POV-Ray : Newsgroups : povray.off-topic : Colorspaces. Server Time
19 Oct 2026 16:41:53 EDT (-0400)
  Colorspaces. (Message 1 to 5 of 5)
Subject: Colorspaces.
Date: 21 Jul 2008 13:18:37
Message: <4884c4ed$1@news.povray.org>
Remember me mentioning the color matrix feature of GDI+
Experimenting and playing with the feature has given me some really good
insight.
http://www.pfk.ff.vu.lt/cie/1931CIE_explanation.htm
Talks about conversion to the CIE XYZ colorspace. The numbers in the
matrix were strange and mysterious to me. (Not only that, but uhg to do
the conversion I have to use matrix arithmetic. I used to hate doing
matrix multiplication simply because I'd get confused. I know, I know.)
anyway ... onward.
Those mystery numbers are actually the values that determine the make up
of the resulting channels so, in the example of XYZ -> RGB R is actually
made up of 0.412453 X, 0.357580 Y, 0.180423 Z ... its actually really
simple!
You can also do weird things with color matricies such as rotate the
colors along an axis, etc ... much as you can do with points. You can
also, of course use these matricies to convert a color from one RGB
profile to another (i.e. from sGRB to AdobeRGB) I'm considering taking a
close look at rotation to see what I can do, I'm thinking along the
right axis you can do hue and saturation shifts. :D
Subject: Re: Colorspaces.
Date: 21 Jul 2008 13:27:26
Message: <4884c6fe$1@news.povray.org>
> simple!
Oops, and it's even easier to get backwards.
Convert RGB -> XYZ ... X is actually made up of 0.412453 R, 0.357580 G,
0.180423 B
Date: 22 Jul 2008 03:44:57
Message: <48858ff9$1@news.povray.org>
> simple!
Yep, that's all matrix multiplication is, just a compact way of writing out
those 3 equations of 3 variables :-)
BTW, the mappings that you can do by a matrix only convert to/from *linear*
RGB.  When you show them on a display you need to gamma correct them (or if
you get a bitmap from somewhere, you need to undo the gamma first before
conversion).
> I'm thinking along the right axis you can do hue and saturation shifts. :D
Yup, look at the xy chromaticity diagram on that link, it should be easy to
see geometrically what you need to do in order to get those shifts.
Date: 22 Jul 2008 07:37:18
Message: <4885c66e@news.povray.org>
>> up of the resulting channels so, in the example of XYZ -> RGB R is
>> actually made up of 0.412453 X, 0.357580 Y, 0.180423 Z ... its
>> actually really simple!
> out those 3 equations of 3 variables :-)
> *linear* RGB.  When you show them on a display you need to gamma correct
> them (or if you get a bitmap from somewhere, you need to undo the gamma
> first before conversion).
And components in some schemes can't be derived as a linear combination
of values from another scheme.  Hue, for instance.  A line parallel to
the H axis in an HSV color scheme does not map to a straight line in RGB.
John
Date: 22 Jul 2008 07:53:04
Message: <4885ca20$1@news.povray.org>
Damn you and your nonlinear colourspace transformations! What about
Dibble and Grubb?
http://blog.orphi.me.uk/
