POV-Ray : Newsgroups : povray.off-topic : Aren't complexity classes fun? Server Time
19 Oct 2026 15:27:09 EDT (-0400)
  Aren't complexity classes fun? (Message 1 to 20 of 20)
Subject: Aren't complexity classes fun?
Date: 30 Jul 2008 11:05:42
Message: <48908346@news.povray.org>
Weee... check this out:
A full scan of a table containing ten million items requires up to ten
million operations. (On average, half that.) Using binary chop, it takes
only the binary logarithm of that - about 25 operations.
If a computer can process 1,000 operations per second (bearing in mind,
comparing a record to the target being looked up is a far few machine
instructions), we achieve the following times:
   Full scan:   2.777 hours
   Binary chop: 0.025 seconds
So one way takes almost three hours to do a single lookup, while the
other can do 40 lookups per second. O(log N) FTW!
But wait, check this out. Perhaps you are somehow unimpressed with
taking a 3-hour operation and completing it in 1/40th of a second. Well
try this for size:
Assume there are 10^80 atoms in the observable universe. If you
sequentially full scan then all, one by one, at 1,000 atoms per second,
it'll take you 10^77 seconds.
This is longer than the universe has existed (10^11 seconds).
Hypothetically, it's longer than it will take for all the energy in the
universe to be exhausted. By the time 10^77 seconds is up, the universe
will have died a cold, dark, silent death of total equilibrium a very
long time ago.
In short, this procedure is so slow that there isn't enough time or
energy in the whole of the known universe to actually complete it. (But
then, who's going to pin a unique record to every atom in the universe
anyway?)
On the other hand, according to my sums 10^80 is roughly 2^266. Thus,
the binary chop algorithm requires only 266 operations, and can easily
complete the entire process in well under a second. [If we assume
completely random access to any atom in the universe, which completely
defies several known physical laws...]
Like, wow man!
http://blog.orphi.me.uk/
Subject: Re: Aren't complexity classes fun?
Date: 30 Jul 2008 12:41:43
Message: <489099c6@news.povray.org>
  It would require for the atoms to be sorted in a specific order.
How would you sort them?
Date: 30 Jul 2008 13:16:44
Message: <4890a1fc$1@news.povray.org>
Clearly by the value of the time component of the space-time event where
the atom currently exists. ;-)
Date: 30 Jul 2008 16:37:56
Message: <4890d124@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:48908346@news.povray.org...
Which is why we really, really like indexes on database tables.
Date: 31 Jul 2008 04:10:09
Message: <48917361$1@news.povray.org>
To quote Team America, "**** YEAH!"
Although - and not many people seem to understand this part - indexes
make looking up *one* element much faster (if you index the right
thing). However, if you're doing to end up needing to process a large
percentage of the table anyway, it's actually faster to *not use* any
indexes there might be.
This is why we have complex database engines with sophisticated
algorithms which attempt to pick the best method for performing each
query. Yet still it seems that certain people think that the task of
"tuning" an SQL query means working out which combination of optimiser
hints cause the database to always use indexes for that query. *sigh*
Date: 31 Jul 2008 04:22:22
Message: <4891763e$1@news.povray.org>
Some of the guys mentioned here might have disagreed with you on that one:
http://en.wikipedia.org/wiki/12th_century_BC
Date: 31 Jul 2008 07:15:18
Message: <48919ec6@news.povray.org>
news:48917361$1@news.povray.org...
Really? I'll go and discard everything I know about using indexes right
away....
If you're processing a portion of a table and you have an index that covers
the required columns and finds you the portion of the table you want, it's
much, much better to use the index than to scan the table. Think about it
this way. If you need all the entries in the phone book where the first
letter of the surname in between N and T, would you prefer the phone book
ordered by surname or would you prefer an unorganised heap of phone book
entries?
Date: 31 Jul 2008 07:25:01
Message: <4891a10d$1@news.povray.org>
> away....
> entries?
My point is that if you need to process 75% of the rows of the table,
it's probably faster to do a sequential full scan than to use an index
and do lots of random I/O. Obviously if you only need to process, say,
5% of the table, you'd be mad to not use an index...
Date: 31 Jul 2008 07:26:47
Message: <4891a177@news.povray.org>
"Gail Shaw" <initialsurname@sentech sa dot com> wrote in message
news:48919ec6@news.povray.org...
> away....
Sorry, that cam out a little snarkier than I intended.
Taking SQL Server as an example (so I can give specific numbers), if an
index does not contain all the columns required, the break point for use the
index or scan the table is around 1% of the table. If the index does contain
all the columns, then the index will be used whether 1 row is required or
the entire table.
It's not hard to demonstrate.
Date: 31 Jul 2008 07:32:35
Message: <4891a2d3@news.povray.org>
news:4891a10d$1@news.povray.org...
I'm talking about range queries (all values between 1 and 100, all surnames
with first letters between N and Z). In that case you;'re not going to be
doing random IOs. One seek to find the start of the range (3 -5 random IOs),
then scan along the index leaf pages (sequential IOs). Provided all the data
required is included in the leaf pages, that is going to be faster than a
scan of the entire table.
Firstly because in general indexes are smaller than the entire table so
fewer IOs are required, second because the inapplicable 25% can be ignored
and doesn't have to be read and examined.
Of course, if you're looking for a random 75% of the table, then it's a
table scan.
Date: 31 Jul 2008 07:43:13
Message: <4891a551$1@news.povray.org>
> the entire table.
Ah, right.
I was thinking of something like "you have a bunch of invoices, indexed
by invoice number. You want to do something to all the invoices who's
numbers are less than 999,999,999". In which case, after you've found
the index nodes that tell you where those table rows are, you still need
to seek to them and load them. If you're processing a high enough
percentage of the rows in the table, just sequentially scanning the
table is going to wind up faster because sequential I/O is faster, and
reading only the table rather than table + index is less data to
transfer too.
I hadn't considered the possibility of the entire table data being in
the index itself. That would move the tipping point somewhat...
Date: 31 Jul 2008 07:50:39
Message: <4891a70f@news.povray.org>
news:4891a551$1@news.povray.org...
Not the entire table, just the columns required by the query in question.
Say the index table has 15 columns and the query that is looking for all
invoice numbers <  999,999,999 needs to return the date, the address and the
customer name, then an index on InvoiceNumber, Date, Address, CustName is
called a covering index, as it covers this particular query.
If an index is not covering, then, as I mentioned before, the tipping point
isn't most of the table (at least for SQL Server), it's somewhere around 1%
Date: 31 Jul 2008 08:14:28
Message: <4891aca4@news.povray.org>
Right, that's the other point I overlooked - you might not actually want
every single column in the table for a given query.
So, now that we've got all that out of the way, I'm sure you'll agree
with me that there are times when you do *not* want to use an index,
even if there is one. ;-)
Date: 31 Jul 2008 08:33:06
Message: <4891b102@news.povray.org>
news:4891aca4@news.povray.org...
<g> No.
Dunno about Oracle, but in SQL Server it's possible (and recommended) to
make the table into an index that contains, at the leaf levels, all of the
data in the table. It's called the clustered index.
I will agree that there are times when you want to scan an index, rather
than doing a seek on it.
Date: 31 Jul 2008 08:33:46
Message: <4891b12a$1@news.povray.org>
> <g> No.
Oracle provides an "index-organised table" which sounds like it's
similar. I don't know about "recommended" though - it seems to be more
for special situations.
I still think if you have a huge table with an index in just one field,
full-scanning the table would be faster than an index scan if you're
processing a very large percentage of the table's rows. But apparently
that's just me. :-}
BTW, what does "<g>" mean? I always thought it was short for "Gail" or
something, but that doesn't make much sense...
Date: 31 Jul 2008 08:40:54
Message: <4891b2d6@news.povray.org>
news:4891b12a$1@news.povray.org...
> that's just me. :-}
Ah, but read again. The clustered inde (or index-organised table) is an
index that has ALL of the data at the leaf level of the index. In essence,
it is the table.
So, if the index is the table, and you scan all the leaf pages of the index
Short hand for <grin>
Date: 31 Jul 2008 11:13:02
Message: <4891d67e$1@news.povray.org>
That's funky. Every time I ask an expert what a "clustered index" is, I
get a different definition. And I don't think they're compatible but
differing descriptions of the same concept.
I'd been told a clustered index is one in which the rows in the table
date are in physically the same order as the rows in the index. And that
that's why you can only have one clustered index for a table.
Date: 31 Jul 2008 11:26:26
Message: <4891d9a2@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4891d67e$1@news.povray.org...
Mostly correct.
The clustered index is the table. The leaf levels of the cluster are the
actual data pages and they are stored physically in the order of the
clustering key. The index's b-tree is built above those pages.
A scan of the clustered index is a scan of the data pages of the table.
With a clustered index, the clustering key is the row's 'address' and is
used in all other indexes to indicate the row's location if a lookup is
necessary (to retrieve additional columns)
There's a fairly decent diagram here - :
http://msdn.microsoft.com/en-us/library/ms177443.aspx
Does thet help at all, or have I just muddied the water more?
Bear in mind, I'm talking specifically for MS SQL Server. If other database
products have something with the same name, the physical implementation may
be different
Date: 31 Jul 2008 12:08:05
Message: <4891e365$1@news.povray.org>
> clustering key.
Oh, OK. I guess that makes sense, once I realize that there *is* no
"table data" outside the index.
That's a fairly good picture of a B-tree. :-)
It helps. I guess I just wasn't thinking it through. Thanks for
clarifying that.
Date: 31 Jul 2008 12:16:32
Message: <4891e560@news.povray.org>
news:4891e365$1@news.povray.org...
Yup. Look at that and the one for the nonclustered indexes (link's at the
bottom of the page) and compare what's at the leaf level
> clarifying that.
Pleasure. There are a lot  of full time SQL Server people who have little to
no clue what a clustered index is.
