POV-Ray : Newsgroups : povray.off-topic : A silly little toy (~200 kb) Server Time
3 Nov 2026 01:50:25 EST (-0500)
  A silly little toy (~200 kb) (Message 1 to 27 of 27)
Subject: A silly little toy (~200 kb)
Date: 15 Oct 2008 11:25:23
Message: <48f60b63@news.povray.org>
Hey people, check it out: Attached to this post is a small program I wrote.
(The attached binary works for M$ Windoze only. I'm not sure precisely
which versions, but it DOES work for XP and DOES NOT work for NT 4.0. In
principle it could be compiled for Linux or Mac OS X. The program is
about 20 KB of Haskell source code.)
The program isn't terribly exciting; it's a predicate solver. That is,
it attempts to solve extremely simple equations.
To run the program, double-click it. You should get a window of
multicoloured terminal output, including a "Predicate>" prompt.
If you enter, say, "x = 1", then the program will respond that to solve
this predicate, you have to set x equal to 1. (DUH!)
Alternatively, if you set "4 = 4", the program will find "1 solution",
and that solution will be empty. This basically means that the predicate
*always* holds. If you do "1 = 2", the program will report "no solutions
found", indicating that the predicate can never be satisfied. So far so
good.
If you say "x = 1 & y = 2" then the program will report a self-evident
solution. If you say "x = 1 | y = 2" it will report two seperate
solutions. And if you say "x = 1 & x = 2" it will fail to find any
solutions (pretty obviously).
You can of course put predicates in brackets; by default, AND has a
higher priority than OR. You can also prefix anything with "~" to
indicate NOT (note that the engine doesn't support this quite so well).
The program understands (signed) integers and equality. It also
understands lists. Try "{1, 2, 3} = {1, 2, 3}" and you will get an empty
solution (i.e., the predicate always holds). Try "{1, 2, 3} = {3, 2, 1}"
and you will get no solutions (i.e., the predicate never holds). You can
also do "{x, y, z} = {1, 2, 3}", which yields a fairly obvious result.
Notice that, mathematically speaking, "x = 1" and "1 = x" are the same
equation, and the program treats them identically.
The fun part begins when you start using the built-in predicate
functions. There are currently just 4 of these; I plan to make it
possible to add your own, but I haven't implemented this yet.
First, the rather dull "Empty" function tests whether a list is empty:
- "@Empty[{}]" will yeild an empty result set.
- "@Empty[{1, 2, 3}]" will give no results.
The "Element" function tests whether a given element is in a list:
- "@Element[5, {1, 2, 3}]" gives no results.
- "@Element[5, {4, 5, 6}]" gives an empty result set.
The weird part is that this works backwards as well as forwards:
- "@Element[x, {1, 2, 3}]" tells you all possible values for x that will
satisfy the predicate!
Adventurers beware: Attempting to find all possible lists that 5 could
be an element of will result in an infinite loop from which only Ctrl+C
will escape.
Also of interest is the "Join" function:
- "@Join[{1, 2, 3}, {4, 5, 6}, {1, 2, 3, 4, 5, 6}]" gives an empty
result set, indicating that the 3rd list is indeed the first two joined
together.
- "@Join[{1, 2, 3}, {4, 5, 6}, z]" will set z to the join of the first
two lists.
This also works backwards:
- "@Join[{1, 2, 3}, y, {1, 2, 3, 4, 5, 6}]" will find the correct value
for y by stripping the first list off of the 3rd list.
- "@Join[x, {4, 5, 6}, {1, 2, 3, 4, 5, 6}]" works similarly.
- "@Join[x, y, {1, 2, 3}]" will find every possible way of splitting the
final list into two sublists. How neat is that?!
Again, beware that other combinations may yield an infinite number of
valid solutions [which will take an infinite amount of time to compute,
and nothing is displayed until *all* solutions are fully computed].
Finally, there is the "Subset" function, which tells you if one set is a
subset of another. For example, "@Subset[{1, 2}, {1, 2, 3}]". It
_should_ also work backwards, but currently doesn't. I'm not sure why.
Anyway, it's an amusing little diversion...
Download 'logic.exe.dat' (182 KB)
Subject: Re: A silly little toy (~200 kb)
Date: 15 Oct 2008 12:16:37
Message: <48f61765@news.povray.org>
Will it solve simple stuff like "x + 1 = 3" in version 1.5? :)
(or does it already...?)
Date: 15 Oct 2008 12:48:18
Message: <48f61ed2@news.povray.org>
Everyone loves to design languages.  Parsec?
Date: 15 Oct 2008 12:50:16
Message: <48f61f47@news.povray.org>
  Solving equations is an interesting programming task in itself.
  Solving an equation where the variable to be solved appears only once
is fairly trivial. Things become quite a lot more complicated if the
variable can appear more than once...
Date: 15 Oct 2008 13:41:43
Message: <48f62b57$1@news.povray.org>
May I suggest that perhaps dark blue on black (and similar color
schemes) aren't the best choice? Most of it, I can't read. Stick to
either bright colors on a dark background or vice versa. Or at least
make things like the prompt dim and the results bright. :-)
And if you say "x = y + 3 & y = 17" it says "x = y", which wouldn't seem
to be right. Unless I have the syntax wrong or something.
Date: 15 Oct 2008 14:47:48
Message: <48f63ad4$1@news.povray.org>
...yeah...what he said... ;-)
http://blog.orphi.me.uk/
Date: 15 Oct 2008 14:54:23
Message: <48f63c5f$1@news.povray.org>
Oh, OK. It's actually all very readable on my screen; I guess it has a
higher gamma or something.
> Stick to
Actually I made the prompt bright and the input + result dim. :-} Maybe
I should reverse that?
The mean reasoning behind all this multicoloured madness is so that if a
predicate produces 6 pages of output, you can easily find the thing you
typed in, because it's a different colour.
...and then I tried to extend this concept as far as humanly possible,
possibly resulting in a screen that's a tad too busy. ;-)
BTW, are you impressed that I got this to work? Somebody wrote a small
Haskell library that invokes windows.h under Windoze or emits ANSI
escape sequences on POSIX. Neat, eh? Also, notice the window title
bar... ;-)
Really? That shouldn't - ah, wait, I see what's happening.
Check the second line of output:
   Predicate: x = y
Since "+" isn't a valid token, the parser has ignored everything after
that point. If the predicate *is* x = y, then the result you got would
be perfectly correct.
This is one of the irritating things about Parsec. It can silently fail
to parse all of the input. Like, if some prefix of the input is a valid
expression but the rest isn't, it returns just the prefix. (Obviously it
depends how you structure your parser.) I must figure out how to fix that...
Anyway, *this* is why it prints out what it thinks it parsed the
expression as. (With lots of extra brackets.) In all cases, check that
the program has parsed something that matches what you intended! o_O
Date: 15 Oct 2008 14:54:37
Message: <48f63c6d$1@news.povray.org>
Yeah, Parsec. ;-)
Date: 15 Oct 2008 14:56:50
Message: <48f63cf2$1@news.povray.org>
Probably not.
Logic programming systems like this are more targetted at questions like
"if Sue is Helen's mother and Helen is Jamie's mother, is James related
to Helen?" and similar.
Currently the thing has no way to store "facts" and no way to define new
predicate functions. Once I add that... I will have basically
reimplemented the Prolog programming language. o_O
(Go look that up on Wikipedia BTW.)
Date: 15 Oct 2008 16:18:50
Message: <48f6502a$1@news.povray.org>
I actually live where it's sunny during the daytime. ;-)
I have trouble with a lot of video games, too.
Couldn't hurt.
> bar... ;-)
Yep. I'm impressed. :-)
Ah.
> that...
Doesn't it also return the rest of the unparsed string? So if that isn't
empty, something failed?
Date: 15 Oct 2008 16:43:42
Message: <48f655fe@news.povray.org>
Ah, OK. My office at work [where I coded this program] has no sunlight.
I don't even know if it's day or night or whatever. A bit like caving,
actually... random...
As for my bedroom at home... I just close the curtains when I want to
play HL2. ;-)
>> bar... ;-)
Heh. Actually I wrote a small library of my own that calls windows.h
directly. [You've seen the code, haven't you?] But somebody else came up
with a nice library that works on Windoze *and* POSIX, so now I'm using
that instead. So I really could compile my program for Linux or
something if I want.
> Ah.
>> fail to parse all of the input. Like, if some prefix of the input is a
>> valid expression but the rest isn't, it returns just the prefix.
>> (Obviously it depends how you structure your parser.) I must figure
Nope.
Remember, each "parser" can be combined with other parsers to make a
larger parser at any time. And it might be that the parser is only
*trying* to parse some prefix of the input.
I just asked about it, and some people recommended adding the "eof"
parser to the top-level parser. (This causes the parser to fail if the
entire input is not parsed. The error message is likely to be pretty
opaque though...)
BTW, have you tried making the parser deliberately fail? It doesn't just
crash the program, it actually reports a (moderately) friendly message
to the user. It even hilights where in your input it's upset - in case
you can't mentally work out where "column 28" is. Neat, eh? ;-)
Date: 16 Oct 2008 04:26:03
Message: <48f6fa9b$1@news.povray.org>
> wrote.
What does the result y <- #2 mean?
Try the two below:
@Element[x,{1,y}]
@Element[x,{y,1}]
The 2nd one contains the "y <- #2" result but the first one doesn't.
Also I agree with what Darren said, the dark blue used for the "<-" is a bit
too dark (visible, but hard to see, how about dark red instead?).
Date: 16 Oct 2008 04:34:31
Message: <48f6fc97$1@news.povray.org>
> Try the two below:
> @Element[x,{1,y}]
> @Element[x,{y,1}]
Consider the expression "?x: y = x". This is read as "there exists an x
such that y = x". What it "really" does is replace x with a unique
variable name (in this case, "#1").
The only reason you would do this is if you're running a recursive
predicate, so that successive recursions all get unique variable names.
Internally, all of the predefined functions except @Empty are recursive
and so use such variables.
Ordinarily, all these temporary variables either have nothing bound to
them, or are bound to a specific value. But occasionally they do show up
in the final result. In the example you give, "y <- #2" actually means
nothing at all, so the program should probably elide that. (It means
that y is equal to some temporary variable which itself doesn't have a
defined value, and hence y has no defined value - which would be the
same as the result set not mentioning y at all!)
See? This stuff is harder than it looks! ;-)
> bit too dark (visible, but hard to see, how about dark red instead?).
Hmm, yes, that *is* a little dark...
Date: 16 Oct 2008 08:26:56
Message: <48f73310$1@news.povray.org>
> Yeah, Parsec. ;-)
Wanna see the code?
Subject: Build #70 (bugfixes)
Date: 16 Oct 2008 08:56:03
Message: <48f739e3@news.povray.org>
Here it is, people: build #70.
Changes since the last released version:
- Fixed: Parser used to silently ignore invalid parts of the input, as
long as some prefix of it is a valid expression. (E.g., "x = 1 + 1"
would silently parse 'successfully' as "x = 1".) You should now get an
error message instead.
- Changed "<-" from dark blue to dark cyan. (On my system, that shows up
significantly brighter.)
Download 'logic.exe.dat' (183 KB)
Subject: Build #86 (user-defined functions)
Date: 16 Oct 2008 11:47:00
Message: <48f761f4@news.povray.org>
Well that didn't last long! Here's build #86. (I promise there won't be
any more for a while yet...)
Changes:
- The predicate "?x: a = x & b = x" now yields "a <- b" as you'd expect.
(It's a hack, so it doesn't always work.)
- Fixed a very evil bug where calling functions with certain variable
names as arguments would cause bizare malfunctions. (Basically the
variable names used inside the function clashing with the arguments
passed in. This *should* be fixed now...)
- Functions are no longer hard-wired into the program; you can define
your own! The Library.txt file (it must be called exactly that) contains
the definitions. If this file doesn't exist or is not parsable,
currently the situation isn't handled terribly gracefully.
I've included the hard-wired functions, but feel free to add your own!
Download 'logic.exe.dat' (189 KB) Download 'us-ascii' (1 KB)
Date: 16 Oct 2008 13:46:10
Message: <48f77de2$1@news.povray.org>
Actually... if you encode "numbers" as lists of 1s of the appropriate
length, then the @Join[] function essentially implements addition and
subtraction! o_O
@Join[{1, 1}, {1, 1}, z]
z <- {1, 1, 1, 1}
@Join[{1, 1, 1}, y, {1, 1, 1, 1, 1}]
y <- {1, 1}
etc.
Obviously this isn't an especially intuitive or efficient way to work,
but hey - Peano integers FTW! :-D
Subject: Re: Build #86 (user-defined functions)
Date: 16 Oct 2008 18:49:46
Message: <48f7c50a@news.povray.org>
And you wondered why Lisp has that funky "gensym" function.
Date: 17 Oct 2008 04:07:00
Message: <48f847a4$1@news.povray.org>
What is "gensym", and why does Lisp have it?
Date: 17 Oct 2008 12:09:40
Message: <48f8b8c4@news.povray.org>
It creates a guaranteed-unique variable name that you can use as a local
in a macro or a dynamically-scoped function.   What did you *think* it
might be for, given the bit I quoted and the name of the LISP function?
Date: 17 Oct 2008 13:14:44
Message: <48f8c804@news.povray.org>
Mmm, OK.
This isn't hard to do in Haskell - it's just that you have to remember
to do it! (And more subtly, do it at the correct moment.)
Date: 17 Oct 2008 13:34:41
Message: <48f8ccb1$1@news.povray.org>
Yep. Of course, in LISP, you do this all the time. When you're good at
it, about 30% of your code winds up being code-generating macros. So
figuring out where gensym goes is like figuring out whether you need
global or stack-based variables in a block-structured language. You just
crash and burn if you don't learn it.
Date: 17 Oct 2008 13:47:08
Message: <48f8cf9c@news.povray.org>
Heh. Crazy language... I thought computer science experts concluded,
like, 30 years ago that self-modifying code is actually an Extremely Bad
Idea? (Originally of course everybody thought it was "cool"...)
Date: 17 Oct 2008 13:52:44
Message: <48f8d0ec@news.povray.org>
  Code generation is not the same thing as self-modifying code.
Date: 17 Oct 2008 14:12:58
Message: <48f8d5aa$1@news.povray.org>
It's only "self-modifying code" if you modify it after it has already
been run.
Computer scientists quite like code-generating macros. They have some
pretty sophisticated ones, called "compilers".
Date: 20 Oct 2008 04:06:22
Message: <48fc3bfe@news.povray.org>
> been run.
Well, technically that's true. But Lisp macros run at runtime, not
compile time, so technically you could run the same macro twice and have
it generate different code each time...
Yeah. And as I understand it, writing one is supposedly the hardest task
in all of Computer Science. :-P
Sounds like writing one as part of your application is an excellent idea...
Date: 20 Oct 2008 11:16:01
Message: <48fca0b1$1@news.povray.org>
>> been run.
But the macro still doesn't modify the code after that code is run, so
that's OK. Having the same macro generate different code at different
places is the point of a macro.
Certainly it used to be before the theories were worked out. Writing one
that generates anything close to optimal code is difficult given the
complexity of current chips.
Yep. ;-)
