POV-Ray : Newsgroups : povray.off-topic : Sometimes, Haskell wins Server Time
3 Nov 2026 02:46:24 EST (-0500)
  Sometimes, Haskell wins (Message 1 to 33 of 33)
Subject: Sometimes, Haskell wins
Date: 22 Sep 2008 08:07:46
Message: <48d78a92$1@news.povray.org>
Some guy invented a language which he calls "Markdown":
   http://daringfireball.net/projects/markdown/
It's a markup langauge that looks almost like plain text, but he wrote a
Perl script that can transform it into HTML with pretty formatting.
(Stuff like lines prefixed with "-" become bullet points, words unclosed
with "*" become italic, URLs become links, etc.)
That's pretty neat. But then a bunch of Haskell hackers came along and
developed a program called Pandoc:
   http://johnmacfarlane.net/pandoc/
This translates Markdown into HTML, LaTeX (and therefore PDF),
Micro$oft's Rich Text format, DocBook XML, OpenDocument XML, OpenOffice
ODT, Texinfo or groff man, or even MediaWiki markup. It also adds a few
new syntax constructs [which can be disabled for compatibility], and it
follows the written Markdown language spec more closely than the Perl
version does.
This tool is written entirely in Haskell. As we all know, Haskell is
slower than all other programming languages. This explains how Pandoc
manages to outperform the Perl Markdown script:
   Perl Markdown: 15 seconds
   Compiled Perl Markdown: 10 seconds
   Pandoc (compiled Haskell): 0.9 seconds
So, in summary:
- Pandoc handles Markdown more correctly than the author's own Perl
implementation.
- Pandoc handles many more output formats than the author's own Perl
implementation.
- Pandoc handles more syntax constructs than the author's own Perl
implementation.
- Pandoc is approximately 10x faster than the author's own Perl
implementation.
So it's more correct, has more features, and runs faster. I call that a win!
Subject: Re: Sometimes, Haskell wins
Date: 22 Sep 2008 08:47:00
Message: <48d793c4@news.povray.org>
  But is it better specifically because it was made in Haskell, or is it
better simply because they made it better?
  If I make a Java version which supports a few more formats and is faster
than the Haskell version, does that mean that Java wins Haskell, or does
it mean I spent more time making it better? And if I make a C++ version
which is even faster, does that mean C++ wins all?
Date: 22 Sep 2008 09:02:04
Message: <48d7974c$1@news.povray.org>
This is the operative question.
First, notice that this application consists entirely of processing text
strings in a complex way - which is practically what the entire Perl
language was *designed* for from the very beginning. This is what many
people consider to be Perl's greatest strength, and what Perl is
supposedly highly optimised to do efficiently.
And yet, Haskell outperformed it, and matches the spec more exactly.
All of this *suggests* many things - significantly, that Haskell matches
the spec more closely hints that Haskell makes complex algorithms
"easier" to express, and so a closer match could be achieved.
But what does it *prove*? Well, strictly, nothing. Maybe the Perl
implementation just sucks? Maybe the Perl version could easily be
modified to be faster. Maybe there are bugs that could easily be fixed
to make it fit the spec better too.
Actually, I take that back. It does prove one thing worth knowing: some
people used Haskell to build a real-world tool that people who know
nothing about Haskell actually use to do stuff. That's not an
earth-shattering result, but it's an important one none the less.
> And if I make a C++ versionwhich is even faster, does that mean C++ wins all?
I was about to say "I'd be interested in seeing something like that",
but then I realised that in my current state of learning, I wouldn't
understand a word of it. :-S
Date: 22 Sep 2008 14:27:27
Message: <48d7e38f$1@news.povray.org>
	Eh? Compiled Haskell's not all that slow. It beats scripting languages
easily. Comparing it with Perl is not very illustrative of much.
Atheism is a non-prophet organization.
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 22 Sep 2008 16:24:32
Message: <48d7ff00$1@news.povray.org>
> languages easily. Comparing it with Perl is not very illustrative of much.
How about compiled Perl then? Cos it beat that too...
http://blog.orphi.me.uk/
Date: 22 Sep 2008 17:45:00
Message: <web.48d8118556396d9e773c9a3e0@news.povray.org>
Compiled Perl just means stored bytecode loading faster into Perl's VM/AST
/whatever.  Same for Python or Ruby.  The bytecode is still interpreted without
a JIT and those are still highly dynamic languages where code optimizations
through type analysis is very much impossible.
Haskell compiles to native code and is a static typeful language.  The
comparison is unfair.  Haskell also comes complete with a very succint syntax
reminiscent of Perl, except not quite as unreadable.  I think the time of Perl
has gone and suggest people trying Perl6 with Pugs to drop it and go Hugs
instead. :)
That said, there's no language out there to do batch flat file processing with
such ease and grace as Perl.  Not even Haskell or Ruby.  The problem, I guess,
is that it's a structured file format and handling it with regexes alone gets
ugly pretty fast... if they go for std XML processing instead, they have no
real advantage over any other languages doing the same...
Date: 22 Sep 2008 18:43:49
Message: <48d81fa5$1@news.povray.org>
It's not impossible. It just hasn't been applied very much to those
languages yet. You won't get the optimization that Haskell can get, but
you can get much better than people currently get. The trick is to use
run-time information to improve your run-time. Build a table at the
dynamic dispatch sites that run often and cache the lookup results, for
example. There are a number of recent (last year or two, up to next
year) techniques that do a significantly good job, but I can't find the
original article that discussed lots of the recent cutting-edge advances.
One such technique is
http://www.ics.uci.edu/~franz/Site/pubs-pdf/ICS-TR-06-16.pdf
Date: 22 Sep 2008 23:00:00
Message: <web.48d85b4f56396d9e9da6bd580@news.povray.org>
Nothing is impossible, just pretty much unlikely. :)
> languages yet.
The best I've ever seen for any dynamically typed language is the Stalin
compiler for the Lisp dialect Scheme.  It creates, from normal, unoptimized
Scheme code, very fast native code roughly approaching that of compiled C.
It's a true little wonder.  OTOH, it compiles a pretty static subset of Scheme:
 no eval, no load, no redefinitions of functions, no metaprogramming with
syntatic extensions and, though not dynamicism related, no arbitrary precision
arithmetic allowed.  Still, mighty impressive.
It does whole program compilation and lots of type inferencing to achieve that.
The code produced is very fast and quite small (though no match to the tiny C
executables), but the compiler itself, having to do all kinds of analysis in
the absence of type declarations, is probably the slowest you've ever seen.
Good thing any error messages are spot-on.
Languages like python and ruby abuse of their dynamic nature by going beyond
just dynamic typing and allowing all kinds of funky and slow runtime
metaprogramming.  A native compiler has no chance here.
Yes, it's what Hotspot does on the Java runtime and also what goes on on .NET's
CLR.  Not available to the official C runtimes of python, ruby and perl, except
when running on such VMs... still, I think their extreme dynamic nature makes
things difficult and allows for lots of sloppy style programming just for the
sake of it...
Date: 23 Sep 2008 04:07:10
Message: <48d8a3ae$1@news.povray.org>
Well OK. But given that the Perl version is presumably just making a
half dozen calls to the internal regex engine, you'd still expect decent
performance...
Anyway, whatever. My point is that Haskell isn't nearly as slow as
everybody thinks it is.
Date: 23 Sep 2008 14:15:00
Message: <web.48d9316456396d9ef48316a30@news.povray.org>
> performance...
yes.  Something more is getting in the way.
It's not slow at all.  It's just not nearly as fast as C/C++, but then, few are.
 And fewer are as high level and concise as Haskell. :)
Date: 23 Sep 2008 16:12:27
Message: <48d94dab$1@news.povray.org>
Like Warp suggested, maybe his Perl coding just sucks for some reason?
Heh. The Haskell bods are currently real excited because Haskell is
ranked 3rd is the new parallel benchmark table. (But then, most of the
other languages haven't submitted any parallel code yet.) It's lagging
behind C++, but just faster than C.
Of course, as somebody pointed out, the C and C++ implementations are
using OS threads, while Haskell is using lightweight Haskell threads,
"so it's not a fair comparison". Debate that if you will...
Date: 23 Sep 2008 17:55:01
Message: <web.48d9658156396d9e773c9a3e0@news.povray.org>
ah, that's it!  The thing between the chair and the keyboard...
I read the thread in the Haskell mailing-list.  Checking it out, both g++ and
ghc are behind some newcomer:  ATS.
http://shootout.alioth.debian.org/u64q/benchmark.php?test=all&lang=all
Yet Another High Level Language with C syntax and performance and functional
programming semantics.  Joining D for candidates for next C/C++.
Date: 23 Sep 2008 18:08:18
Message: <48d968d1@news.povray.org>
  Like D (and a bunch of others), also probably doomed to failure.
  Many people have attempted in making a "better" C/C++, and many have
failed. Some attempts have good ideas, but they just don't get popular,
no matter how much they are advertised. Basically nobody knows what D is.
Another good example is Objective C, which has a rather small market
(which is growing a bit due to the iPhone, though).
  Not all attempts have failed though. Java and C# are examples of
successful ones. (Although in their cases the changes from C/C++ have
been a bit more radical.)
Date: 23 Sep 2008 21:38:10
Message: <48d99a02$1@news.povray.org>
I thought all the NeXT and thus Mac OSX stuff was programmed in
Objective-C? (Which was around even before the NeXT, also.)
Date: 24 Sep 2008 04:37:21
Message: <48d9fc41$1@news.povray.org>
I recall seeing a language floating around (a *long* time ago!) called
E, and another called F.
IIRC, the language before C was called B, so it's quite possible that
more than one person has come up with a "better than C" language and
called it "D" or "E" or whatever... ;-)
The conspicuous thing is that both of those languages are backed be huge
well-known corporations...
Date: 24 Sep 2008 15:44:00
Message: <48da9880@news.povray.org>
> beyond just dynamic typing and allowing all kinds of funky and slow
> runtime
But also, languages like python and ruby are often used where performance
doesn't really matter. Last I checked, the de-facto implementation (CPython
interpreter) doesn't even do constant folding.
Date: 24 Sep 2008 15:46:48
Message: <48da9928@news.povray.org>
Yes. All apps on Mac are made in Objective-C. Non-GUI Objective-C code from
a Mac application can probably run unmodified on the iPhone. It's just the
GUI frameworks that changed completely.
Date: 24 Sep 2008 15:47:13
Message: <48da9941@news.povray.org>
Do you know why C# is called that way?
Date: 24 Sep 2008 16:12:30
Message: <48da9f2d@news.povray.org>
  Well, when it was a pretty new thing, I heard that # in the name was
actually four + symbols, so it's C++++, ie. "C# is to C++ what C++ is
to C".
  I don't know if it was just a joke.
Date: 24 Sep 2008 16:17:37
Message: <48daa061$1@news.povray.org>
> to C".
Given that it's pronounced "C Sharp", I expect it's because it's half a
note higher than C. Like, on a piano keyboard.
Date: 24 Sep 2008 17:10:26
Message: <48daacc2@news.povray.org>
>> to C".
That's the one.
C++ is C postincremented by 1 in C syntax.
C# is C incremented by one semitone in musical syntax.
Date: 24 Sep 2008 17:15:00
Message: <web.48daace956396d9e773c9a3e0@news.povray.org>
> > to C".
Yes.  Java decided to diss C/C++ by dropping any mention to it in the name, but
Microsoft in their infinite marketing wisdom felt they should instead try to
get to the hearts of old C/C++ folks.  They also catered for buying managers by
substituting the irrelevant term "bytecode" for "managed code":  you know, if
it's managed, it knows its place. :)
Date: 24 Sep 2008 17:20:00
Message: <web.48daae3456396d9e773c9a3e0@news.povray.org>
The sad thing is that the places where performance shouldn't really matter is
the place where C/C++/Java/C# are firmly entrenched:  running custom apps in TI
sections of non-software developer firms.  It doesn't matter because such apps
are not usually infrastructure and if more performance is needed, it should
suffice to just throw more hardware.  OTOH, throwing more programmers at late
projects is a bad idea, according to Fred Brooks...
Date: 24 Sep 2008 17:29:07
Message: <48dab123$1@news.povray.org>
Bytecode comes from Smalltalk, where each opcode was a byte. "Managed
code" means your resources are managed by the VM. So they really do mean
different orthogonal things.
Date: 24 Sep 2008 17:47:27
Message: <48dab56f@news.povray.org>
  I think that one reason for that is the vast amount of libraries available
for those languages, as well as the amount of programmers with experience.
Date: 25 Sep 2008 04:28:25
Message: <48db4ba9@news.povray.org>
I think Haskell won't start really winning big-time until it has at
least one or other of those things.
Date: 25 Sep 2008 04:30:49
Message: <48db4c39$1@news.povray.org>
Strictly, shouldn't it be ++C? I mean, "C++" would have the same value
as "C" (yet incrimenting C afterwards).
That's a noteworthy fact.
Date: 25 Sep 2008 13:15:00
Message: <web.48dbc6ad56396d9e773c9a3e0@news.povray.org>
But that's not the point.  The point is that "bytecode" running in a "VM" were
suplanted by "managed code" because that sounds better to manager ears:  if
it's managed, then it's code that know its place and works in schedule. ;)
Microsoft are marketing geniuses.
Date: 25 Sep 2008 14:04:03
Message: <48dbd293$1@news.povray.org>
Finally, a comment I won't disagree with...
Date: 25 Sep 2008 17:30:57
Message: <48dc0311$1@news.povray.org>
I think that goes without saying.  (Yes, I understood what you were
saying. I was just clarifying where the terms came from, in general,
showing off my big brain. ;-)
Date: 25 Sep 2008 18:04:16
Message: <48dc0ae0$1@news.povray.org>
Actually, they're not - their marketing is outsourced. ;-)
Jim
Date: 25 Sep 2008 19:49:24
Message: <48dc2383@news.povray.org>
You're not the first pedant to mention that.
Date: 26 Sep 2008 04:28:18
Message: <48dc9d22$1@news.povray.org>
Yay, me!
