POV-Ray : Newsgroups : povray.off-topic : Strange GPU Server Time
3 Nov 2026 04:29:31 EST (-0500)
  Strange GPU (Message 1 to 34 of 34)
Subject: Strange GPU
Date: 16 Aug 2008 15:00:54
Message: <48a723e6$1@news.povray.org>
During the course of playing FarCry, I noticed several times that random
polygon edges ended up in the wrong place sometimes. (By "noticed" I
mean "now and then I couldn't see half of the room because one of the
wall polygons was stretched across the entire width of it".)
I had assumed this was a software glitch - FarCry is rather old now
after all. I had assumed something in the game's coding was interacting
badly with my video card.
However, I've just been playing TF2, and the exact same thing happened.
This has *never* happened before in TF2 with this video card. So now I'm
thinking there is actually something wrong somehow.
I see three possibilities:
1. The GPU is overheating.
2. There's a bug in the version of the video driver I have installed.
3. Valve have made an update to TF2 which introduces some kind of
rendering bug.
Apparently the nVidia control panel no longer tells you your GPU
temperature; you have to download and install an additional tool.
Anyway, having just stopped using the GPU, the temperature was reading
55 °C. Over the course of the last 5 minutes, that's fallen to 53°C.
To me, that sounds rather damned hot. Is it usual for a GPU to get this
warm?
OTOH, the fact that it isn't cooling down especially fast seems to
indicate that this isn't an issue. (The nVidia tool allows you to set a
temperature warning, and the default is 127 °C.)
At this point, I'm not sure if my GPU is failing, or whether I just need
to update my drivers...
http://blog.orphi.me.uk/
Subject: Re: Strange GPU
Date: 16 Aug 2008 15:49:17
Message: <48a72f3d$1@news.povray.org>
> warm?
Very hot to touch, not so hot to run.  IIRC, most chips are fine up to
65-70C, and several can go higher w/o a problem.
Myself, I try to keep them around 45C.  If they go higher than that,
then I look at additional cooling.
...Chambers
Date: 16 Aug 2008 16:54:43
Message: <48a73e93@news.povray.org>
Shutdown. Let it cool for a few minutes. Open your tower, clean dust out.
And I mean *clean* dust out. Open your power unit, (yes, open your power
unit) and clean the dust out of that too. Open your fan covers, and clean
the grime off the blades of the fan/s. Pull your graphics card out, and with
a small screwdriver, (or similar), get as much grime off the fan blades as
possible. (Hard to get in there if it's a sealed unit, but you've got to do
it - be careful).
  I did exactly this the other day. You should have seen the crap in mine!
Get a hoover in there to mop up. Be careful of the wires.  ;)
   If you don't do what I said, bye-bye graphics card. Hello new one.
Seriously. I learnt this a long time ago.
    Edit: Oh, you're using a laptop aren't you? That must suck with dust in
one of those. :o/
   ~Steve~
Date: 17 Aug 2008 04:13:09
Message: <48a7dd94@news.povray.org>
  Get one of these too:
http://www.extendyourlashes.com/images/air-blower.jpg
  They are really handy when cleaning your computer of dust. You might also
want to use a vacuum cleaner at the same time if the amount of dust is large.
Date: 17 Aug 2008 12:48:12
Message: <48a8564c@news.povray.org>
There's also "canned air", which is just what it sounds like. A bit more
vigorous than a bulb for camera lens cleaning.
I've seen vacuum cleaners advertised as static-free. I don't know if
that makes any difference, but you might want to consider it if you're
going to vacuum directly inside the case.
Date: 17 Aug 2008 14:17:21
Message: <48a86b31@news.povray.org>
  But limited contents.
Date: 17 Aug 2008 16:16:18
Message: <48a88712@news.povray.org>
>> more vigorous than a bulb for camera lens cleaning.
I used to see cans of compressed air that came with a hand pump so they
could be refilled.  I never managed to get my hands on one to see if they
worked well, and haven't seen them for a while (the store that sold them
has since gone out of business).
But I imagine they still exist *somewhere*.
Jim
Date: 18 Aug 2008 03:34:15
Message: <48a925f7$1@news.povray.org>
> rendering bug.
4. Hardware fault on the graphics card (eg bad RAM)
> temperature; you have to download and install an additional tool. Anyway,
> having just stopped using the GPU, the temperature was reading 55 °C. Over
Try showing the temperature in parallel with running the GPU (eg 3D game in
a window), IIRC when I did those sorts of tests before, the GPU temperature
dropped rapidly very quickly (eg 10-15 degrees in just a second after
exiting a game).
> warm?
Actual chip core temperature of 55 degrees seems fine to me, if it got to 80
or 90 I would start to get worried.
One very easy and cheap way to check...
Date: 18 Aug 2008 09:43:23
Message: <48a97c7b$1@news.povray.org>
>> rendering bug.
Surely that's a rather rare failure mode on a graphics card? That seems
to me more like the kind of thing where you get a brand new card and
it's DOA. This card has been installed and running without issue for years.
> in a window), IIRC when I did those sorts of tests before, the GPU
> temperature dropped rapidly very quickly (eg 10-15 degrees in just a
> second after exiting a game).
While idling, it got down to about 53°C. I ran nVidia's "GPU stress
test" and it climbed as high as 63°C. Didn't seem to go any higher.
>> this warm?
> to 80 or 90 I would start to get worried.
Oh, OK. Generally my CPU doesn't get anywhere near that hot - but then,
I guess my CPU doesn't develop several hundred GFLOPS...
>> need to update my drivers...
Well, I did it anyway, just for the hell of it. Next time I play, I'll
see if it makes any difference.
(The wonderful thing about intermittent faults is that you can never
truly know if they are fixed.)
Date: 18 Aug 2008 09:44:27
Message: <48a97cbb$1@news.povray.org>
>>> out. And I mean *clean* dust out.
I own this. I'll give it a try later. If it *outside* of my PC is
anything to go by, it's probably about time... o_O
Date: 18 Aug 2008 09:54:18
Message: <48a97f0a$1@news.povray.org>
About the same as getting some bad RAM bits in your normal PC RAM probably.
> That seems to me more like the kind of thing where you get a brand new
> card and it's DOA. This card has been installed and running without issue
> for years.
I had the RAM in my desktop machine at work partially fail after some time.
It started when dealing with big zip files, it would complain that the CRC
check didn't match up, even though I had just downloaded it.  Then it would
blue-screen randomly, and gradually got more frequent.  I did the memcheck86
or whatever it was and there was an area of RAM that was totally corrupt,
it's a wonder Windows even booted, let alone worked normally most of the
time.  Replaced the RAM and very reliable now.
I had the same with my nVidia Ti4200 graphics card, actually identical
symptoms to you, random triangles flickering across the screen.  Gradually
got worse over time, and also while playing a game until it crashed.  Tried
it in my sisters PC and the same symptoms.  I didn't bother trying to figure
out the cause, but just assumed it was bad RAM.
Date: 18 Aug 2008 10:00:36
Message: <48a98084$1@news.povray.org>
Well, you'd think. ;-)
I've bought brand new RAM sticks to find that they're defective, and
I've occasionally damaged one inserting or removing it, but never seen
one just fail during normal use. They seem to be quite reliable.
> time. It started when dealing with big zip files, it would complain that
> the CRC check didn't match up, even though I had just downloaded it.
> Then it would blue-screen randomly, and gradually got more frequent.  I
> did the memcheck86 or whatever it was and there was an area of RAM that
> was totally corrupt, it's a wonder Windows even booted, let alone worked
> normally most of the time.  Replaced the RAM and very reliable now.
Yeah, RAM failures cause weird crap to happen. Depending on where in RAM
the problem is, it often only causes problems when you try to do certain
things. (But what with virtual memory, it's quite hard to predict when
it will or won't show up a problem.) Diagnosing RAM faults without a
real RAM tester is just Not Fun...
> Gradually got worse over time, and also while playing a game until it
> crashed.  Tried it in my sisters PC and the same symptoms.  I didn't
> bother trying to figure out the cause, but just assumed it was bad RAM.
Well, since the RAM isn't replaceable on a graphics card, I guess it
really just boils down to "does this graphics card work properly or not?"
Date: 18 Aug 2008 11:16:52
Message: <op.uf28qdkq7bxctx@e6600>
Not if it has been overheating.
Have you checked the temperature of the video RAM?
FE
Date: 18 Aug 2008 11:25:25
Message: <48a99465@news.povray.org>
True, but since the GPU generates far more heat than a block of RAM does...
I don't have a way to do that.
Date: 18 Aug 2008 11:36:51
Message: <op.uf29nnnl7bxctx@e6600>
> does...
The GPU also has far better cooling. Modern high-performance RAM can get
rather hot, particularly video RAM.
Try touching a VRAM chip (very briefly) while the game is running.
FE
Date: 18 Aug 2008 11:39:49
Message: <48a997c5$1@news.povray.org>
>> does...
Well, if they don't bother fitting cooling to a component, that
presumably means they don't think it's necessary. ;-)
Wouldn't simply having the case open radically alter the operating
temperature of the components inside? ;-)
Date: 18 Aug 2008 11:48:29
Message: <48a999cd@news.povray.org>
Compare it to your CPU temperature. I dunno about my GPU, but my CPU is
close to 55 just sitting idle.
Date: 18 Aug 2008 11:53:11
Message: <op.uf3aexz77bxctx@e6600>
>>> does...
>> get rather hot, particularly video RAM.
It can also mean that they chose not to include VRAM coolers because it is
cheaper that way. Whether they are necessary or not depends on many
factors outside the control of video card designers. Also, simply having a
cooler is not the same as having an effective cooler.
It can change the temperature, but not radically, unless you are talking
about the video card casing. In any event I doubt you could get an
accurate temperature reading using only your fingertip under any
circumstances. The point of the exercise is simply to get a feel for how
hot those things get.
FE
Date: 18 Aug 2008 11:53:34
Message: <48a99afe$1@news.povray.org>
Really? Mine is usually about 30°C or so...
Date: 18 Aug 2008 11:54:24
Message: <48a99b30$1@news.povray.org>
Ooo... Maybe I should use my IR thermometer? :-D
Date: 18 Aug 2008 15:53:12
Message: <48a9d328$1@news.povray.org>
Also, I've read somewhere that that is a very bad thing to do. (Touch an
operating chip to check its temperature) it has something to do with
heat saturation at the point of contact and can cause a chip that was
operating within its parameters to actually overheat.
Of course, that's just hearsay...
Date: 18 Aug 2008 15:53:45
Message: <48a9d349@news.povray.org>
Now you're thinking :)
Date: 18 Aug 2008 16:58:23
Message: <48a9e26f@news.povray.org>
My Pentium IV used to be at 72C constantly (full load; I never let a CPU
idle :P). According to specs, 75C is the limit.
Date: 19 Aug 2008 02:22:21
Message: <48aa669d$1@news.povray.org>
Where is that temperature measured though?
Date: 19 Aug 2008 02:30:58
Message: <48aa68a2$1@news.povray.org>
I don't know. I assume it's an on-die heat sensor. AFAIK, most modern
CPUs have them, so that they can turn up the fan speed or go into lower
power states if the die temperature gets too high...
Date: 23 Aug 2008 09:26:01
Message: <48b00fe9$1@news.povray.org>
>>> reading 55 °C. Over the course of the last 5 minutes, that's fallen
>>> to 53°C.
>> game in a window), IIRC when I did those sorts of tests before, the
>> GPU temperature dropped rapidly very quickly (eg 10-15 degrees in just
>> a second after exiting a game).
OK, I was just playing TF2 and noticed a few stray polygons. (I.e., the
driver update hasn't fixed this.) When I quit the game, I opened up the
temperature monitor. It was reading 70°C (and dropping quickly).
Next time I play TF2, I must remember to open the monitor *first*. ;-)
I wonder why it gets so much hotter running a real game (which is
optimised to run smoothly) than running a stress test (which is designed
to use up as much GPU resources as possible)...
Date: 25 Aug 2008 02:59:41
Message: <48b2585d$1@news.povray.org>
Can't you play TF2 in windowed mode?  Or download some game demo that can be
played in windowed mode.
I guess the stress test wasn't written very well, or without the knowledge
of your particular card.  Lots of things in the GPU can be the bottleneck, a
well-written stress test should work this out and adjust the test details so
that every part is almost at maximum throughput.  If it's not very well
written, then - for example - the vertex shader might be loaded at 100%
while the pixel shader and texture lookup units are sitting idle for 90% of
the time.
BTW what is the CPU load during the stress test and TF2?  Maybe that is
affecting the GPU temperatures?
Date: 25 Aug 2008 13:15:28
Message: <48b2e8b0@news.povray.org>
> can be played in windowed mode.
I guess I could - but it would be very hard to play it and enjoy it.
FWIW, last time I played, I did remember to start up the monitor. I've
done this a few times, and the temperature never seems to go abve 70°C.
Which sounds pretty damned hot to me, but hey...
>> designed to use up as much GPU resources as possible)...
> knowledge of your particular card.
Given that it's an nVidia GPU running a stress test written by nVidia,
you'd think so. ;-)
AMD Athlon64 X2 4200+ socket 939.
(When I built the system, everybody said that socket 939 was going to be
the future. Now it appears that actually it's AM2... oh well!)
Date: 25 Aug 2008 19:22:28
Message: <48b33eb4@news.povray.org>
That's the CPU model; and the load while playing the game? :)
Date: 26 Aug 2008 03:36:31
Message: <48b3b27f@news.povray.org>
I meant just so you could see the temperatures while playing.
Date: 26 Aug 2008 03:57:53
Message: <48b3b781$1@news.povray.org>
Yes, and a lot of people were p***ed off about that...
...Chambers
Date: 26 Aug 2008 04:21:05
Message: <48b3bcf1@news.povray.org>
Chambers wrote:
>> be the future. Now it appears that actually it's AM2... oh well!)
AMD claim to have learned their lesson there. Certainly the new AM2+
chips all work in socket AM2 motherboards (although obviously not as
well as they could do).
But then, I heard people saying things like "this could be the end for
AMD" (referring to the way Phenom pales in comparison to Core 2).
Date: 26 Aug 2008 10:11:47
Message: <48b40f23@news.povray.org>
I doubt it.  A company the size of AMD doesn't just disappear overnight,
no matter how hard times are.
They've got time to get their act together.
...Chambers
Date: 26 Aug 2008 10:14:28
Message: <48b40fc4$1@news.povray.org>
Heh. I guess "oh noes, this is teh endzors!" just makes better headlines
or something. ;-)
They just bought ATi, so they can't be doing that badly. (Or,
alternatively, ATi were doing *really* badly!)
That put me in a bit of a spot. I always buy AMD CPUs, and I always guy
nVidia GPUs. So AMD buying ATi was a problem. Of course, currently AMD
is nowhere in terms of CPU performance, so if I were to upgrade sometime
soon, I'd have to go with Intel...
(Now and then I get these crazy ideas that I might buy a Mac or
something... This usually wears off when I look at the price list.)
