POV-Ray : Newsgroups : povray.off-topic : My first C++ program Server Time
29 Jun 2026 00:08:13 EDT (-0400)
  My first C++ program (Message 10 to 19 of 149)
<<< Previous 9 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: My first C++ program
Date: 19 Sep 2008 10:56:08
Message: <48d3bd88@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> > bool StackCheck(const std::vector<int>& stack, int min)
> >   Usually with big objects (such as vectors) you basically always want
> > to pass by const reference rather than by value.
> Ooo... I didn't realise you could do that. (Pass a const reference, that
> is.) So that means, what? If you accidentally try to change it, you'll
> get a compiler warning?
  No, you get a compiler error. Since you declared the parameter as const,
you *can't* modify it.
  Declaring everything you don't intend to modify as 'const' is a good
programming practice in C++ for many reasons:
1) If you don't intend to modify the parameter, very especially if the
   parameter is a reference (in which case you would be modifying the
   original rather than a copy), then you will get a compiler error if
   you try to modify it anyways. This will catch programming mistakes
   at compile time, which is a good thing.
2) Declaring a reference parameter as 'const' is self-documenting: You are
   not only telling the compiler that that parameter is not modified in the
   function, more importantly you are telling that to a human reader. In
   other words, you are effectively documenting that the parameter is a
   pure input parameter, not something the function uses to pass values
   to the calling code.
3) As a bonus, it is possible that in certain situations the compiler might
   be able to optimize const variables better than non-const ones.
  Personally I have got the habit of declaring *everything* that I don't
intend to modify as 'const'. Even simple local variables. For example
I will typically write code like this:
    const int retVal = someFunction();
    somethingElse();
    return ratVal;
  In principle there's no need for the 'const' there, but I have got the
habit of doing it. After a while it becomes self-documenting even for
myself.
> Can you do that with non-reference types?
  Yes. Anything can be declared 'const', even variables and parameters
which are passed by value. In other words, it's perfectly possible to
do this:
void foo(const int value)
    const int anotherValue = value+1;
  In practice you seldom see 'const' used in function parameters like
that, though.
  Note that (not surprisingly) pointers are slightly more complicated
with regard to 'const':
    const Type* ptr = something;
  This defines a pointer named 'ptr' which points to a const value.
In other words, you can't modify the value pointed by 'ptr'. However,
you can modify 'ptr' itself, to make it point somewhere else (or make
it null, of whatever).
  If what you want is for 'ptr' itself to be const, not the value it's
pointing to, you have to write it like this:
    Type* const ptr = something;
  Now you can modify the value pointed by 'ptr' but you can't modify 'ptr'
itself. Naturally if you want *both* things, you write:
    const Type* const ptr = something;
  Now you can't modify either 'ptr' nor the value it's pointing to.
  References do not have this kind of complication because the reference
variable itself is always const. What the 'const' keyword determines is
whether the object it's pointing to is const or not.
> Since you're here... do you happen to know the C++ name for stderr?
  std::cerr << "An error message.\n";
  (Anything taking an std::ostream& can be given std::cout or std::cerr
as parameter. Or an output file stream. Or an output string stream.)
> I was thinking along the lines of "each line of input is either +, -, or
> a number". But I don't know how to convert a string into a number.
> Apparently the ">>" operator will do this if you hand it a number-type
> variable, so there must be some library function somewhere that does the
> conversion. I just don't know it's name yet.
  The problem with the >> operator is that you have to know in advance
what the type of the input will be. In this case you don't know it because,
as you say, the input can be an operator (+ or -) or a number.
  What you can do is this:
    std::string s;
    while(true)
        std::cin >> s;
        if(!std::cin.good()) break;
        int value;
        std::istringstream iss(s);
        iss >> value;
        if(!iss.fail())
            std::cout << "The input was an integer: " << value << "\n";
        else
            std::cout << "The input was something else: " << s << "\n";
> >> PS. Nano is a horrid, horrid text editor!
> >   Why don't you use something better?
> Because my virtual machine is slow enough already without starting X11,
> and Nano is the only text-mode editor I have available (other than Vim
> and Emacs anyway).
  Why don't you use an editor in your host OS?
Date: 19 Sep 2008 10:56:56
Message: <48d3bdb8@news.povray.org>
> The tutorial recommends the C function atoi() - which, being a C
> function, is about as user-friendly as Windows 2. Much hair-pulling
> involving pointers ensues.
  No need for atoi(). You can use stringstreams, as I wrote in the other
post.
Date: 19 Sep 2008 11:09:56
Message: <48d3c0c4@news.povray.org>
> post.
I did think using a C function seemed a little bogus.
(For one thing, AFAIK, there is *no way* to know whether atoi()
succeeded or failed; if it "fails", you get a zero. So was the string
actually a zero, or did the conversion fail??)
Date: 19 Sep 2008 11:10:50
Message: <48d3c0fa$1@news.povray.org>
Even better.
Agreed.
...ouch. >_< OK, well let's hope I don't need to use pointers too much then!
OK.
Indeed.
>     std::string s;
>     while(true)
>         std::cin >> s;
>         int value;
>         iss >> value;
>         if(!iss.fail())
>         else
...you mean, you can take a string and make a stream that will read from
it? (Or, presumably, write to it, if you desire.) So what exactly do the
good() and fail() functions do?
>> and Emacs anyway).
Because I haven't found a way to transfer files between the host OS and
the guest OS.
Date: 19 Sep 2008 11:31:55
Message: <48d3c5ea@news.povray.org>
  Correct. Or, more precisely, you can write to an ostringstream and then
get a regular string out of it (with the str() function).
  Where this becomes fancy is when a function takes an std::istream or an
std::ostream reference, for example:
void readSomethingFrom(std::istream& is) { ... }
void writeSomethingTo(std::ostream& os) { ... }
  You can give those functions any of these things:
readSomethingFrom(std::cin);
std::ifstream inputFile("filename.txt");
readSomethingFrom(inputFile);
std::istringstream iss(someString);
readSomethingFrom(iss);
writeSomethingTo(std::cout);
writeSomethingto(std::cerr);
std::ofstream outputFile("filename.txt");
writeSomethingTo(outputFile);
std::ostringstream oss;
writeSomethingTo(oss);
  The functions themselves don't know (and don't need to know) what the
exact type of stream actually is. All of them are used in the same way.
For example:
    for(int i = 0; i < 10; ++i)
        os << i << "\n";
  This is, in fact, pure object-oriented programming (all of those things
are inherited from std::istream or std::ostream, so they can be given to
those two functions). Beautiful.
> So what exactly do the good() and fail() functions do?
http://www.cplusplus.com/reference/iostream/ios/good.html
http://www.cplusplus.com/reference/iostream/ios/fail.html
  Basically you can think of good() as "did the last read succeed?"
(the most common reason for the stream to be not good() is EOF).
It's an overall "is the stream still good?".
  And fail() as "did the input contain a value of the correct type?".
In other words, with the "std::cin >> integer; if(std::cin.fail() ..."
you are asking "did reading an integer fail?". The most common reason
for fail() to be true is that input did not contain what was expected
by the parameter (in this example an integer value).
Date: 19 Sep 2008 11:35:36
Message: <48d3c6c7@news.povray.org>
> > post.
  There's merit in those C functions, though: They are much more efficient
than using stringstreams. (For one, they parse the string *in place*,
rather than copying the string around in memory.)
  Of course their usage is more difficult.
  Another C function can be used to both parse an integer from a string
and know if there was one: strtod(). However, its usage is even more
complicated than atoi().
Date: 19 Sep 2008 11:37:52
Message: <48d3c750$1@news.povray.org>
Ah  - because a string is fixed-size once created?
> std::ostream reference.
OOP as it should be.
OK... So good() is a property of the stream, and fail() is a property of
the last thing read from it?
Date: 19 Sep 2008 11:38:05
Message: <48d3c75d@news.povray.org>
Invisible wrote:
> Also, there's an interesting glitch where the program won't continue if
> you enter a blank line - you must enter *something* or the program won't
> continue. Presumably this is just the defined behaviour of the >>
> operator...
	If you DO want to read a whole line, look up the getline function. That
will also take in an "empty" line.
Inoculatte: To take coffee intravenously when you are running late.
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 19 Sep 2008 15:31:33
Message: <48d3fe15$1@news.povray.org>
>     std::string s;
>     while(true)
>         std::cin >> s;
>         int value;
>         iss >> value;
>         if(!iss.fail())
>         else
"Variable 'iss' has initialiser but has incomplete type."
WTF...?
Oh, wait, I see. That means "you didn't include <sstream>". Well, that
was quite clear. o_O
http://blog.orphi.me.uk/
Date: 19 Sep 2008 15:39:24
Message: <48d3ffec$1@news.povray.org>
Spot the mistake:
int foo(vector<int>& stack)
   int x = stack.back();
   stack.pop_back();
For reasons I can't begin to understand,
1. This doesn't produce any compile-time error.
2. This function always returns the value "2144912088".
