POV-Ray : Newsgroups : povray.off-topic : You lose some... Server Time
19 Oct 2026 11:43:15 EDT (-0400)
  You lose some... (Message 1 to 31 of 31)
Subject: You lose some...
Date: 4 Oct 2008 14:37:18
Message: <48e7b7de$1@news.povray.org>
Hmm, and I though everything was going so well. :-/
OK, any C++ experts have any idea why this code snippet causes my
program to crash at runtime?
   typedef std::vector<bool> Codeword;
   std::string codeword(const Codeword &c)
     std::string out;
     for (unsigned int i=0; i<c.size(); i++)
       if (c[i]) out.append("1"); else out.append("0");
     return out;
"Unhandled exception at 0x00414166 in Huffman01.exe: 0xC0000005: Access
violation reading location 0x00000004."
The code looks fine to me - but what I do know?
http://blog.orphi.me.uk/
Subject: Re: You lose some...
Date: 4 Oct 2008 15:51:54
Message: <48e7c95a@news.povray.org>
>      std::string out;
>      return out;
  I can't see anything wrong with it, and I tried it and there was
nothing wrong with it. The error must be somewhere else.
  If you are running it in linux, try running it using valgrind (if you
don't have it, install it; it's essential). In other words:
valgrind ./yourprogram
  If will tell you if you have some out-of-bounds access or memory leaks.
Date: 4 Oct 2008 16:09:39
Message: <48e7cd83$1@news.povray.org>
Right. So maybe I'm passing it a reference to something that doesn't
exist anymore then?
M$ Visual Studio is telling me something is wrong, but it isn't telling
me much beyond that. (I probably need to figure out how to work the
debugger first...)
Date: 4 Oct 2008 16:47:23
Message: <48e7d65b@news.povray.org>
> exist anymore then?
  Without seeing the whole program it's impossible to tell.
  Btw, have you been using the at() function rather than operator [] like
I have been suggesting?
> debugger first...)
  Just compile in debug mode and run the debugger (F5).
  However, the Visual Studio debugger won't tell you if you have, for
example, a memory leak. The place where the program crashes (which will
be shown by the debugger) is not necessarily the place where the bug is.
It might be able to tell you if you are writing out of bounds or accessing
freed memory, but not necessarily. Valgrind will be able to do that.
Unfortunately, AFAIK, valgrind is not available for Windows or VS projects,
so you'll have to do the testing in linux.
  (Profilers like valgrind which support VS programs in Windows exist,
but I know of no free one.)
Date: 4 Oct 2008 18:27:56
Message: <48e7edec$1@news.povray.org>
True; sometimes you have to step carefully through the program to see what
it's doing and figure out where your memory management is going wrong. In
this case though, the error is
Access violation reading location 0x00000004 means it's very likely you're
dereferencing a NULL pointer somewhere, because of how close 4 is to 0. (The
program is taking a NULL pointer, treating it as a struct or class of some
sort, and trying to get the member that is 4 bytes into it.) So, if you just
hit F5 and run the program as usual, it will tell you right where it is when
it crashes by pointing at the line. You can also look at the call stack pane
to see how it got there. It will probably be easy to see what the NULL
pointer is.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 4 Oct 2008 18:31:23
Message: <48e7eebb@news.povray.org>
This isn't the cause of your crash, but I recommend not squishing your code
together like that. Keep each statement on a separate line and use brackets
around anything that's not a single simple statement:
    for ( unsigned int i = 0; i < c.size(); i++ )
        if ( c[i] )
            out.append( "1" );
        else
            out.append( "0" );
Also put spaces around your operators like "=", "+" and "<". Readable code
is superior to short code.
 - Slime
Date: 5 Oct 2008 00:42:08
Message: <48e845a0$1@news.povray.org>
>         if ( c[i] )
>             out.append( "1" );
>         else
>             out.append( "0" );
If he wants brevity he could also code it like this:
  for (int i = 0; i < c.size(); i++)
    out.append(c[i] ? "1" : "0");
which is just as valid and avoids running the if/else together.
-- Chris
Date: 5 Oct 2008 05:17:59
Message: <48e88647$1@news.povray.org>
Yeah, seems plausible. (Except that I'm not using pointers anywhere,
only references.)
> So, if you just
> pointer is.
It's somewhere inside vector.cpp. (And the code makes *no sense* to me
at all. The comments mumble something about copy constructors though...)
Now if I could somehow figure out which part of *my* code is calling the
failing routine, and with what arguments, I'd have a shot...
Subject: Some code
Date: 5 Oct 2008 05:28:31
Message: <48e888bf$1@news.povray.org>
Well, the program isn't that large, so just for a giggle I'll include it
here. The compiler claims there's nothing wrong with it, but clearly
there is. I can't wait to see how many different kinds of mistake I've
made... :-}
#include <iostream>
#include <vector>
#include <string>
typedef char Symbol;
   std::string out;
   return out;
class SymbolInfo
public:
   Symbol symbol;
   double prob;
   Codeword code;
   SymbolInfo(Symbol s, double pr) : code()
     symbol = s;
     prob = pr;
   void prefix(const bool p)
     code.push_back(p);
class Tree
public:
   Tree(SymbolInfo& s) : symbols()
     symbols.push_back(s);
     prob = s.prob;
   void join(const Tree& tree)
     for (unsigned int i=0; i<symbols.size(); i++)
       symbols[i].prefix(false);
     for (unsigned int i=0; i<tree.symbols.size(); i++)
       SymbolInfo s = tree.symbols[i];
       s.prefix(true);
       prob += s.prob;
   const Codeword& lookup(const Symbol key)
       if (symbols[i].symbol == key) return symbols[i].code;
   const double Prob() {return prob;}
private:
   std::vector<SymbolInfo> symbols;
   double prob;
const Tree& build_tree(std::vector<SymbolInfo> info)
   std::vector<Tree> trees;
   for (unsigned int i=0; i<info.size(); i++)
     Tree t(info[i]);
     trees.push_back(t);
   while (trees.size() > 1)
     int index = 0;
     for (unsigned int i = 1; i<trees.size(); i++)
       if (trees[i].Prob() < trees[index].Prob()) index = i;
     Tree t0 = trees[index];
     trees.erase(trees.begin() + index);
     index = 0;
     Tree t1 = trees[index];
     t0.join(t1);
     trees.push_back(t0);
   return trees[0];
int main()
   SymbolInfo A('A', 0.5);
   SymbolInfo B('B', 0.25);
   SymbolInfo C('C', 0.125);
   SymbolInfo D('D', 0.125);
   symbols.push_back(A);
   symbols.push_back(B);
   symbols.push_back(C);
   symbols.push_back(D);
   Tree t = build_tree(symbols);
   std::cout << "A: " << codeword(t.lookup('A')) << std::endl;
   std::cout << "B: " << codeword(t.lookup('B')) << std::endl;
   std::cout << "C: " << codeword(t.lookup('C')) << std::endl;
   std::cout << "D: " << codeword(t.lookup('D')) << std::endl;
Date: 5 Oct 2008 05:43:27
Message: <48e88c3f@news.povray.org>
> It's somewhere inside vector.cpp. (And the code makes *no sense* to me at
Yeah, the STL code provided with visual studio is very unreadable.
You need to find the call stack window. It will give you a list of the
functions that called each other to get where the code is currently
executing. It should be one of the tabs along the bottom when debugging, or
you might have to look through the menus (under "window" or "debug") to turn
it on. Then you can double click on each level of function call and see what
its local variables' values are.
 - Slime
Subject: Re: Some code
Date: 5 Oct 2008 06:00:38
Message: <48e89046@news.povray.org>
>   return trees[0];
You are returning a reference to a local variable. When the function
finishes, trees' destructor will be called and all of its contents will be
deallocated. So you're returning a reference to invalid memory. If you're
not worried about copying Trees around, you can just remove the & from the
return type.
You might also want to assert( trees.size() > 0 ) to make sure the function
worked properly and there's something there to return.
That's the only actual problem I see. Otherwise I'm a little worried,
efficiency-wise, about how many vectors you're copying around, but that may
not be worth worrying about at this stage.
 - Slime
Date: 5 Oct 2008 06:08:17
Message: <48e89211$1@news.povray.org>
>>   return trees[0];
DOH!! >_<
Yeah, that can't be good...
The loop right above that is while(trees.size() > 1). Each pass of the
loop removes two trees and inserts one tree.
Yeah, that too...
Date: 5 Oct 2008 06:26:19
Message: <48e8964b$1@news.povray.org>
>> function worked properly and there's something there to return.
It definitely matters less when you're the only one editing the code, but
asserting things like this is still a good habit to get into. I noticed that
the loop had that behavior, but what if:
 - The loop didn't work as intended and sometimes, for instance, broke out
before inserting the new element?
 - The loop works right, but at a later date you change it for some
unrelated reason and break it in a subtle way?
 - trees.size() is 0 in the first place? This could happen if an empty
vector was passed in.
The alternative to adding an assert is a small risk that at some point in
the future you'll spend hours tracking down a crash. The more asserts you
use, the more time you'll save! It takes time to learn where to add them,
and I admit I went for years without using a single one. Once you start to
use them consistently, you can be surprised at how frequently you see them
fail, and you learn more about your own potential to make mistakes.
By the way, I wouldn't have recommended adding that assert if the loop were
while( trees.size() != 1 ), since that would make the assert perfectly
redundant. Of course in that case, I would assert that trees.size() >= 1
before the loop to make sure the loop could work properly.
 - Slime
Date: 5 Oct 2008 06:36:40
Message: <48e898b8@news.povray.org>
  In this case the error messages given by valgrind wouldn't have been
the clearest possible, but they nevertheless point to this line being
the ultimate culprit (which, ultimately, is caused by build_tree() returning
a reference to a local variable).
  Anyways, I'm wondering why you are passing the parameter by value rather
than by const reference...
Date: 5 Oct 2008 07:49:31
Message: <op.uiju4thu7bxctx@e6600>
On Sun, 05 Oct 2008 06:42:07 +0200, Chris Cason
The compiler would likely warn about the signed/unsigned comparison in the
loop condition. The proper type for the index is Codeword::size_type.
He could also skip the conditional in the loop body entirely:
std::string codeword( Codeword const& c )
	std::string out;
	for( Codeword::size_type i = 0; i < c.size(); ++i )
		out += ( '0' + int(c[i]) );
	return out;
FE
Date: 5 Oct 2008 08:06:28
Message: <48e8adc4@news.povray.org>
>         std::string out;
  Also after this it can be a good idea to do:
          out.reserve(c.size());
  This will make it slightly more efficient because it avoids reallocations
later, when the string is filled with that many characters.
Date: 5 Oct 2008 08:50:32
Message: <48e8b818$1@news.povray.org>
Yeah. I guess since the error only came to light when I added a new
function, I assumed that the new function must be the problem. In fact
it was just exhibiting a problem that already existed...
Ooo, well spotted. That's simply an oversight on my part. Since all the
syntax is still kinda new to me, I keep forgetting to write bits. (E.g.,
the compiler keeps complaining that I'm using signed integers to index
things.)
Date: 5 Oct 2008 08:52:26
Message: <48e8b88a$1@news.povray.org>
OK, fair enough.
There probably *should* be an assert to check that the vector passed in
is non-empty...
Date: 5 Oct 2008 08:55:38
Message: <48e8b94a$1@news.povray.org>
Ooo, I like that. (It makes it clear that append() is always called, and
it's only the argument that changes depending on c[i].)
Date: 5 Oct 2008 08:59:19
Message: <48e8ba27$1@news.povray.org>
Slime wrote:
> If you're
> return type.
Changing this single character makes my program work as intended. Yay me!
I guess the efficient thing to do would be to have the caller allocate
an empty tree and pass it in by reference and mutate that... Hmm, but
how to be sure the tree passed in is empty? I guess I could just add
another assert() for that...
Date: 5 Oct 2008 09:35:28
Message: <48E8C2ED.3070400@hotmail.com>
>>         if ( c[i] )
>>             out.append( "1" );
>>         else
>>             out.append( "0" );
Didn't we code that more like out.append("0" + c[i]) just to confuse the
readers?
Date: 5 Oct 2008 09:51:11
Message: <op.uij0rkwh7bxctx@e6600>
On Sun, 05 Oct 2008 15:36:45 +0200, andrel <a_l### [at] hotmailcom>
> readers?
Nitpick: It has to be '0', not "0".
You could also do it like this:
	out += c[i]["01"];
If you were in a particularly foul mood, you could write it like this:
	out += c??(i??)??("01"??);
FE
Date: 5 Oct 2008 09:51:41
Message: <48E8C6BB.4040202@hotmail.com>
>>> your code together like that. Keep each statement on a separate line
>>> and use brackets around anything that's not a single simple statement:
>>>         if ( c[i] )
>>>             out.append( "1" );
>>>         else
>>>             out.append( "0" );
> readers?
Been a long time since I actually did write sufficient amount of C. :( I
think I meant the character constant '0' and not the string "0".
Date: 5 Oct 2008 09:54:55
Message: <48E8C77C.9060509@hotmail.com>
>> the readers?
Yeah I remembered too late.
>     out += c[i]["01"];
Is that C or C++?
what += does??(that??)??("Mean"??)
Date: 5 Oct 2008 10:03:35
Message: <op.uij1b8k97bxctx@e6600>
On Sun, 05 Oct 2008 15:56:12 +0200, andrel <a_l### [at] hotmailcom>
>>     out += c[i]["01"];
> Is that C or C++?
Either.
??( is an alternative token for [. Similarly for ??) and ].
FE
Date: 5 Oct 2008 10:38:24
Message: <48E8D1AE.7020501@hotmail.com>
I don't remember that one. I seem to have dislocated my k&r and bjarne
books and I seem not to be able to find that on the web either. Are you
sure that that isn't just a compiler/hardware specific hack?
Date: 5 Oct 2008 11:12:44
Message: <48e8d96c@news.povray.org>
http://en.wikipedia.org/wiki/C_trigraph
Date: 5 Oct 2008 11:18:35
Message: <op.uij4s9vt7bxctx@e6600>
On Sun, 05 Oct 2008 16:39:42 +0200, andrel <a_l### [at] hotmailcom>
Yes, I am sure. They are called trigraphs and are listed in section 2.3 of
the C++ standard.
Strictly speaking, they are not actually alternative tokens. They are
substituted before any other processing of the source.
There is a set of actual alternative tokens though. They are sometimes
called digraphs. You could thus write:
	out += c<:i:><:"01":>;
FE
Date: 5 Oct 2008 11:46:46
Message: <48E8E1B4.3050004@hotmail.com>
Thanks warp and frederick. This wiki page still keeps me wondering when
these trigraphs were introduced. Must be before the 1994 digraphs (which
is indeed long after my sort of formal training in C).
I could not find them with google. searching for ??) did not give any
result. Any of the google wizards know what I should have asked? (Apart
from trigraph, because that was the term I didn't know, otherwise I
would not be looking)
Date: 5 Oct 2008 12:22:55
Message: <op.uij7sgtx7bxctx@e6600>
On Sun, 05 Oct 2008 17:48:04 +0200, andrel <a_l### [at] hotmailcom>
wrote:
> This wiki page still keeps me wondering when these trigraphs were
> introduced. Must be before the 1994 digraphs (which is indeed long after
Late eighties I think.
FE
Date: 5 Oct 2008 17:31:07
Message: <48e9321b$1@news.povray.org>
Orchid XP v8 nous illumina en ce 2008-10-04 14:37 -->
>     std::string out;
>     return out;
Maybe you have an uninitialised pointer.
Do you get any output? If you don't, it mean that the variable "c" don't get
initialised properly.
Look at the caller. Maybe the variable that is supposed to be passed is in fact
a null, or an uninitialised pointer, or maybe a constant.
"The way England treats her prisoners, she doesn't deserve to have any."
        --Oscar Wilde
