POV-Ray : Newsgroups : povray.off-topic : Re: stochastic (monte-carlo) tracing Server Time
19 Oct 2026 14:10:58 EDT (-0400)
  Re: stochastic (monte-carlo) tracing (Message 1 to 22 of 22)
Subject: Re: stochastic (monte-carlo) tracing
Date: 11 Sep 2008 14:05:45
Message: <48c95df9$1@news.povray.org>
Ray Bellis wrote:
>> Very nice images! Path tracing really gives very realistic
>> result with very little tweaking. Nice!
> What's a good place to discuss algorithms?
> I've written a simple stochastic tracer in Java and I'm struggling with
> doing diffuse inter-reflection, and getting enough rays to hit my ambient
> "light sources".
I think Off-topic is the best place. If you mean this news server. (You
can answer to this post and the follow-up will be posted in the correct
group.)
I have also done my own renderer:
http://www.saunalahti.fi/~sevesalm/ssRay.html
Still a lot of work to be done...
Date: 11 Sep 2008 17:28:39
Message: <48c98d87@news.povray.org>
> (You can answer to this post and the follow-up will be posted in the
> correct group.)
Yes - yours was the inspiration for my work.
So far mine only does spheres and planes, though.
However I've abstracted out a lot of stuff so that new shading algorithms
can be implemented as a standalone Java class.
Hence I have standard "Refract" and "Reflect" shaders, but two versions of
"Diffuse" - one that does standard light source tracing and shadow
detection, and a Monte-Carlo one which fires off rays in random directions,
hopefully hitting other objects.  These shaders are hence a little bit like
Renderman shaders.
It's also fully multithreaded :).  Bizarrely the JRE on MacOSX seems
*really* fast compared to other O/S.  On my MacBook Pro with a Core2Duo I
get better performance than on my 3.0 GHz Core2Quad XP machine, and only
slightly worse performance than on the 16 core Opteron server at work.
For anti-aliasing I do multiple passes, just throwing rays in at completely
random coordinates.
cheers,
Ray
Date: 11 Sep 2008 22:09:55
Message: <48c9cf73@news.povray.org>
Still waiting for you to release the code :) Or even a binary! I want to
play with it!
Date: 12 Sep 2008 11:36:12
Message: <48ca8c6c$1@news.povray.org>
We both have to thank Fidos for path tracing inspiration! I immediately
got interested when he posted the images on this news server.
I also have only a few objects. So much to do even with those only.
Sounds a good approach. I started this project cause I wanted to learn
some C++ (and OO programming). So you can imagine I have re-structured
my code quite a bit.
That kinda sucks if the differences are big. I don't know Java but it
sounds off if multithread performance on XP is significantly slower.
> random coordinates.
Yeah. That works well. You can improve it (and many other random things)
by not choosing totally random samples but using some pseudo-random
sampling that gives more evenly spread samples.
I'm now implementing direct lighting calculations. The results are
impressive. So instead of just letting rays bounce randomly and hoping
that they hit a light source, I now evaluate direct lighting component
at each bounce. The result is that the noise reduces A LOT faster. If
the light sources are small, the difference gets bigger. If I used point
light sources, my original program would never hit them.
Still some nasty bugs I have to figure out but this one is a keeper. The
downside is that I have no idea if I can implement this feature for any
kind (shape) of light source. Now it works for spheres as it is easy to
calculate the solid angle. We'll see...
Severi
Date: 12 Sep 2008 11:37:27
Message: <48ca8cb7@news.povray.org>
> play with it!
Never...NEVER!! It's my precioussss..... :)
Date: 12 Sep 2008 12:14:10
Message: <48ca9552@news.povray.org>
>> "light sources".
> group.)
Now if you want to get really realistic:
* Instead of shooting RGB rays, shoot photons of a particular wave
length, selected randomly from the spectrum of the light source at the
emission point;
* at each surface of intersection, calculate the chances of refraction,
reflection, absorption, and possible emission, and either shoot the
photon off at another angle, or count it as absorbed and start a new photon;
* Remember that the angle of refraction is dependent on wavelength.
Voila:  Rainbows are built in.
* Do constructive and destructive interference so that you can produce
realistic iridescence.
* A photon isn't drawn on the screen unless it hits the virtual film.
Then you calculate its RGB value, and add that to the pixel at that
point in the screen.
John
Date: 12 Sep 2008 14:04:29
Message: <48caaf2d$1@news.povray.org>
I've done a few refactorings on mine too.
The biggest one was then I realised that the bulk of the work in the tracer
used a function with the same parameters as the shaders, so that itself
became a shader. :)
>> completely random coordinates.
> things) by not choosing totally random samples but using some
> pseudo-random sampling that gives more evenly spread samples.
Mine does seem to work pretty well as is.
> point light sources, my original program would never hit them.
I've had this problem - can you please explain this direct lighting
algorithm in more detail?
> The downside is that I have no idea if I can implement this feature
> for any kind (shape) of light source. Now it works for spheres as it
> is easy to calculate the solid angle. We'll see...
This sounds promising.
BTW, I implemented simple "rough" reflections earlier today.  That algorithm
was trivial:
  d = original_reflection_direction
  s = surface_smoothness
  if (s > 0) {
    pt = random_vector();
    d += s * pt;
    normalize(d);
  cast_new_ray(d);
I haven't checked that it's mathematically accurate (it's possible that the
distribution of the pertubed ray around the original direction isn't
uniform) but it looks nice enough.
Ray
Date: 12 Sep 2008 14:18:18
Message: <48cab26a@news.povray.org>
> algorithm was trivial:
>  if (s > 0) {
>    d += s * pt;
>    normalize(d);
>  cast_new_ray(d);
> that the distribution of the pertubed ray around the original
> direction isn't uniform) but it looks nice enough.
p.s. I've uploaded a sample image to:
http://ray.bellis.googlepages.com/mc-balls-01.jpg
A lot of the noise on that image is from the JPG compression.  This is from
1.75 hours of rendering on a MacBookPro (Core2Duo)
Ray
Date: 13 Sep 2008 09:05:01
Message: <web.48cbb9c63ac6d32033b2d9360@news.povray.org>
> emission point;
Yes. This should be implemented at some point to enable accurate dispersion.
Done!
Too far a way now...
I start the rays from film plane so all rays always hit the film. I'm not sure
if anyone does it the other way and how it works in practice.
Date: 13 Sep 2008 09:20:00
Message: <web.48cbbd6c3ac6d32033b2d9360@news.povray.org>
Ok, I'll try. Let's assume we have found the first intersection point along the
ray. Instead of choosing a random new direction (if it is a diffuse surface)
you can do this:
1. Pick a random point on a light source.
2. Check if it is visible or not.
3. If it is, add the radiance it contributes. You must take the cosine term into
account as well as the ratio of solid angle of the source and hemisphere (the
last one thus handles the distance of the light source).
4. After this you can continue tracing the path normally. But if the ray next
hits the same light source, ignore it as otherwise you have calculated it
twice.
Oh, and there are 2 ways to handle multiple light sources:
A. Sample only 1 source from N light sources and multiply the result by N. This
is unbiased and gives the correct result with many passes.
B. Sample all light sources and add the results together.
Example. We have 3 lights that give these values: 0.4, 0.6, 1.0. Let's do 100
passes.
B gives 100*(0.1+0.5+1.0) = 200.
A might give 40*3*0.4+30*3*0.6+30*3*1.0 = 192.
Increasing passes decreases the error. Nice technique that might give good
results if you have many light sources.
That is the basics. The devil lies in the details and I still have some nasty
bug(s) somewhere.
Severi
Date: 13 Sep 2008 09:25:00
Message: <web.48cbbf0b3ac6d32033b2d9360@news.povray.org>
Nice! Maybe no accurate but the results look good. If you want better, see this:
http://en.wikipedia.org/wiki/Specular_highlight
(I have not implemented them yet, but some people use Blinn or Cook...) Anyway,
good that I'm not the only one interested in this madness :)
Date: 13 Sep 2008 10:30:36
Message: <48cbce8c$1@news.povray.org>
> along the ray. Instead of choosing a random new direction (if it is a
> diffuse surface) you can do this:
> cosine term into account as well as the ratio of solid angle of the
> source and hemisphere (the last one thus handles the distance of the
> light source).
> ray next hits the same light source, ignore it as otherwise you have
> calculated it twice.
Do you still trace some random diffuse rays too?  Otherwise how do you end
up with diffuse inter-reflection?
In either event the maths sounds pretty tricky :(
It also appears to mean that you need to treat your light sources
differently to normal objects.  At the moment my light sources are just
high-ambient primitives.
Ray
Date: 13 Sep 2008 10:59:21
Message: <48cbd549$1@news.povray.org>
> Cook...)
I'm familiar with Phong, but I've not used any of the others.
Curiously these models all seem to describe ways to approximate the
resulting light intensity fall-off for direct ray-tracing to light sources.
None of them seem to describe methods to actually perturb the normal to
directly simulate micro-facets.
Hence my method (whilst not strictly accurate) produces blurred reflections
of the entire scene, and not just specular reflections of the light sources.
I guess that's the advantage of the Monte Carlo method - if you're going to
cast millions of rays you can afford to average out the results numerically,
rather than use a mathematical approximation.
> Anyway, good that I'm not the only one interested in this
> madness :)
Indeed.
I'd also be happy to share my code...
Do you happen to have the geometry of your sample images available?  I'd
like to try to create the same scenes to compare results.
cheers,
Ray
Date: 13 Sep 2008 11:10:01
Message: <web.48cbd75d3ac6d32033b2d9360@news.povray.org>
Yes, that is the step 4 above. After you evaluate direct lighting component you
can continue normally to random direction. And at the next intersection you do
the same steps again. We definitely want to have global illumination...
It is not really _that_ tricky. But I needed a pencil and a piece (or 2) of
paper to figure out how to calculate the solid angle thingy. And how to take
the object color into account during this incremental path creation.
Yes, that is correct. The renderer has to have a list of light sources. I also
did first what you do now: light sources are normal objects with emission. And
all images on my page are rendered that way. This "new" method is great because
it improves speed so much. It is worth implementing.
Date: 13 Sep 2008 23:53:13
Message: <48cc8aa9@news.povray.org>
>> emission point;
I should say that the weakness of this approach is that a surface that
is supposed to be a uniform color will now appear to be a mixture of
pixels that average to that color.
So it traces from 'film' to light source, instead of the other way
around?  I had assumed that it went the other way.  Maybe I could try
writing a renderer that does that.
John
Date: 14 Sep 2008 03:05:01
Message: <web.48ccb7173ac6d32033b2d9360@news.povray.org>
Then you just have to give it a few more days to render and the variance will go
away :-)
Join the crowd! If you start from light sources you have to have some clever way
to get the rays inside camera view angle and then hit the camera. The other way
around you have to make them hit the light sources eventually. Both are
plausible but I have no idea how to prevent from shooting totally unnecessary
rays (ie. those just misses the camera) with the first method.
Date: 14 Sep 2008 11:28:57
Message: <48cd2db9@news.povray.org>
John VanSickle nous illumina en ce 2008-09-13 23:53 -->
>>> emission point;
>> dispersion.
>> not sure
> Regards,
> John
All ray tracers go from the camera to the objects in the scene then to the light
source(s). It's called backward ray tracing. Much more effecient that way.
If That Phone Was Up Your Butt, Maybe You Could Drive A Little Better!
Date: 14 Sep 2008 12:36:17
Message: <48cd3d81$1@news.povray.org>
> the light source(s). It's called backward ray tracing. Much more
> effecient that way.
Actually, many raytracers do a hybrid: they start simultaneously from
camera AND lightsource. At least bidirectional path tracing works like
that. They then connect the paths somewhere in between. That seems very
promising technique.
Date: 14 Sep 2008 14:25:36
Message: <48cd571f@news.povray.org>
>> effecient that way.
I saw one that starts from the light sources (which are high-ambient
objects) bouncing rays around. When the rays hit objects, the "hits" are
saved in a buffer. When the buffer gets full, it does a normal backwards
raytracing (from the camera), collecting the buffered hits near the
intersection point of the bw-raytracing ray. Then the buffer is emptied and
process repeats.
Date: 16 Sep 2008 08:06:08
Message: <48cfa130@news.povray.org>
I would probably set the renderer so that after so many reflections, the
current ray origin is tested to see if it is in the camera view.  If so,
reflect the photon directly at the camera.  Otherwise, cancel the
photon.  It probably won't help much, but it could help a bit.
The real weakness of the whole approach is that for animation work, the
rendering has to be allowed to go on until the graininess is gone, and
there isn't a reliable way to predict that.
John
Date: 17 Sep 2008 05:53:42
Message: <48d0d3a6$1@news.povray.org>
Not sure if the wikipedia article was the best to cover path tracing
needs. But at least pbrt/Luxrender has implemented Blinn stuff. And it
seems good (and definitely works for any light arriving to a point, not
just direct)
Yeah, and with modern multi-core CPUs Monte Carlo is actually possible.
You get good image usually in hours and more the cores we get, the
better. This stuff scales perfectly.
Not at present. I still try to figure out a few problems in my code.
When I know the results are truly unbiased and accurate, I can put a few
simple test scene geometries somewhere and the output.
Date: 19 Sep 2008 03:54:51
Message: <48d35acb@news.povray.org>
I think the new feature is working properly now. Still have to test a
bit more. But the speedup is really astonishing. The newest image (the
grid of colorful blocks) on my site was first rendered in over 24 hours
with the old and slow method.
With the new direct lighting method I can achieve same noise levels in
less than hour, more like 30minutes! Than is more than one order of
magnitude speedup! And the smaller the light source is, the bigger the
difference gets.
W00t.
