POV-Ray : Newsgroups : povray.off-topic : Linux & drivers Server Time
3 Nov 2026 03:33:34 EST (-0500)
  Linux & drivers (Message 1 to 43 of 43)
Subject: Linux & drivers
Date: 4 Sep 2008 10:07:42
Message: <48bfebae$1@news.povray.org>
While building my new PC I ran into an interesting problem trying to
boot a live Linux CD - at least all of the ones I tried.
Many motherboards are using the Marvell IDE controller - which is
currently not supported by most Linux distributions.
So while it starts booting fine, when it hands off to the kernel
everything comes to a screeching halt because it cannot find the CD.
I found pendrivelinux.com that helped me with w very quick boot from USB
solution.
Funny enough, it was the Knoppix screen shot that Andrew posted that I
had been seeing for the past few days.
And all I wanted - fdisk
<sigh>
Tom
Subject: Re: Linux & drivers
Date: 4 Sep 2008 11:12:18
Message: <48bffad2@news.povray.org>
Interesting...
My motherboard uses the nVidia nForce 4 chipset, and as a result many
Linux live CDs can't see any of the SATA drives. However, they all find
the PATA ones just fine.
(I remember seeing "Marvell" and thinking "oo, that's what I have". But
it isn't. I have a Marvell NIC. The IDE controller is nVidia.)
I discovered that many if not most live CDs can be coaxed into seeing
the drives by manually executing a modprobe command. (No, I have no idea
which one... and it wouldn't help you anyway.)
http://blog.orphi.me.uk/
Date: 4 Sep 2008 11:24:44
Message: <48bffdbc$1@news.povray.org>
> Interesting...
That's what I ran across - I just didn't have the energy to dig into
which one.
I guess I should learn it sometime as this PC is going to have this
issue for a while and I plan on doing some fun Linux things with it.
Tom
Date: 4 Sep 2008 11:34:38
Message: <48c0000e$1@news.povray.org>
>> idea which one... and it wouldn't help you anyway.)
> which one.
IIRC, most live CDs failed to find either my harddrives or my NIC. To
fix it, you have to say something like
   modprobe nv_forcedeth
   modprobe nv_sata
and then they both work again. I figured this out by searching several
billion manpages, discovering where kernal modules (such as device
drivers) are stored, and then listing the contents of the folder and
looking for anything that sounded like it might work.
Hard to fix? No. User-friendly? No!
I still have no idea what "force deth" actually means...
Date: 4 Sep 2008 12:04:40
Message: <48c00718$1@news.povray.org>
>> which one.
>   modprobe nv_sata
I find that I can get into Linux fairly easily and remember quite a bit,
but when i step back from the guts for a while I have to figure things
out again.  Granted it all seems familiar and doesn't take as long, but
it's hard to remember exactly what everything does when you mess with it
once in a while.
Date: 4 Sep 2008 13:10:18
Message: <op.ugyvbgqh7bxctx@e6600>
It makes more sense as "forced eth", even though the idea of a module that
forces death is somewhat amusing...
Apparently, the ambiguity is at least partially intentional.
FE
Date: 4 Sep 2008 13:43:50
Message: <48c01e56@news.povray.org>
> once in a while.
I know what you mean...
At one time I installed Gentoo Linux. (As in, that Linux that doesn't
come with an installer and has to be manually compiled from source and
installed piece by piece.) Now I have _no clue_ how I did it.
Date: 4 Sep 2008 13:56:22
Message: <48c02146$1@news.povray.org>
What does fdisk give you that diskpart doesn't?
Date: 4 Sep 2008 15:28:06
Message: <48c036c6$1@news.povray.org>
Weird, my HP system here has that same chipset on it, and the live discs
do OK with it - SATA drive works beautifully with openSUSE 11.0 running
on it, too.
Jim
Date: 4 Sep 2008 15:40:01
Message: <48c03991@news.povray.org>
I usually do a Linux From Scratch for most things.
While I do the automated build, it at least keeps me in touch with the
roots of what is going on.
Date: 4 Sep 2008 15:42:17
Message: <48c03a19$1@news.povray.org>
I know how to use it and get to it easier than thru the XP recovery console.
I actually tried to get to it, but was prompted for an XP installation
to recover before I got to a prompt that I could use.
I figured that at that point I would rather learn how to get Linux
running on my machine because I plan on messing around with it later.
Tom
Date: 4 Sep 2008 16:47:12
Message: <48c04950$1@news.povray.org>
> console.
Diskpart runs for me from the XP command line. Oh, I see what you mean.
You had nothing at all on the machine. OK.
Yeah, I can see where that would slow you down. :-) BartPE is a good
cure if you do that sort of thing regularly.
Yeah. And live CDs are certainly easier to find for Linux than Windows.
I just thought there might have been functionality missing or something
that I didn't know about in fdisk.
Date: 4 Sep 2008 20:53:14
Message: <48c082fa@news.povray.org>
  Does Windows support creating so-called live CDs at all (maybe through
extensive hacking)? I know you can create recovery boot disks from Windows,
but if I'm not completely mistaken, those just basically create a DOS disk
with some text-based utilities. You *could* call that a "live CD", but
not really, IMO.
  Of course even if Windows had full support, there's always the pesky
limiation that it's commercial software which is illegal to distribute
without permission. There really are certain situations where free
software does have its advantages.
Date: 4 Sep 2008 21:56:24
Message: <48c091c8$1@news.povray.org>
> extensive hacking)?
Yes. It's not extensive hacking. It's a normal supported thing. They
call it "Preinstall Environment."  You can buy it from Microsoft, or you
can google for BartPE, which provides a free program that takes the
files from the XP install disk and makes them bootable.
> You *could* call that a "live CD", but not really, IMO.
Nope. This is a full graphical environment and everything. Not the same
as a Linux live-cd, as (for example) most services aren't running. But
it's good enough for what I want to do, which is (for example) resize
the system partition, or back up *everything* including the registry, etc.
This is true. But the program that takes your legal Windows CD and turns
it into a live CD is free.
Date: 5 Sep 2008 03:55:31
Message: <48c0e5f3@news.povray.org>
People say that about Gentoo too, but... watching pages of gibberish
scroll past keeps you "in touch with the roots of it"? Hmm. Not so much...
Date: 5 Sep 2008 03:56:57
Message: <48c0e649$1@news.povray.org>
> that forces death is somewhat amusing...
Well, "force" because it's the nForce 4 chipset. "eth" because it's the
Ethernet interface. I have no idea what the "d" is for. ("Disassembled"?
As in, they reverse-engineered a drives from the Windoze version?)
Date: 5 Sep 2008 03:57:40
Message: <48c0e674$1@news.povray.org>
> on it, too.
When I tried this, openSUSE 11.0 did not exist.
(IOW, now that it's no longer a brand new chipset, maybe drivers are
more widely available.)
Date: 5 Sep 2008 04:27:02
Message: <48c0ed56@news.povray.org>
  Another question is whether the Windows usage license allows you to do
that...
  Commerciality also makes it difficult to distribute projects like this:
http://en.wikipedia.org/wiki/Hikarunix
Date: 5 Sep 2008 05:57:06
Message: <48c10272$1@news.povray.org>
Warp wrote:
>   Does Windows support creating so-called live CDs at all?
Yes.
My dad owns such a CD. It's Symantec Ghost. (The consumer version.) If
you boot the CD, it loads Windows XP and allows you to perform Ghost
restore operations.
Let me tell you: It runs SLOWER THAN MOLASSES! If you thought Linux live
CDs were slow, you ain't seen nothing yet!
(You'll notice that the Ghost boot CD now no longer allows you to
perform backups. ONLY restores. To perform a backup, you must "install"
and "activate" the program over the Internet. But restore you can do
using the boot CD. Presumably useful if you somehow break your Windoze
installation and can't boot it to run Ghost...)
Absolutely.
I have nothing against having to pay for software. (I have several
things against M$ products, but the fact that there's a fee isn't one of
them.) But having to keep track of whether you're "allowed" to be doing
what you're trying to do can be really which tricky and awkward - even
if you're *trying* to stay within the law. When companies add features
to try to "enforce" this, it always makes things more complex.
There is definitely a lot to be said for software that you can just
*use*, however you feel like using it.
Date: 5 Sep 2008 08:43:54
Message: <48c1298a$1@news.povray.org>
It isn't watching pages of gibberish - it's the few steps that aren't
done automatically that does it for me.  And that's not selecting "go"
either.
For me a typical LFS build consists of
fdisk
run LFS automated
setup grub
select kernel options & compile
setup boot scripts
pick which actual applications I want & manually install them
I agree that this isn't for everyone.
I have more interest in the guts than most people.
What I think I enjoy the most is learning how each application really
works as I install it.  That way I know what my options are - instead of
'just use this'.
Tom
Date: 5 Sep 2008 08:51:40
Message: <48c12b5c$1@news.povray.org>
Darren New wrote:
>> console.
yep - blank slate - was kinda nice.
I think I remember running across that a couple of years ago - Live
Windows, but for some reason never pursued it.
but finding one that would boot on my machine.....
pendrivelinux is a pretty nifty site.
It's amazing what people are doing.
I wish I had that kind of time.....
probably not
DiskPart is a pretty powerful program.
I had to use it to set up hot-swap IDE on a Windows Server - along with
a lot of other things.
Later... Tom
Date: 5 Sep 2008 08:53:25
Message: <48c12bc5$1@news.povray.org>
One advantage of using a Live-Windows boot - you can actually do things
with NTFS.
My understanding is that Linux and NTFS still aren't the best of friends.
Tom
Date: 5 Sep 2008 12:07:34
Message: <48c15946@news.povray.org>
Tom Austin wrote:
> setup grub
Actually, I was wondering about that, and about booting in general.
The boot sector is really only part of one sector. That doesn't seem
like enough room to write code to find NTLDR or whatever the second step
of Linux boot code is (GRUB I assume, or LILO). Especially given the
wide range of partition types and RAID types a boot partition is allowed
to be on in Linux.
How does it fit enough of the file system code into the boot mechanism
to find the files it needs? Is there something special, such that (say)
copying the file to a different place on the disk would keep things from
booting?
I know you don't have to do anything special if you move NTLDR around,
but that could be a special case in the Windows file system code, I'd
guess. (Maybe I'll try moving it with my live CD and see if stuff still
boots. :-) Even if not, both FAT and NTFS are relatively easy to deal
with, so I can imagine the code being sufficiently simple for a
specifically-named file in the root directory.
Date: 5 Sep 2008 12:14:29
Message: <48c15ae5$1@news.povray.org>
> that...
According to the BartPE page...
Also, according to the Microsoft EULA for Windows XP/2003, a user may
not simultaneously use more installations of these operating systems
than the user has license(s) for.
I.e., if you only run BartPE on machines for which you have a Windows
license already, you shouldn't be violating the license. I'm not a
lawyer, so I really couldn't say more than that.
Obviously, if you make a BartPE disk and boot it on half a dozen
machines which you bought with Linux preinstalled, you're likely
No doubt. (And yes, that's a pretty silly project. :-)
Date: 5 Sep 2008 12:18:24
Message: <48c15bd0$1@news.povray.org>
Hmmm... Unless you create it from an XP disk you never installed and
therefore never agreed to the license for. That could be a curious
situation.  (Altho, I *think* I remember BartPE asking me if I agreed to
the XP license before it would make its copies. But that would seem easy
to patch out of BartPE. :-)
Date: 5 Sep 2008 12:57:34
Message: <48c164fe$1@news.povray.org>
>>> find the PATA ones just fine.
>> discs do OK with it - SATA drive works beautifully with openSUSE 11.0
>> running on it, too.
Well, as Darren said, 3 months is an eternity in the Linux world.  :-)
That most certainly is the case. :-)
Jim
Date: 5 Sep 2008 12:58:09
Message: <48c16521$1@news.povray.org>
> extensive hacking)?
In a roundabout way, yes - BartPE is one that I've seen used for
specialized applications like imaging.
Jim
Date: 5 Sep 2008 12:59:16
Message: <48c16564$1@news.povray.org>
> friends.
ntfs-3g solves those issues.
Jim
Date: 5 Sep 2008 13:15:53
Message: <op.ug0p8ri57bxctx@e6600>
Presumably "driver".
> ("Disassembled"? As in, they reverse-engineered a drives from the
> Windoze version?)
The Linux version actually.
http://kerneltrap.org/node/1606
FE
Date: 5 Sep 2008 13:29:46
Message: <op.ug0qvwv47bxctx@e6600>
> to be on in Linux.
> booting?
http://www.gnu.org/software/grub/manual/html_node/Bootstrap-tricks.html
http://www.gnu.org/software/grub/manual/html_node/Images.html
I know from experience that moving stuff around on the boot partition can
break GRUB.
FE
Date: 5 Sep 2008 13:44:12
Message: <48c16fec$1@news.povray.org>
>> step of Linux boot code is (GRUB I assume, or LILO). Especially given
>> the wide range of partition types and RAID types a boot partition is
>> allowed to be on in Linux.
>> (say) copying the file to a different place on the disk would keep
>> things from booting?
> can break GRUB.
So the location of the real meat is hard-coded into the MBR. Neat...
Date: 5 Sep 2008 13:46:14
Message: <48c17066$1@news.povray.org>
>> Windoze version?)
Ah. So there *is* a Linux driver, the guys just dislike closed-source
drivers, so they wrote their own?
Date: 5 Sep 2008 13:49:19
Message: <48c1711f$1@news.povray.org>
>> friends.
Several programs claim to "solve" these issues - with varying degrees of
safety warnings. ;-)
(There are kernel NTFS drivers, there's a gizmo that loads NTFS.SYS from
your Windoze partition and uses that, there are read-only NTFS drivers,
and so on and so forth.)
Date: 5 Sep 2008 13:53:19
Message: <op.ug0ry5xf7bxctx@e6600>
On Fri, 05 Sep 2008 19:46:19 +0200, Orchid XP v8 <voi### [at] devnull> wrote:
Presumably, though I do not actually know their motives.
Eventually nVidia started contributing to forcedeth, and a couple of years
ago they dropped their own driver.
FE
Date: 5 Sep 2008 14:56:02
Message: <48c180c2$1@news.povray.org>
>>> mechanism to find the files it needs? Is there something special,
>>> such that (say) copying the file to a different place on the disk
>>> would keep things from booting?
>> can break GRUB.
He beat me to it.
Yes, the MBR's job is only to load the real boot code.
I've never dug enough into it, but I've always been interested in what
calls the MBR has to make to load sectors and what not.
Those are calls that I could have access to to make my own boot junk.
I wish I had more time.....
Tom
Date: 5 Sep 2008 15:21:26
Message: <op.ug0v10hh7bxctx@e6600>
http://en.wikipedia.org/wiki/INT_13#INT_13h_AH.3D02h:_Read_Sectors_From_Drive
FE
Date: 5 Sep 2008 16:58:51
Message: <48c19d8b$1@news.povray.org>
Well, yeah, those are the BIOS calls to read sectors from a disk while
in real mode. But then, once you've grabbed enough blocks from disk in
real mode *then* you can worry about entering protected mode and
initialising a real filesystem driver, etc.
BTW, I believe Grub supports booting *any* OS that complies with a set
of simple guidelines. It isn't just limited to booting Linux. (Although
it won't boot Windoze - but it can call the Windoze bootloader
automatically.)
And yes, *I* wish I had more time...!
Date: 5 Sep 2008 18:40:00
Message: <web.48c1b4247002093234d207310@news.povray.org>
Ahem.  So did more than one person try out "some" live CD's and found several
wanting as far as hardware recognition and drivers?!?!!?
Please write up reviews on your blogs! Let the world know!  Linux distros, even
if they are free, are still in a "marketplace" for users.
Date: 5 Sep 2008 18:41:08
Message: <48c1b584$1@news.povray.org>
>>> friends.
ntfs-3g is what uses ntfs.sys - and that one is very stable and usable.
I don't know that it comes with a bunch of warnings, but of course using
closed code with Linux is going to get people to give "warnings" about
the difficulty in solving problems should they arise.
But there's *always* risk to using ntfs.sys even with Windows - things
can go wrong even in a native Windows environment.
Either that, or I imagined the gradual corruption on a coworkers machine
a few weeks ago. :-)
Jim
Jim
Date: 6 Sep 2008 00:34:02
Message: <48c2083a$1@news.povray.org>
Is that how it works? That's rather ... baroque. I'm going to have to
laugh next time someone tells me that having the source code is
necessary to understand how something works. :-)
What surprises me is that there's anything on the file system that can
grow without bound. But as I understand it, at least the security
descriptors (i.e., the ACLs) can get put in a hash table and never
removed. Seems odd.
Date: 6 Sep 2008 04:26:01
Message: <48c23e99$1@news.povray.org>
It's also not necessary to understand how something works just to use it
s public interface. ;-)
Date: 19 Sep 2008 16:54:12
Message: <48d41174$1@news.povray.org>
> several wanting as far as hardware recognition and drivers?!?!!?
> distros, even if they are free, are still in a "marketplace" for users.
Not sure why you wrote this back to me - I was just commenting that
ntfs-3g solves the issues with native NTFS solutions in the Linux kernel.
Jim
Date: 19 Sep 2008 16:55:38
Message: <48d411ca$1@news.povray.org>
I believe that's how it works - much like how ndiswrapper can be used to
use Windows WLAN drivers on Linux.
But using a closed-source driver doesn't mean you have any idea how it
works, just how to interface with it - and that's what reverse
engineering is for.
> removed. Seems odd.
Yeah, I'd agree with that.
Jim
