POV-Ray : Newsgroups : povray.off-topic : Coolest thing EVER! Server Time
3 Nov 2026 03:33:34 EST (-0500)
  Coolest thing EVER! (Message 1 to 50 of 112)
Goto Latest 50 Messages Next 50 Messages >>>
Subject: Coolest thing EVER!
Date: 31 Aug 2008 09:46:40
Message: <48baa0c0@news.povray.org>
OK, so I realise I'm probably about 20 years behind everybody else, but
seriously... this is THE coolest thing I've seen this year! I would
never have believed it was physically possible - and certainly not
without spending hours setting it up. I can't get over how EASY this was!
http://blog.orphi.me.uk/
Download 'qemu.jpg' (157 KB)
Preview of image 'qemu.jpg'
Subject: Re: Coolest thing EVER!
Date: 31 Aug 2008 10:47:49
Message: <48baaf15@news.povray.org>
"im in ur windoze, runnin ur linux."
Date: 31 Aug 2008 11:06:50
Message: <48bab38a$1@news.povray.org>
	You're not that far behind. I only recently set up VirtualBox on my
Linux so that I could run Windows. Works like a charm - I was really
surprised.
It is kisstomary to cuss the bride.
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 31 Aug 2008 12:14:45
Message: <48bac375@news.povray.org>
"Orchid XP v8" <voi### [at] devnull> wrote in message
news:48baa0c0@news.povray.org...
Virtual machines are soooo useful. I've been using them for some time to
test out beta software that I don't want breaking my machine, or to try out
things that I know are going to break stuff (hence the name of the VPC in
the picture)
Download 'lovevirtualpc.png' (131 KB)
Preview of image 'lovevirtualpc.png'
Date: 31 Aug 2008 12:27:29
Message: <48bac671$1@news.povray.org>
> out things that I know are going to break stuff (hence the name of the
> VPC in the picture)
My PC at work is barely powerful enough to run *one* OS, let alone two.
It _would_ be quite useful for test purposes though. (Aside from the
small matter that most of the things I want a test machine for relate to
specific hardware issues, which obviously a virtual machine doesn't help
with...)
However, the idea of being able to just plug in a USB stick and click an
icon and instantly have a complete Linux environment set up exactly the
way I want it is... pretty neat, actually. It's like I can just put my
life on a USB stick, keep it in my pocket, and never again find myself
sat at a PC that lacks a development environment. Haskell EVERYWHERE! >:-D
Only trouble is... it would have to be a pretty damned big USB stick.
DSL is nice, but rather minimal. (Shocker.) KNOPPIX is 700 MB
compressed, and decompresses to something like 4 GB...
Date: 31 Aug 2008 12:30:31
Message: <pmhlb49pho3518hld68ob2f0h600na7nk4@4ax.com>
On Sun, 31 Aug 2008 18:16:57 +0200, "Gail" <gail (at) sql in the wild (dot) co
[dot] za> wrote:
A new email address, Gail!
Have you started your new job yet?
Regards
Date: 31 Aug 2008 12:52:20
Message: <48bacc44@news.povray.org>
"Stephen" <mcavoysAT@aolDOTcom> wrote in message
news:pmhlb49pho3518hld68ob2f0h600na7nk4@4ax.com...
> (dot) co
That's actually the email address related to my blog
(http://sqlinthewild.co.za) not a work address.
I have started the job. Going slowly at the moment. Should be picking up in
a week or two. Lots of clients are currently 'considering what they want'
Date: 31 Aug 2008 12:53:23
Message: <48bacc83$1@news.povray.org>
Also - virtual machines are SOOOO SLOOOOOW... :-/
Date: 31 Aug 2008 12:55:20
Message: <48baccf8@news.povray.org>
news:48bac671$1@news.povray.org...
>> VPC in the picture)
> My PC at work is barely powerful enough to run *one* OS, let alone two. It
That's one of the main reasons I went for a quad core with lots of memory
when I upgraded. So that I could have a couple of virtuals running and still
have the base machine usable.
For example, this afternoon, I was doing performance testing on SQL 2008 on
the base machine while I had a virtual running that was doing a 2005-2008
upgrade
You might have problems with IO speed if you do that. USB is a lot slower
than SATA.
Date: 31 Aug 2008 12:57:39
Message: <48bacd83@news.povray.org>
news:48bacc83$1@news.povray.org...
They can be. Depends how much resources you give them though.
Date: 31 Aug 2008 12:59:42
Message: <48bacdfe$1@news.povray.org>
>> two. It _would_ be quite useful for test purposes though.
> memory when I upgraded.
I can see how that would be the case. ;-)
>> an icon and instantly have a complete Linux environment set up exactly
>> the way I want it is... pretty neat, actually.
> slower than SATA.
Depends what you want to do. Running Damn Small Linux from a USB drive
is probably *faster* than running it from a CD-ROM due to the vastly
superior seek time. (CD-ROM drives typically have a horrible seek time!)
Also, DSL is based on KNOPPIX and uses a cloop compressed filesystem
image, so there's less data to shift (but more CPU load).
If I get bored enough maybe I'll benchmark it. But either way, it's a
trivial matter to copy a folder off the USB drive and onto a spare
folder on the local HD, run it for a while, and then just delete it when
you're done. That's about the easiest install/uninstall procedure
imaginable! ;-)
Date: 31 Aug 2008 13:01:05
Message: <48bace51$1@news.povray.org>
> VPC in the picture)
I use them at work, while one real server can easily hold up the work of
3 smaller servers, and having only one hardware makes less heat, uses
less power, costs less money and takes up less space.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 31 Aug 2008 13:07:12
Message: <ucjlb4l1ddf87j4lves2ms6p2hgf8i7cra@4ax.com>
On Sun, 31 Aug 2008 18:54:53 +0200, "Gail" <gail (at) sql in the wild (dot) co
>> (dot) co
You have a blog dedicated to SQL? Is that so you don't use this forum for Haskel
Oops! Sorry Andrew :)
Yes, I understand. My new job (with Dwr Cymru (Welsh Water)) started off slow
then accelerated so that I've little time for Pov-ing.
I hope yours goes well.
Regards
Date: 31 Aug 2008 15:48:33
Message: <48baf591$1@news.povray.org>
I've been thinking of playing with some virtual machine technology, but
I wasn't aware there was one under Windows that would run Linux. Which
virtual machine are you running here? (I.e., what's the Windows software?)
Date: 31 Aug 2008 16:13:26
Message: <48bafb66@news.povray.org>
1. Go to http://www1.interq.or.jp/t-takeda/top.html
2. Download the zip file at the top of that page.
3. Unzip it somewhere.
4. Find an ISO image for a Linux LiveCD.
5. Do the following:
   qemu.exe -cdrom My_LiveCD.iso
6. Watch it boot up.
It's that easy.
(Actually no, it isn't. The path to the ISO image must contain only
FORWARD SLASHES, not backslashes. Also, if the current directory isn't
the QEMU folder, you must add the -L switch with the correct path so the
emulator can find things like the BIOS image, keymaps, etc.)
The *home page* for QEMU is here:
   http://bellard.org/qemu/
But you have to hunt around a bit for the Windoze port. So I have you
the direct URL...
If all of that is too much effort, go to
   http://www.damnsmalllinux.org/
and download the "embedded" Zip file. This contains a .bat file that you
can just double-click to start up Linux.
PS. If you want to "install" Linux rather than run off a read-only
LiveCD, you can create a harddisk image using the qemu-img.exe tool.
Something like this:
   C:\> qemu-img create Disk1.img 500MB
   C:\> qemu -cdrom My_Install_Disk.iso -hda Disk1.img
Now install Linux onto /dev/hda. Once you've done that, you can run
   C:\> qemu -hda Disk1.img
and you have a read/write Linux system. (Obviously similar steps work
for *any* OS. Build an empty harddisk image, run the emulator with the
install CD ISO image and the harddisk, install, you're done.)
My God... I sound like I know what I'm talking about! This morning when
I woke up, I knew none of this. ;-)
Date: 31 Aug 2008 16:17:12
Message: <48bafc48$1@news.povray.org>
Very nifty. Thanks very much!  I was going to try out the VM from
Microsoft, but this sounds a lot easier to get working. :-)
Date: 31 Aug 2008 16:23:16
Message: <48bafdb4$1@news.povray.org>
Yeah. Zero install. Unzip a file and you're ready to execute stuff.
As I say, DSL uses it to run off a USB flash drive. Stick the flash
drive in, double-click, you have Linux running. Don't even have to
reboot. Live CDs EAT YOUR HEART OUT! (OTOH, emulation is obviously just
a tad slower...!)
Actually, I *think* you can even tell it to use your real CD-ROM drive
as the emulated CD-ROM, if you don't have an ISO image but have a real
CD... You can also do the same with your HD, but... uh... don't!
Date: 31 Aug 2008 17:54:32
Message: <48bb1318$1@news.povray.org>
I'll have to see if I can make it run the Linux on the other partition,
just to see. It could be pretty cool if I could get into my work
machine's configuration for a bit without having to stop what I'm doing
in Windows every time they want some free advice. :-)
Date: 31 Aug 2008 19:54:28
Message: <48bb2f34@news.povray.org>
They aren't that slow. Thing is, you're using QEMU, which isn't a virtual
machine, it's an emulator. Software like VMware or VirtualBox use your real
CPU instead of basically executing x86 code on an interpreter.
Date: 31 Aug 2008 19:56:33
Message: <48bb2fb1@news.povray.org>
Huh? I have yet to see virtual machine software that *can't* run Linux on a
Windows host...
Date: 31 Aug 2008 19:58:34
Message: <48bb3029@news.povray.org>
That's apparently a bad idea. The VM would have different hardware than your
real machine. It's like taking the HD off and booting it on a machine with
completely different CPU, motherboard, network card, graphics card...
At least Windows would pop up a dozen "new hardware detected" messages :)
Date: 31 Aug 2008 20:26:05
Message: <48bb369d@news.povray.org>
> real machine.
Oh. I wasn't aware it was an emulator rather than a VM.
I'll give it a go and watch it crash and burn anyway. :-)
Date: 31 Aug 2008 20:26:50
Message: <48bb36ca$1@news.povray.org>
> Windows host...
"I've been thinking of playing with some VM technology" kind of implies
  I haven't already, you see. :-)
Date: 31 Aug 2008 21:37:47
Message: <48bb476b@news.povray.org>
>> your real machine.
VMware, VirtualBox, and VirtualPC are VMs. QEMU is a CPU emulator.
Being a VM means they virtualize rather than emulate the CPU, but usually
not much more. The graphics processor, sound card, network card, etc. are
still emulated (access efficiently forwarded to the real hardware, but the
guest OS still doesn't see the real hardware).
Heck, VMware Workstation even lets you simulate packet loss in the virtual
network cards :)
Same for HD and memory. A tool like CPU-Z wouldn't be able to see the real
manufacturer of the RAM sticks. The RAM in the guest OS is actually a
memory-mapped file in the host OS hard disk. The guest OS hard disk is
usually just a big file too; no way the guest OS can see real SMART data
from the physical disk.
Date: 1 Sep 2008 04:03:13
Message: <48bba1c1$1@news.povray.org>
Presumably that requires *very* specialised hardware though?
Date: 1 Sep 2008 04:06:31
Message: <48bba287@news.povray.org>
QEMU apparently allows you to emulate different CPUs for that matter...
It appears to have emulation for Motorola 68000 for example.
> still emulated.
To be honest, I'm surprised that QEMU can exist. I would have expected
the emulated CPU to be maybe 1,000,000x slower than the real one, which
would of course be unusably slow. But somehow they've made it not be
that slow - and given it away for free too.
(I am still constantly amazed at the amount of high-quality software you
can pick up for free these days. Emulating an entire IBM PC must surely
be many man-centuries of development work...)
Date: 1 Sep 2008 04:07:19
Message: <48bba2b7$1@news.povray.org>
> Windows host...
I've heard of plenty of VMs that run on Linux, but I wasn't aware that
any free ones existed for Windoze.
Date: 1 Sep 2008 04:16:02
Message: <48bba4c2@news.povray.org>
news:ucjlb4l1ddf87j4lves2ms6p2hgf8i7cra@4ax.com...
Yup. For over a year now. It's surprising how the hits have grown,
especially over the last 3 months
Somehow I don't think too many people here would be interested in a deep
discussion on the internals of the query optimiser. ;-)
Date: 1 Sep 2008 04:22:13
Message: <48bba635@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:48bba1c1$1@news.povray.org...
>> real
Not at all. VirtualPC is what I'm using on my destop. I run  it on my laptop
as well. VMWare (workstation) will run on any modern PC with a compatible
processor (virtually all of the intel and AMD chips)
That's the whole point of virtual machines, they don't need specialised
hardware
Date: 1 Sep 2008 04:32:07
Message: <48bba887@news.povray.org>
news:48bba2b7$1@news.povray.org...
>> a
>> Windows host...
> I've heard of plenty of VMs that run on Linux, but I wasn't aware that any
VirtualPC and VirtualServer are both free. I don't know offhand if they will
run *nix. I've seen some web sites that say it's possible, never tried
myself.
VMWare's ESXi is free now, though that's a server-level product, not
necessarily something for a desktop. Should be able to run on a desktop.
Definitly supports Linus at lease asa  guest OS
Date: 1 Sep 2008 04:34:36
Message: <48bba91c$1@news.povray.org>
>>> virtual
>>> your real
> laptop as well. VMWare (workstation) will run on any modern PC with a
> compatible processor (virtually all of the intel and AMD chips)
> hardware
But surely if you're going to run a guest OS on the physical host CPU,
the host CPU would need to have hardware support for enforcing the host
seperation?
Date: 1 Sep 2008 04:37:44
Message: <48bba9d8$1@news.povray.org>
> will run *nix. I've seen some web sites that say it's possible, never
> tried myself.
I didn't say there weren't any, I said I hadn't heard of any. ;-)
Until yesterday, the only products I'd heard of where Bochs (only runs
on Linux) and VMware (AFAIK that's extremely expensive). Oh, and doesn't
Micro$oft now have some product that's just called "virtual server" or
something undistinctive? Presumably that's a server product that is only
available enterprise customers who've signed an NDA...
Date: 1 Sep 2008 04:43:23
Message: <48bbab2b@news.povray.org>
news:48bba91c$1@news.povray.org...
> But surely if you're going to run a guest OS on the physical host CPU, the
> seperation?
I don't know how they work, but they can and do run on any standard modern
PC.
Date: 1 Sep 2008 04:49:36
Message: <48bbaca0@news.povray.org>
news:48bba9d8$1@news.povray.org...
> Until yesterday, the only products I'd heard of where Bochs (only runs on
Mostly, but one of their server products is free now.
> Oh, and doesn't Micro$oft now have some product that's just called
> "virtual server" or something undistinctive? Presumably that's a server
> product that is only available enterprise customers who've signed an
> NDA...
Yes they do, and if you'd read a few lines up you'd  have seen that. It's
free. As in, go and download, no purchases or NDAs necessary.
I don't personally run virtual server, I get by just fine with it's little
brother (Virtual PC), but it's not a server-only app. It does run on XP,
though it's designed more for server-usage.
Then, of course, there's Hyper-V built into Server 2008.
Date: 1 Sep 2008 04:54:54
Message: <48bbadde$1@news.povray.org>
> Only trouble is... it would have to be a pretty damned big USB stick. DSL
> is nice, but rather minimal. (Shocker.) KNOPPIX is 700 MB compressed, and
ebuyer have a 8GB USB stick for 14.09 inc VAT.  You could buy a couple of
them, one for the OS/programs, and another one for data files etc.
Date: 1 Sep 2008 04:56:28
Message: <48bbae3c$1@news.povray.org>
Or get this beast:
http://www.ebuyer.com/product/140327
(I didn't even realise you could get 32GB USB sticks now!)
Date: 1 Sep 2008 04:58:55
Message: <48bbaecf$1@news.povray.org>
I see...
>> server product that is only available enterprise customers who've
>> signed an NDA...
As I say, I couldn't remember it's exact name, so I wasn't sure if the
virtual server you were referring to was the M$ product or somebody else's.
> It's free. As in, go and download, no purchases or NDAs necessary.
That's an... interesting move. Still, I guess if you have 100 virtual
servers and they all run Windows, you still need 100 server licenses.
> little brother (Virtual PC), but it's not a server-only app. It does run
> on XP, though it's designed more for server-usage.
Until yesterday, I had always assumed that any kind of emulation or
virtualisation solution would be roughly 1,000,000x slower than native
execution, so it's not something I've ever been interested in. Hence
it's something I know almost nothing about. However, since it appears
that you can actually run real software at almost native speeds,
suddenly it becomes far more interesting... ;-)
Date: 1 Sep 2008 05:03:06
Message: <48bbafca$1@news.povray.org>
>> of them, one for the OS/programs, and another one for data files etc.
> Or get this beast:
I was looking at all this myself just last night. ;-)
There seems to be a rather big jump from 8GB to 32GB with nothing in the
middle. Hmm. (And yeah, *I* didn't know they'd got that big now either.
Last time I looked, 4GB was about the best that money could buy.)
But anyway, the 8GB stick certainly seems like a very reasonably
proposition, and I am seriously considering such a thing. ;-)
As an aside, my current USB stick (which I always take everywhere with
me) is an LG 1GB from ebuyer. It cost something absurd like £1.20. IIRC
the postage was vastly more than the actual drive! Best of all: it's
shiny. (You can actually see your reflection in it.) The cap is actually
slightly wonky, but for £1.20 who's complaining?
Date: 1 Sep 2008 05:09:00
Message: <48bbb12c$1@news.povray.org>
...The *other* thing I've often wanted to try is making a bootable USB
flash drive. But apparently that's really hard. And besides, a virtual
Linux environment has certain advantages. (E.g., you can use the local
HD if you want.)
Date: 1 Sep 2008 05:25:38
Message: <48bbb512@news.povray.org>
news:48bbaecf$1@news.povray.org...
Yup. But you'd also need 100 licences if you had 100 seperate physical
servers, so it kinda works out cheaper to buy a single large server and
virtualise several 'servers' onto one where possible. Save on power,
cooling, space in the server room, probably on hardware. Plus most large
companies will probably have site-licences so they don't worry about buying
individual licences like you or I would.
> However, since it appears that you can actually run real software at
> almost native speeds, suddenly it becomes far more interesting... ;-)
Most and almost.
I know that currently SQL Server isn't supported for production usage on any
form of virtual machine. It may change in the upcoming months with HyperV.
Date: 1 Sep 2008 05:33:27
Message: <48bbb6e7$1@news.povray.org>
In other words, a company that wouldn't buy 100 physical servers might
consider running 100 virtual servers - so M$ still get their cheque.
> Plus most large
> buying individual licences like you or I would.
How exactly does that work? I know how I *thought* it worked, but
apparently I'm wrong; I heard one of our head IT guys complaining that
we actually have more Server 2003 Enterprise installations running than
we're "supposed to".
> Most and almost.
> any form of virtual machine. It may change in the upcoming months with
> HyperV.
"Supported" and "working" aren't the same thing. ;-)
It might be that it *works* perfectly well, but the testing department
haven't assured themselves fully about it yet, so they don't want to
spend time supporting it until they have.
(Theoretically *every* application should work... depending on how well
the VM works anyway.)
Date: 1 Sep 2008 06:03:29
Message: <48bbbdf1@news.povray.org>
news:48bbb6e7$1@news.povray.org...
>> Plus most large companies will probably have site-licences so they don't
>> worry about buying individual licences like you or I would.
> apparently I'm wrong; I heard one of our head IT guys complaining that we
> actually have more Server 2003 Enterprise installations running than we're
> "supposed to".
Licencing's not my specialty. Sounds like you have a certain number of
licences and you have more servers than that.
A previous company I worked for had a site-wide licence for certain apps.
Meant they could install as many as they liked and still paid a fixed amount
every year (support/upgrade contract). It's expensive for smaller companies,
but as the number of PCs increase, it becomes more reasonable than paying
for each one.
I don't know if it's still an option. As I said, I don't do licencing if I
can help it.
>> Most and almost.
>> HyperV.
> haven't assured themselves fully about it yet, so they don't want to spend
Indeed. The problem with multiple SQL instances in VMs is IO. You can
allocate CPUs and memory to specific VMs, but there's still a single IO
channel, and SQL database tend to be IO bound more often than CPU or memory.
Date: 1 Sep 2008 06:07:51
Message: <48bbbef7$1@news.povray.org>
>> than we're "supposed to".
> apps. Meant they could install as many as they liked and still paid a
> fixed amount every year (support/upgrade contract). It's expensive for
> smaller companies, but as the number of PCs increase, it becomes more
> reasonable than paying for each one.
Right. Well we definitely have a company-wide license for Windows XP,
Office 2003, and a few other bits. I *thought* we had a company-wide
license for all the products we've licenced, but perhaps not?
> I can help it.
Amen! But some of us don't have that luxury. :-S
> memory.
Yeah, database engines by definition are I/O hungry (and memory hungry
if you want to cache some of that rather than reread it a zillion
times). Depending on what you're doing it can be CPU-heavy too, but
mainly just I/O.
I'm sure it'll *work*, but how fast...? ;-)
Date: 1 Sep 2008 11:01:29
Message: <48bc03c9@news.povray.org>
> seperation?
There's two ways to do it. The other one needs hardware virtualization
support (practically any C2D+ and X2+ -processors do have it nowadays)
and the other one uses somekind of simulation (dunno for sure how - but
ie. Xen and Linux with slightly modified kernel can do this without
mentionable powerloss).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 1 Sep 2008 11:04:34
Message: <48bc0482$1@news.povray.org>
But that's Windows ;). With Linux, you can compile different kernel for
the VM/emu and ie. create another X.org -config file and use it with the
VM/emu.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 1 Sep 2008 11:09:01
Message: <48bc058d$1@news.povray.org>
Isn't ESXi a hypervisor like Xen? Meaning that it kind of runs even
under the main-OS, not on it.
VMWare has several tools available free of cost. Check the website ;).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 1 Sep 2008 11:09:19
Message: <48bc059f@news.povray.org>
Yes, but nowadays it's built into all the CPUs already. You couldn't do
something like this on, say, a 68000 or an 8086.
Date: 1 Sep 2008 11:10:08
Message: <48bc05d0$1@news.povray.org>
Go to microsoft.com and do a search. :-)
Date: 1 Sep 2008 11:10:47
Message: <48bc05f7$1@news.povray.org>
How many machine instructions do you think it takes to execute an
interpreter for a machine instruction? A hundred maybe, but a million?
Date: 1 Sep 2008 11:12:10
Message: <48bc064a$1@news.povray.org>
A good mainframe these days will run 30,000 images without much problem.
