I just sat down and attempted to draw a chart representing all the most
important topic of the Haskell programming language, and how they relate
to each other.
Unfortunately, it looks like this:
Download 'haskell1.png' (136 KB)
Preview of image 'haskell1.png'
I was wondering how much I could reduce the file size of your PNG if
lossiness is allowed, but without degrading the image quality noticeably.
I was able to reduce your original 138408 bytes png to a 49074 bytes one:
Download 'Haskell1_optimized.png' (48 KB)
Preview of image 'Haskell1_optimized.png'
Impressive. How did you manage that?
> to each other.
Of course, the other problem is that you draw something like this, and
you end up with related concepts which happen to be at opposite ends of
the chart. (E.g., "Exceptions" should be connected to "I/O".)
But hell, doing this on a computer was way easier than with pen and
paper! o_O
Looking at this chart, I'm starting to comprehend why teaching Haskell
is so damned hard. Everything is related to everything else. Where the
hell would *you* start?!
Reduced to 8 colors (without dithering) and then ran through optipng and
pngout.
> pngout.
Ah. Yes, I should probably have thought of that myself...
The AA on the diagonal lines certainly looks noticeably worse...
Ever consider using Freemind to make such drawings?
May your screen live long and phosphor.
/ \/ \ u e e n / \/ a w a z
>>>>>>mue### [at] nawaz org<<<<<<
anl
As a matter of fact, that is the exact tool I started with.
Unfortunately, it seems that Freemind is constrained to strictly
hierachical diagrams only, which is obviously no use at all...
And now, colour-coded by priority...
(I just like posting binary attachments really. Heh.)
Download 'haskell2b.png' (65 KB)
Preview of image 'haskell2b.png'
I don't think it reduces the readability and clarity of the graph in
any way.
You know, the longer I stare at this diagram, the more features and
concepts I realise I've left out. It's true: when you know a subject
well, it really becomes very difficult to avoid overlooking things that
have become completely "obvious" to you...
If I run it through optipng and pngout, it gets reduced from 66135 bytes
to 61569 bytes losslessly.
If I reduce it to 64 colors first, it gets reduced to 50843 bytes without
noticeable loss.
And then they say C++ is complicated...
Perhaps you could try drawing up a similar diagram for C++? I'm sure
that between integer type modifiers, pointers & references, const &
volatile, the new operator, implicit conversions, default
constructors/descructors, templates, the preprocessor, function
overriding, and everything else C++ has to offer, it'll come out
similarly tangled. ;-)
The difference, I think, is that in C++ you don't need to know so many
things to start writing useful code, whereas in Haskell, since
everything is related to almost everything else, you need to actually
know quite a lot of stuff all at once before you can "get going".
http://blog.orphi.me.uk/
Warp escreveu:
> pngout.
5+ GeekPoints
Invisible escreveu:
> to each other.
I'm sure I spotted a WTF somewhere...
"Warp" <war### [at] tag povray org> wrote in message
news:48f892ff@news.povray.org...
28461 bytes, who does better :p
cu!
_(0x+y.5+y/2x)_(0x-y.5+y/2x) // ZK http://www.povplace.com
Download 'Haskell1-2.png' (28 KB)
Preview of image 'Haskell1-2.png'
"Zeger Knaepen" <zeg### [at] povplace com> wrote in message
news:48f8f356@news.povray.org...
on second thought, readability isn't as good anymore :)
cu!
Could get smaller size and of higher resolution.
(compressed SVG :P)
> paper! o_O
I started trying to do it with graphviz. It quickly got into a mess. Clearly
it would need manually tweaking some positions and edge weights...
Download 'us-ascii' (1 KB)
Download 'haskell.png' (35 KB)
Preview of image 'haskell.png'
> (compressed SVG :P)
Yeah, and editable too.
But VUE won't do that, so.....
>> paper! o_O
Nice... Not a tool I'm familiar with. (I heard somebody rambling about
it a while back though.)
Perhaps you mean "WHNF"? :-P
Well, as you can see from the source code I included, it's not exactly hard
to use :)
Even a simple 16-color GIF is only 32,518 bytes, and that's without even
trying hard or losing the AA on the arrows. :-)
>> > noticeably.
>> > one:
> any way.
Me neither, but it certainly is noticeable. I wonder if you use just
horizontal and vertical lines, rather than diagonal lines, and don't use
rounded boxes, or a coloured background, or AA text, how that would affect
the file size?
> the file size?
Probably makes the file a lot smaller because it compresses better that
way.
>> the file size?
> way.
I imagine if I were somehow able to generate an SVG version, it would be
many, many times smaller than any compressed bitmap.
> to use :)
...and yet it's taken me this long to download and install the thing! ;-)
I see what you mean about a mess. Even with a very simple, almost
trivial graph, the produced layouts are extremely suboptimal. (Nodes on
top of each other, edges that consist only of arrow heads, absurdly long
edges for no reason, etc.) All of the graphs could trivially be improved
by just moving a few nodes to one side or another by a very small
amount. And it doesn't seem to matter which layout engine I use; they
all seem to produce hopeless layouts.
Still, it *is* much faster than doing this stuff by hand! ;-)
OOC, do you have any idea how I make it draw the edges as splines? I
have tried and tried and tried to make it do this, but it won't.
Um, splines=true? (graph property)
splines=boolean. Setting this to true causes edges to be drawn as
splines if nodes don't overlap. The default is false.
Also try concentrate=true.
Yeah. I did that. It has no effect. (The manual says it should work, but
it doesn't.)
Mmm, OK...
