<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html;charset=ISO-8859-1" http-equiv="Content-Type">
<title></title>
</head>
<body bgcolor="#ffffff" text="#000000">
You know, I'm kind of surprised I've never seen a programming language
(that uses different fonts for different purposes. Something like
boldface for reserved words, italics for built-ins, so you could do
something like<br>
<br>
<b>foreach</b> index <b>in </b>mylist <b>do </b>item +=
<i>length</i>(mylist[index])<br>
<br>
or something like that. Then you could use things like "in" and "do" as
variable names as well. :-)<br>
<pre class="moz-signature" cols="72">--
</pre>
</body>
</html>
> something like
> *foreach* index *in *mylist *do *item += /length/(mylist[index])
Yes, but that would imply that the set of reserved words is static. Hmm,
am I suffering from deja vu?
No. It would imply anything in bold is a reserved word while anything in
regular font isn't. Kind of like using different alphabets/fonts in
math to distinguish the variable "R" from the symbol meaning "Real numbers".
Darren New escreveu:
> something like
> Darren New / San Diego, CA, USA (PST)
That would utterly suck. Programming languages should be about meaning
and meaning is conveyed by words, not by how they are drawn or spelled.
Let external tools do any styling to the source text if you will.
>> something like
>> as variable names as well. :-)
http://compsoc.dur.ac.uk/whitespace/
http://www.dangermouse.net/esoteric/piet.html
http://www.ni.com/labview/
andrel escreveu:
>>> language (that uses different fonts for different purposes. Something
>>> like boldface for reserved words, italics for built-ins, so you could
>>> do something like
>> meaning and meaning is conveyed by words, not by how they are drawn or
>> spelled.
Yeah, if you want a Turing Complete toy or brainfuck...
Speaking of esoteric languages, I like the basic idea behind befunge, but
I hate its actual implementation.
The execution of the program following the 2D arrangement of the command
characters is a clever idea, and could result in very interesting programming
challenges. However, the actual implementation of befunge sucks because it's
way too limited. It's almost impossibly hard to have actual *variables* and,
AFAIK, basically impossible to access anything but the value at the top of
the value stack. This makes writing even simple programs, such as for example
an ascii mandelbrot drawing program, incredibly difficult.
IMO befunge's clever idea was ruined by a poor implementation, which has
a way too limited set of commands.
Befunge's idea with a much more powerful and expressive set of commands
could be actually very interesting.
Warp escreveu:
I thought the point of such languages was in overcoming such
difficulties per se rather than actually writing useful programs...
"nemesis" <nam### [at] gmail com> wrote in message
news:48f8f145$1@news.povray.org...
Meaning is conveyed by anything that is meant to convey meaning, be it
words, grunts, connections between gears, flowcharts, hearldry symbols,
colours... etc. Pictorial representations will eventually assume a more
prominant role in general programming. Software audio synthesizers, CAD
histories, UML.. etc already use flowchart style, graphical representations
and are none the less rigorous for it.
Meaning isn't conveyed by words in programming languages. It's conveyed
by tokens and formal matches between tokens at different parts of the
source.
{ int index = 23;
cout << index;
The meaning there isn't conveyed by "int". In chinese, you might use
something different than "int" (maybe 整數 or something) an
d it would be
just as meaningful if not moreso to a native chinese speaker (assuming
you fixed the compiler, of course). The compiler doesn't care what
token you use to mean what Warp means by "int" in his code.
The word "index" doesn't provide any meaning, and the program would work
identically if both instances of the word "index" were changed to the
word "age". The compiler doesn't care what you name your variables.
The text doesn't mean anything per se to the compiler. Only the
relationship of one part of the text to other parts of the text.
OK, so reserved words are in greek, and user-defined words are in latin
characters, no matter what fonts you use. Better? If so, why? If not,
why not?
>> spelled.
> source.
> { int index = 23;
> cout << index;
> something different than "int" (maybe 整數 or something) and it would be
Fine. 整數 is still a word with a meaning associated, which is my
point: words should convey meaning, not how 整數 is written or spelled.
I mean, surely 整數 can be written in italics or bold without altering
its meaning. And no, I'm not a fan of case-sensitive syntax either.
Yes. You may use whatever font you please, as long as it's Unicode and
can correctly display the greek and latin words in the text or else the
meaning is lost. This is not the same as styling with bold or italics,
nor as capitalizing words.
> colours... etc.
You know? That's very true. And I can even imagine a tokenizer to a
compiler accepting italicized words to be different from non-italicized
words if it was to internally apply some transform like:
*Foo* /foo/;
bold_foo -> italic_foo ->
etc.
To me, it just sucks, though. It means, when I'm writing a program I
have now to think not only of good identifier names, but also of
correctly applying the right styling, besides also capitalization.
Sure, UML and company have been around for quite some time already. And
it all eventually gets converted to a stream of text in some language
anyway, and that to a stream of bytes in machine language, so hey!,
perhaps it's time we communicate using just jpgs and emoticons as well... :P
I for one find some things much easier to write about than to drag
balloons, boxes and arrows around and apply meaning by combos,
radiobuttons and so on, besides messing with a UI looking like that of a
top aircraft...
BTW, perhaps you'd be interested in this nutjob and his take on the
future of computers and programming:
http://rebelscience.blogspot.com/2008/09/cosa-new-kind-of-programming-part-i.html
I still find much simpler writing a textual while loop though... :P
hout altering
> its meaning.
Again, it depends on the field of study. "R" is a variable. Bold-face R
means the set of real numbers, in mathematical notation.
And capital delta and lower-case delta mean two different things in
math, too.
You've yet to actually provide a reason for your disagreement.
Darren New <dne### [at] san rr com> wrote:
> hout altering
> > its meaning.
Nice try, but in one given program it means one and only one thing.
> math, too.
We're not talking about math, we're talking about a program, possibly a domain
specific one with its own business rules and meanings.
I thought I was clear enough. I consider "foobar", *foobar*, /foobar/, Foobar,
FooBar, FOOBAR to be all the same. It's still a foobar like any other...
yes, I know C++ users will say FOOBAR is a constant, Foobar or FooBar a class
and foobar an instance of such class. Baloney...
R
You assert this without justification.
>> math, too.
domain
Yes? You don't understand hypotheticals?
Foobar,
Maybe you mean that you simply disagree with the merit of the idea.
That's fine. But you phrase it as if there's actually a good reason why
the idea needn't be considered other than your personal preference.
You say "surely 整數 can be written in italics or bold with
out altering
its meaning." I'm disagreeing that it is as sure as you say, but your
justification seems to be "saying the same thing louder". :-)
> Foobar,
Yes. I can certainly see the value of having different identifiers binded to
the same word under different graphisms, from a practical standpoint, but still
do not agree with it.
It's not mine alone. The Pascal and Lisp languages have long supported this
notion.
Besides, case-sensitiveness is already bad enough, but at least most editors
support it. I'm guessing your proposal would not play nice with notepad
folks...
nemesis wrote:
> I'm guessing your proposal would not play nice with notepad folks...
Less a proposal than a thought thrown out to look over, yes. And you'd
definitely not be writing it in notepad, unless you used wordstar or
html conventions or something. (I.e., embedded markers, like <b>int</b>
or embedded control characters or something.)
APL, after all, used greek letters (mostly) for built-in functions
(along with things like a proper division sign), and ascii for
user-defined variables and functions, and with the appropriate
infrastructure (such as keyboards with the characters printed on them)
it really wasn't a problem as such. You couldn't read the program on a
terminal that didn't have the right character sets, of course, but
that's hardly a problem nowadays.
And of course 8-bit BASIC interpreters did something similar internally,
but decoded it into text for display.
But yeah, it doesn't seem like there's a particular technological
benefit to trying that.
I'd be much more interested in that if he'd actually written something
larger than a quicksort. Or even a quicksort that would actually work in
a generic sort of way, like with different types, or different size
arrays, or whatever.
Too much handwaving while loudly proclaiming he's solved every problem.
He thinks hardware is very reliable, but he's clearly never worked at
building hardware, where you ship off dozens of versions of chips, and
when you're done, you use software to patch the bugs in the hardware
design. He also doesn't seem to realize that there are all kinds of
timing problems in hardware, and that indeed solving the timing problems
in "synchronous" hardware is a major part of the development effort.
He also thinks that hardware is more complex than software, but the
reason people write software instead of building hardware is that much
that software does is too complex to implement in hardware.
He also seems to think that the problems with making software work is
problems with getting from detailed correct specs to software that
implements those specs. Much more often, the specs on what a piece of
software is to do is far more vague than what hardware is to do. Nobody
starts building a chip before they decide what all the CPU instructions
are going to be for sure. I'd also suspect it's pretty rare that
hardware is designed in a way that's easy to upgrade - add-on floating
point units would seem to be the most obvious example of what I mean,
while every piece of software is meant to be "soft". Virtually nobody is
happy with software that never changes once released, and for those who
are (a la cell phones, microwave ovens, etc) it seems we manage a pretty
good level of reliability.
He also seems to think that hardware doesn't have the same problems as
software, yet http://www.opencores.org/ exists.
When he shows how you'd build an air traffic control system that's more
reliable than what we have, or even a SQL RDBM server, using his system,
I'll maybe start to worry about it. :-)
I think you devoted too much time to the guy's ideas. He's a well-known,
long-time internet crackpot and he knows it:
http://rebelscience.blogspot.com/2007/10/who-am-i-what-are-my-credentials.html
Beware, he may be an online sentient being. One day I innocently invoked his
name in comp.lang.lisp and he appeared all of a sudden!
http://groups.google.com/group/comp.lang.lisp/browse_thread/thread/e0ee331cfe13f214/9f84e2cccc7c0269?lnk=gst&q=louis+sa
vain#9f84e2cccc7c0269
He may drop by here as well... :P
It's hard to tell without looking. Anyway, he's just proposing "data
flow" types of languages. Of course, he doesn't know that, since he
never actually studied the field. :-) They work great, until you need
an algorithm.
I specially enjoy reading him bashing physicists and astrophysics:
http://www.rebelscience.org/Crackpots/notorious.htm
http://groups.google.com/group/sci.physics/browse_thread/thread/2d91a6c420a0bcb0/3faf25bc7bdaa0de
I specially like this quote:
"It is a pity Dr. Sagan passed away because I liked him, crackpot or not."
fairly amusing. :)
nemesis wrote:
> fairly amusing. :)
I didn't really look at anything beyond his computer stuff. I do like
this one:
"This gem of pseudoscience comes from one of the most celebrated
physicists of the twentieth century."
Um, and you, in calling him a crackpot, are obviously more celebrated? I
mean, I'm not one of those who believes in Proof By Authority, but I'll
take the word of "most celebrated physicists" over "never studied
physics" any time. Especially when the celebrated results lead directly
to the technology I have sitting in front of me.
"Second, dt/dt is always the same (1) regardless of the actual rate of
velocity." I'm pretty sure this isn't true, actually, is it?
Indeed, that whole page is silly. First he says you can't have a time
dimension, because otherwise things wouldn't move. Then he says "people
talk about time changing, but time doesn't change." Well, yes. You're
confusing two meanings of "time" there, and complaining that the popular
meaning doesn't match the physics meaning. So?
Heh. "Time does not dilate (as if time could change!). On the contrary,
it is the clocks that slow down (for whatever reason) resulting in
longer measured intervals." Riiiight. He's another one of these
crackpots who attempt proof by vigorous assertion.
""Time dilation" = process slowdown. There is no causal link between the
two. They are equivalent." Um, yes. Clearly he doesn't understand what
is even meant by "time dialation".
A master troll indeed. Such creatures are amusing in their natural
habitat... :)
