POV-Ray : Newsgroups : povray.off-topic : Random C craziness Server Time
19 Jan 2026 19:21:08 EST (-0500)
  Random C craziness (Message 1 to 10 of 34)
Subject: Random C craziness
Date: 24 Jul 2008 06:02:39
Message: <4888533f$1@news.povray.org>
Can somebody interpret this for me?
   while (TRUE) { cont = (*cont)(); }
What on earth...?
http://blog.orphi.me.uk/
Subject: Re: Random C craziness
Date: 24 Jul 2008 07:31:02
Message: <488867f6$1@news.povray.org>
> What on earth...?
cont is a pointer to a function that is expected to return a pointer to
a function.  The code here causes a series of functions to be called,
each one specifying another function to be called afterwards by
returning the address of the function to be called.
John
Date: 24 Jul 2008 07:50:02
Message: <48886c6a$1@news.povray.org>
>> What on earth...?
Ah, so it *is* possible to read C? :-)
So cont points to a zero-argument function that returns a zero-argument
function? And this loop just calls it repeatedly?
Date: 24 Jul 2008 08:24:57
Message: <48887499@news.povray.org>
>> What on earth...?
I was thinking the same, but I can't seem to find the right type
definition to make it work without casting to and from void*... Which is
apparently illegal
(http://www.parashift.com/c++-faq-lite/pointers-to-members.html#faq-33.8)
Here's what I ended up with:
typedef void* (*pfunc)();
void* test1()
     return (void*)test1;
int main()
     pfunc cont = test1;
     while (true) { cont = (pfunc)(*cont)(); }
     return 0;
I'd like to write:
typedef pfunc (*pfunc)();
pfunc test1()
     return test1;
int main()
     pfunc cont = test1;
     while (true) { cont = (*cont)(); }
     return 0;
But the typedef here does not seem to work. I can't say I blame the
compiler for choking on that one either :-)
I'm not too comfortable with function pointers though, so it's likely
that I'm missing something here... Any hints?
Vincent
Date: 24 Jul 2008 08:27:06
Message: <4888751a@news.povray.org>
>> to a function.  The code here causes a series of functions to be
>> called, each one specifying another function to be called afterwards
>> by returning the address of the function to be called.
> apparently illegal
This is example code, so it might not be literally runnable... (It might
be simplified somewhat.)
Don't look at me! ;-)
Date: 24 Jul 2008 09:07:24
Message: <48887e8c$1@news.povray.org>
>> is apparently illegal
Does it still provide the declaration of cont, by any chance?
Vincent
Date: 24 Jul 2008 13:19:46
Message: <op.ues3q8fh7bxctx@e6600>
On Thu, 24 Jul 2008 14:24:51 +0200, Vincent Le Chevalier
> apparently illegal
It is illegal because a 'void *' is a data pointer, not a function pointer.
On a related note, we do not know if the original code was supposed to be
standards-compliant or not, nor if it was supposed to be C or C++.
[...snipped...]
The "right" way to do it, assuming C++:
http://www.gotw.ca/gotw/057.htm
FE
Date: 24 Jul 2008 13:39:06
Message: <4888be3a$1@news.povray.org>
> be standards-compliant or not, nor if it was supposed to be C or C++.
Ment to be ANSI C (not C++).
Date: 25 Jul 2008 04:48:00
Message: <48899340$1@news.povray.org>
Assuming TRUE is a value that always returns non-zero, yes. The code itself
appears to implement a state machine.
Of course, this being C, 'TRUE' could be a macro that expands to a function
 that returns a value and thus the loop need not be infinite. It could even
expand to a variable with a decrement or increment operator. Or really
anything - if the code were presented to someone as part of an computer
science exam, for example, they would probably be expected to pick that
possibility up. In the real world, no programmer would ever do something
that mean with a macro called TRUE. Right? :-)
-- Chris
Date: 25 Jul 2008 04:53:42
Message: <48899496$1@news.povray.org>
More exactly: It's a workaround for C's lack of lack of GOTO.
[This fragment appears in the output of a compiler that's using C as
"portable assembly".]
Hey, I found this cool site, it's called The Daily WTF... ;-)
