$1@news.povray.org>
> saw to move exactly straight.  THat way you will get perfect cuts every
> time.
Frankly, first I need to find a saw that isn't blunt.
(Actually, finding any kind of tool isn't easy. My mum *has* millions of
tools - every time she goes to start another job, she can never find the
tool she wants, so she buys a new one. It gets used once, and is never
found again.)
> You reckon?
I said "chance". :-P
> Navier-Stokes equations.
> Good luck :-)
Actually... it's possibly not directly related, but Wolfram showed a
trivially simple cellular automaton which has no sophisticated
properties encoded into it, and isn't even an accurate simulation of any
physical system, and yet exhibits the same characteristics as a flowing
liquid. (Most particularly, it has both laminar and turbulent flow.)
This is much simpler to model then exotic differential equations. OTOH,
it's a few orders of magnitude less efficient too... ;-)
Subject: Sum ting wong
Date: 21 Oct 2008 10:38:38
Message: <48fde96e$1@news.povray.org>
OK, so I simulated the wave equation and got... this?
Hmm. I started with a green square on a black background. The corners
lit up, and plausibly wave-like projections radiated out from the
corners. But... why only those two corners? Why not all four?
I think I must have done something rather wrong here... :-S
Subject: Re: Sum ting wong
Date: 21 Oct 2008 10:40:10
Message: <48fde9ca$1@news.povray.org>
Try including the attachment, dork! :-P
Download 'test.png' (4 KB)
Preview of image 'test.png'
Date: 21 Oct 2008 11:08:46
Message: <48fdf07e@news.povray.org>
I made some POV code to simulate the wave equation a long time ago, see
attached.  Maybe you can compare with your code and see where it's giving
different answers?
BTW in my version it forces the central point to follow a sine wave up and
down, and that then causes the circular "ripple" effect outwards.
Download 'us-ascii' (3 KB) Download 'waves.png' (47 KB)
Preview of image 'waves.png'
Date: 21 Oct 2008 11:23:58
Message: <48fdf40e$1@news.povray.org>
> giving different answers?
How did you arrive at
#local XD = waveHeight[X+1][Y] - 2*waveHeight[X][Y] + waveHeight[X-1][Y];
According to my calculations,
   (v[x-1] - v[x]) + (v[x] - v[x+1]) =
   v[x-1] - v[x] + v[x] - v[x+1] =
   v[x-1] - v[x+1]
which is completely different to what you have.
Date: 21 Oct 2008 12:04:01
Message: <48fdfd71$1@news.povray.org>
Cool. Where did you see this?   I couldn't track down anything obvious
with Google, due to conflicting hits.
Date: 21 Oct 2008 13:22:30
Message: <48fe0fd6$1@news.povray.org>
>> any physical system, and yet exhibits the same characteristics as a
>> flowing liquid. (Most particularly, it has both laminar and turbulent
>> flow.)
Wolfram's "A New Kind of Science".
Maddeningly, I've searched and searched the online version, but cannot
find any reference to this experiment. It definitely appears in the
paper copy I have though.
(As an aside, I found the book to be somewhat dissapointing. But there
were one or two very interesting things to be found. This was one of them!)
http://blog.orphi.me.uk/
Date: 21 Oct 2008 14:00:15
Message: <48fe18af$1@news.povray.org>
Cool. I'll dig thru the index.
I thought a lot of it was pretty cool, and he did a good job of
organizing it into "the part you read for fun" and "the part you read if
you're actually going to do something technical with the results".
(Unlike several other tomes of this sort I've read.) Altho, yeah, the
hubris was rather astounding. :-)
I trust you've read Godel-Escher-Bach?
Date: 21 Oct 2008 15:42:18
Message: <48fe309a$1@news.povray.org>
Chapter 8, "Implications for everyday systems", section title "Fluid
Flow", page 376 in my hardback copy.
He shows a cellular automaton consisting of a hexagonal grid. Each cell
may optionally contain a particle, which can have one of 6 possible
velocities. (Note that all particles have unit momentum. There is no
attempt to simulate varying particle speeds.)
When two neighboring cells both contain particles, a simple automaton
rule defines the new velocities for those particles. (Again, casually
glossing over a vast swathe of actual phenomina that occur with
molecular collisions. Here there is no vague attempt at Newton's laws of
motion, or even intuitive plausibility really.)
Viewed locally, all the particles dance around more or less at random.
However, if you average over a very large number of particles, you what
something looking suspiciously like fluid dynamics. Specifically,
Wolfram demonstrates that if all the particles have random initial
velocities, the overall net flow is zero. If a large minority of
particles all move in one direction, and there is an obsticle in the
way, you get trailing vorticies behind it. And if enough particles are
made to move the same way, you get real turbulence behind the obsticle.
All this from just individual particles interacting in a very
physically-incorrect manner. (OTOH, you have to average absurd numbers
of particles to get this, so it's very ineffient stuff!)
>> them!)
It makes some valid points... it's just not very interesting to read.
Never heard of it.
Date: 21 Oct 2008 17:08:57
Message: <48fe44e9$1@news.povray.org>
> organ. When I started learning about the stop names, I had a second dream
Good thing you haven't been learning bag-pipes. That would have been
particularly grusome.
H²
Date: 21 Oct 2008 19:59:32
Message: <48fe6ce4@news.povray.org>
Thank you!
BTW, if you liked Wolfram's thing and you like science fiction, check
out "Permutation City" by Greg Egan. A very fun geeky read.
I found it pretty interesting, but repetitive. I also really like CAs.
> Never heard of it.
http://www.amazon.com/Godel-Escher-Bach-Eternal-Golden/dp/0465026567
Wow.  I'm not sure why it came up in the conversation, but it's a
must-read for anyone who enjoys computers and waded thru Wolfram's stuff.
Date: 22 Oct 2008 02:27:17
Message: <48fec7c5$1@news.povray.org>
That should be a "-" in the middle, because you are taking the differential
of the differential.
Date: 22 Oct 2008 02:30:33
Message: <48fec889$1@news.povray.org>
Oh, and just for clarity, you should probably write that as:
(v[x+1]-v[x]) - (v[x]-v[x-1])
rather than:
(v[x-1]-v[x]) - (v[x]-v[x+1])
In your case it makes no difference because you are differentiating twice,
but in general differentials are usually defined to be positive if v[x]
increases with x.
Date: 22 Oct 2008 04:15:16
Message: <48fee114$1@news.povray.org>
> Thank you!
Well, go implement! :-P
I find CAs to be dull and boring.
>> Never heard of it.
I actually didn't bother finishing to read it. It didn't have anything
much interesting to say.
Date: 22 Oct 2008 04:16:51
Message: <48fee173$1@news.povray.org>
> differential of the differential.
The above formula is only meant to be the 1st derivative. I run it twice
to get the second derivative.
Except that, as noted, my code fails miserably, whereas the formula you
used seems to work perfectly for some reason...
Date: 22 Oct 2008 05:00:41
Message: <48feebb9@news.povray.org>
If it's your thing, I must recommend:
http://www.amazon.co.uk/Linked-Everything-Connected-Business-Everyday/dp/0452284392
It's a really nice book. (E.g., did you know that the software marked is
like a Bose-Einstine condensate? If you care about such things, you'll
love this quirky little book...)
Date: 22 Oct 2008 05:33:57
Message: <48fef385$1@news.povray.org>
To get the 1st derivative you just need:
v[x+1] - v[x]
What you are doing is to essentially average the differential of one point
and the point before, which is going to blur out any sharp gradients.  (eg
if you have points 5 0 5 the gradient your way will come out as zero)
Date: 22 Oct 2008 08:37:18
Message: <48ff1e7e@news.povray.org>
Reminds me of something I had some time ago. It was a software synth
based on the physical characteristics of the instrument, I think it was
put out by Creative at the time, bundled with their sound card. I've
since forgotten the name of it, though. Ahh, called WaveGuide:
http://en.wikipedia.org/wiki/Digital_waveguide_synthesis
Interesting technology. Good luck if you do produce a pipe organ simulator.
~Mike
Date: 22 Oct 2008 09:00:38
Message: <48ff23f6$1@news.povray.org>
The Reaktor product from Native Instruments features a sound module
named "Steam Pipe" which uses a (1D) digital waveguide to simulate
string and wind instruments. It does a delightful flute sound. ;-)
(What can I say? I like flutes!)
It's really interesting. You can "over-blow" the flute just like a real
one. It sounds ever so believable.
Of course, Steam Pipe does all this using a few non-physical shortcuts.
(E.g., instead of a true gas turbulence engine, it uses a simple
nonlinear waveshaper to produce wave saturation.) The next step would be
to move to 2D or even 3D with real turbulence simulation. I suspect this
would result in an instrument that takes weeks to simulate and doesn't
sound all that much different.
Date: 22 Oct 2008 10:50:24
Message: <48ff3db0@news.povray.org>
Wow. OK.  I'll note that it took me several readings to even realize it
was two books in one cover, for example, in spite of the author telling
you so several times.  It's a rather complex tome.  But if it's not your
thing, I can understand that... :-)
 > http://www.amazon.co.uk/Linked- ...
I'll check it out, thanks!
Date: 22 Oct 2008 12:42:54
Message: <48ff580e$1@news.povray.org>
To do things in realtime, you must take shortcuts :)
Wonder if there's a sound card out there that has a programmable DSP
that's got enough parallelism to add as much realism to your simulation
as possible.
~Mike
Date: 22 Oct 2008 15:48:48
Message: <48ff83a0$1@news.povray.org>
>> was put out by Creative at the time, bundled with their sound card.
>> I've since forgotten the name of it, though. Ahh, called WaveGuide:
Here ya go:
http://download.orphi.me.uk/Music/G3/Silhouettes.ogg
This entire piece of music was created using *only* Steam Pipe.
Everything you hear is a digital waveguide simulation.
Neat, isn't it?
Date: 22 Oct 2008 19:35:00
Message: <web.48ffb77345093b77e0c9e9540@news.povray.org>
> Laplacian is! :-S
In a realistic setting, this could be pressure and velocity, in which case they
usually just differ by a phase of 90 degrees, if I recall correctly.
Or, think of it as a string under tension.  If it has a positive second
derivative, then it is curved upward and that part of the string will tend to
accelerate upward. According to Newton's 2nd law, F=ma, so if the curvature
acts as a force, then it is proportional to the acceleration, a=d^2(u)/dt^2.
Using the constant c^2, which happens to end up as the wave speed, this gives
the 1-D wave equation:
d^2(u)/dt = c^2 * d^2(u)/dx^2.
For two dimensions, you just have curvature acting in two directions, so you add
them up and
d^2(u)/dt^2 = c^2 * ( d^2(u)/dx^2 + d^2(u)/dy^2 ) = c^2 * Laplacian(u)
To solve this, remember that the second derivative can be written discretely as
d^2(f)/dx^2  =  ( f(i+1) - 2*f(i) + f(i-1) ) / ( dx^2 )
where f(i+1) and f(i-1) are the neighboring grid points and dx is the grid
spacing.  Applying this to the time and space derivatives across a
two-dimensional grid, (assuming dx=dy),
( u(n+1) - 2*u(n) + u(n-1) ) / dt^2 = c^2 * ( u(i+1,j) + u(i-1,j) + u(i,j+1) +
u(i,j-1) - 4*u(i,j) ) / dx^2
Assuming you know the previous two time steps and that the right-hand side is
evaluated at time level n, just solve for u(n+1):
u(n+1) = 2*u(n) - u(n-1) + (c*dt/dx)^2 * ( u(i+1,j) + u(i-1,j) + u(i,j+1) +
So to solve the equation, make three grids.  Set grids (n-1) and (n) to zero.
Solve for (n+1).  Then transfer (n)->(n-1) and (n+1)->n.  Now you're back where
you started so just repeat over and over.  This should be stable as long as
(c*dt/dx) < 1.  This is called the CFL number and ensures that waves don't
travel across more than one cell per time step.
To make it interesting, just say instead that
d^2(u)/dt^2 - c^2*Laplacian(u) = f(x,y,t)
where f(x,y,t) is just any old forcing function that can depend on space and
time and makes it actually move.
Sorry.  That got a little long.  Hope it's remotely useful...
 - Ricky
Date: 23 Oct 2008 02:54:32
Message: <49001fa8@news.povray.org>
> as possible.
I imagine a GPU would be quite good at this sort of thing.
Date: 23 Oct 2008 03:51:07
Message: <49002ceb@news.povray.org>
Am Tue, 21 Oct 2008 12:30:58 +0100 schrieb Invisible:
Maybe this is something for you: http://www.kokkinizita.net/linuxaudio/
aeolus
Haven't tried it yet, but looks interesting.
Date: 23 Oct 2008 08:49:21
Message: <490072d1$1@news.povray.org>
>> simulation as possible.
I suspect you're right. It has built-in support for parallel operations.
Can you repurpose a GPU for that sort of thing?
~Mike
Date: 23 Oct 2008 08:51:13
Message: <49007341$1@news.povray.org>
> Here ya go:
I'll download and listen when I get home ...
> Neat, isn't it?
It is. I know the AWE64 software synth portion was quite nice. guitars
sounded like guitars, etc ..
~Mike
Date: 23 Oct 2008 08:54:08
Message: <490073f0@news.povray.org>
Probably.
The math isn't even that complex - there's just *a lot* of it.
Date: 23 Oct 2008 09:49:30
Message: <490080ea$1@news.povray.org>
>>> as possible.
A GPU is basically very fast if you want to perform exactly the same
function on big arrays of data.  Nowadays there are very few limitations on
what you can and can't do, and the few remaining are easily got around by
using temporary arrays and multiple functions.
Even if your algorithm apparently doesn't work on huge arrays of data, it
can often be forced to do so in order to get a big speed up.  eg With an IFS
program that transforms one point repeatedly to generate a picture, on the
GPU you can transform millions of points in parallel and you get the same
result.
Date: 23 Oct 2008 13:50:09
Message: <4900b951$1@news.povray.org>
There's an artist named Larry Fast who has a one-man band called
"Synergy."  He produces what was called "electronic music" a few decades
ago, more rock than trance-like. In the liner notes of his first album
talking about what instruments he used, he lists a dozen synthesizers
and such, and ends with "and no guitars." In his second album, other
synthesizers, and "and still no guitars."  Third album the same. Fourth
album, one of the synthesizers is "Madrong M-500 guitar synthesizer."[1]
And at the bottom, he adds "Finally, guitars, sort of."
[1] I don't know the exact brand offhand, no. :-) Don't google "madrong".
Date: 23 Oct 2008 16:28:03
Message: <4900de53$1@news.povray.org>
Oh, good. it doesn't come up with anything nasty, thankfully.
(And just what did you think I was gonna do if you said don't google for
[X] ... Google it, of course ;) )
~Mike
Date: 23 Oct 2008 16:31:14
Message: <4900df12$1@news.povray.org>
Don't google "bukkake". Especially not at work.
Date: 23 Oct 2008 16:48:14
Message: <4900e30e$1@news.povray.org>
Errrrr ....
~Mike
Date: 23 Oct 2008 16:54:02
Message: <4900e46a@news.povray.org>
> Errrrr ....
WIN!!!!!eleven! :-D
Date: 23 Oct 2008 17:17:58
Message: <4900EA58.5080409@hotmail.com>
I think it was just a way to bring the power of google again to the
attention of our mascot. Most of the more obvious ways seem to have
failed too often. ;)
Date: 24 Oct 2008 08:33:57
Message: <4901c0b5$1@news.povray.org>
I've heard this tune before. I think you might have posted it a while
back, but yes... neat. All waveguide? one patch sounded kind of
electronic, too.
~Mike
Date: 24 Oct 2008 08:59:00
Message: <4901c694$1@news.povray.org>
> back
Indeed yes.
> electronic, too.
All waveguides. Just different settings of the sliders. ;-)
There's a sound in there which actually runs two notes very slightly out
of tune for a phasing effect; it sounds moderately electronic.
Date: 24 Oct 2008 12:13:11
Message: <jts3g41te6vg1h3hogsfq6o8sa9cfu2phn@4ax.com>
On Fri, 24 Oct 2008 07:32:32 -0500, Mike Raiford <"m[raiford]!at"@gmail.com>
It was used as a pop tune decades ago. I can't remember the name.
Andrew, your touch is getting better. :D
Regards
Date: 24 Oct 2008 14:25:34
Message: <4902131e@news.povray.org>
It was called - wait for it - Silhouettes.
http://artists.letssingit.com/hermans-hermits-lyrics-silhouettes-xbj5f89
(A favourite tune of mine, BTW.)
Heh, sadly not. This is purely sequenced. ;-)
Date: 24 Oct 2008 16:31:29
Message: <9ub4g4t17b163im4i07var2hvqqb21b6pb@4ax.com>
On Fri, 24 Oct 2008 19:25:37 +0100, Orchid XP v8 <voi### [at] devnull> wrote:
I played it to my wife (Delphi the oracle) and she not only told me it was
Silhouettes on the shade by Herman's Hermits (January 1965), she sang all the
verses
Then I saw your link when I was replying.
I was 14 when it reached #3.
Opps!   One more time, with feeling :)
Regards
Date: 24 Oct 2008 16:34:49
Message: <49023169$1@news.povray.org>
> verses
Heh. I hadn't even been born yet. (But I can still sing all the lyrics...)
