Last week I decided to try my hand at making a fractal program, to test
some ideas. I may have come up with a new variation of the Mandelbrot.
Here are some snapshots from a few areas:
http://i447.photobucket.com/albums/qq199/stbenge/complex1o.jpg
http://i447.photobucket.com/albums/qq199/stbenge/complex1p.jpg
http://i447.photobucket.com/albums/qq199/stbenge/complex1q.jpg
The program itself is fairly simple. It can only zoom in and reset the
view. To get different resolutions I have to recompile the code. I need
to implement antialiasing. Also the logarithmic smoothing isn't perfect
yet, but looks better than it would if I just returned the iteration steps.
I would rather just use a program already geared towards
user-friendliness, since I'm lazy when it comes to the boring aspects of
programming (Windows API stuff). Does anyone know of a good fractal
generator that lets you alter the parameters at a low, less-abstract
level? I don't mean z=z+c, but rather something like xx=x*x-y*y,
yy=x*y*2. It would have to allow me to use mathematical expressions
since I make use of min(n,n) for the more interesting fractals I've come
up with. I wonder if Fractint would allow me to do that...
Sam
Yeah, FractInt will do it. The syntax is something like
x = real(z);
y = imag(z);
z = {x*x - y*y, 2*x*y};
off the top of my head...
The fun part - apparently - is getting FractInt to actually run any
more. Being an old MS-DOS program that manually frobnicates the video
hardware in advanced ways, it doesn't tend to run very happily under
Windoze. (Indeed, you might have more luck with the Linux port...)
Winfract?
Regards
> Winfract?
If you check the other newsgroup, Warp posted a lovely little Haskell
program that prints out the Mandelbrot set in ASCII art. ;-)
>> Winfract?
Sorry, what other newsgroup?
Regards
> Winfract?
For some reason I read that as "Winfarct?". That would even have made
sense as a description of the what happens when you manipulate the video
directly under windoze.
I was actually kidding.
(But if you have a look at the Haskell groups on this news server...)
>> Winfract?
Is it my accent? ;)
Too true :)
And Winfract does not do colour cycling :(
Regards
You got me :) but I've seen a Mandelbrot in ASCII art.
Lordy, there is a lot there :)
Regards
And there is, in fact, a Haskell program from Warp that generates one.
(He's learning Haskell, apparently.) Obviously, being a beginner's
program, it's not really useful for much other than learning about
Haskell - so my suggestion to use it instead of FractInt was the part I
was joking about.
There is indeed a lot there - and much of it is from a Finnish guy, but
I'm fairly sure there's no Lordy in there. ;-)
Pretty. JPG is probably not the way to go with fractal images, tho. :-)
Invisible wrote:
> x = real(z);
> y = imag(z);
I checked around and found ChaosPro(free), which allows one to build
expressions like the one you placed above. It uses a C-like syntax which
is just fine with me :) You can built your own functions. For instance,
I made new min() and max() functions to manipulate complex numbers. Now
if I can just replicate the same fractal I posted here with the program
:/ I came up with something which looks like it superficially, but upon
closer examination, looks like a cheap knock off. Less detail... I must
be doing something wrong. (like staying up till three working on
fractals ;))
It pisses me off that MS dropped DOS. Now all I can do is run this lousy
DOS-box. It supports some games, but not any programs I have made to run
under DOS SVG modes >:(
stbenge wrote:
> I must
> fractals ;)
Er... yuh-huh. ;-)
I'd say "use a virtual machine", except that'll be... a tad... slow.
http://blog.orphi.me.uk/
Darren New wrote:
>> test some ideas. I may have come up with a new variation of the
>> Mandelbrot.
Not if I want to preserve the detail and color intensity... but I have
dialup over here, so posting PNGs might have been prohibitive. That's
life in the sticks :/
After hacking and slashing my way through ChaosPro's syntax and coloring
methods, I have finally recreated one of my fractals:
http://i447.photobucket.com/albums/qq199/stbenge/complex1qCP.jpg
It's exactly the same fractal! Up until a little while ago all my
attempts looked like cheap toy replicas of the real thing, and I was
beginning to wonder about the quality of ChaosPro. I still need to work
on the coloring method, to make it more smooth, but this is some
progress :) I can now convert all my fractals over to CP and render them
with AA, changed resolutions, etc.
Well I'm excited anyway, even if nobody else is :)
Sam
