Hey what is it with women and hammers? Before I get flamed I'll admit that
this maybe an unfair generalization because I'm sure there are just as many
Men and Hammers stories out there .... it just seems the gals have it hands
down for the comedic content alone.
I started getting busy with fall chores, one of them service the lawn mower.
I'd got the blade off to be sharpened, drained the oil and refilled it, then
the firewood guy shows up. I still had to change the spark plug but needed
to go help with the unloading. The wife decided to be helpful and when she
couldn't get the spark plug to budge with the socket wrench she takes a
hammer to it!!!!! Lord help me ..... what's a guy to do?
OK, so tell me now I'm not the only one with women and hammers stories.
Jim
My mum once tripped over while carrying an electric drill and
accidentally drilled a hole in her arm...
"Invisible" <voi### [at] dev null> wrote in message
news:48db82d1$1@news.povray.org...
> My mum once tripped over while carrying an electric drill and accidentally
yikes that had to hurt!!!!
wife has nailed her shirt tail to a saw horse once
If violence didn't help, you didn't use enough force. Having a hammer
makes applying more force to violence easy.
> Jim
Eero "Aero" Ahonen
http://www.zbxt.net
aer### [at] removethis zbxt net invalid
Well... a trip to hospital, a mild muscle infection, a few months off
work, that kinda thing.
Heh. My mum screwed me and my sister to a plank of wood...
> mower. I'd got the blade off to be sharpened, drained the oil and refilled
> it, then the firewood guy shows up. I still had to change the spark plug
> but needed to go help with the unloading. The wife decided to be helpful
> and when she couldn't get the spark plug to budge with the socket wrench
> she takes a hammer to it!!!!! Lord help me ..... what's a guy to do?
Teach her to use her foot, or show her how you can attach a length of piping
to the wrench to get a better mechanical advantage. I find that 1 metre
usually undoes most things (unfortunately it also undid the top of a bolt
from the bolt itself once, but hey).
OTOH, it's cool that a) she tried to help out on something like that without
even being asked, and b) that she had a rough idea what needed doing. My
other half wouldn't have a clue, and even if you paid her wouldn't go
anywhere near something loud and dirty like a mower.
1. You sharpened the blade? I've never seen anybody do that, ever.
2. The mower isn't electric?
news:48db8818$1@news.povray.org...
>> refilled it, then the firewood guy shows up. I still had to change the
>> spark plug but needed to go help with the unloading. The wife decided to
>> be helpful and when she couldn't get the spark plug to budge with the
>> socket wrench she takes a hammer to it!!!!! Lord help me ..... what's a
>> guy to do?
yep .... have a grinder. I usually sharpen every other year. that's the
mower for the close in stuff. the tractor has 5 blades I take them to a shop
for those.
haha ..... big yard extension cords not long enough.
And the correct technic to check that the wrench actually turns to a
right direction. Some ASCII-art, seen from top, "b" is bolt, g is
grabbing-place of wrench
| g
|b--|
And seen from side (just wrench and bolt)
b
|---g
And from the front:
|b--g
If you'll just press the wrench down directly, it won't only try to
unscrew the bolt, but also turn itself (and the bolt) downwards looked
from the bolt (pic from front):
|b-_
| g
So you'll need something to hold the wrench vertical while turning it
(pic from front, H is just right sized object to keep the wrench vertical):
|b--g
| H
I hope I and my ASCII are understandable...
Eero "Aero" Ahonen
http://www.zbxt.net
"Invisible" <voi### [at] dev null> a écrit dans le message de news:
And you tell there are scary people here?
Marc
"Jim Holsenback" <jho### [at] hotmail com> a écrit dans le message de news:
48db8a59@news.povray.org...
> shop for those.
It is less painfull when you cut your own toes with a sharpened blade >:-)
With electric mowers, the 1st thing you're likely to cut is the power cord
but before you have to slaughter flower beds with it and mess it between
trees and shrubs :-)
Marc
Your mother should never ever be allowed near power tools again. Ever.
~Mike
Mmm, the old "I learned a new programming technology" axiom. "When all
you have is a hammer, everything looks like a nail"
~Mike
Its a good thing to do occasionally. This way it cleanly cuts the grass,
rather than shredding it.
Whats real fun is to run a thatch blade over a lawn. Actually buying one
got incredulous looks from the "know-it-all" at the hardware store who
proceeded to lecture me about how he's been mowing his lawn for some 15
years and never needed one.
Bermuda grass needs to be thatched occasionally, or it strangles the
soil. That year, I had the nicest, lushest, greenest lawns on the block,
though it looked like hell immediately after the dethatching.
There's electric mowers? I'd be a bit paranoid about running over the cord.
~Mike
I would like the record to show the following:
This experience was rather painful for both my sister and me. When my
mum realised what was going on, she immediately tried to put the drill
into reverse drive.
Unfortunately, she put the drill into hammar action instead.
This not only tightened the screws even further, but also hammars our
fingers.
Finally she found reverse, releasing my sister, who she then rushed
indoors and put her fingers under the cold tap. I, however, was still
trapped. I can vividly remember my sister's pained expression as she
looked up from the sink and saw me still trapped.
And laughed at me! >:-[
She didn't, like, *tell* mum I was still trapped or anything. She
just took there and laughed at me through the kitchen window.
Damnit.
Well, that used to be her _job_...
[Which is why she even owns power tools. She certainly didn't *buy* them
herself!]
http://blog.orphi.me.uk/
That's not scary - just incompetent.
There's also the time she walked into a concrete bollard and went
face-first into the pavement.
Or the time she stepped backwards down a small half-step and twisted her
ankle.
Or the time she accidentally amputated her entire fingernail because she
couldn't be bothered to use the safety guard on the new vegatable slicer
she bought.
Or the time she took skiing lessons and twisted her angle. (My mate
who's a ski race coach tells me this is physically impossible since the
boots prohibit the movement of the ankle.)
I'm not saying my mum's clumsy or reckless or anything, but...
Oh, OK. I just assumed it was impossible for a mower to work well...
The cord is neon orange for a very good reason. In all my years of being
alive, I have almost never seen a petrol mower (except the big
industrial ones for mowing parks and greens and such). I have also never
seen anybody actually cut their power cord while mowing either.
When was the last time you ran your vacuum cleaner over the power cord?
Or is that petrol-powered too? ;-)
> into reverse drive.
> fingers.
Again, let me reiterate what I said *your mother should never be allowed
near power tool again. Ever.* Holy crap!
> She didn't, like, *tell* mum I was still trapped or anything. She just
> Damnit.
Its a wonder you came out as close to 'normal' as you did, and didn't go
all Ted Bundy.
> herself!]
Good gods ... someone paid her to use power tools? 0,o Be very afraid ...
~Mike
> ankle.
> she bought.
Seriously. Take all the power tools, sharp objects, heck anything that's
not soft and padded, lock it up and throw away the key. I'm shocked you
(your sister and your mother) have managed to survive at all!
~Mike
Just the other day, as a matter of fact. :)
And no, not gasoline powered. Electric is already loud enough. :)
~Mike
>> cord? Or is that petrol-powered too? ;-)
Really?
Hmm, ours has a spinning brush on the underside. The one time somebody
run over the cable, it chewed up the insulation on it. :-/
Heh. Just imagine, a petrol-powered vacuum cleaner... Surely your house
would end up more dirty than when you started! :-D
Tell me about it!! o_O
Should I even tell you about when my mum and dad first brought me home
from hospital, and it took them 4 hours to figure out why I wouldn't
stop crying?
It was like a scene from a badly scripted sitcom. Except... real. o_O
> all Ted Bundy.
Uh.......
>> them herself!]
Yes. British Telecom used to pay her to go round people's houses and
wire up their telephones. Obviously, this involves drilling holes
through walls and climbing ladders to each overhead cables. Not to
mention the climbing through trees and driving to deserted farmer's
fields in a large Ford Transit...
On Thu, 25 Sep 2008 19:02:35 +0100, Orchid XP v8 <voi### [at] dev null> wrote:
So that you can see the cord you just cut in half?
A gas powered vacuum would be awesome.
"Kyle" <hob### [at] gate net> a écrit dans le message de news:
0prnd4dd068bichsucnbdr9crfju5u9ocj@4ax.com...
Steam and coal as in Wild wild West
Marc
> stop crying?
Well, I'm sure the instruction manual you were delivered with didn't
cover it. ;-)
(As I've said before, babies don't come with instruction
manuals.....parents just do the best they can with what they've got....)
Jim
This is my dad's mower. Seriously. "Wolf" is a friend of mine describing
it, and every word is true.
http://cellar.org/showpost.php?p=131059&postcount=311
"Darren New" <dne### [at] san rr com> a écrit dans le message de news:
48dc10cc$1@news.povray.org...
>> cord but before you have to slaughter flower beds with it and mess it
>> between trees and shrubs :-)
Arghhhh !
Marc
Marginally more understandable I suspect than if you had talked about
torques in 3D ;-)
Petrol lawn mowers, as well as not needing a cable, are usually much more
powerful, so you can charge through quite long wet grass that likely would
block up an electric one.
> I have also never seen anybody actually cut their power cord while mowing
> either.
A friend of ours borrowed our electric hedge cutter, she cut through cord.
Then she borrowed it again, and we joked to her about not cutting through it
again. Of course she cut through it *again*. She can go and buy her own
one now.
Erm, the whole time actually, but the consequences aren't nearly as bad,
plus it's a pain in the ass having to rearrange the cable and keep
plug/unplugging it the whole time as you move around the house, getting it
tangled around chairs/tables etc.
> Hmm, ours has a spinning brush on the underside. The one time somebody run
Oh, mine doesn't have the spinny brush bit on the main unit, only at the end
of the pipe.
Nah, you just store the exhaust on-board in a canister, then dispose of it
once it's full. Or have the engine part outside, and a long pipe :-)
> into reverse drive.
Ok. So what on Earth was the meaning of that experiment? :O
Eero "Aero" Ahonen
http://www.zbxt.net
Fortunately, babies don't come with a warranty either. Cos my parents
would have taken me back as "damaged goods". o_O
> torques in 3D ;-)
I actually started thinking that maybe I should trace the situation (and
reveal the code), 'cause it would be easier to understand ;).
Eero "Aero" Ahonen
http://www.zbxt.net
> end of the pipe.
They call it a "beater bar", apparently. These's a little switch to
deactivate it. (It's actually just a lever that pulls the drive belt
tight or slack.)
>> house would end up more dirty than when you started! :-D
> it once it's full.
The laws of thermodynamics seem to suggest this wouldn't work too well...
Apparently that's how the first vacuum cleaners worked...
>> my mum realised what was going on, she immediately tried to put the
>> drill into reverse drive.
She was actually trying to screw a wooden frame together, but the weight
of it kept making it twist, so she got me and my sister to hold it still
while she did the screws up with an electric drill.
Unfortunately, the only possible way to hold it still... was... to put
your fingers in the way...?
> deactivate it. (It's actually just a lever that pulls the drive belt tight
> or slack.)
Yep, it's the bit that gets all the hairs tangled around it making it hard
to turn ;-) On mine the beater bar is powered by the air-flow, because it's
at the end of the pipe.
Use a balloon stretched over the exhaust pipe then :-)
The warranty would only cover manufacturer defects anyway. Damages
caused by, say, accidentally screwing you to a board wouldn't be covered
by the warranty :)
~Mike
> by the warranty :)
LMAO!
Thanks for that... :-)
> it once it's full. Or have the engine part outside, and a long pipe :-)
No, you store the canister and engine outside, and just use a really
long hose.
http://home.howstuffworks.com/central-vacuum.htm
> ankle.
> she bought.
Your mom should be kept as far from power tools as Ethan.
What are you doing posting ASCII art on *this* newsgroup, when you could be
posting a raytraced image? :)
Maybe I posted my previous message too soon (= before reading this one).
LOL
Nnnnnnnice.
Eero "Aero" Ahonen
http://www.zbxt.net
Because it's povray.*off-topic*.
Eero "Aero" Ahonen
http://www.zbxt.net
Heh, that's a little unfair...
...Ethan built a sentient Xbox! ;-)
>> be posting a raytraced image? :)
Heh, fair enough :)
>> got....)
Nah, I'd doubt that....
Jim
> Nnnnnnnice.
Clamps are a wonderful thing.
~Mike
