POV-Ray : Newsgroups : povray.off-topic : Strange GPU Server Time
15 Apr 2026 07:50:04 EDT (-0400)
  Strange GPU (Message 1 to 10 of 34)
Subject: Strange GPU
Date: 16 Aug 2008 15:00:54
Message: <48a723e6$1@news.povray.org>
During the course of playing FarCry, I noticed several times that random
polygon edges ended up in the wrong place sometimes. (By "noticed" I
mean "now and then I couldn't see half of the room because one of the
wall polygons was stretched across the entire width of it".)
I had assumed this was a software glitch - FarCry is rather old now
after all. I had assumed something in the game's coding was interacting
badly with my video card.
However, I've just been playing TF2, and the exact same thing happened.
This has *never* happened before in TF2 with this video card. So now I'm
thinking there is actually something wrong somehow.
I see three possibilities:
1. The GPU is overheating.
2. There's a bug in the version of the video driver I have installed.
3. Valve have made an update to TF2 which introduces some kind of
rendering bug.
Apparently the nVidia control panel no longer tells you your GPU
temperature; you have to download and install an additional tool.
Anyway, having just stopped using the GPU, the temperature was reading
To me, that sounds rather damned hot. Is it usual for a GPU to get this
warm?
OTOH, the fact that it isn't cooling down especially fast seems to
indicate that this isn't an issue. (The nVidia tool allows you to set a
At this point, I'm not sure if my GPU is failing, or whether I just need
to update my drivers...
http://blog.orphi.me.uk/
Subject: Re: Strange GPU
Date: 16 Aug 2008 15:49:17
Message: <48a72f3d$1@news.povray.org>
> warm?
Very hot to touch, not so hot to run.  IIRC, most chips are fine up to
65-70C, and several can go higher w/o a problem.
Myself, I try to keep them around 45C.  If they go higher than that,
then I look at additional cooling.
...Chambers
Date: 16 Aug 2008 16:54:43
Message: <48a73e93@news.povray.org>
Shutdown. Let it cool for a few minutes. Open your tower, clean dust out.
And I mean *clean* dust out. Open your power unit, (yes, open your power
unit) and clean the dust out of that too. Open your fan covers, and clean
the grime off the blades of the fan/s. Pull your graphics card out, and with
a small screwdriver, (or similar), get as much grime off the fan blades as
possible. (Hard to get in there if it's a sealed unit, but you've got to do
it - be careful).
  I did exactly this the other day. You should have seen the crap in mine!
Get a hoover in there to mop up. Be careful of the wires.  ;)
   If you don't do what I said, bye-bye graphics card. Hello new one.
Seriously. I learnt this a long time ago.
    Edit: Oh, you're using a laptop aren't you? That must suck with dust in
one of those. :o/
   ~Steve~
Date: 17 Aug 2008 04:13:09
Message: <48a7dd94@news.povray.org>
  Get one of these too:
http://www.extendyourlashes.com/images/air-blower.jpg
  They are really handy when cleaning your computer of dust. You might also
want to use a vacuum cleaner at the same time if the amount of dust is large.
Date: 17 Aug 2008 12:48:12
Message: <48a8564c@news.povray.org>
There's also "canned air", which is just what it sounds like. A bit more
vigorous than a bulb for camera lens cleaning.
I've seen vacuum cleaners advertised as static-free. I don't know if
that makes any difference, but you might want to consider it if you're
going to vacuum directly inside the case.
Date: 17 Aug 2008 14:17:21
Message: <48a86b31@news.povray.org>
  But limited contents.
Date: 17 Aug 2008 16:16:18
Message: <48a88712@news.povray.org>
>> more vigorous than a bulb for camera lens cleaning.
I used to see cans of compressed air that came with a hand pump so they
could be refilled.  I never managed to get my hands on one to see if they
worked well, and haven't seen them for a while (the store that sold them
has since gone out of business).
But I imagine they still exist *somewhere*.
Jim
Date: 18 Aug 2008 03:34:15
Message: <48a925f7$1@news.povray.org>
> rendering bug.
4. Hardware fault on the graphics card (eg bad RAM)
> temperature; you have to download and install an additional tool. Anyway,
Try showing the temperature in parallel with running the GPU (eg 3D game in
a window), IIRC when I did those sorts of tests before, the GPU temperature
dropped rapidly very quickly (eg 10-15 degrees in just a second after
exiting a game).
> warm?
Actual chip core temperature of 55 degrees seems fine to me, if it got to 80
or 90 I would start to get worried.
One very easy and cheap way to check...
Date: 18 Aug 2008 09:43:23
Message: <48a97c7b$1@news.povray.org>
>> rendering bug.
Surely that's a rather rare failure mode on a graphics card? That seems
to me more like the kind of thing where you get a brand new card and
it's DOA. This card has been installed and running without issue for years.
> in a window), IIRC when I did those sorts of tests before, the GPU
> temperature dropped rapidly very quickly (eg 10-15 degrees in just a
> second after exiting a game).
>> this warm?
> to 80 or 90 I would start to get worried.
Oh, OK. Generally my CPU doesn't get anywhere near that hot - but then,
I guess my CPU doesn't develop several hundred GFLOPS...
>> need to update my drivers...
Well, I did it anyway, just for the hell of it. Next time I play, I'll
see if it makes any difference.
(The wonderful thing about intermittent faults is that you can never
truly know if they are fixed.)
Date: 18 Aug 2008 09:44:27
Message: <48a97cbb$1@news.povray.org>
>>> out. And I mean *clean* dust out.
I own this. I'll give it a try later. If it *outside* of my PC is
anything to go by, it's probably about time... o_O
