POV-Ray : Newsgroups : povray.off-topic : My first C++ program Server Time
19 Oct 2026 12:58:13 EDT (-0400)
  My first C++ program (Message 1 to 50 of 149)
Goto Latest 50 Messages Next 50 Messages >>>
Subject: My first C++ program
Date: 19 Sep 2008 08:03:59
Message: <48d3952f$1@news.povray.org>
(Yeah, I realise nobody else is going to care...)
#include <iostream>
#include <vector>
#include <string>
using namespace std;
bool StackCheck(vector<int> stack, int min)
   if (stack.size() >= min) return true;
   cout << "Stack underflow." << endl;
   return false;
void Add(vector<int>& stack)
   if (!StackCheck(stack, 2)) return;
   int x = stack.back(); stack.pop_back();
   int y = stack.back(); stack.pop_back();
   stack.push_back(x + y);
void Sub(vector<int>& stack)
   stack.push_back(x - y);
int main()
   cout << "Calc #01" << endl;
   vector<int> stack;
   string cmd;
   while (true)
     for (int i=0; i<stack.size(); i++)
     cout << "[" << i << "]: " << stack[i] << endl;
     cout << "Calc> ";
     cin  >> cmd;
     if (cmd == "^") break;
     if (cmd == "+") {Add(stack); continue;}
     if (cmd == "-") {Sub(stack); continue;}
     stack.push_back(1);
   cout << "Exit." << endl;
Almost unbelievably, even though this program is written in C++ and
involves I/O, it seems to work correctly. I'm sure anybody who actually
knows how C++ is supposed to work will have a good laugh at this, but I
learned a few things by doing it.
The first mistake was passing the stack by value - which, obviously,
fails miserably. The next thing I tried was returning the new stack to
the caller, but that didn't work either. (Much like C, C++ compiler
errors seem rather cryptic. Plus I'm running GCC under QEMU, so it takes
about 60 seconds for each compiler run!)
At present, I haven't figured out how to convert a string to an integer
yet, so this "calculator" is pretty much useless. I'm sure it'll be
explained later in the tutorial. I also find myself constantly cursing
that I have to write an entire 5 lines of (nearly identical) code for
every arithmetic operation I want to implement and there's no way to
abstract this. (I don't have copy & paste available!)
Also, there's an interesting glitch where the program won't continue if
you enter a blank line - you must enter *something* or the program won't
continue. Presumably this is just the defined behaviour of the >>
operator...
Still, I have a program that reads user input without segfaulting.
That's gotta be pretty impressive!
PS. Nano is a horrid, horrid text editor!
Subject: (And in Haskell. Obviously.)
Date: 19 Sep 2008 08:20:08
Message: <48d398f8$1@news.povray.org>
Invisible wrote:
> #include <iostream>
> #include <vector>
> #include <string>
>   return false;
> int main()
>   vector<int> stack;
>   string cmd;
>   while (true)
>     cout << "Calc> ";
>     cin  >> cmd;
>     stack.push_back(1);
module Main (main) where
main = do
   putStrLn "Calc #01"
   main_loop []
main_loop stack = do
   mapM_ (\(n,v) -> putStrLn $ "[" ++ show n ++ "]: " ++ show v) (zip
[0..] stack)
   putStr "Calc> "
   cmd <- getLine
   case cmd of
     "^" -> return ()
     "+" -> binary (+) stack
     "-" -> binary (-) stack
     _   -> main_loop (1:stack)
binary fn stack = case stack of
   x:y:zs -> do main_loop ((fn x y) : zs)
   _      -> do putStrLn "Stack underflow."; main_loop stack
Somehow... it seems so much easier in Haskell. ;-)
Subject: Re: My first C++ program
Date: 19 Sep 2008 08:23:31
Message: <48d399c3@news.povray.org>
> I also find myself constantly cursing that I have to write an entire 5
> lines of (nearly identical) code for every arithmetic operation I want to
> implement and there's no way to abstract this. (I don't have copy & paste
> available!)
What you could do, is have a function like DoOperation(stack,op), and use
"op" as a token for the operation.
So you would call it like:
     if (cmd == "+") {DoOP(stack,0); continue;}
     if (cmd == "-") {DoOP(stack,1); continue;}
     if (cmd == "/") {DoOP(stack,2); continue;}
     if (cmd == "*") {DoOP(stack,3); continue;}
Or you could even use some fancy look-up table to convert from the character
code to op number, or just use the ASCII code of the operator as the op
number... you get the idea.
Then, DoOperation() would look like:
   int answer;
   if(op==0) answer=x+y;
   if(op==1) answer=x-y;
   if(op==2) answer=x/y;
   if(op==3) answer=x*y;
   stack.push_back(answer);
I'm sure there's a better way of doing it, but I think that's less work than
your first version.
PS good work on the first C++ program, it's way cooler than any of my first
programs.
Date: 19 Sep 2008 08:27:49
Message: <48d39ac5$1@news.povray.org>
> use "op" as a token for the operation.
In other words, move the operation check to the place where all the
values are available. I guess that could work.
> first programs.
I figured copying out HelloWorld.cpp didn't count is "MY first program". ;-)
Warp gave me the link of Tuesday, and I have now written working code of
my own design, not based on any example code. This would have been quite
impossible in C. (Unless you avoid I/O, anyway.) So it seems they did
make C++ at least a little easier. ;-)
Date: 19 Sep 2008 08:59:40
Message: <48d3a23c@news.povray.org>
  Don't do that. It might feel tempting, but don't. It's better in the long
run to avoid it.
  You are passing the vector by value here, which may not be a good idea,
especially if the vector is big. That's because the entire vector will be
copied. (Some STL implementations *might* use copy-on-write, but most of
them don't, and instead just deep-copy.)
  Teach yourself to intuitively write:
bool StackCheck(const std::vector<int>& stack, int min)
  Usually with big objects (such as vectors) you basically always want
to pass by const reference rather than by value. (You should pass by
value only if that's *really* what you want to do.)
  Sure, this might sound like a nuisance, but C and C++ are value based
languages, and by default everything is passed by value. To pass by
reference (or by pointer) you need additional syntax.
  You could also save a bit of writing by doing it like this:
    stack.back() += x;
  Or if you want to really minimize things:
    stack.at(stack.size()-2) += stack.back();
    stack.pop_back();
  Of course it starts being a bit obfuscated.
> int main()
  While it is perfectly valid to omit the return value of main()
(IIRC it defaults to EXIT_SUCCESS), it's generally recommended to
return EXIT_SUCCESS or EXIT_FAILURE (which are defined in some header
file).
  Having said that, when I write very small test programs like this one,
I don't bother writing any return command in main() either. So it's not
that bad. :P
  It depends on what your input syntax is. Making a parser in C++ is not
one of the easiest things. Especially a stack calculator is difficult
because you can't know what the type of the next input element will be
in advance, but you have to simply read it as a string and then examine
its contents. The next element might be a number or an operator, and you
can't know which until you read it as a string and examine it.
  If the input had a very specific format, then it would be easier.
For example if your input consisted of lines like:
command 1 2
that is, if the keyword "command" appears in the input, it will always
be followed by two integers, then you could write code like this:
std::string keyword;
std::cin >> keyword;
if(keyword == "command")
    int x, y;
    std::cin >> x >> y;
    executeCommand(x, y);
  But as I said, if the next parameter can be a number or an operator or
a keyword or something else, it becomes more complicated.
> operator...
  If you call >> with a string, then it will read the input until it finds
a whitespace-delimited string. >> is not line-based in any way, it's
whitespace-based.
  Why don't you use something better?
Date: 19 Sep 2008 09:11:17
Message: <48d3a4f5$1@news.povray.org>
>   Don't do that.
So noted.
> copied.
Right, OK.
Ooo... I didn't realise you could do that. (Pass a const reference, that
is.) So that means, what? If you accidentally try to change it, you'll
get a compiler warning? Can you do that with non-reference types? (Not
that it would matter if you were to change those - except that your
program might not do what you intended.)
>     stack.back() += x;
>     stack.pop_back();
...ouch.
> file).
Noted.
Since you're here... do you happen to know the C++ name for stderr?
I was thinking along the lines of "each line of input is either +, -, or
a number". But I don't know how to convert a string into a number.
Apparently the ">>" operator will do this if you hand it a number-type
variable, so there must be some library function somewhere that does the
conversion. I just don't know it's name yet.
>> operator...
> whitespace-based.
Well, that's consistent at least.
Because my virtual machine is slow enough already without starting X11,
and Nano is the only text-mode editor I have available (other than Vim
and Emacs anyway).
Date: 19 Sep 2008 09:35:35
Message: <48d3aaa7$1@news.povray.org>
>> to implement and there's no way to abstract this. (I don't have copy &
>> paste available!)
I wrote a function that returns the top element from the stack while
simultaneously removing it. That cuts down the typing quite a bit.
Note to self: Do *not* attempt to remove an element from an empty vector...
Date: 19 Sep 2008 10:05:39
Message: <48d3b1b3$1@news.povray.org>
The tutorial recommends the C function atoi() - which, being a C
function, is about as user-friendly as Windows 2. Much hair-pulling
involving pointers ensues.
(It turns out that you can assign a string to a char*, but not the
reverse. Go figure. Anyway, the solution is simple enough...)
Date: 19 Sep 2008 10:10:25
Message: <48d3b2d1$1@news.povray.org>
void *(*(*fp1)(int))[10];
...OK, I'm scared! o_O
At least when somebody writes (Either (Maybe (Set Int) (Map Int String))
[(Word32, Int -> IO Int)]), it's relatively easy to work out what that is.
(Presumably in either language, if you ever write something like this
for real, you're doing something worribly wrong somewhere...)
Date: 19 Sep 2008 10:56:08
Message: <48d3bd88@news.povray.org>
  No, you get a compiler error. Since you declared the parameter as const,
you *can't* modify it.
  Declaring everything you don't intend to modify as 'const' is a good
programming practice in C++ for many reasons:
1) If you don't intend to modify the parameter, very especially if the
   parameter is a reference (in which case you would be modifying the
   original rather than a copy), then you will get a compiler error if
   you try to modify it anyways. This will catch programming mistakes
   at compile time, which is a good thing.
2) Declaring a reference parameter as 'const' is self-documenting: You are
   not only telling the compiler that that parameter is not modified in the
   function, more importantly you are telling that to a human reader. In
   other words, you are effectively documenting that the parameter is a
   pure input parameter, not something the function uses to pass values
   to the calling code.
3) As a bonus, it is possible that in certain situations the compiler might
   be able to optimize const variables better than non-const ones.
  Personally I have got the habit of declaring *everything* that I don't
intend to modify as 'const'. Even simple local variables. For example
I will typically write code like this:
    const int retVal = someFunction();
    somethingElse();
    return ratVal;
  In principle there's no need for the 'const' there, but I have got the
habit of doing it. After a while it becomes self-documenting even for
myself.
  Yes. Anything can be declared 'const', even variables and parameters
which are passed by value. In other words, it's perfectly possible to
do this:
void foo(const int value)
    const int anotherValue = value+1;
  In practice you seldom see 'const' used in function parameters like
that, though.
  Note that (not surprisingly) pointers are slightly more complicated
with regard to 'const':
    const Type* ptr = something;
  This defines a pointer named 'ptr' which points to a const value.
In other words, you can't modify the value pointed by 'ptr'. However,
you can modify 'ptr' itself, to make it point somewhere else (or make
it null, of whatever).
  If what you want is for 'ptr' itself to be const, not the value it's
pointing to, you have to write it like this:
    Type* const ptr = something;
  Now you can modify the value pointed by 'ptr' but you can't modify 'ptr'
itself. Naturally if you want *both* things, you write:
    const Type* const ptr = something;
  Now you can't modify either 'ptr' nor the value it's pointing to.
  References do not have this kind of complication because the reference
variable itself is always const. What the 'const' keyword determines is
whether the object it's pointing to is const or not.
  std::cerr << "An error message.\n";
  (Anything taking an std::ostream& can be given std::cout or std::cerr
as parameter. Or an output file stream. Or an output string stream.)
  The problem with the >> operator is that you have to know in advance
what the type of the input will be. In this case you don't know it because,
as you say, the input can be an operator (+ or -) or a number.
  What you can do is this:
    std::string s;
    while(true)
        std::cin >> s;
        if(!std::cin.good()) break;
        int value;
        std::istringstream iss(s);
        iss >> value;
        if(!iss.fail())
            std::cout << "The input was an integer: " << value << "\n";
        else
            std::cout << "The input was something else: " << s << "\n";
> and Emacs anyway).
  Why don't you use an editor in your host OS?
Date: 19 Sep 2008 10:56:56
Message: <48d3bdb8@news.povray.org>
  No need for atoi(). You can use stringstreams, as I wrote in the other
post.
Date: 19 Sep 2008 11:09:56
Message: <48d3c0c4@news.povray.org>
> post.
I did think using a C function seemed a little bogus.
(For one thing, AFAIK, there is *no way* to know whether atoi()
succeeded or failed; if it "fails", you get a zero. So was the string
actually a zero, or did the conversion fail??)
Date: 19 Sep 2008 11:10:50
Message: <48d3c0fa$1@news.povray.org>
Even better.
Agreed.
...ouch. >_< OK, well let's hope I don't need to use pointers too much then!
OK.
Indeed.
>     std::string s;
>     while(true)
>         std::cin >> s;
>         int value;
>         iss >> value;
>         if(!iss.fail())
>         else
...you mean, you can take a string and make a stream that will read from
it? (Or, presumably, write to it, if you desire.) So what exactly do the
good() and fail() functions do?
>> and Emacs anyway).
Because I haven't found a way to transfer files between the host OS and
the guest OS.
Date: 19 Sep 2008 11:31:55
Message: <48d3c5ea@news.povray.org>
  Correct. Or, more precisely, you can write to an ostringstream and then
get a regular string out of it (with the str() function).
  Where this becomes fancy is when a function takes an std::istream or an
std::ostream reference, for example:
void readSomethingFrom(std::istream& is) { ... }
void writeSomethingTo(std::ostream& os) { ... }
  You can give those functions any of these things:
readSomethingFrom(std::cin);
std::ifstream inputFile("filename.txt");
readSomethingFrom(inputFile);
std::istringstream iss(someString);
readSomethingFrom(iss);
writeSomethingTo(std::cout);
writeSomethingto(std::cerr);
std::ofstream outputFile("filename.txt");
writeSomethingTo(outputFile);
std::ostringstream oss;
writeSomethingTo(oss);
  The functions themselves don't know (and don't need to know) what the
exact type of stream actually is. All of them are used in the same way.
For example:
    for(int i = 0; i < 10; ++i)
        os << i << "\n";
  This is, in fact, pure object-oriented programming (all of those things
are inherited from std::istream or std::ostream, so they can be given to
those two functions). Beautiful.
> So what exactly do the good() and fail() functions do?
http://www.cplusplus.com/reference/iostream/ios/good.html
http://www.cplusplus.com/reference/iostream/ios/fail.html
  Basically you can think of good() as "did the last read succeed?"
(the most common reason for the stream to be not good() is EOF).
It's an overall "is the stream still good?".
  And fail() as "did the input contain a value of the correct type?".
In other words, with the "std::cin >> integer; if(std::cin.fail() ..."
you are asking "did reading an integer fail?". The most common reason
for fail() to be true is that input did not contain what was expected
by the parameter (in this example an integer value).
Date: 19 Sep 2008 11:35:36
Message: <48d3c6c7@news.povray.org>
> > post.
  There's merit in those C functions, though: They are much more efficient
than using stringstreams. (For one, they parse the string *in place*,
rather than copying the string around in memory.)
  Of course their usage is more difficult.
  Another C function can be used to both parse an integer from a string
and know if there was one: strtod(). However, its usage is even more
complicated than atoi().
Date: 19 Sep 2008 11:37:52
Message: <48d3c750$1@news.povray.org>
Ah  - because a string is fixed-size once created?
> std::ostream reference.
OOP as it should be.
OK... So good() is a property of the stream, and fail() is a property of
the last thing read from it?
Date: 19 Sep 2008 11:38:05
Message: <48d3c75d@news.povray.org>
> operator...
	If you DO want to read a whole line, look up the getline function. That
will also take in an "empty" line.
Inoculatte: To take coffee intravenously when you are running late.
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 19 Sep 2008 15:31:33
Message: <48d3fe15$1@news.povray.org>
>     std::string s;
>     while(true)
>         std::cin >> s;
>         int value;
>         iss >> value;
>         if(!iss.fail())
>         else
"Variable 'iss' has initialiser but has incomplete type."
WTF...?
Oh, wait, I see. That means "you didn't include <sstream>". Well, that
was quite clear. o_O
http://blog.orphi.me.uk/
Date: 19 Sep 2008 15:39:24
Message: <48d3ffec$1@news.povray.org>
Spot the mistake:
int foo(vector<int>& stack)
   stack.pop_back();
For reasons I can't begin to understand,
1. This doesn't produce any compile-time error.
2. This function always returns the value "2144912088".
Date: 19 Sep 2008 16:02:04
Message: <48d4053c$1@news.povray.org>
> and Emacs anyway).
Well, that made *me* laugh.
"Nano is awful. I have nothing better. Oh, except the two most popular
text editors."
Date: 19 Sep 2008 16:05:00
Message: <48d405ec$1@news.povray.org>
> text editors."
Have *you* ever tried to make Vim or Emacs work? :-P
Besides, Emacs isn't even a text editor - it's an operating system! ;-)
Date: 19 Sep 2008 16:15:49
Message: <48d40875$1@news.povray.org>
Orchid XP v8 wrote:
> Spot the mistake:
>   stack.pop_back();
	Function lacks a return statement.
                                    anl
Date: 19 Sep 2008 16:19:31
Message: <48d40953$1@news.povray.org>
Mueen Nawaz wrote:
> Orchid XP v8 wrote:
>> Spot the mistake:
Yup. A simple and obvious mistake. But unfortunately, not one the
compiler warned me about. (I'm also curios to know exactly what the hell
the function is returning... No doubt the reason there's no compiler
warning is that this is actually a valid thing to do due to some bizare
C language rule kept for compatibility or something random like that.)
Date: 19 Sep 2008 16:31:10
Message: <48d40c0e@news.povray.org>
Orchid XP v8 a écrit :
> Mueen Nawaz wrote:
>> Orchid XP v8 wrote:
>>> Spot the mistake:
If you are using g++, you can add the option -Wall to your command line.
The compiler should give a warning in this case... Well two actually,
one because the variable x is not used for anything and one because the
function does not return.
I'm leaving the explanation of why this is still legal to someone more
competent :-)
Vincent
Date: 19 Sep 2008 17:51:59
Message: <48d41eff$1@news.povray.org>
I have used both for years at a time. I prefer vim, except for one
stretch of time when it was still "vi" and I wanted automatic
indentations for Tcl.
Subject: Re: (And in Haskell. Obviously.)
Date: 19 Sep 2008 18:56:12
Message: <48d42e0c@news.povray.org>
I understand the C++ one and the Haskell one looks like line noise.
Date: 19 Sep 2008 19:02:40
Message: <48d42f90@news.povray.org>
No. std::string is mutable, and can change its size.
This is how you can convert numbers to/from strings:
int answer = 42;
oss << answer;
//oss.str() returns a std::string containing "42".
int answer;
std::istringstream iss("42");
iss >> answer;
//answer now contains the number 42.
Date: 19 Sep 2008 19:03:22
Message: <48d42fb9@news.povray.org>
>> text editors."
Vim is my main text editor. Even on Windows.
Date: 19 Sep 2008 19:07:41
Message: <48d430bc@news.povray.org>
Invisible wrote:
>> post.
atoi is always a bad idea.
If you're writing C, you should use strtol instead. If you're writing C++,
you should use a stringstream instead.
Or use boost lexical_cast, which looks like a cast but works with streams to
do string-number conversions. But any boost library involves lots of
inter-library dependencies, and would surely increase your compilation
times (the compiler has to untangle all the templated mess :P). So just
stick to streams.
Date: 19 Sep 2008 19:09:09
Message: <48d43115@news.povray.org>
Whatever random value happened to be in the appropriate place of the stack.
Date: 19 Sep 2008 19:33:45
Message: <48d436d8@news.povray.org>
The reason that isn't built-in is that it doesn't work well with objects.
If vector.pop_back() returned a reference to the popped object, you'd get
sure crashes (reading from freed memory, or at least, a destructed object).
If vector.pop_back() returned a copy of the popped object, you'd get bad
performance even when you don't need the object (useless copying), you just
want to remove it. And who would free that copy?
ints, however, are easily copyable and don't need "freeing" :)
Date: 20 Sep 2008 00:59:53
Message: <48d48349$1@news.povray.org>
>   stack.pop_back();
What compiler are you using?
If it's possible for you to acquire a copy of Visual Studio (even an oldish
one), I strongly recommend it.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 20 Sep 2008 01:07:51
Message: <48d48527$1@news.povray.org>
> The tutorial recommends the C function atoi() - which, being a C function,
> is about as user-friendly as Windows 2. Much hair-pulling involving
> pointers ensues.
C strings aren't so bad. If you have a std::string, you can call its c_str()
method to get a (const) pointer to the internal string, which is just a
sequence of bytes. So, you can use
atoi( mystring.c_str() )
to convert to an integer. This is what I always use, though I see there are
other ways to do it.
As I understand it, atoi's behavior is to return the integer represented by
the longest sequence of characters starting at the beginning of the string
that represent an integer, defaulting to 0. By this definition it's not
possible to fail. =) Sometimes this is useful.
 - Slime
Date: 20 Sep 2008 01:13:53
Message: <48d48691$1@news.povray.org>
This is good, but instead of using integers like 0 1 2 3, I'd use an enum:
enum Operation
    OP_ADD,
    OP_SUBTRACT,
    OP_DIVIDE,
    OP_MULTIPLY,
An enum gives meaning to this sort of approach so you don't have to remember
what something like "2" means.
 - Slime
Date: 20 Sep 2008 03:09:15
Message: <48d4a19b@news.povray.org>
Related to that, the express editions of Visual Studio are available
free of charge. Some say that the express editions are somewhat limited,
I however did not run into any walls with them. OpenGL, DirectX, GUI
work with Qt, all not a problem. Commandline apps work well, too.
For C/C++ work obviously you only need "Visual C++ 2008 Express
Edition". Download here: http://www.microsoft.com/express/download/
Manuel Kasten
Date: 20 Sep 2008 04:45:04
Message: <48d4b810@news.povray.org>
  As I said in my other post, there is merit in the C functions: They are
much more efficient than stringstreams.
  So if you are converting a *huge* amount of strings to ints in a tight
loop, you might want to consider the C functions rather than stringstreams.
  In situations where speed has absolutely no relevance stringstreams are
much easier and safer to use.
Date: 20 Sep 2008 04:47:04
Message: <48d4b888@news.povray.org>
  Yeah, it's strtol(), not strtod(). The latter is to read a floating
point number.
  (This shows how clear those C function names are... ;) )
Date: 20 Sep 2008 04:49:55
Message: <48d4b932@news.povray.org>
  The problem is that with atoi() you can't know if there was an integer
in that string in the first place. If there wasn't, it just returns zero,
and you can't know if there was a zero in the string or something which
was not a parseable number.
  (And no, it's not enough to check if mystring[0] == '0'. There are a
multitude of other ways for a valid number 0 to be in the string.)
  This might be very relevant if you are checking if there was a number
of something else in the string, and act accordingly.
Date: 20 Sep 2008 04:59:13
Message: <48d4bb61@news.povray.org>
  The problem with getline() is precisely that it reads an entire line.
If there are several whitespace-separated things in that line, it will
still read the entire line.
  Of course you can give that line to istringstream and then read those
whitespace-separated things with >> (and check with good() to see if it
succeeds).
Date: 20 Sep 2008 05:20:05
Message: <48d4c045@news.povray.org>
  Than turn on the warning flags. You should always compile with warning
flags.
g++ -Wall -Wextra -pedantic -ansi -O3 yourprogram.cc
  Learn to use makefiles too. You can use the attached generic makefile
to automatically build your program. (You'll probably need gnu make.)
  (Note that if you add, remove or change any #include line in your
program, except those which include standard libraries, you'll have to
delete the .dep file before running make.)
Download 'Makefile.txt' (1 KB)
Date: 20 Sep 2008 05:58:53
Message: <48d4c95d@news.povray.org>
> flags.
Actually, when I want to compile something, I usually just say "make
foo". Otherwise GCC insists on naming it "a.out", which is very irritating.
I'm rather surprised that forgetting to return anything at all isn't
considered a non-maskable error, but anyway... (Certainly returning
something from a void function seems to cause an error.)
I guess at some point I'll have to read the GCC manpage to find out how
to control it directly.
So there *is* a way to automate dependency analysis?
Personally, I'm used to a programming language where I write some code,
save it in a couple of files, and say "ghc --make Foo" and it
automatically builds a dependency tree, decides which things do or don't
need recompiling (including noting whether the *external* interface is
different or not), compiles everything to machine code, and
automatically links all the necessary libraries.
This whole concept of having to manually write makefiles and manually
write header files and so forth just seems tedious and error-prone.
Date: 20 Sep 2008 05:59:43
Message: <48d4c98f$1@news.povray.org>
GCC, on Linux, running under QEMU. (Because it's what I have to hand.)
Date: 20 Sep 2008 06:00:36
Message: <48d4c9c4$1@news.povray.org>
>> oldish one), I strongly recommend it.
> free of charge.
Hmm. OK, maybe I'll give that a try at some point.
Date: 20 Sep 2008 06:02:18
Message: <48d4ca2a$1@news.povray.org>
> point number.
<insert "I told you so" remarks here> ;-)
At least C++ manages to be a little more intuitive here.
Date: 20 Sep 2008 06:05:23
Message: <48d4cae3$1@news.povray.org>
More technically, "Emacs isn't a text editor, it's an EList interpretter
that comes bundled with a text editor implementation". :^)
Date: 20 Sep 2008 06:06:07
Message: <48d4cb0f$1@news.povray.org>
Well forget the comments about M$ Word training courses - surely you
must have taken some pretty advanced courses to be able to comprehend
either of these editors!
Date: 20 Sep 2008 06:07:30
Message: <48d4cb62@news.povray.org>
  I use emacs to write C++, in both Linux and Windows (where I program
for my payjob). Of course it's a heavily configured emacs.
  If you ever want to use emacs, I could give you my emacs configuration
file. It sets up quite many things which make it more usable.
Date: 20 Sep 2008 06:22:34
Message: <48d4cee9@news.povray.org>
  If you don't specify an executable name, how can gcc guess what is it
that you want? Note that you can write something like:
g++ file1.cc file2.cc file3.cc
  Which one of those is the one you want the executable named after?
Or maybe you don't want the executable to be named anything those.
  AFAIK all compilers require you to specify an executable name. It's
just that in most compilers this happens when you are creating a project.
However, gcc is command-line oriented and doesn't have projects. It doesn't
need to support projects because 'make' is the de-facto project software
in unix systems, and there's no need for gcc to step onto its toes.
  Of course the way to tell gcc the name of the executable is to tell it
to it with the -o parameter.
  C++ inherits many things from C, good and bad.
  The -MM option of gcc (which I use in that generic makefile I attached)
auto-generates makefile dependencies for all the specified source
files. Makefiles themselves (at least with gnu make) are so versatile
that this can be used to completely automatize dependency building.
  Well, *almost* completely. 'make' has no way of knowing if you have
changed some #include line in some source code file, which would change
the dependencies. Of course it would be perfectly possible to make it
build the dependency file every time you run 'make', but I usually don't
want that, because the "g++ -MM" command often takes a few seconds to run,
which can be irritating, and dependencies change rarely.
  If you want it to run the "g++ -MM" every time, you can do it like in
the attached Makefile.
  You don't need to manually write makefiles. Just use a generic one.
Date: 20 Sep 2008 06:25:05
Message: <48d4cf81$1@news.povray.org>
Uh-huh, and let me guess: You already know how to read and write C++
fluently, but you know nothing about Haskell yet? :-P
Seriously, I am constantly baffled by statements like this. The code I
posted contains one line which is a little cryptic (the really long one
where I dump the stack to stdout with 1 line of code). Other than that,
it's all really quite straightfoward.
Or are you seriously telling me that the meaning of
     stack.push_back(1);
is somehow clearer than
   case cmd of
     "^" -> return ()
To me, all that tricky slight of hand with "break" and "continue" seems
far less clear then just directly saying exactly what you want to
happen, as the Haskell version does.
I really can't figure out what everybody finds so confusing about
Haskell. Is it just that it uses different syntax to other "common"
programming languages? (E.g., no curly braces, no function call
brackets.) Or is it something deeper?
Date: 20 Sep 2008 06:32:41
Message: <48d4d149$1@news.povray.org>
Now there's interesting. I didn't know you could actually compile
multiple source files together; I was under the impression that in that
case, you must manually invoke g++ several times, and then manually
invoke ld to produce the final binary. (Or, more likely, write a
makefile that does that.)
Apparently so. ;-)
[I'm currently compiling a list...]
Well, that's a step up from manually writing a makefile, writing it
wrong, and producing a binary that segfaults because it's built from
incompatible object files...
Has anybody come up with a tool for autogenerating header files yet?
(Presumably you'd need to edit such a file to remove references to
things that aren't meant to be public, but at least the function names
and signatures would match.)
