POV-Ray : Newsgroups : povray.off-topic : Something file systems need Server Time
13 Aug 2025 19:59:16 EDT (-0400)
  Something file systems need (Message 1 to 10 of 16)
Subject: Something file systems need
Date: 22 Aug 2008 13:16:42
Message: <48aef47a@news.povray.org>
A flag that says "don't back up this file, ever."
Set on cache directories/files, especially those where it's faster to
rebuild the file than to restore it, or where it's likely to be out of
date if you restore something.
Bonus points for adding the user(s) and program(s) that use the files,
so you can safely delete them to recover space whenever that program
isn't running.
Because, damn, people spray those things all *over* the file system.
Subject: Re: Something file systems need
Date: 22 Aug 2008 17:37:36
Message: <48af31a0@news.povray.org>
From chattr manpage:
  A file with the ‘d’ attribute set is not candidate for backup when the
  dump(8) program is run.
(and of course any other program could read the attribute and do something
with it)
Date: 23 Aug 2008 11:46:33
Message: <48b030d9$1@news.povray.org>
Yeah. Sadly, as far as I can tell, nobody actually uses it. Windows
programs don't even turn off the archive bit on cache files.
Date: 25 Aug 2008 01:09:43
Message: <48b23e97@news.povray.org>
>>   the dump(8) program is run.
So maybe it's not that the filesystem needs the capability, but that
programmers need to use it?
Jim
Date: 25 Aug 2008 11:40:10
Message: <48b2d25a$1@news.povray.org>
Generally, when something like this isn't used, it's due to either it
being bolted on the side after the fact, not being ubiquitous, or the
programs that come with the OS not doing it and thus discouraging others
from bothering to do it.
Date: 25 Aug 2008 13:23:16
Message: <48b2ea84@news.povray.org>
Well, from a FAT standpoint, I doubt anyone can say the archive bit is
"bolted on the side".
Maybe what needs to happen is for programmers to use what's there rather
than invent something else for them to ignore, though - or worse, create
something additional that means now there's more than one way to
accomplish the task, making it more confusing for people writing backup
software.
Jim
Date: 25 Aug 2008 14:25:46
Message: <48b2f92a$1@news.povray.org>
True. On the other hand, the original FAT file system had the semantics
of the CP/M file system. But yes, by the time it got to the point where
you actually did backups and had temp files you left hanging around, the
archive bit was pretty well established. That MS's own programs didn't
mark things as "don't archive this" (and that it really isn't a "don't
backup" bit but more a "don't incrementally back up" bit) didn't help.
Pretty much anything that isn't lowest-common-denominator is going to
get ignored by the majority, I expect.  That's why it would be nice if
the bit actually got by-default inherited by files inside directories
with the bit set. Then you could set that bit on (say) /tmp and be done
with it.
Date: 25 Aug 2008 14:37:20
Message: <48b2fbe0$1@news.povray.org>
True.
I do recall that MS' DOS-based backup utility (I forget what it was
called) did actually observe the archive bit.  The apps didn't use it
often enough, though; it was typically used by the backup utilities to
flag that a file had been archived by a backup system, not as a means of
skipping files you didn't want backed up (but a little creative thinking
would've come to the conclusion you could use it for both).
>> rather than invent something else for them to ignore, though
> with it.
True.  And I agree it would be nice if it recursed; considering the speed
of computers of the day, though, I wonder how practical it would've been
to implement - true you could do a dynamic evaluation, but MS so likes
doing the "traverse and stamp every object", as evidenced by the horribly
broken behaviour in AD version 1 when assigning rights through a
filesystem.   Thank goodness they fixed that behaviour.
Jim
Date: 25 Aug 2008 14:44:47
Message: <48b2fd9f@news.povray.org>
All the backup utilities did (and do) pay attention to it. But the flag
automatically gets turned on whenever you open a file for writing, so
its use is primarily for differential backups. You do a full backup and
while doing so turn off the bit, then later you can back up just the
files with the bit set.
It would only skip files you didn't want *incrementally* backed up.  A
full backup would still copy the file, and there's no semantics (in UNIX
or Windows file systems at least) for "this is a temp file" sort of
thing, so don't ever back it up, or at least throw it away if you need
the room.
That must have been a while ago. All the MS file systems I've ever
looked at had heritable privileges. (Given they had privileges to start
with, of course.) I'm not real sure where AD comes into it.
Date: 25 Aug 2008 15:54:38
Message: <48b30dfe$1@news.povray.org>
Oh, right, I forgot about that bit with it getting reset when a file is
opened for writing.
> the room.
Well, arguably, there is - you put it in /tmp - most programs do that.
Then you just exclude the directory from your backups.
Demonstration I saw showed it pegging the CPU at 100% for nearly 40
minutes because the rights were stamped on each object.  Come to think,
it wasn't the filesystem - it had to do with assigning rights in AD
itself, not to the filesystem.  It's been a few years.
Jim
