POV-Ray : Newsgroups : povray.off-topic : My first C++ program Server Time
19 Mar 2026 09:13:55 EDT (-0400)
  My first C++ program (Message 71 to 80 of 149)
Subject: Re: My first C++ program
Date: 20 Sep 2008 15:55:05
Message: <48d55519$1@news.povray.org>
>> What compiler are you using?
> GCC, on Linux, running under QEMU. (Because it's what I have to hand.)
Huh. Crazy that it wouldn't give at least a warning for that. Maybe there's
a switch to give more picky warnings?
 - Slime
 [ http://www.slimeland.com/ ]
Subject: Re: (And in Haskell. Obviously.)
Date: 20 Sep 2008 16:05:30
Message: <48d5578a$1@news.povray.org>
> I have a similar issue with stuff like
>   while (*x++ = *y++) {}
FYI, I have an issue with stuff like that too. C and C++ do make it easy to
write bad code. This is the second time you've mentioned that example, so I
assume someone once showed it to you and thought they were being clever.
They weren't! Or maybe it's just a popular example, because I was just
reading a book about coding style last night that gave that as a bad
example.
That code tries to do too much at once and is difficult to understand. If
you made a small mistake while writing it, it wouldn't be immediately
obvious that there's a problem with the logic. It's bad code. Its only use
is to help you understand operator precedence and the behavior of the
different operators. It's very possible to write code that does the same
thing in a clearer way.
C and C++ just require responsibility. =)
 - Slime
Date: 20 Sep 2008 16:11:31
Message: <48d558f3$1@news.povray.org>
> To me, all that tricky slight of hand with "break" and "continue" seems
> far less clear then just directly saying exactly what you want to happen,
> as the Haskell version does.
You can eliminate the "continue" in your example if you write it like this:
    if ( cmd == "^" )
        break;
    else if ( cmd == "+" )
        Add(stack);
    else if ( cmd == "-" )
        Sub(stack);
    else
        stack.push_back(1);
As for the break, it could just as easily be a 'return' like in the haskell
code, if you didn't want to print "exit" or if you brought the loop into its
own function.
 - Slime
Subject: Re: A test
Date: 20 Sep 2008 16:14:22
Message: <48D559E7.2000105@hotmail.com>
On 20-Sep-08 21:30, Darren New wrote:
> andrel wrote:
>> why would want you distinguish reserved words, variables and functions?
>> In C(++) they might be implemented quite differently, that does not
>> mean however that are fundamentally different on a conceptual level.
> I'm pretty sure "reserved words" are conceptually quite different from
> variables, yes.
Indeed, but only if you assume you have a language that makes that
distinction. It is not a concept that is inherently a part of any
language. Maths does not have 'reserved words'. I.e. for the casual
observer things like '=' and '+' looks as though they are universally
defined and understood the same way. In practice even these are
sometimes redefined to suit a specific field or application in a way
that may even go deeper than overloading. Many operators are also
'reserved words' in certain subfields and not existent in others. If you
want to model a language on the way mathematics is used, defining
'reserved words' is something you might want to leave out.
> Unless you're talking about an extensible language like
> LISP or FORTH or Tcl, the reserved words let you do things that you
> can't do with functions and variables, and vice versa.
I think that FORTH introduced me to the idea that it makes sense to
introduce user level control flow mechanisms.
> Knowing what's an argument and what's a function is also pretty
> important for understanding how a given line of code works.
Again absolutely true, for a imperative language. In lambda calculus and
any functional language derived from that this distinction make no sense
at all.
> If you can't
> look at the code and figure out which function bodies get evaluated, it
> makes it really rough to work out what's going on, even in a functional
> language.
I don't think so. If you have an entity called current_temperature it
should not matter if that is derived by looking at a specific memory
location (a variable), by looking at an index in a circular buffer
(array) or by doing something more complicated like calling a function
of generating an interrupt. OK, it does matter sometimes but only in an
implementation. It should not have any influence on understanding the
code conceptually.
I think you understood that my mean reason for my response was that Warp
is looking with imperative spectacles to lines of code in a functional
language and desperately trying to force it into his own mindframe. Then
again, he might just be pulling Andy's legs. I know he does that
sometimes and I have not followed the entire thread.
Date: 20 Sep 2008 17:19:11
Message: <48d568cf$1@news.povray.org>
Yeah. -Wall. Apparently.
http://blog.orphi.me.uk/
Subject: Re: A test
Date: 20 Sep 2008 17:24:45
Message: <48d56a1d$1@news.povray.org>
Warp wrote:
>   Now you'll have to implement the same program in C++. ;)
Yes. That'll be harder, of course - I don't know the standard library
for C++ inside-out yet. ;-)
I know you probably won't care, but take a look at this:
   http://haskell.org/hoogle/
Now, suppose I want a function that takes a String and turns it into an
Integer. If you type in
   String -> Integer
and hit the search button, the very first result is
   Prelude.read :: (Read a) => String -> a
   (base)
Which tells you that the "Prelude" module (implicitly imported by all
Haskell modules) contains a function named "read", which will transform
a String into any type "a" that is a memory of the "Read" class. (And it
turns out that *all* the basic types are members of this class.)
Similarly, suppose I want to, say, discover whether a given list
contains a specified element. Well, the function that does that is
obviously going to take two arguments - a list, and a thing to find.
Slightly less obviously, you can only do this for types that can be
compared. In Haskell, that means types that belong to the
cryptically-named "Eq" class. So we have
   (Eq x) => [x] -> x -> Bool
A quick search, and we get
   Prelude.elem :: (Eq a) => a -> [a] -> Bool
   (base)
Notice how the arguments are actually the other way round, but the
search still found the function. (You can also search by name - useful
if you find yourself asking something like "dude, WTF is 'nub' supposed
to be?!")
You might not care about Haskell, but you gotta admit all of this is
pretty neat, eh?
Now, the question is... is there a similar resource for C++? Because for
starters, the first thing I'm gonna want to know is how to choose a
random number in C++. ;-) (Altough I dare say for *that*, a simple
Google search will probably answer...)
Subject: Re: A test
Date: 20 Sep 2008 17:36:36
Message: <48d56ce4$1@news.povray.org>
Warp wrote:
>>    case compare number target of
>   I think this line illustrates well what I wrote earlier. Just a list
> of whitespace-sepaated words. No delimiters, no hints about what might be
> a reserved keyword, what might be a variable, what might be a function.
Fair point.
The following are reserved keywords in Haskell:
   module, where, import, qualified, hiding, as, case, of, let, in,
data, type, newtype, class, instance, deriving, do
I'm pretty sure that's the complete list. I count 17 reserved words. (A
quick Google search indicates that C++ has roughly 90 of 'em.) If you
see any of these words, it's a keyword.
(It's actually kinda irritating that "in" and "as" are keywords; these
would make convinient variable names from time to time, e.g., handles
named "in" and "out". But, alas, no...)
>   I'm no at all sure how that should be parsed. Could it, perhaps, be
> something like:
>     case(compare(number, target)) of
>   What would be wrong with a syntax like that?
You can write
   case (compare number target) of
if you prefer. This is completely valid syntax.
Now, if it was pretty-printed like THIS:
   http://hpaste.org/10565
you wouldn't be as confused. (?) If you have some kind of text editor
with syntax-hilighting, this isn't an issue. (I don't know anything
about Emacs, but I imagine it can't be hard to program it so that just
the 17 words above print in a different colour...)
As for why functions aren't called like foo(x, y, z) like in C... that's
due to function currying. In Haskell, you say "foo x y z" because then
you can write "foo x y" to mean a function that just accepts "z". (Or
just "foo x" for one that accepts "y" and "z", or "foo" for the function
itself, or whatever.)
Note that you *can* write foo (x, y, z) in Haskell, because "(x, y, z)"
is what Haskell calls a "tuple". This has a different type though. (It's
like the difference between calling a C++ function with an array verses
a vector. Same concept, different implementation - and type.) This is a
so-called "uncurried function", and they aren't used much.
Subject: Re: A test
Date: 20 Sep 2008 17:40:13
Message: <48d56dbd$1@news.povray.org>
Vincent Le Chevalier wrote:
> Honestly just from the strings that are being printed one can guess what
> this program is meant to be doing... Should be true of any language.
Well, you'd hope so, yes... ;-)
Subject: Re: A test
Date: 20 Sep 2008 17:49:16
Message: <48d56fdc$1@news.povray.org>
>   module, where, import, qualified, hiding, as, case, of, let, in, data,
WRONG! It's actually 21. I forget if/then/else, and apparently "default"
is a keyword...? (Ah, yes. The Haskell '98 Language Report explains that
this very obscure keyword is for adjusting the type defaulting
mechanism. As if you'd want to...)
Apparently it's already been done. (SUPRISE!)
http://www.iro.umontreal.ca/~monnier/elisp/#haskell-mode
Date: 20 Sep 2008 18:52:58
Message: <48d57eca@news.povray.org>
Orchid XP v8 wrote:
> Nicolas Alvarez wrote:
>> I understand the C++ one and the Haskell one looks like line noise.
> Uh-huh, and let me guess: You already know how to read and write C++
> fluently, but you know nothing about Haskell yet? :-P
Correct.
> Seriously, I am constantly baffled by statements like this.
But you used to say the same in the opposite direction. "That C++ looks SO
unreadable, yet I fully understand this mess of a haskell program".
