POV-Ray : Newsgroups : povray.off-topic : Database question (for Gail? :-) Server Time
19 Oct 2026 11:43:18 EDT (-0400)
  Database question (for Gail? :-) (Message 1 to 13 of 13)
Subject: Database question (for Gail? :-)
Date: 7 Oct 2008 02:43:06
Message: <48eb04fa$1@news.povray.org>
Say you're doing some accounting stuff, and you have different kinds of
accounts, but you want a table of movements of money between the
accounts. I'm trying to figure out how to get the details of having a
single record split over one of any of several different tables to be
enforced by constraints.
For example, I have a savings account type, a checking account time, a
credit card account type, etc. Obviously the credit card account is
going to have a CC#, an expiration date, etc. The savings account might
have some other paramters like guaranteed interest rate or something. So
obviously they can't all be in the same table.
Here, I'm trying to figure out how you would set up the parent account
such that you can't have a parent account with an account type of
"savings" without having a corresponding entry in the savings account.
Are triggers the only way to ensure this? (I mean, other than obviously
writing the insert statements correctly. :-) A simple foreign key
restraint keeps it going in the other direction.
So you'd put one table in with the account ID and anything that's common
to all accounts (owner, creation date, etc) and other tables, one for
each kind of account. And then anything that can reference multiple
kinds of accounts (like a transfer of money) would have a FK into the
account table.
// Using awful syntax because I'm too lazy to look it up...
create table account (
   id autoinc integer,
   acctnumber varchar(50),
   accttype enum (savings, checking, ...),
   owner integer
   primary key id
   owner foreign key customers.id
create table savings (
   id integer,
   interestrate decimal,
   foreign key id is account.id
create table creditcard (
   id integer,
   exxpirationdate date,
So all savings accounts have details in the savings table, with a
foreign key into the master account table. But what keeps a record in
the account table from losing its corresponding record in the savings table?
Thanks for thoughts. :-)
Subject: Re: Database question (for Gail? :-)
Date: 7 Oct 2008 16:07:47
Message: <48ebc193@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:48eb04fa$1@news.povray.org...
> accounts, but you want a table of movements of money between the accounts.
> I'm trying to figure out how to get the details of having a single record
> split over one of any of several different tables to be enforced by
> constraints.
You'd probably need triggers. It's hard to enforce a 1-1 relationship
without.
Depending how many columns are only applicable to one account type, I might
take a short cut and put everything in one table. It does depend though.
Date: 8 Oct 2008 03:11:31
Message: <48ec5d23$1@news.povray.org>
> without.
Thanks!  I just wasn't sure if there was something clever I was missing.
> might take a short cut and put everything in one table. It does depend
> though.
That doesn't really solve the consistency problem, tho. You could still
wind up with an account where all the details are null, for example. I
think SQL is just a bit too lacking in its data definition language to
enforce some of the more complex constraints (without triggers, at least).
Date: 8 Oct 2008 03:40:24
Message: <48ec63e8@news.povray.org>
news:48ec5d23$1@news.povray.org...
>> though.
For that you could use check constraints.
ALTER TABLE Accounts ADD CONSTRAINT ck_AccountType CHECK (AccountType =
'CreditCard' AND exxpirationdate IS NOT NULL)
etc
Date: 8 Oct 2008 05:54:37
Message: <48ec835d$1@news.povray.org>
Ah. Very cool.  Sadly, this is MySQL, which sucks, so altho it parses
check constraints, it doesn't actually enforce them.  Welcome to the
wonderful world of toy RDBMs.
Date: 8 Oct 2008 09:48:45
Message: <48ecba3d@news.povray.org>
Not even in InnoDB?
Date: 8 Oct 2008 10:20:01
Message: <48ecc191@news.povray.org>
news:48ec835d$1@news.povray.org...
Oh lovely. Don't suppose you can port it to SQL Server? Express edition's
free.
Does MySQL enforce foreign keys yet?
Date: 8 Oct 2008 14:41:11
Message: <48ecfec7$1@news.povray.org>
Nicolas Alvarez wrote:
> Not even in InnoDB?
Foreign keys, yes. Check constraints, no. At least not in 5.0 docs.
Date: 8 Oct 2008 14:41:39
Message: <48ecfee3$1@news.povray.org>
> edition's free.
No. I definitely think in the future I'll pick postgresql for Linux
production DBs.
Only sometimes.  That is, there are different back-end storage
mechanisms, and only one actually enforces FKs and transactions.
Otherwise you're pretty screwed.
Maybe the bleeding edge allows it, but I haven't seen it.
Date: 9 Oct 2008 06:57:34
Message: <blore4tu23l41kcp4imii5fm7njm416j92@4ax.com>
I think you're really asking for trouble splitting this info up into separate tables,
since it is all account id specific.  You WILL get inconsistent data at some point.
I'd suggest to just suck it
up and put all of the columns into one table, like this...
   id autoinc integer,
   owner integer,
// start of account type specific columns
// end of account type specific columns
   primary key id
Date: 10 Oct 2008 03:35:16
Message: <48ef05b4$1@news.povray.org>
tables, since it is all account id specific.  You WILL get inconsistent data at some
point.  I'd suggest to just suck it
Likely correct. This doesn't really help too much if you don't have
check-constraints tho. Having them in separate tables has the benefit
that you don't need to store the empties for fields that aren't
applicable, and you can add a new type of account without having to frob
the big table. Of course, if it's easy to enforce data consistency one
way and not the other, that pretty much trumps things. :-)
Date: 10 Oct 2008 07:44:44
Message: <4ffue45aajrv4o735odm9bf0mbrm7np0o9@4ax.com>
You would still want a check constraint, driven by the account type.
>applicable,
Does MySql use much space for null values?  Either way, that's really a non-issue,
compared to the benefit of data integrity.
>the big table.
It boils down to "alter big-table" vs. "create new-table".  With "create new-table",
you'd additionally have to set up foreign key constraints back to the big table's
primary key.  You'd have to
modify the check constraint in either case.
Date: 10 Oct 2008 10:43:56
Message: <48ef6a2c@news.povray.org>
Sure. MySql doesn't support them, tho.  Definitely gonna use postgresql
for the next project I get to start from scratch. :-)
I think I said that. :-)
>> the big table.
Sure. With "create new-table", you don't have to worry about whether you
broke any part of the program that doesn't deal with the new types of
accounts, at least.  But it's really half of one, a dozen of the other,
I'll agree. :-)
