POV-Ray : Newsgroups : povray.off-topic : Colour consoles Server Time
19 Oct 2026 14:11:01 EDT (-0400)
  Colour consoles (Message 1 to 33 of 33)
Subject: Colour consoles
Date: 20 Aug 2008 09:08:38
Message: <48ac1756$1@news.povray.org>
You *know* something's wrong when you find yourself envying people who
use Unix because it can emulate an obsolete VT100... o_O
Basically, I have a perfectly working console application, but I wish I
could just make certain parts of its output come out in a different
colour. On Unix, this would be a fairly trivial matter of writing some
escape codes to stdout and you're done. On Windoze... well that doesn't
work.
I wonder... Is there some function call in the Win32 API that can
actually change the colour of the text in a console window? Or is that
impossible? Does anybody here know the Win32 API well enough to know the
answer?
(Certainly the "color" command changes the colours of the console window
- but it changes the colour of *everything*. I don't know if you can
change just some of the text, rather than all of it...)
http://blog.orphi.me.uk/
Subject: Re: Colour consoles
Date: 20 Aug 2008 10:03:09
Message: <op.uf6uniy17bxctx@e6600>
> work.
NT-based console windows do not support colour escape codes. Only 16-bit
applications (running under NTVDM) can use colour escapes.
http://msdn.microsoft.com/en-us/library/ms682088.aspx
FE
Date: 20 Aug 2008 10:12:10
Message: <48ac263a$1@news.povray.org>
>> doesn't work.
Indeed. So that isn't much help.
Bugger. I don't have bindings for those particular functions. :-(
I wonder if I could write some...?
Date: 20 Aug 2008 10:54:03
Message: <48ac300b$1@news.povray.org>
Oh. My. God.
I literally can't believe this... I just wrote and compiled a C program
that calls the Win32 API directly, AND IT FRIGGIN WORKED!! 0_0
*dies*
I would never have believed it was possible... I was sure it would
blue-screen the machine or crash spectacularly, but no, it actually
worked properly. (AND, best of all, it IS possible to change the colour
of just some characters in a console window. I wasn't sure it could be
done.)
I was a little shocked to discover that I already have the necessary C
header files. And, obviously, it took a litle while to figure out how to
make my Haskell compiler compile raw C files instead of Haskell programs.
The hardest part was figuring out what "warning: function foo() defined
implicitly" means. Apparently it means you spelt the function's name
wrong, so the compiler couldn't find it in the header file. This also
causes the linker to make rude comments.
But once you get over all of these things... my God, I made a direct OS
call and *didn't* crash the OS. Astonishing!
I think I need to go sit down...
Date: 20 Aug 2008 11:01:39
Message: <48ac31d3$1@news.povray.org>
Invisible wrote:
> Oh. My. God.
> *dies*
..and it only took you twelve minutes!
*Falls_over_in_amazement*
John
"Eppur si muove" - Galileo Galilei
Date: 20 Aug 2008 11:20:18
Message: <48ac3632@news.povray.org>
Really? Gee, it seemed like much longer than that to me...
The hard part, of course, is writing some Haskell bindings. ;-) In
particular, I cannot for the life of me figure out how to get at
symbolic constant names. :-(
Date: 20 Aug 2008 11:38:38
Message: <48ac3a7e$1@news.povray.org>
On Wed, 20 Aug 2008 16:20:17 +0100, Invisible wrote:
> In
In C?  Look at #define
Jim
Date: 20 Aug 2008 11:40:26
Message: <op.uf6y5oqx7bxctx@e6600>
If you are looking for 'FOREGROUND_BLUE' and the like, they are defined in
'WinCon.h'. There you will also find the structure definitions relevant to
the console subsystem.
FE
Date: 20 Aug 2008 11:42:13
Message: <48ac3b55$1@news.povray.org>
>> In
I meant how to get that stuff into Haskell.
It seems Haskell provides a magical command which somehow lets you call
a C function as if it's a Haskell function, assuming you can find a
header file that contains the C function you're after. (I literally have
*no idea* how the linker finds the actual code...) However, there seems
to be no way to import constants. In fact, every Haskell binding I've
looked at has these hard-coded in the Haskell source code rather than
imported, so I've just waded through a few KB of header files tracking
down all the #defines and their literal values.
And you know what?
I just ported my program to Haskell, AND IT STILL WORKS CORRECTLY! 0_0
This is an unprecidented level of success. It seems I can actually call
any C function I have a header file for. Wow.
Date: 20 Aug 2008 11:43:05
Message: <48ac3b89$1@news.povray.org>
So this doesn't work?
http://www.windowsnetworking.com/kbase/WindowsTips/Windows2000/UserTips/Miscellaneous/CommandInterpreterAnsiSupport.html
Date: 20 Aug 2008 11:47:00
Message: <op.uf6zgld97bxctx@e6600>
>> 16-bit applications (running under NTVDM) can use colour escapes.
"the command.com shell interpreter"
"Any DOS applications you run in this command shell will now have ANSI
support."
FE
Date: 20 Aug 2008 11:50:46
Message: <48ac3d56$1@news.povray.org>
> support."
I've tried things like this several times before, and it's never worked
for me...
Date: 20 Aug 2008 11:51:37
Message: <48ac3d89$1@news.povray.org>
> in 'WinCon.h'. There you will also find the structure definitions
> relevant to the console subsystem.
Yes. I eventually tracked those down.
Also, apparently STD_OUTPUT_HANDLE is -10, not 10. >_<
Date: 20 Aug 2008 11:55:21
Message: <op.uf6zuilk7bxctx@e6600>
> for me...
As I said before, only 16-bit applications can use colour escapes under NT.
FE
Date: 20 Aug 2008 12:01:37
Message: <48ac3fe1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:48ac3d56$1@news.povray.org...
>> support."
> for me...
I run ksh on my windows xp machine and I'm able to do all that with just a
few escape sequences in my .profile
Jim
Date: 20 Aug 2008 12:07:12
Message: <48ac4130@news.povray.org>
Technically, there's no such thing in C as such. The #define substitutes
the actual value for the name before the "compiler proper" ever sees it.
That's why the C standard requires something like
   f(3 + 2);
to not do any additions before invoking f(5). Otherwise, people would
hesitate to use something like
#define LAST (PREV+1)
Date: 20 Aug 2008 12:08:05
Message: <48ac4165@news.povray.org>
> support."
Oh. OK. So you can't invoke it from command.com and have it work?
Date: 20 Aug 2008 12:24:51
Message: <op.uf607owp7bxctx@e6600>
Only if it is a 16-bit application. The colour escape functionality is
provided by 'ansi.sys' which is a 16-bit driver.
FE
Date: 20 Aug 2008 13:42:18
Message: <48ac577a$1@news.povray.org>
> answer?
Yes, there is:
#include "stdio.h"
#include "windows.h"
void main()
     HANDLE hCon = GetStdHandle(STD_OUTPUT_HANDLE);
     SetConsoleTextAttribute(hCon, 0x0C);
     printf("Hello in red");
     SetConsoleTextAttribute(hCon, 0x09);
     printf(" and in blue\n");
     getchar();
Detailed here:
http://msdn.microsoft.com/en-us/library/ms686047.aspx
Date: 20 Aug 2008 15:22:28
Message: <48ac6ef4@news.povray.org>
  AFAIK, the VT100 didn't support colors. That came with later versions
of VT.
Date: 20 Aug 2008 18:34:52
Message: <48ac9c0c$1@news.povray.org>
Oh, I see....
Jim
Date: 21 Aug 2008 03:49:21
Message: <48ad1e01@news.povray.org>
Mike Raiford wrote:
> Yes, there is:
> #include "stdio.h"
> void main()
>     getchar();
> Detailed here:
Yah, that works.
Date: 21 Aug 2008 03:54:45
Message: <48ad1f45$1@news.povray.org>
> of VT.
Rather alarmingly, you're right again...
Date: 21 Aug 2008 05:22:42
Message: <48ad33e2$1@news.povray.org>
Not any more! Now I have my simple console application set up so that
the command prompt comes out in a different colour to the command
output. You have *no idea* how much easier this makes it when scrolling
through the programs output!
(Of course, it's still no help if you decide to pipe output to a file...
But for that, there is HTML and other markup languages.)
I'm seriously chuffed now. :-D
Date: 21 Aug 2008 06:49:20
Message: <48ad4830$1@news.povray.org>
...and then he wastes an entire morning agonising over exactly which
colour combinations look the nicest! o_O
The answer: They ALL look like something from the 1980s. (Or Teletext.)
Date: 21 Aug 2008 10:53:11
Message: <48ad8157@news.povray.org>
  Next you'll need colored file listing.
http://warp.povusers.org/snaps/ColoredListing.png
  You wouldn't believe how much easier it makes to visualize files by
type.
Date: 21 Aug 2008 10:57:55
Message: <48ad8273$1@news.povray.org>
> type.
What, with only 16 possible colours available? ;-)
Actually, I tend to work with files through a GUI instead. And I also
tend to not have very many of them. Distinguishing by icon is almost as
easy as by colour.
Date: 21 Aug 2008 11:17:15
Message: <48ad86fb@news.povray.org>
  Even 16 colors makes your life a LOT easier with file listings.
> easy as by colour.
  I disagree. Icons are small and often hard to distinguish from each
other, and it's difficult to view at a glance what type of file is
being listed at a certain position. The icon is not any better than
the file extension itself. You may as well look for the file extension.
However, coloring makes it much easier to see the file types at a quick
glance, without having to focus on a specific icon or extension.
  In Windows in particular, the icon is actually worse than the file
extension. The icon does *not* represent the file type. It represents
the program which opens that file. This sometimes leads to completely
ridiculous situations where you have two files with the exact same
name (if extension have been disabled, as it's the default in Windows)
and exact same icon. If you are looking at the icon listing (rather
than the detailed listing) there's absolutely no way to visually
distinguish which file is which.
Date: 21 Aug 2008 11:29:02
Message: <48ad89be@news.povray.org>
Well it's probably a lot better than just 1.
>> easy as by colour.
Depends on the icons in question. For example, I'm currently working on
a Haskell program. All the source code files show up as a white page
with a black lambda on them. All the other files (object files,
interface files, etc.) show up with that default Windoze "gee, I don't
know what the hell this file is" icon, which has a lot less white in it.
I can visually scan down a list of files and instantly find the source
files.
...which means that if I had a folder full of PNG files, some of which
had also been converted to JPEG, I'd have a problem, because they would
all have identical icons.
OTOH, are you really telling me your system has a different colour for
every possible filetype? It only has 16 colours available, remember.
A very stupid default, IMHO. I changed that long ago.
I have mine default to details. Occasioanlly I change it to thumbnail.
(Possibly the *only* genuinely useful feature M$ has ever come up with.
I wonder which competitor they stole it from?)
Date: 21 Aug 2008 13:55:17
Message: <48adac05@news.povray.org>
Incredibly. I hate getting on someone's system and finding that I can't
read the extensions. I know the rationale behind it, but in practice
with Windows the extension is part of the file name. On other (Mac)
systems, the file has a separate fork that has metadata about the file,
files can't share the same name,so you don't get two files that are
practically indistinguishable from each other.
ACDSee? ThumbsPlus?  hmmm...
Date: 21 Aug 2008 19:04:12
Message: <48adf46c$1@news.povray.org>
	Did they never make a Norton Commander that'll work with Windows
consoles? Or a similar app?
When everything's coming your way, you're in the wrong lane
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 22 Aug 2008 13:18:13
Message: <48aef4d5$1@news.povray.org>
>> type.
...and 16 different backgrounds, so a theoretical 16^2 pssible
combinations (I am of course assuming you can change the default black
as you can on *nixes) though not all are usable
John
Date: 22 Aug 2008 13:24:24
Message: <48aef648$1@news.povray.org>
Doctor John wrote:
> ....and 16 different backgrounds, so a theoretical 16^2 pssible
> combinations
If you want to get really picky, subtract out at least 16 combinations.
I don't think you want too many files listed as blue on blue. :-)
