POV-Ray : Newsgroups : povray.off-topic : My first C++ program Server Time
28 Jun 2026 02:08:36 EDT (-0400)
  My first C++ program (Message 140 to 149 of 149)
Subject: Re: A test
Date: 24 Sep 2008 09:35:12
Message: <48da4210$1@news.povray.org>
Warp wrote:
>   Or I could simply make an overloaded version of the fold function which
> takes an iterator range.
Now what happens if you want to only process elements having some
arbitrary property? (E.g., only the odd numbers.) Or what if the
function you're trying to fold is non-associative, and you want to
rearrange the list so the elements can be processed in a different order?
The idea behind Haskell's data processing function is that each function
does *one* job, which makes it possible to combine them in any possible
way. (This is not unlike the Unix idea of implementing complex
functionallity by "piping" data between multiple simple utility
programs, as seen in millions of shell scripts.) As soon as you start
trying to rely on particular pre-combined functions, you lose that
flexibility.
With lists in particular, the new stream-fusion library means that most
if not all common combinations of list processing functions get
automatically fused together by the compiler.
There used to be a function called "concatMap", which does the same
thing as "concat . map", but more efficiently. It's actually still there
for compatibility, but with stream fusion you don't actually need it any
more [because "concat . map" gets optimised into the same thing].
If you really need killer performance on a critical region of your
program... well actually, in that case you probably wouldn't be using
lists anyway, but still... if you really need killer performance
somewhere, you can manually fuse if the compiler somehow fails to do it
for you. But otherwise, the code is much more maintainable if you don't.
Subject: Re: A test
Date: 24 Sep 2008 09:42:32
Message: <48da43c8@news.povray.org>
  I make the function take a functor which tells which elements to process.
This is a standard technique in C++.
> Or what if the
  Then rearrange the list as you like and give it to the function?
  There are algorithms for which linked lists are the most efficient
data container. You still don't want to be needlessly copying the elements
around, though.
Subject: Re: A test
Date: 24 Sep 2008 09:44:42
Message: <48da4449@news.povray.org>
> I can certainly see why the standard doesn't mandate anything either
> way. Do you happen to know the "typical" behaviour of any well-known C++
> compilers? (Presumably it varies depending on the optimisation level you
> select...)
  Compilers use some kind of heuristic to determine whether it's beneficial
to inline some function or not. What those heuristics are, I don't know.
  From the programmer's point of view, it doesn't really matter. The program
will behave identically in either case (except maybe a small difference in
execution speed).
Subject: Re: A test
Date: 24 Sep 2008 09:51:18
Message: <48da45d6$1@news.povray.org>
Right. And now what if the elements to process depends on the
surrounding context and you have to make several passes of the list to
identify them?
We're missing my point though. My point is that you can't write a
specialised implementation for every possible combination of list
processing operations. But with stream fusion, the compiler can generate
those for you - and yet the source code stays easily readable and
modifiably.
> around, though.
Agreed.
This is why people have spent years doing research and coming up with
sophisticated optimisation techniques. :-)
Subject: Re: A test
Date: 24 Sep 2008 09:53:01
Message: <48da463d@news.povray.org>
> execution speed).
Right. Well I guess that more or less answers my question. I was just a
little worried that maybe if you don't explicitly say "inline", the
compiler will never attempt to inline it and hence introduce way too
much overhead. It seems that's not the case...
Subject: Re: A test
Date: 24 Sep 2008 11:33:56
Message: <48da5de4$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> fold goes from yadda.begin() to yadda.end(). If you don't want to do
>> that, use a different function. Or write it more iteratively, so to
>> speak. Think about your C++ implementation of fold - you would have to
>> copy the list there too if you wanted to use that on a subset.
Which is what I was suggesting be done with Haskell, when I said "write
a more iterative version". Pass in a start index and a length, walk down
the list "start" elements, apply the operator to "length" elements,
return the result. If you don't want to copy the list, don't separate
out the function of copying the subset from the function of applying the
operator. (I don't know, Haskell might even be smart enough to lazily do
the Right Thing there even if you do it naively.)
Subject: Re: A test
Date: 24 Sep 2008 11:46:04
Message: <48da60bc$1@news.povray.org>
Yeah, if it bothers you that much, you could manually say something like
   my_fold fn x0 i0 i1 list
     | x0 > 0 = my_fold fn x0 (i0-1) (i1-1) (tail list)
     | x1 > 0 = fn (head list) (my_fold fn x0 0 (i1-1) (tail list))
     | otherwise = x0
while will skip over list elements until i0 counts down to 0, then it
starts folding until i1 counts down to zero, then it stops.
In Haskell, writing
   list_function_1 . list_function_2 . list_function_3
is an extremely common idiom, and one which the compiler is designed to
handle well. GHC has had produce/consume fusion for years, but now
there's the stream-fusion library, which does even better:
   http://www.cse.unsw.edu.au/~dons/papers/CLS07.html
The fundamental idea is to take list-processing functions, remove the
recursive part, let the compiler inline like hell, wrap the recursion
around it, and you end up with something like a single for-loop with all
the work inside it. No copying involved. (And if the thing that produces
the list can be fused, the list might not actually exist in memory at
all. It might be kept in CPU registers. Depending on type, obviously.)
Subject: Re: A test
Date: 24 Sep 2008 12:02:18
Message: <48da648a@news.povray.org>
http://yosefk.com/c++fqa/inline.html#fqa-9.1
(Warp will hate me for quoting that, but it's actually a pretty good
explanation.  "inline" has nothing to do with inlining functions.)
Subject: Re: A test
Date: 24 Sep 2008 15:37:41
Message: <48da9705@news.povray.org>
> process.
You can even write a custom iterator that, when incremented, skips even
numbers. Then you can use it with the existing fold function.
Subject: Re: A test
Date: 24 Sep 2008 15:44:25
Message: <48da9899@news.povray.org>
> > process.
  Good point. In fact, you can create iterators which do a lot of fancy
things, like for example one which traverses the container backwards
(a standard such iterator exists), if you need to perform an operation
in reverse order, or whatever you wish. And all this without having to
modify nor copy the data container.
  Well, I assume that when you say in Haskell "reverse the list and then
give it to this function" the compiler might be able to avoid copying the
list to another one with the elements in reverse order.
