POV-Ray : Newsgroups : povray.off-topic : Random C craziness Server Time
3 Nov 2026 05:21:10 EST (-0500)
  Random C craziness (Message 1 to 34 of 34)
Subject: Random C craziness
Date: 24 Jul 2008 06:02:39
Message: <4888533f$1@news.povray.org>
Can somebody interpret this for me?
   while (TRUE) { cont = (*cont)(); }
What on earth...?
http://blog.orphi.me.uk/
Subject: Re: Random C craziness
Date: 24 Jul 2008 07:31:02
Message: <488867f6$1@news.povray.org>
> What on earth...?
cont is a pointer to a function that is expected to return a pointer to
a function.  The code here causes a series of functions to be called,
each one specifying another function to be called afterwards by
returning the address of the function to be called.
John
Date: 24 Jul 2008 07:50:02
Message: <48886c6a$1@news.povray.org>
>> What on earth...?
Ah, so it *is* possible to read C? :-)
So cont points to a zero-argument function that returns a zero-argument
function? And this loop just calls it repeatedly?
Date: 24 Jul 2008 08:24:57
Message: <48887499@news.povray.org>
>> What on earth...?
I was thinking the same, but I can't seem to find the right type
definition to make it work without casting to and from void*... Which is
apparently illegal
(http://www.parashift.com/c++-faq-lite/pointers-to-members.html#faq-33.8)
Here's what I ended up with:
typedef void* (*pfunc)();
void* test1()
     return (void*)test1;
int main()
     pfunc cont = test1;
     while (true) { cont = (pfunc)(*cont)(); }
     return 0;
I'd like to write:
typedef pfunc (*pfunc)();
pfunc test1()
     return test1;
int main()
     pfunc cont = test1;
     while (true) { cont = (*cont)(); }
     return 0;
But the typedef here does not seem to work. I can't say I blame the
compiler for choking on that one either :-)
I'm not too comfortable with function pointers though, so it's likely
that I'm missing something here... Any hints?
Vincent
Date: 24 Jul 2008 08:27:06
Message: <4888751a@news.povray.org>
>> to a function.  The code here causes a series of functions to be
>> called, each one specifying another function to be called afterwards
>> by returning the address of the function to be called.
> apparently illegal
This is example code, so it might not be literally runnable... (It might
be simplified somewhat.)
Don't look at me! ;-)
Date: 24 Jul 2008 09:07:24
Message: <48887e8c$1@news.povray.org>
>> is apparently illegal
Does it still provide the declaration of cont, by any chance?
Vincent
Date: 24 Jul 2008 13:19:46
Message: <op.ues3q8fh7bxctx@e6600>
On Thu, 24 Jul 2008 14:24:51 +0200, Vincent Le Chevalier
> apparently illegal
It is illegal because a 'void *' is a data pointer, not a function pointer.
On a related note, we do not know if the original code was supposed to be
standards-compliant or not, nor if it was supposed to be C or C++.
[...snipped...]
The "right" way to do it, assuming C++:
http://www.gotw.ca/gotw/057.htm
FE
Date: 24 Jul 2008 13:39:06
Message: <4888be3a$1@news.povray.org>
> be standards-compliant or not, nor if it was supposed to be C or C++.
Ment to be ANSI C (not C++).
Date: 25 Jul 2008 04:48:00
Message: <48899340$1@news.povray.org>
Assuming TRUE is a value that always returns non-zero, yes. The code itself
appears to implement a state machine.
Of course, this being C, 'TRUE' could be a macro that expands to a function
 that returns a value and thus the loop need not be infinite. It could even
expand to a variable with a decrement or increment operator. Or really
anything - if the code were presented to someone as part of an computer
science exam, for example, they would probably be expected to pick that
possibility up. In the real world, no programmer would ever do something
that mean with a macro called TRUE. Right? :-)
-- Chris
Date: 25 Jul 2008 04:53:42
Message: <48899496$1@news.povray.org>
More exactly: It's a workaround for C's lack of lack of GOTO.
[This fragment appears in the output of a compiler that's using C as
"portable assembly".]
Hey, I found this cool site, it's called The Daily WTF... ;-)
Date: 25 Jul 2008 05:18:38
Message: <48899a6e@news.povray.org>
> [...snipped...]
Thanks for that!
Vincent
Date: 25 Jul 2008 08:56:37
Message: <4889cd85@news.povray.org>
  Except that C does have goto.
Date: 25 Jul 2008 08:59:08
Message: <4889ce1c@news.povray.org>
  Actually there are other ways for the loop to end. For instance, the
function being called could execute an exit() call.
  (Another less fancy way would be to return a null pointer from the
function, in which case the program will end with a segmentation fault.)
Date: 25 Jul 2008 09:00:04
Message: <4889ce54@news.povray.org>
Ooo, really?
In that case, I have *no clue* why they did it this way...
Oh, wait, maybe I do... Can you use GOTO to jump to a *pointer*? Or only
a literal label?
Date: 25 Jul 2008 09:01:29
Message: <4889cea9$1@news.povray.org>
I believe that is in fact what's meant to happen, yes.
...or have count() perform any other illegal program-halting action.
Date: 25 Jul 2008 09:05:47
Message: <4889cfab@news.povray.org>
> Ooo, really?
  Because "while(1)" is a common idiom, and avoids the ugly goto.
> a literal label?
  Jumping to a pointer is normally called "function call".
  Goto works only with labels.
Date: 25 Jul 2008 09:21:50
Message: <4889d36e$1@news.povray.org>
>> Ooo, really?
>> a literal label?
Yes, but jumping to a function pushes a return address onto the stack.
And they specifically don't want to do that. (Because it would use an
unbounded amount of stack.)
Date: 25 Jul 2008 09:31:58
Message: <4889d5ce@news.povray.org>
  Functions in C don't need to return anything.
Date: 25 Jul 2008 09:37:59
Message: <4889d737@news.povray.org>
	I thought that's what "lack of lack of GOTO" meant.<G>
I almost had a psychic girlfriend, but she left me before I met her.
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 25 Jul 2008 10:04:59
Message: <4889dd8b$1@news.povray.org>
The idea here is that we jump to one label, then jump to another, then
jump to another, never returning to the "caller".
If we implement this using C functions that never return, an unbounded
amount of stack gets eaten.
Hence, they arranged for each function to *return* the function it would
like to jump to next, rather than actually jumping to it, and the loop I
posted is apparently the magic incantation that implements the jumping.
Date: 26 Jul 2008 15:39:36
Message: <488b7d78@news.povray.org>
There was an entry over at the Daily WTF in which someone posted code,
written by another person, containing this:
#define TRUE 0
#define FALSE 1
I swear that I am not making this up.
John
Date: 26 Jul 2008 15:45:22
Message: <488b7ed2@news.povray.org>
>>> What on earth...?
> apparently illegal
Casting back and forth from void* is considered exceptionally unwise in
C++, but it's considered a great way of writing tighter code in C.
John
Date: 26 Jul 2008 15:47:39
Message: <488b7f5b$1@news.povray.org>
Or return a pointer to the exit() function, which is the same as above.
John
Date: 26 Jul 2008 16:31:44
Message: <488b89af@news.povray.org>
  In fact, for example casting method pointers to void* and back is
undefined behavior and in no way guaranteed to work. (And, in fact,
in many compilers method pointers are as large as two regular pointers,
and thus casting to void* would drop information.)
Date: 26 Jul 2008 17:30:00
Message: <web.488b96f97f33a1c3de7267810@news.povray.org>
Yes, indeed.
http://en.wikipedia.org/wiki/Tail_recursion#Implementation_methods
I take it that you were looking at the C output of GHC, right?  Haskell relies
on tail-recursion as much as any other functional language, as Scheme.  The
method it is implemented underneath is as a trampoline.
Date: 28 Jul 2008 05:13:26
Message: <488d8db6$1@news.povray.org>
> #define TRUE 0
> #define FALSE 1
I remember it well...
Date: 28 Jul 2008 16:21:44
Message: <488E2A94.3030104@hotmail.com>
> #define TRUE 0
> #define FALSE 1
Probably Unix convention?
http://en.wikipedia.org/wiki/True_(Unix)
http://en.wikipedia.org/wiki/False_(Unix)
Date: 28 Jul 2008 16:35:08
Message: <488e2d7c@news.povray.org>
>> #define TRUE 0
>> #define FALSE 1
Ah yes - return code 0 = OK, any other code = failure.
What have we learned here? That using integers to represent Booleans is
a Very Bad Thing. :-P
Date: 28 Jul 2008 16:56:21
Message: <488e3274@news.povray.org>
> >> #define TRUE 0
> >> #define FALSE 1
  C actually distinguishes between TRUE/FALSE and EXIT_SUCESS/EXIT_FAILURE.
They shouldn't be confused nor mixed.
Date: 29 Jul 2008 11:20:42
Message: <488f354a$1@news.povray.org>
Either that or for(;;) { ... }
Date: 29 Jul 2008 11:27:01
Message: <488f36c5@news.povray.org>
...and to think people complain when a Haskell programmer writes
   fix ((1:) . scanl (+) 1)
or something... :-P
Date: 29 Jul 2008 15:39:00
Message: <488f71d4$1@news.povray.org>
Well, maybe if you're lucky. :-) Otherwise, it just goes off happily
executing whatever is at memory address zero (or whatever NULL maps to).
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 29 Jul 2008 17:05:51
Message: <488f862f@news.povray.org>
  I'm pretty sure POSIX or some other type of standard states that jumping
to the null pointer will always cause a segmentation fault.
Date: 29 Jul 2008 17:21:04
Message: <488f89c0$1@news.povray.org>
But not the C standard. Try it on MS-DOS, Win 3.1, AmigaDOS, a credit
card terminal, a cell phone, etc. :-)  Basically, you're saying you
can't have a POSIX-compliant system without memory mapping, methinks.
But C is used in particular because of its primitiveness and lack of
reliance on a particular complex bit of hardware.
"The operating system is there to provide the facilities the language
designer left out."
